From yesterday wont work the nvidia card in my laptop
What’s the output of
mhwd --listall
please because:
sudo mhwd --install pci video-nvidia
should have just worked (unless you made a typo instead of me now)
:grin:
mhwd --listall
> All PCI configs:
   network-broadcom-wl            2018.10.07                true            PCI
     network-rt3562sta            2013.12.07                true            PCI
       network-slmodem            2013.12.07                true            PCI
         network-r8168            2016.04.20                true            PCI
          video-sisusb            2020.01.18                true            PCI
           video-linux            2018.05.04                true            PCI
       video-rendition            2020.01.18                true            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2020.11.30               false            PCI
    video-nvidia-390xx            2020.11.30               false            PCI
          video-voodoo            2017.03.12                true            PCI
  video-virtualmachine            2020.03.26                true            PCI
      video-openchrome            2020.01.18                true            PCI
              video-s3            2020.01.18                true            PCI
Warning: No USB configs found!
I tried to install the proprietary nVidia driver as written in Manjaro Wiki:
sudo mhwd -a pci nonfree 0300
Here is the result:
mhwd --listinstalled
> Installed PCI configs:
Why is it freedriver? It was in the command as clear as can: nonfree.
So, mhwd put up a free driver. Which one is misleading? The wiki or the mhwd?
Edit:
Finally I got rid the problem. Now it works.
Did you re-install while using non-free drivers???
:thinking:
Removed video-linux.
Installed nvidia-linux510. I think that was the solution.
That is freedriver but works.
changed original post to do just that and marked it as a solution so that the next person that has the same problem as you is helped too!
:+1:
