When I try to resize the Galculator window by dragging it with the mouse, the window width stops shrinking at a certain point and cannot be reduced any further. It looks like the application has a fixed minimum width, which is too large for my needs. Is this a feature or a bug? Can it be changed somehow? Thank you.
Kernel: 5.15.197-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
root=UUID=aaf5c39b-140c-4787-916d-d80159456cee rw quiet apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: MICRO-STAR model: P45 Platinum (MS-7512) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: BIOS
vendor: American Megatrends v: 1.0B1 date: 11/19/2008
System RAM: total: 8 GiB available: 7.76 GiB used: 1.66 GiB (21.4%)
Array-1: capacity: 8 GiB note: est. slots: 4 modules: 4 EC: None
max-module-size: 2 GiB note: est.
Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
volts: N/A width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
serial: N/A
Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
serial: N/A
Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
serial: N/A
Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
serial: N/A
Info: model: Intel Core2 Duo E8500 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x dies: 1 cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2238 min/max: 2003/3166 scaling: driver: acpi-cpufreq
governor: schedutil cores: 1: 2238 2: 2238 bogomips: 12702
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Type: vmscape status: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Cedar [Radeon HD
5000/6000/7350/8350 Series] vendor: PC Partner / Sapphire driver: radeon
v: kernel arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: DVI-I-1
empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:68f9 class-ID: 0300
temp: 44.5 C
Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 509x318mm (20.04x12.52")
s-diag: 600mm (23.63") monitors: <missing: xrandr>
Monitor-1: DVI-I-1 model: NEC 24WMGX3 serial: <filter> built: 2008
res: 1920x1200 dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
x: 0.294 y: 0.608 blue: x: 0.141 y: 0.075 white: x: 0.314 y: 0.329
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
modes: 1920x1200, 1600x1200, 1680x1050, 1400x1050, 1280x1024, 1440x900,
1280x960, 1152x864, 1024x768, 832x624, 800x600, 640x480, 720x400
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
inactive: wayland
API: OpenGL v: 3.1 vendor: mesa v: 25.3.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD CEDAR (DRM 2.50.0 / 5.15.197-1-MANJARO
LLVM 21.1.6) device-ID: 1002:68f9 memory: 500 MiB unified: no
gpu: radeontop x11: xdpyinfo,xprop
Device-1: Intel 82801JI HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Cedar HDMI Audio [Radeon HD
5400/6300/7300 Series] vendor: PC Partner / Sapphire driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 1002:aa68 class-ID: 0403
API: ALSA v: k5.15.197-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e800 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd
Local Storage: total: 465.76 GiB used: 415.72 GiB (89.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 415.72 GiB (90.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: aaf5c39b-140c-4787-916d-d80159456cee
Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 3-1:2 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1
System Temperatures: cpu: 35.0 C mobo: 21.0 C gpu: radeon temp: 44.5 C
Fan Speeds (rpm): cpu: 1079 fan-2: 0 fan-3: 0 fan-4: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.28
Packages: pm: pacman pkgs: 1341 libs: 371 tools: pamac pm: flatpak pkgs: 0
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.fcix.net/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 210
1: cpu: 8.5% command: chromium pid: 10625 mem: 218.2 MiB (2.7%)
2: cpu: 6.0% command: chromium pid: 10570 mem: 262.0 MiB (3.2%)
3: cpu: 5.5% command: chromium pid: 10486 mem: 154.3 MiB (1.9%)
4: cpu: 4.3% command: chromium pid: 10453 mem: 277.9 MiB (3.4%)
5: cpu: 3.6% command: Xorg pid: 792 mem: 88.0 MiB (1.1%)
Memory top: 5 of 210
1: mem: 277.9 MiB (3.4%) command: chromium pid: 10453 cpu: 4.3%
2: mem: 262.0 MiB (3.2%) command: chromium pid: 10570 cpu: 6.0%
3: mem: 218.2 MiB (2.7%) command: chromium pid: 10625 cpu: 8.5%
4: mem: 154.3 MiB (1.9%) command: chromium pid: 10486 cpu: 5.5%
5: mem: 153.9 MiB (1.9%) command: safeeyes started-by: python pid: 1332
cpu: 0.1%
Processes: 210 Power: uptime: 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.09 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 258 default: graphical tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
running-in: xfce4-terminal inxi: 3.3.40
The different calculator shown in the screenshot at the top has a smaller width, which I would like to use. The Galculator is at the bottom and the width is just too large
