So are this two programβs also the reason why you evade Wayland?
Yes, you are right.
So your vs code that crashed two times today, didnt crashed your Desktop?
Yes, you are right again.
KDE-plasma didnβt collapse after cleaning the cache.
But I believe we should wait for it more.
I have reinstalled obs studio and it started to work by the way.
I think at least it shows that this VS Code crash and KDE Plasma crash are separated now. But yeah its worth to wait what happen after some time.
Btw. edit next time your last post to add stuff, instead double post, gives better overview.
I want to use this system some more.
It looks like we may have reached a solution.
Alternatively, I will work from another computer.
Unfortunately, kde-plasma crashed again.
Error from kernel:
[drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
whole output is too long. I couldnβt copy here.
I have this too, thatβs normal(at least not serious error):
Jul 04 15:55:50 koboldx-z170 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Check this logs:
journalctl -p 3 -xb
Thank you. You are very quick.
Also When these crushes happened, I was using the Discord app also.
I suspect that my crush might be related to my increased use of Discord recently.
this is output.
[ckurdu@ckurdu-last-denver ~]$ journalctl -p 3 -xb
Subject: Process 146091 (pamac-manager) dumped core
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ Documentation: man:core(5)
ββ
ββ Process 146091 (pamac-manager) crashed and dumped core.
ββ
ββ This usually indicates a programming error in the crashing program and
ββ should be reported to its vendor as a bug.
Tem 04 20:38:17 ckurdu-last-denver systemd-coredump[187971]: Process 791 (Xorg) of user 0 dumped core.
Stack trace of thread 791:
#0 0x00007fc7f6c19e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fc7f6bc1a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fc7f6ba94c3 abort (libc.so.6 + 0x244c3)
#3 0x0000555a3c76612e OsAbort (Xorg + 0x14b12e)
#4 0x0000555a3c7675e7 FatalError (Xorg + 0x14c5e7)
#5 0x0000555a3c76e268 n/a (Xorg + 0x153268)
#6 0x00007fc7f6bc1ae0 n/a (libc.so.6 + 0x3cae0)
#7 0x00007fc7f5cb0f05 n/a (nvidia_drv.so + 0x4b0f05)
ββ Subject: Process 791 (Xorg) dumped core
ββ
ββ Process 791 (Xorg) crashed and dumped core.
ββ
Tem 04 20:38:17 ckurdu-last-denver xembedsniproxy[188040]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: offscreen, wayland, minimalegl, eglfs, vkkhrdisplay, wayland-egl, linuxfb, xcb, vnc, minimal.
Tem 04 20:38:17 ckurdu-last-denver gmenudbusmenuproxy[188043]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Tem 04 20:38:17 ckurdu-last-denver systemd-coredump[188049]: Process 188040 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 188040:
#0 0x00007f6e6eaa8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f6e6ea50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f6e6ea384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f6e6e48c6b7 n/a (libQt6Core.so.6 + 0x8c6b7)
#4 0x00007f6e6e48ce5b _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce5b)
#5 0x00007f6e6ecdaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f6e6ed7af38 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17af38)
#7 0x00007f6e6e548d75 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148d75)
#8 0x00007f6e6ed7afce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17afce)
#9 0x00007f6e6ed73bdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173bdd)
#10 0x000055a81704024e n/a (xembedsniproxy + 0x624e)
#11 0x00007f6e6ea39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f6e6ea39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055a8170405b5 n/a (xembedsniproxy + 0x65b5)
Stack trace of thread 188045:
#0 0x00007f6e6eb1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f6e6dde48fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f6e6dd81f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f6e6e7a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007f6e6e54f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007f6e6e63a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007f6e6f4efdfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007f6e6e6c96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007f6e6eaa6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f6e6eb2a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 188040 (xembedsniproxy) dumped core
ββ
ββ Process 188040 (xembedsniproxy) crashed and dumped core.
