Fresh Install no analog sound
Hello, I am pretty new to manjaro and linux in general. I just installed manjaro in my PC and everything but the the speakers are working.
I have an NVIDIA GP107 GeForce GTX 1050 Ti and i have seen people with similar problems with HDMI sound but nothing about the speaker connected to the jacks of the card.
The output of inxi -GA is:
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 515.48.07
  Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: nvidia
    gpu: nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
  OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 515.48.07
  Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 16.0 running: yes
  Sound Server-3: PipeWire v: 0.3.52 running: yes
Hope someone can help.
post output from:
inxi -Fazy
install sof firmware:
pamac install sof-firmware
reboot and test
Fazy:
  Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=317294c6-533c-41e9-976d-a8cd2b857ea6 rw quiet pcie_aspm=off
    apparmor=1 security=apparmor
    resume=UUID=8ae42f6d-3b02-4d4f-891f-0eff133456bf udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: B360 AORUS GAMING 3 WIFI v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B360 AORUS GAMING 3 WIFI-CF v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F13
    date: 06/05/2019
  Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
    stepping: 0xA (10) microcode: 0xF0
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
    desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    bogomips: 34814
  Type: l1tf
    STIBP: disabled, RSB filling
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte GV-N105TOC-4GD
    driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x292mm (41.73x11.50")
    s-diag: 1099mm (43.29")
  Monitor-1: DVI-D-0 pos: right res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
    size: 530x290mm (20.87x11.42") diag: 604mm (23.79") modes: N/A
    v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Sound Server-3: PulseAudio v: 16.0 running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 1.35 TiB used: 482.58 GiB (35.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 14.48 GiB (23.2%)
    fs: ext4 dev: /dev/sda6 maj-min: 8:6
    used: 292 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 234.62 GiB size: 229.88 GiB (97.98%)
    used: 3.97 GiB (1.7%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda5 maj-min: 8:5
  System Temperatures: cpu: 27.8 C pch: 39.0 C mobo: 16.8 C gpu: nvidia
    temp: 45 C
  Processes: 229 Uptime: 13m wakeups: 0 Memory: 15.56 GiB
  used: 2.03 GiB (13.0%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1244
  lib: 337 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: yakuake inxi: 3.3.17
Something odd happened, when I connect a headset to the front panel(integrated intel) the sound from the NVIDIA card is disabled but if there is nothing connected to the front panel the speaker work perfectly when connected to the NVIDIA card.
install sof firmaware:
pacman install sof-firmware
reboot and test
Installed sof-firmware and rebooted, same problem when i have both back and front panel, tried changing. only one works when i try changing which device i want to work with in “system settings”->audio->playback devices.
try different kernels - 5.10 & 5.17
also install pipewire with this:
pamac install manjaro-pipewire
it will give you dependency issues, so uninstall them first, then run the command again, reboot and test
Already tried pipewire, same problem. I will try the kernels, thanks for the suggestion.
It works with kernel 5.10, thanks.
