Hi,
I have just done a full system upgrade
pacman -Syu
upgraded linux510 (5.10.89-1 → 5.10.109-1)
upgraded linux515 (5.15.12-1 → 5.15.32-1)
I noticed some errors and I am concerned that I may end up with boot issues when I reboot. The errors I saw were:
[2022-05-09T16:34:47-0400] [ALPM] running '70-dkms-install.hook'...
[2022-05-09T16:34:47-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod nvidia/510.60.02 -k 5.15.7-1-MANJARO
[2022-05-09T16:34:57-0400] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 5.15.7-1-MANJARO (x86_64)
[2022-05-09T16:34:57-0400] [ALPM-SCRIPTLET] Consult /var/lib/dkms/nvidia/510.60.02/build/make.log for more information.
[2022-05-09T16:34:57-0400] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod nvidia/510.60.02 -k 5.15.7-1-MANJARO' exited 10
2021-12-31T20:37:49-0500] [ALPM] running '70-dkms-install.hook'...
[2021-12-31T20:37:49-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod nvidia/495.44 -k 5.15.7-1-MANJARO
[2021-12-31T20:37:50-0500] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 5.15.7-1-MANJARO (x86_64)
[2021-12-31T20:37:50-0500] [ALPM-SCRIPTLET] Consult /var/lib/dkms/nvidia/495.44/build/make.log for more information.
[2021-12-31T20:37:50-0500] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod nvidia/495.44 -k 5.15.7-1-MANJARO' exited 10
I’ve had a look in the dkms make logs and there’s no errors in the logs…I’m not sure what I should do to resolve?
TIA
Jade1:
nvidia/495.44
Er? That shouldn’t be there.
Please post the output of the following:
mhwd-kernel -li
mhwhd -li
pacman -Qs nvidia
Jade1
10 May 2022 12:38
4
Thanks for taking a look.
mhwd-kernel -li
Currently running: 5.15.12-1-MANJARO (linux515)
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
pacman -Qs nvidia
local/cuda 11.6.1-1
NVIDIA's GPU programming toolkit
local/egl-wayland 2:1.1.9+r3+g582b2d3-1
EGLStream-based Wayland external platform
local/lib32-nvidia-utils 510.60.02-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
Nvidia VDPAU library
local/libxnvctrl 510.60.02-1
NVIDIA NV-CONTROL X extension
local/linux510-nvidia 510.60.02-2 (linux510-extramodules)
NVIDIA drivers for linux.
local/linux515-nvidia 510.60.02-3 (linux515-extramodules)
local/mhwd-nvidia 510.60.02-1
MHWD module-ids for nvidia 510.60.02
local/mhwd-nvidia-390xx 390.147-2
MHWD module-ids for nvidia 390.147
local/mhwd-nvidia-470xx 470.103.01-1
MHWD module-ids for nvidia 470.103.01
local/nvidia-dkms 510.60.02-1
NVIDIA drivers - module sources
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 510.60.02-1
local/opencl-nvidia 510.60.02-1
OpenCL implemention for NVIDIA
