Yeah iβve masked it, it does help, but looks like there might still be a 10 second delay? I was able to find where my reboot starts:
Jun 06 17:53:38 ManjaroPC dbus-daemon[706]: [session uid=1000 pid=706] Activating service name='org.kde.LogoutPrompt' requested by ':1.15' (uid=1000 pid=837 comm="/usr/bin/plasmashell --no-respawn")
Jun 06 17:53:38 ManjaroPC dbus-daemon[706]: [session uid=1000 pid=706] Successfully activated service 'org.kde.LogoutPrompt'
Jun 06 17:53:38 ManjaroPC ksmserver-logout-greeter[1923]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jun 06 17:53:40 ManjaroPC dbus-daemon[706]: [session uid=1000 pid=706] Activating service name='org.kde.Shutdown' requested by ':1.60' (uid=1000 pid=1923 comm="/usr/lib/ksmserver-logout-greeter")
Jun 06 17:53:40 ManjaroPC dbus-daemon[706]: [session uid=1000 pid=706] Successfully activated service 'org.kde.Shutdown'
Jun 06 17:53:40 ManjaroPC plasmashell[837]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:125: TypeError: Cannot read property 'compactRepresentationItem' of null
Jun 06 17:53:40 ManjaroPC kaccess[1019]: The X11 connection broke (error 1). Did the X11 server die?
Jun 06 17:53:40 ManjaroPC plasmashell[1320]: [1320:1320:0606/175340.506053:ERROR:connection.cc(46)] X connection error received.
Jun 06 17:53:40 ManjaroPC systemd[678]: app-kaccess@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd-logind[501]: The system will reboot now!
Jun 06 17:53:40 ManjaroPC kwin_wayland[718]: QtDBus: cannot relay signals from parent QObject(0x560030d52dc0 "") unless they are emitted in the object's thread QThread(0x560030b04988 "libinput-connection"). Current thread is QThread(0x560030a9d8d0 "").
Jun 06 17:53:40 ManjaroPC systemd-logind[501]: System is rebooting.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Session 2 of User jorogumo4...
Jun 06 17:53:40 ManjaroPC sddm[572]: Authentication error: "Process crashed"
Jun 06 17:53:40 ManjaroPC sddm[572]: Auth: sddm-helper crashed (exit code 15)
Jun 06 17:53:40 ManjaroPC sddm[572]: Auth: sddm-helper exited with 15
Jun 06 17:53:40 ManjaroPC sddm[572]: Socket server stopping...
Jun 06 17:53:40 ManjaroPC sddm[572]: Socket server stopped.
Jun 06 17:53:40 ManjaroPC sddm[572]: Display server stopping...
Jun 06 17:53:40 ManjaroPC sddm[572]: Display server stopped.
Jun 06 17:53:40 ManjaroPC sddm[572]: Running display stop script "/usr/share/sddm/scripts/Xstop"
Jun 06 17:53:40 ManjaroPC systemd[1]: Removed slice Slice /system/getty.
Jun 06 17:53:40 ManjaroPC sddm[572]: Removing display ":0" ...
Jun 06 17:53:40 ManjaroPC sddm[572]: Adding new display on vt 1 ...
Jun 06 17:53:40 ManjaroPC sddm[572]: Loading theme configuration from ""
Jun 06 17:53:40 ManjaroPC sddm[572]: Display server starting...
Jun 06 17:53:40 ManjaroPC sddm[572]: Adding cookie to "/var/run/sddm/{01cbb5ec-ccd7-4599-a435-91e53c5761ba}"
Jun 06 17:53:40 ManjaroPC systemd[678]: app-brave\x2dbrowser-6d8b3bf455cb4df9b3e474d2a43fcfa0.scope: Consumed 55.318s CPU time.
Jun 06 17:53:40 ManjaroPC sddm[572]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{01cbb5ec-ccd7-4599-a435-91e53c5761ba} -noreset -displayfd 18
Jun 06 17:53:40 ManjaroPC systemd[1]: Removed slice Slice /system/modprobe.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped target Graphical Interface.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped target Multi-User System.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped target Login Prompts.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped target Sound Card.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped target Timer Units.
