Frequent screen flickering when navigating through Gnome
This strange behaviour starting occuring a couple of days ago. What happens is that very frequently and quite easily reproducilble, my display will flickr and dim for a split second when I click certain UI elements in Nautilus (the favorite places on the left), or when just scrolling Firefox, or when hovering on open windows in Dash to Panel and also when doing many other things.
Perhaps related, perhaps not but might be worth mentioning is that when I switch Firefox tabs from a dark backgound website to a light one, I can see the page starting up somewhat dim white getting progressively brighter over a couple of seconds.
I have tried disabling all extensions, ensuring I am running all the most stable recent updates, reinstalling the nvidia drivers, doing a fresh OS install (Vanilla and Endeavour) and that was all I could think of. Nothing made any difference.
See this video for the behaviour I mention.
  Kernel: 5.19.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/vmlinuz-linux
    root=UUID=e9f9089e-2a7b-4784-b970-1482b5d34a8c rw rootfstype=ext4
    loglevel=3 ibt=off
  Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
    Distro: Arch Linux
  Type: Laptop System: LENOVO product: 82JM v: Legion 5 17ITH6H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 17ITH6H
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: H1CN49WW date: 08/16/2022
  ID-1: BAT0 charge: 71.9 Wh (86.1%) condition: 83.5/80.0 Wh (104.4%)
    volts: 16.8 min: 15.4 model: Celxpert L20C4PC2 type: Li-poly
    serial: <filter> status: not charging
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
    family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 2218 high: 2300 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
    4: 1000 5: 2300 6: 2300 7: 2300 8: 2300 9: 2300 10: 2300 11: 2300
    12: 2300 13: 2300 14: 2300 15: 2300 16: 2300 bogomips: 73744
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
    (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
    gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
  Device-3: Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:2
    chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,intel,nouveau,nv,vesa gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0x449d built: 2018 res: 1920x1080
    hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
    diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Sound Server-1: ALSA v: k5.19.12-arch1-1 running: yes
  Sound Server-4: PipeWire v: 0.3.58 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 58:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp88s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: N/A type: USB driver: btusb v: 0.8 bus-ID: 3-14:4
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 1.16 TiB used: 568.79 GiB (47.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
    250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
    temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: SK Hynix model: HFS001TDE9X084N
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22
    temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 232.38 GiB size: 227.68 GiB (97.97%) used: 18.42 GiB
    (8.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot raw-size: 511 MiB size: 510 MiB (99.80%) used: 87.6 MiB
    (17.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
  System Temperatures: cpu: 41.0 C mobo: N/A
  Processes: 348 Uptime: 15m wakeups: 1 Memory: 15.41 GiB used: 3.63 GiB
  (23.6%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 955 libs: 284
  tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.21
Do you have the /etc/X11/xorg.conf.d/20-intel.conf with
Section "Device"
  Identifier "Intel Graphics"
  Driver "intel"
  Option "TearFree" "true"
EndSection
in it? Have you tried the early KMS only for the i915 driver? Do you run Firefox with prime-run and using the wayland variable aka MOZ_ENABLE_WAYLAND=1 firefox ?
Other than that i would suggest what @seth suggested on Arch Linux forum …
By the way:
I would go with either one or the other, but not both.
Apparently this is a known issue with the newer versions of kernel 5.19, which started with 5.19.8 and sure enough downgrading the kernel to 5.19.7 solved my issues.
What I also noticed subsequently was that before, with kernel 5.19.12, the max screen brightness was really low compared to what it is now.
I’m not sure how this happened, because I specifically chose to only install pulseaudio during the archinstall script.
So now I ran systemctl disable --global pipewire and it did disable pipewire. Is this good enough, because if I try to remove it it complains about breaking multiple dependencies, including mutter
