Hello Everyone,
I recently wiped my SSD and installed Manjaro on my ‘new to me’ X1 Carbon 6th generation. For some reason, it seems to hang after doing a fresh install of Manjaro Gnome.
Attaching some log details below:
inxi -zav7 Output:
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d44a9032-e25e-4ec7-a8f2-0a03785901d6 rw quiet splash apparmor=1
security=apparmor resume=UUID=9c8cef51-9607-45cc-a640-3ba3afe44c60
udev.log_priority=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 20KH002JUS v: ThinkPad X1 Carbon
Mobo: LENOVO model: 20KH002JUS v: SDK0K17763 WIN
serial: <superuser required> UEFI: LENOVO v: N23ET84W (1.59 )
date: 01/03/2023
ID-1: BAT0 charge: 21.1 Wh (68.5%) condition: 30.8/57.0 Wh (54.0%)
volts: 12.0 min: 11.6 model: LGC 01AV494 type: Li-poly serial: <filter>
status: discharging cycles: 249
RAM: total: 15.5 GiB used: 1.28 GiB (8.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1450 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2100 2: 800 3: 800
4: 2100 5: 800 6: 800 7: 2100 8: 2100 bogomips: 33615
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 13d3:56b2 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x233d built: 2017 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
class-ID: 0280
Local Storage: total: 476.94 GiB used: 9.82 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1001 size: 476.94 GiB block-size: physical: 512 B
rev: 11170101 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.69 GiB (9.9%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: d44a9032-e25e-4ec7-a8f2-0a03785901d6
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F3DF-3207
ID-3: /home raw-size: 351.65 GiB size: 345.06 GiB (98.13%)
used: 129 MiB (0.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 1aee4b25-d47d-4846-b6b3-4f3a1b8b8565
ID-1: swap-1 type: partition size: 25 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9c8cef51-9607-45cc-a640-3ba3afe44c60
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:3 info: IMC Networks Integrated Camera type: Video
Device-2: 1-9:4 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Device-3: 1-10:5 info: Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 96mA chip-ID: 2386:4328 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Realtek USB3.0-CRW type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0328 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.0 C pch: 41.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 251 Uptime: 1m wakeups: 4 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1195 libs: 310 tools: gnome-software,pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
journalctl -b0 -p4 --no pager Output:
Feb 28 16:15:16 aahmad-x1c kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Feb 28 16:15:16 aahmad-x1c kernel: x86/cpu: SGX disabled by BIOS.
Feb 28 16:15:16 aahmad-x1c kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Feb 28 16:15:16 aahmad-x1c kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Feb 28 16:15:16 aahmad-x1c kernel: #5 #6 #7
Feb 28 16:15:16 aahmad-x1c kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Feb 28 16:15:16 aahmad-x1c kernel: pnp 00:0b: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 28 16:15:16 aahmad-x1c kernel: pnp 00:0b: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 28 16:15:16 aahmad-x1c kernel: pnp 00:0b: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 28 16:15:16 aahmad-x1c kernel: pnp 00:0b: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Feb 28 16:15:16 aahmad-x1c kernel: hpet_acpi_add: no address or irqs in _CRS
Feb 28 16:15:16 aahmad-x1c kernel: usb: port power management may be unreliable
Feb 28 16:15:16 aahmad-x1c kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Feb 28 16:15:16 aahmad-x1c kernel: caller snb_uncore_imc_init_box+0x84/0xd0 [intel_uncore] mapping multiple BARs
Feb 28 16:15:19 aahmad-x1c kernel: kauditd_printk_skb: 57 callbacks suppressed
Feb 28 16:15:19 aahmad-x1c kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Feb 28 16:15:20 aahmad-x1c kernel: Bluetooth: hci0: Failed to send firmware data (-19)
Feb 28 16:15:20 aahmad-x1c kernel: Bluetooth: hci0: sending frame failed (-19)
Feb 28 16:15:20 aahmad-x1c kernel: Bluetooth: hci0: FW download error recovery failed (-19)
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 28 16:15:20 aahmad-x1c bluetoothd[510]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 28 16:15:25 aahmad-x1c kernel: kauditd_printk_skb: 24 callbacks suppressed
Feb 28 16:15:26 aahmad-x1c gsettings[644]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:26 aahmad-x1c gsettings[644]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:26 aahmad-x1c gnome-session-b[643]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:26 aahmad-x1c gnome-session-b[643]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:26 aahmad-x1c gnome-session-binary[643]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
Feb 28 16:15:26 aahmad-x1c gnome-shell[651]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:26 aahmad-x1c gnome-shell[651]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:27 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=651 comm="/usr/bin/gnome-shell")
Feb 28 16:15:27 aahmad-x1c at-spi-bus-laun[671]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:27 aahmad-x1c at-spi-bus-laun[671]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:27 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.a11y.Bus'
Feb 28 16:15:27 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=651 comm="/usr/bin/gnome-shell")
Feb 28 16:15:27 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=651 comm="/usr/bin/gnome-shell")
Feb 28 16:15:27 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=651 comm="/usr/bin/gnome-shell")
