Can you hear the fans on turbo mode at this time?
I’m hearing it but, xfce4-sensors still aren’t reading that the fans are running.
Can you try it with the hardinfo
(System Profiler and Benchmark) application?
This is how mine looks like (graph at bottom showing Fan RPM over time)
Everything seems to be read by the sensors but the fan sensor reads 0.
However, the fan seems to be running well when I enable boost as seen in TUF controller.
Just to add, I have to relaunch TUF controller to see if it changes the fan mode after opening it once and switching fan modes.
What is this?
The GUI that it came recommended with the repository.
I’m not sure what the problem might be as I’m inexperienced myself. Maybe you can raise an issue on GitHub.
It works fine for me though.
It looks like they’ll be submitting this to the mainline kernel. Hopefully, it gets recieved well.