Jun 06 17:53:40 ManjaroPC systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Jun 06 17:53:40 ManjaroPC systemd[1]: fstrim.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Discard unused blocks once a week.
Jun 06 17:53:40 ManjaroPC systemd[1]: logrotate.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Daily rotation of log files.
Jun 06 17:53:40 ManjaroPC systemd[1]: man-db.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Daily man-db regeneration.
Jun 06 17:53:40 ManjaroPC systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Monthly clean packages cache.
Jun 06 17:53:40 ManjaroPC systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Generate mirrorlist weekly.
Jun 06 17:53:40 ManjaroPC systemd[1]: pkgfile-update.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped pkgfile database update timer.
Jun 06 17:53:40 ManjaroPC systemd[1]: shadow.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Daily verification of password and group files.
Jun 06 17:53:40 ManjaroPC systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jun 06 17:53:40 ManjaroPC systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Closed LVM2 poll daemon socket.
Jun 06 17:53:40 ManjaroPC systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 06 17:53:40 ManjaroPC ModemManager[518]: <info> caught signal, shutting down...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Modem Manager...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Save/Restore Sound Card State...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Periodic Command Scheduler...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping CUPS Scheduler...
Jun 06 17:53:40 ManjaroPC systemd[1]: Starting Generate shutdown-ramfs...
Jun 06 17:53:40 ManjaroPC systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC NetworkManager[502]: <info> [1686088420.7328] modem-manager: ModemManager no longer available
Jun 06 17:53:40 ManjaroPC ModemManager[518]: <info> ModemManager is shut down
Jun 06 17:53:40 ManjaroPC crond[498]: (CRON) INFO (Shutting down)
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopped Hold until boot process finishes up.
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Power Profiles daemon...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Simple Desktop Display Manager...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Load/Save OS Random Seed...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Disk Manager...
Jun 06 17:53:40 ManjaroPC systemd[1]: Stopping Daemon for power management...
Jun 06 17:53:40 ManjaroPC udisksd[644]: udisks daemon version 2.9.4 exiting
Jun 06 17:53:40 ManjaroPC udisksd[644]: **
Jun 06 17:53:40 ManjaroPC udisksd[644]: GLib-GIO:ERROR:../glib/gio/gresource.c:1451:g_static_resource_fini: assertion failed: (g_atomic_int_get (&resource->ref_count) >= 2)
Jun 06 17:53:40 ManjaroPC udisksd[644]: Bail out! GLib-GIO:ERROR:../glib/gio/gresource.c:1451:g_static_resource_fini: assertion failed: (g_atomic_int_get (&resource->ref_count) >= 2)
Jun 06 17:53:40 ManjaroPC mkinitcpio[1970]: ==> Starting build: 'none'
Jun 06 17:53:40 ManjaroPC mkinitcpio[1970]: -> Running build hook: [sd-shutdown]
Jun 06 17:53:40 ManjaroPC mkinitcpio[1970]: ==> Build complete.
Jun 06 17:53:40 ManjaroPC kded5[798]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC plasmashell[837]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC kactivitymanagerd[878]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC org_kde_powerdevil[880]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC polkit-kde-authentication-agent-1[879]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC remmina[1014]: Error reading events from display: Broken pipe
Jun 06 17:53:40 ManjaroPC msm_kde_notifier[1007]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC pamac-tray-plasma[1022]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC kdeconnectd[1008]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC konsole[1192]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC xdg-desktop-portal-kde[881]: The Wayland connection broke. Did the Wayland compositor die?
Jun 06 17:53:40 ManjaroPC systemd[678]: app-org.kde.kdeconnect.daemon@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: app-remmina\x2dapplet@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: app-remmina\x2dapplet@autostart.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-polkit-agent.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-polkit-agent.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: app-msm_kde_notifier@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-kded.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-kded.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-powerdevil.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-powerdevil.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: app-pamac\x2dtray\x2dplasma@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: app-konsole-089c3141183a4892bcdc158d2e051f32.scope: Consumed 8.050s CPU time.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target plasma-workspace-wayland.target.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target KDE Plasma Workspace.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target Startup of XDG autostart applications.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping Geoclue Demo agent...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping Accessibility services bus...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped KDE PolicyKit Authentication Agent.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped Powerdevil.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target KDE Plasma Workspace Core.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping KDE Plasma Workspace...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping Portal service...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping flatpak document portal service...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping sandboxed app permission store...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopping Baloo File Indexer Daemon...