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[676]: dbus-daemon[676]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=651 comm="/usr/bin/gnome-shell")
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[676]: dbus-daemon[676]: Successfully activated service 'org.a11y.atspi.Registry'
Feb 28 16:15:28 aahmad-x1c geoclue[717]: Failed to connect to avahi service: Daemon not running
Feb 28 16:15:28 aahmad-x1c gsd-sharing[754]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-sharing[754]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-keyboard[765]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-keyboard[765]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.gnome.Shell.Notifications'
Feb 28 16:15:28 aahmad-x1c gsd-color[762]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-color[762]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-wacom[774]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-wacom[774]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-a11y-settin[804]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-a11y-settin[804]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gnome-shell[651]: JS ERROR: TypeError: this._managerProxy is undefined
_onGeoclueVanished@resource:///org/gnome/shell/ui/status/location.js:163:9
Feb 28 16:15:28 aahmad-x1c gsd-smartcard[773]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-smartcard[773]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-datetime[781]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-datetime[781]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-media-keys[790]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-media-keys[790]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-usb-protect[758]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-usb-protect[758]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.gtk.vfs.Daemon' requested by ':1.23' (uid=120 pid=772 comm="ibus-daemon --panel disable")
Feb 28 16:15:28 aahmad-x1c gsd-housekeepin[807]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-housekeepin[807]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-sound[803]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-sound[803]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-power[809]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-power[809]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=754 comm="/usr/lib/gsd-sharing")
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=758 comm="/usr/lib/gsd-usb-protection")
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Feb 28 16:15:28 aahmad-x1c gsd-sharing[754]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.gtk.vfs.Daemon'
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.freedesktop.portal.IBus' requested by ':1.23' (uid=120 pid=772 comm="ibus-daemon --panel disable")
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.freedesktop.portal.IBus'
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Successfully activated service 'org.gnome.ScreenSaver'
Feb 28 16:15:28 aahmad-x1c gsd-usb-protect[758]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Feb 28 16:15:28 aahmad-x1c gnome-shell[651]: Unhandled promise rejection. To suppress this warning, add an error handler to your promise chain with .catch() or a try-catch block around your await expression. Stack trace of the failed promise:
_onConnected@resource:///org/gnome/shell/misc/inputMethod.js:64:23
Feb 28 16:15:28 aahmad-x1c gnome-shell[651]: ATK Bridge is disabled but a11y has already been enabled.
Feb 28 16:15:28 aahmad-x1c gsd-xsettings[806]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-xsettings[806]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Feb 28 16:15:28 aahmad-x1c gsd-media-keys[790]: Failed to grab accelerator for keybinding settings:hibernate
Feb 28 16:15:28 aahmad-x1c gsd-media-keys[790]: Failed to grab accelerator for keybinding settings:playback-repeat
Feb 28 16:15:28 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.freedesktop.portal.IBus' requested by ':1.39' (uid=120 pid=978 comm="ibus-daemon --panel disable -r --xim")
Feb 28 16:15:30 aahmad-x1c kernel: kauditd_printk_skb: 22 callbacks suppressed
Feb 28 16:15:31 aahmad-x1c gdm-password][1023]: gkr-pam: unable to locate daemon control file
Feb 28 16:15:31 aahmad-x1c systemd-xdg-autostart-generator[1044]: /home/aahmad/.config/autostart/auto:1: Assignment outside of section. Ignoring.
Feb 28 16:15:31 aahmad-x1c systemd-journald[345]: File /var/log/journal/9820939f7ebf4f5eafdab14582a5c452/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Feb 28 16:15:31 aahmad-x1c systemd-xdg-autostart-generator[1044]: /home/aahmad/.config/autostart/manjaro-starter.desktop: not generating unit, error parsing Exec= line: No such file or directory
Feb 28 16:15:31 aahmad-x1c systemd-xdg-autostart-generator[1044]: /home/aahmad/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, error parsing Exec= line: No such file or directory
Feb 28 16:15:32 aahmad-x1c gnome-session-binary[1109]: WARNING: Could not parse desktop file manjaro-app-folder-settings.desktop or it references a not found TryExec binary
Feb 28 16:15:32 aahmad-x1c gnome-session-binary[1109]: WARNING: Could not parse desktop file manjaro-starter.desktop or it references a not found TryExec binary
Feb 28 16:15:32 aahmad-x1c gnome-keyring-daemon[1122]: discover_other_daemon: 1
Feb 28 16:15:32 aahmad-x1c gnome-keyring-daemon[1123]: discover_other_daemon: 1
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1119.scope: Failed to add PIDs to scope's control group: No such process
Feb 28 16:15:32 aahmad-x1c gnome-keyring-daemon[1124]: discover_other_daemon: 1
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1119.scope: Failed with result 'resources'.
