Having the same issue.
I checked with showkey --scancodes
and neither the fn key nor fn key plus function keys produce anything. Weirdly, I did manage to configure media keys. But they are always in media key mode.
So e.g. fn+F6 does the same as pressing F6.
Scankeys does not pick up F11, FN, or FN+F11. These keys do nothing, Oddly, I can fullscreen the terminal application by pressing CTRL+F11. Which is not a documented short cut (should be just F11).
I have a Samsung laptop but it seems for Apple keyboards, there is a thing called fnmode, which has 3 settings; one of which is ‘disabled’. www.hashbangcode.com/article/turning-or-fn-mode-ubuntu-linux
I’m wondering if there’s something similar going on here. I don’t have an Apple keyboard of course but the problem seems similar.
I’ve also found some really outdated repository from samsung with some supposed fixes: github.com/voria/samsung-tools
There seems to be no documentation. Likewise there’s an outdated samsung-tools AUR that has not been updated in years.
My bios has no keyboard related settings (I checked). I’ve randomly tried a few of the generic keyboard settings (including the Apple layout) but that seems to have no effect either. The fn key is effectively dead, always. As are several of the other keys.
I would appreciate suggestions for other things to try. Otherwise this is actually a really nice Linux laptop. Even the touchpad is not half bad.
inxi -Fx
Host: jilles-galaxy-book Kernel: 5.13.19-2-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0 Desktop: GNOME 41.3 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: SAMSUNG product: 750XDA v: P08CFD
serial: <superuser required>
Mobo: SAMSUNG model: NP750XDA-KD9DE v: SAMSUNG_SW_REVISION_12345+0.0.0000
serial: <superuser required> UEFI: American Megatrends LLC.
v: P08CFD.030.210520.HQ date: 05/20/2021
ID-1: BAT1 charge: 54.9 Wh (98.0%) condition: 56.0/54.4 Wh (103.0%)
volts: 17.3 min: 15.4 model: SAMSUNG Electronics SR Real Battery
status: N/A
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 1267 high: 3512 min/max: 400/4200 cores: 1: 1385 2: 489
3: 481 4: 1604 5: 1014 6: 481 7: 1171 8: 3512 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Samsung Co
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: SunplusIT 720p HD Camera type: USB driver: uvcvideo
bus-ID: 3-7:3
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting resolution: <missing: xdpyinfo>
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Samsung Co
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlo1 state: up mac: e0:2b:e9:e3:b5:f2
IF-ID-1: docker0 state: down mac: 02:42:d5:49:06:97
bus-ID: 3-10:4
Local Storage: total: 476.94 GiB used: 122.3 GiB (25.6%)
ID-1: /dev/nvme0n1 vendor: SSSTC model: CL1-8D512 size: 476.94 GiB
temp: 30.9 C
ID-1: / size: 476.64 GiB used: 122.3 GiB (25.7%) fs: btrfs dev: /dev/dm-0
mapped: luks-443412f3-7aeb-4c4a-99ce-66db2a5a132d
ID-2: /boot/efi size: 299.4 MiB used: 712 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 476.64 GiB used: 122.3 GiB (25.7%) fs: btrfs
dev: /dev/dm-0 mapped: luks-443412f3-7aeb-4c4a-99ce-66db2a5a132d
ID-4: /var/log size: 476.64 GiB used: 122.3 GiB (25.7%) fs: btrfs
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%)
file: /swap/swapfile
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 304 Uptime: 2m Memory: 15.36 GiB used: 3.13 GiB (20.3%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1164
Shell: Zsh v: 5.8 inxi: 3.3.12