ββ
Tem 04 20:38:18 ckurdu-last-denver systemd-coredump[188055]: Process 188043 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 188043:
#0 0x00007f8432ca8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f8432c50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f8432c384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f843268c6b7 n/a (libQt6Core.so.6 + 0x8c6b7)
#4 0x00007f843268ce5b _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce5b)
#5 0x00007f8432edaa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f8432f7af38 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17af38)
#7 0x00007f8432748d75 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148d75)
#8 0x00007f8432f7afce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17afce)
#9 0x00007f8432f73bdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173bdd)
#10 0x000055c816a86c6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007f8432c39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f8432c39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055c816a86f45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 188053:
#0 0x00007f8432d2c47b sendmsg (libc.so.6 + 0x11847b)
#1 0x00007f8433696ebb n/a (libdbus-1.so.3 + 0x35ebb)
#2 0x00007f84336901d1 n/a (libdbus-1.so.3 + 0x2f1d1)
#3 0x00007f84336907e4 n/a (libdbus-1.so.3 + 0x2f7e4)
#4 0x00007f843367647e n/a (libdbus-1.so.3 + 0x1547e)
#5 0x00007f8433676556 n/a (libdbus-1.so.3 + 0x15556)
#6 0x00007f8433678091 dbus_connection_send_with_reply (libdbus-1.so.3 + 0x17091)
#7 0x00007f843387fdc8 n/a (libQt6DBus.so.6 + 0x49dc8)
#8 0x00007f843278c0ff _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x18c0ff)
#9 0x00007f8432744e13 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x144e13)
#10 0x00007f84327451fb _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x1451fb)
#11 0x00007f84329a460c n/a (libQt6Core.so.6 + 0x3a460c)
#12 0x00007f84320bea89 n/a (libglib-2.0.so.0 + 0x5ca89)
#13 0x00007f84321209b7 n/a (libglib-2.0.so.0 + 0xbe9b7)
#14 0x00007f84320bdf95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#15 0x00007f84329a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#16 0x00007f843274f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#17 0x00007f843283a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#18 0x00007f8433863dfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#19 0x00007f84328c96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#20 0x00007f8432ca6ded n/a (libc.so.6 + 0x92ded)
#21 0x00007f8432d2a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 188043 (gmenudbusmenupr) dumped core
ββ
ββ Process 188043 (gmenudbusmenupr) crashed and dumped core.
ββ
Tem 04 20:38:18 ckurdu-last-denver systemd-coredump[188021]: Process 1127 (ksmserver) of user 1000 dumped core.
Stack trace of thread 1127:
#0 0x00007f76cdc43c2b _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x60c2b)
#1 0x00007f76cdc1c648 _ZN14QXcbConnection20updateScreen_monitorEP10QXcbScreenP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x39648)
#2 0x00007f76cdc1efde _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3bfde)
#3 0x00007f76cdc1f997 _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3c997)
#4 0x00007f76cdc13c1d _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x30c1d)
#5 0x00007f76cdc1a962 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x37962)
#6 0x00007f76cdc31edf n/a (libQt6XcbQpa.so.6 + 0x4eedf)
#7 0x00007f76d2db3a89 n/a (libglib-2.0.so.0 + 0x5ca89)
#8 0x00007f76d2e159b7 n/a (libglib-2.0.so.0 + 0xbe9b7)
#9 0x00007f76d2db2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#10 0x00007f76d3ba28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#11 0x00007f76d394f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#12 0x00007f76d394945d _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x14945d)
#13 0x000055dcfb3a335e n/a (ksmserver + 0xb35e)
#14 0x00007f76d3e39c88 n/a (libc.so.6 + 0x25c88)
#15 0x00007f76d3e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#16 0x000055dcfb3a3ce5 n/a (ksmserver + 0xbce5)
Stack trace of thread 1138:
#0 0x00007f76d3f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f76d2e158fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f76d2db2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f76d3ba28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007f76d394f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007f76d3a3a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007f76d48a7dfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007f76d3ac96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007f76d3ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f76d3f2a0dc n/a (libc.so.6 + 0x1160dc)
Stack trace of thread 1139:
#0 0x00007f76d3ea34e9 n/a (libc.so.6 + 0x8f4e9)
#1 0x00007f76d3ea5ed9 pthread_cond_wait (libc.so.6 + 0x91ed9)
#2 0x00007f76d37e3f75 xcb_wait_for_event (libxcb.so.1 + 0xef75)
#3 0x00007f76cdc31211 n/a (libQt6XcbQpa.so.6 + 0x4e211)
#4 0x00007f76d3ac96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#5 0x00007f76d3ea6ded n/a (libc.so.6 + 0x92ded)
#6 0x00007f76d3f2a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 1127 (ksmserver) dumped core
ββ
ββ Process 1127 (ksmserver) crashed and dumped core.
ββ
Tem 04 20:38:18 ckurdu-last-denver xembedsniproxy[188087]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Tem 04 20:38:18 ckurdu-last-denver systemd-coredump[188101]: Process 188087 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 188087:
#0 0x00007f25ec6a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f25ec650a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f25ec6384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f25ec08c6b7 n/a (libQt6Core.so.6 + 0x8c6b7)
#4 0x00007f25ec08ce5b _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce5b)
#5 0x00007f25ec8daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f25ec97af38 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17af38)
#7 0x00007f25ec148d75 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148d75)
#8 0x00007f25ec97afce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17afce)
#9 0x00007f25ec973bdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173bdd)
#10 0x000055971fec624e n/a (xembedsniproxy + 0x624e)
#11 0x00007f25ec639c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f25ec639d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x000055971fec65b5 n/a (xembedsniproxy + 0x65b5)
Stack trace of thread 188096:
#0 0x00007f25ec71c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f25eba358fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f25eb9d2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f25ec3a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007f25ec14f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007f25ec23a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007f25ed138dfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007f25ec2c96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007f25ec6a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f25ec72a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 188087 (xembedsniproxy) dumped core
ββ
ββ Process 188087 (xembedsniproxy) crashed and dumped core.