Feb 28 16:15:32 aahmad-x1c systemd[1036]: Failed to start Application launched by gnome-session-binary.
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dsecrets-1121.scope: Failed to add PIDs to scope's control group: No such process
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dsecrets-1121.scope: Failed with result 'resources'.
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dssh-1118.scope: Failed to add PIDs to scope's control group: No such process
Feb 28 16:15:32 aahmad-x1c systemd[1036]: app-gnome-gnome\x2dkeyring\x2dssh-1118.scope: Failed with result 'resources'.
Feb 28 16:15:34 aahmad-x1c gnome-shell[1129]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
Feb 28 16:15:34 aahmad-x1c gnome-shell[1129]: Some code accessed the property 'ThumbnailsBox' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
Feb 28 16:15:34 aahmad-x1c pulseaudio[1261]: stat('/etc/pulse/default.pa.d'): No such file or directory
Feb 28 16:15:34 aahmad-x1c systemd[1036]: Dependency failed for GNOME XSettings service.
Feb 28 16:15:34 aahmad-x1c gnome-session-binary[1109]: GnomeDesktop-WARNING: Could not create transient scope for PID 1492: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1492 does not exist.
Feb 28 16:15:34 aahmad-x1c gnome-session-binary[1109]: GnomeDesktop-WARNING: Could not create transient scope for PID 1502: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1502 does not exist.
Feb 28 16:15:34 aahmad-x1c systemd[1036]: app-gnome-create\x2dtemplate-1497.scope: Failed to add PIDs to scope's control group: No such process
Feb 28 16:15:34 aahmad-x1c systemd[1036]: app-gnome-create\x2dtemplate-1497.scope: Failed with result 'resources'.
Feb 28 16:15:34 aahmad-x1c systemd[1036]: Failed to start Application launched by gnome-session-binary.
Feb 28 16:15:34 aahmad-x1c systemd[1036]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-1500.scope: Failed to add PIDs to scope's control group: No such process
Feb 28 16:15:34 aahmad-x1c systemd[1036]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-1500.scope: Failed with result 'resources'.
Feb 28 16:15:34 aahmad-x1c gsd-usb-protect[1422]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Feb 28 16:15:34 aahmad-x1c gnome-shell[1129]: Unhandled promise rejection. To suppress this warning, add an error handler to your promise chain with .catch() or a try-catch block around your await expression. Stack trace of the failed promise:
Feb 28 16:15:35 aahmad-x1c gsd-media-keys[1392]: Failed to grab accelerator for keybinding settings:playback-repeat
Feb 28 16:15:35 aahmad-x1c gsd-media-keys[1392]: Failed to grab accelerator for keybinding settings:hibernate
Feb 28 16:15:35 aahmad-x1c gnome-shell[1129]: ATK Bridge is disabled but a11y has already been enabled.
Feb 28 16:15:35 aahmad-x1c pulseaudio[716]: X11 I/O error handler called
Feb 28 16:15:35 aahmad-x1c pulseaudio[716]: X11 I/O error exit handler called, preparing to tear down X11 modules
Feb 28 16:15:35 aahmad-x1c gnome-shell[651]: Connection to xwayland lost
Feb 28 16:15:35 aahmad-x1c /usr/lib/gdm-wayland-session[642]: dbus-daemon[642]: [session uid=120 pid=642] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=754 comm="/usr/lib/gsd-sharing")
Feb 28 16:15:35 aahmad-x1c gdm-launch-environment][623]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Feb 28 16:15:46 aahmad-x1c kernel: kauditd_printk_skb: 9 callbacks suppressed
Feb 28 16:15:46 aahmad-x1c ModemManager[533]: <warn> [plugin/generic] could not grab port ttyS4: Cannot add port 'tty/ttyS4', unhandled port type
Feb 28 16:15:46 aahmad-x1c ModemManager[533]: <warn> [base-manager] couldn't create modem for device '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Feb 28 16:16:44 aahmad-x1c pipewire[2205]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Feb 28 16:16:44 aahmad-x1c pipewire[2205]: mod.rt: found session bus but no portal
Feb 28 16:16:48 aahmad-x1c pamac-manager[2066]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Please let me know if I can provide any additional details. Thanks!
–Asif