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped KDE Window Manager.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-kwin_wayland.service: Consumed 6.612s CPU time.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped sandboxed app permission store.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped Geoclue Demo agent.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped flatpak document portal service.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-plasmashell.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-plasmashell.service: Failed with result 'exit-code'.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped KDE Plasma Workspace.
Jun 06 17:53:40 ManjaroPC systemd[678]: plasma-plasmashell.service: Consumed 4.601s CPU time.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target Current graphical user session.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped target Session services which should run early before the graphical session is brought up.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped Portal service.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped Accessibility services bus.
Jun 06 17:53:40 ManjaroPC systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Jun 06 17:53:40 ManjaroPC systemd[678]: Stopped Baloo File Indexer Daemon.
Jun 06 17:53:40 ManjaroPC systemd[1]: Unmounted /run/user/1000/doc.
Jun 06 17:53:41 ManjaroPC systemd[1]: cronie.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Periodic Command Scheduler.
Jun 06 17:53:41 ManjaroPC systemd[1]: ModemManager.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Modem Manager.
Jun 06 17:53:41 ManjaroPC systemd[1]: cups.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped CUPS Scheduler.
Jun 06 17:53:41 ManjaroPC systemd[1]: upower.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Daemon for power management.
Jun 06 17:53:41 ManjaroPC systemd[1]: rtkit-daemon.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jun 06 17:53:41 ManjaroPC systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Power Profiles daemon.
Jun 06 17:53:41 ManjaroPC systemd[1]: alsa-restore.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Save/Restore Sound Card State.
Jun 06 17:53:41 ManjaroPC systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Finished Generate shutdown-ramfs.
Jun 06 17:53:41 ManjaroPC systemd[1]: systemd-random-seed.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Load/Save OS Random Seed.
Jun 06 17:53:41 ManjaroPC systemd[1]: session-2.scope: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Session 2 of User jorogumo4.
Jun 06 17:53:41 ManjaroPC systemd-logind[501]: Session 2 logged out. Waiting for processes to exit.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopping Authorization Manager...
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopping User Manager for UID 1000...
Jun 06 17:53:41 ManjaroPC systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Jun 06 17:53:41 ManjaroPC systemd[1]: udisks2.service: Failed with result 'core-dump'.
Jun 06 17:53:41 ManjaroPC systemd[678]: Activating special unit Exit the Session...
Jun 06 17:53:41 ManjaroPC systemd[678]: Removed slice User Background Tasks Slice.
Jun 06 17:53:41 ManjaroPC systemd[678]: background.slice: Consumed 1.210s CPU time.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped target Main User Target.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping D-Bus User Message Bus...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping User preferences database...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping Bluetooth OBEX service...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping PipeWire PulseAudio...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped User preferences database.
Jun 06 17:53:41 ManjaroPC systemd[678]: obex.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 17:53:41 ManjaroPC systemd[678]: obex.service: Failed with result 'exit-code'.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped Bluetooth OBEX service.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped PipeWire PulseAudio.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping Multimedia Service Session Manager...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped D-Bus User Message Bus.
Jun 06 17:53:41 ManjaroPC wireplumber[1143]: stopped by signal: Terminated
Jun 06 17:53:41 ManjaroPC wireplumber[1143]: disconnected from pipewire
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Disk Manager.
Jun 06 17:53:41 ManjaroPC systemd[1]: polkit.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped Multimedia Service Session Manager.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopping PipeWire Multimedia Service...
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped PipeWire Multimedia Service.
Jun 06 17:53:41 ManjaroPC systemd[678]: Removed slice User Core Session Slice.
