Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=70faa59c-ed2e-4e81-9777-f823a4e4050c ro
psmouse.synaptics_intertouch=0 quiet apparmor=1 security=apparmor
udev.log_priority=3 idle=nomwait
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_F570ZD
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <filter>
UEFI: American Megatrends v: X570ZD.312 date: 02/25/2020
ID-1: BAT0 charge: 41.9 Wh (99.1%) condition: 42.3/48.1 Wh (88.0%)
volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 219
RAM: total: 6.8 GiB used: 1.99 GiB (29.3%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 810100B cache: L2: 2 MiB bogomips: 31948
Speed: 2240 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 2240 2: 1937 3: 1520 4: 1687 5: 1285 6: 1439 7: 1358 8: 1249
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:4 chip-ID: 13d3:5a05 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.12.9-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f000
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
IF-ID-1: br-718e2cf9ece4 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: outline-tun0 state: down mac: N/A
IP v4: <filter> scope: global
bus-ID: 3-2.1:3 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 931.51 GiB used: 125.74 GiB (13.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
rotation: 5400 rpm serial: <filter> rev: 0J scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 125.74 GiB (13.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 70faa59c-ed2e-4e81-9777-f823a4e4050c
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1EB2-5DFC
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 3-2.2:4 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 53.8 C mobo: 53.0 C
Fan Speeds (RPM): cpu: 3100
GPU: device: amdgpu temp: 53.0 C device: nouveau temp: 45.0 C
Processes: 305 Uptime: 2h 38m wakeups: 3 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1573
lib: 437 flatpak: 0 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
Hello warl0rd,
Did you find out a solution regarding your freeze problem ? Actually I’m struggling with the same issue.
