THE PROBLEM
Every time i open a application/program that is not terminal based i have about 10-20-30 sec time til the program launches and then sometimes if the program opens a floating window (like a settings tab or a color palette stuff) the same problem occurs.
I have no idea what info to share with you, so i only share this:
Applications that has the problem:
- Tunar / Nautilus
- Pulse audio volume controll
- Blueman
Basically everything besides terminal.
System information:
Kernel: 5.15.128-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: i3 v: 4.21.1 dm: 1: LightDM 2: SDDM note: stopped
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET72W (1.47 )
date: 01/03/2023
ID-1: BAT0 charge: 15.7 Wh (85.8%) condition: 18.3/23.9 Wh (76.5%)
volts: 11.7 min: 11.4 model: LGC 01AV489 serial: <filter>
status: not charging
ID-2: BAT1 charge: 57.7 Wh (77.1%) condition: 74.8/71.3 Wh (104.9%)
volts: 11.7 min: 10.8 model: SANYO 01AV427 serial: <filter>
status: discharging
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 899 high: 900 min/max: 400/1901 boost: disabled cores:
1: 899 2: 900 3: 900 4: 899 5: 900 6: 900 7: 900 8: 900 bogomips: 30409
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-8:3 chip-ID: 04f2:b604
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a
driver: X: loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x0521 res: 1920x1080
dpi: 157 diag: 355mm (14")
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel UHD Graphics 620
(KBL GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
API: ALSA v: k5.15.128-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.78 status: off with: pipewire-media-session
status: active
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: enp0s20f0u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 238.47 GiB used: 47.79 GiB (20.0%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 32.9 C
ID-1: / size: 116.5 GiB used: 47.76 GiB (41.0%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 25.4 MiB (26.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Src: /sys System Temperatures: cpu: 44.0 C pch: 41.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 230 Uptime: 1d 4h 36m Memory: total: 8 GiB note: est.
available: 7.51 GiB used: 2.73 GiB (36.4%) Init: systemd v: 253
default: graphical Compilers: gcc: 13.2.1 Packages: pm: pacman pkgs: 1441
Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.29
I really dont want to reinstall everything and i need my laptop for uni, so im really desperate to solve this, i dont want to use windows again!