Jun 06 17:53:41 ManjaroPC systemd[678]: session.slice: Consumed 13.491s CPU time.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped target Basic System.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped target Paths.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped target Sockets.
Jun 06 17:53:41 ManjaroPC systemd[678]: Stopped target Timers.
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed D-Bus User Message Bus Socket.
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed GnuPG network certificate management daemon.
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed GnuPG cryptographic agent and passphrase cache.
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed p11-kit server.
Jun 06 17:53:41 ManjaroPC systemd[678]: Closed PipeWire PulseAudio.
Jun 06 17:53:41 ManjaroPC systemd[678]: Removed slice User Application Slice.
Jun 06 17:53:41 ManjaroPC systemd[678]: app.slice: Consumed 1min 5.085s CPU time.
Jun 06 17:53:41 ManjaroPC systemd[678]: Reached target Shutdown.
Jun 06 17:53:41 ManjaroPC systemd[678]: Finished Exit the Session.
Jun 06 17:53:41 ManjaroPC systemd[678]: Reached target Exit the Session.
Jun 06 17:53:41 ManjaroPC (sd-pam)[679]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[jorogumo4] ruser=[<unknown>] rhost=[<unknown>]
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped Authorization Manager.
Jun 06 17:53:41 ManjaroPC systemd[1]: user@1000.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped User Manager for UID 1000.
Jun 06 17:53:41 ManjaroPC systemd[1]: user@1000.service: Consumed 1min 20.107s CPU time.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jun 06 17:53:41 ManjaroPC systemd-logind[501]: Removed session 2.
Jun 06 17:53:41 ManjaroPC systemd[1]: run-user-1000.mount: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Unmounted /run/user/1000.
Jun 06 17:53:41 ManjaroPC systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Jun 06 17:53:41 ManjaroPC systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jun 06 17:53:41 ManjaroPC systemd[1]: Removed slice User Slice of UID 1000.
Jun 06 17:53:41 ManjaroPC systemd[1]: user-1000.slice: Consumed 1min 20.400s CPU time.
Jun 06 17:55:10 ManjaroPC systemd[1]: sddm.service: State 'stop-sigterm' timed out. Killing.
Jun 06 17:55:10 ManjaroPC systemd[1]: sddm.service: Killing process 572 (sddm) with signal SIGKILL.
Jun 06 17:55:10 ManjaroPC systemd[1]: sddm.service: Killing process 1967 (Xorg) with signal SIGKILL.
Jun 06 17:55:10 ManjaroPC systemd[1]: sddm.service: Main process exited, code=killed, status=9/KILL
Jun 06 17:55:10 ManjaroPC systemd[1]: sddm.service: Failed with result 'timeout'.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped Simple Desktop Display Manager.
Jun 06 17:55:10 ManjaroPC systemd[1]: plymouth-quit.service: Deactivated successfully.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped Terminate Plymouth Boot Screen.
Jun 06 17:55:10 ManjaroPC systemd[1]: Starting Show Plymouth Reboot Screen...
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopping User Login Management...
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopping Permit User Sessions...
Jun 06 17:55:10 ManjaroPC systemd[1]: Received SIGRTMIN+20 from PID 2106 (plymouthd).
Jun 06 17:55:10 ManjaroPC systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped Permit User Sessions.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped target Network.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped target Remote File Systems.
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopping Network Manager...
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.8753] caught SIGTERM, shutting down normally.
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.9220] dhcp4 (enp6s0): canceled DHCP transaction
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.9220] dhcp4 (enp6s0): activation: beginning transaction (timeout in 45 seconds)
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.9221] dhcp4 (enp6s0): state changed no lease
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.9224] manager: NetworkManager state is now CONNECTED_SITE
Jun 06 17:55:10 ManjaroPC systemd[1]: systemd-logind.service: Deactivated successfully.
Jun 06 17:55:10 ManjaroPC dbus-daemon[499]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
Jun 06 17:55:10 ManjaroPC NetworkManager[502]: <info> [1686088510.9257] exiting (success)
Jun 06 17:55:10 ManjaroPC systemd[1]: Stopped User Login Management.
Jun 06 17:55:10 ManjaroPC systemd[1]: NetworkManager.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Network Manager.
Jun 06 17:55:11 ManjaroPC systemd[1]: Started Show Plymouth Reboot Screen.
Jun 06 17:55:11 ManjaroPC dbus-daemon[499]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopping D-Bus System Message Bus...
Jun 06 17:55:11 ManjaroPC systemd[1]: Starting Tell Plymouth To Jump To initramfs...
Jun 06 17:55:11 ManjaroPC systemd[1]: dbus.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped D-Bus System Message Bus.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Basic System.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Path Units.
Jun 06 17:55:11 ManjaroPC systemd[1]: cups.path: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped CUPS Scheduler.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Slice Units.
Jun 06 17:55:11 ManjaroPC systemd[1]: Removed slice User and Session Slice.
Jun 06 17:55:11 ManjaroPC systemd[1]: user.slice: Consumed 1min 21.625s CPU time.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Socket Units.
Jun 06 17:55:11 ManjaroPC systemd[1]: cups.socket: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Closed CUPS Scheduler.
Jun 06 17:55:11 ManjaroPC systemd[1]: dbus.socket: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Closed D-Bus System Message Bus Socket.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target System Initialization.
Jun 06 17:55:11 ManjaroPC systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Local Encrypted Volumes.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Local Integrity Protected Volumes.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Local Verity Protected Volumes.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-sysctl.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Apply Kernel Variables.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-coredump.socket: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Closed Process Core Dump Socket.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-modules-load.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Load Kernel Modules.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Jun 06 17:55:11 ManjaroPC systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Jun 06 17:55:11 ManjaroPC systemd[1]: Finished Tell Plymouth To Jump To initramfs.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Create Volatile Files and Directories.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Local File Systems.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounting /run/credentials/systemd-vconsole-setup.service...
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounting /tmp...
Jun 06 17:55:11 ManjaroPC umount[2115]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount point specified.
Jun 06 17:55:11 ManjaroPC systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Mount process exited, code=exited, status=32/n/a
Jun 06 17:55:11 ManjaroPC systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounted /run/credentials/systemd-tmpfiles-setup.service.
Jun 06 17:55:11 ManjaroPC systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounted /run/credentials/systemd-tmpfiles-setup-dev.service.
Jun 06 17:55:11 ManjaroPC systemd[1]: run-credentials-systemd\x2dvconsole\x2dsetup.service.mount: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounted /run/credentials/systemd-vconsole-setup.service.
Jun 06 17:55:11 ManjaroPC systemd[1]: tmp.mount: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Unmounted /tmp.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Preparation for Local File Systems.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped target Swaps.
Jun 06 17:55:11 ManjaroPC systemd[1]: Reached target Unmount All Filesystems.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Remount Root and Kernel File Systems.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Create Static Device Nodes in /dev.
Jun 06 17:55:11 ManjaroPC systemd[1]: lvm2-monitor.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jun 06 17:55:11 ManjaroPC systemd[1]: Reached target System Shutdown.
Jun 06 17:55:11 ManjaroPC systemd[1]: Reached target Late Shutdown Services.
Jun 06 17:55:11 ManjaroPC systemd[1]: systemd-reboot.service: Deactivated successfully.
Jun 06 17:55:11 ManjaroPC systemd[1]: Finished System Reboot.
Jun 06 17:55:11 ManjaroPC systemd[1]: Reached target System Reboot.
Jun 06 17:55:11 ManjaroPC systemd[1]: Shutting down.
Jun 06 17:55:11 ManjaroPC systemd-shutdown[1]: Syncing filesystems and block devices.
Jun 06 17:55:11 ManjaroPC systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Jun 06 17:55:11 ManjaroPC systemd-journald[384]: Received SIGTERM from PID 1 (systemd-shutdow).
Jun 06 17:55:11 ManjaroPC systemd-journald[384]: Journal stopped
weβve definitely come down on time now, but itβs still taking about 2 minutes just to shutdown.
I noticed thereβs about a minute and a half between these two lines?