ββ
Tem 04 20:38:19 ckurdu-last-denver systemd-coredump[188027]: Process 119985 (Discord) of user 1000 dumped core.
Module /home/ckurdu/.var/app/com.discordapp.Discord/config/discord/0.0.58/modules/discord_spellcheck/node_modules/cld/build/Release/cld.node without build-id.
Module /home/ckurdu/.var/app/com.discordapp.Discord/config/discord/0.0.58/modules/discord_zstd/discord_zstd.node without build-id.
Module /home/ckurdu/.var/app/com.discordapp.Discord/config/discord/0.0.58/modules/discord_utils/node_modules/macos-notification-state/build/Release/notificationstate.node without build-id.
Stack trace of thread 145:
#0 0x00007fa56a462e14 n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x90e14)
#1 0x00007fa56a410dce n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x3edce)
#2 0x00007fa56a3f883f n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x2683f)
#3 0x00007fa4db5b9263 n/a (/home/ckurdu/.var/app/com.discordapp.Discord/config/discord/0.0.58/modules/discord_utils/discord_utils.node + 0x85263)
ββ Subject: Process 119985 (Discord) dumped core
ββ
ββ Process 119985 (Discord) crashed and dumped core.
ββ
Tem 04 20:38:36 ckurdu-last-denver kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Because the output is too long, I have put the last part that error happened.
Anything else which was open? I recommend to get sure, if this crash is happening even when no additional software is running.
Maybe a fresh reboot and let your system idle.
Maybe use your other computer till you can identify which program lets to this problem.
upwork app
barrier
chrome
visual code
vlc ( this is not common)
smplayer ( this is not common)
Today,
I decided to use this system from SSH.
only Chrome was working when the crash happened and also I was trying to open RustDesk.
I pressed Alt + F2 searched for rustdesk and clicked enter then kde-plasma crashed and restarted without previous apps.
Also, ssh service stopped.
I was able to successfully open RustDesk on the second attempt.
Haz 19 17:31:43 ckurdu-last-denver kernel: ACPI Error: No handler for Region [WST1] ((____ptrval____)) [GenericSerialBus] (20230628/evregion-130)
Haz 19 17:31:43 ckurdu-last-denver kernel: ACPI Error: Region GenericSerialBus (ID=9) has no handler (20230628/exfldio-261)
Haz 19 17:31:43 ckurdu-last-denver kernel: ACPI Error: Aborting method \_SB.PCI0.I2C0.PAS1 due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
Haz 19 17:31:43 ckurdu-last-denver kernel: ACPI Error: Aborting method \_GPE._L20 due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
Haz 19 17:31:43 ckurdu-last-denver kernel: ACPI Error: AE_NOT_EXIST, while evaluating GPE method [_L20] (20230628/evgpe-511)
Haz 19 17:31:44 ckurdu-last-denver kernel:
Tem 05 11:10:14 ckurdu-last-denver sddm-helper[999]: gkr-pam: couldn't unlock the login keyring.
Tem 05 11:10:17 ckurdu-last-denver kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Tem 05 12:09:50 ckurdu-last-denver systemd-coredump[7122]: Process 737 (Xorg) of user 0 dumped core.
Stack trace of thread 737:
#0 0x00007f9a45fe5e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f9a45f8da30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f9a45f754c3 abort (libc.so.6 + 0x244c3)
#3 0x0000563cd508112e OsAbort (Xorg + 0x14b12e)
#4 0x0000563cd50825e7 FatalError (Xorg + 0x14c5e7)
#5 0x0000563cd5089268 n/a (Xorg + 0x153268)
#6 0x00007f9a45f8dae0 n/a (libc.so.6 + 0x3cae0)
#7 0x00007f9a450b0f05 n/a (nvidia_drv.so + 0x4b0f05)
ββ Subject: Process 737 (Xorg) dumped core
ββ
ββ Process 737 (Xorg) crashed and dumped core.
ββ
Tem 05 12:09:50 ckurdu-last-denver xembedsniproxy[7170]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Tem 05 12:09:50 ckurdu-last-denver gmenudbusmenuproxy[7173]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Tem 05 12:09:50 ckurdu-last-denver systemd-coredump[7183]: Process 7173 (gmenudbusmenupr) of user 1000 dumped core.
Stack trace of thread 7173:
#0 0x00007fc8a36a8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fc8a3650a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fc8a36384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007fc8a308c6b7 n/a (libQt6Core.so.6 + 0x8c6b7)
#4 0x00007fc8a308ce5b _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce5b)
#5 0x00007fc8a38daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007fc8a397af38 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17af38)
#7 0x00007fc8a3148d75 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148d75)
#8 0x00007fc8a397afce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17afce)
#9 0x00007fc8a3973bdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173bdd)
#10 0x00005578644a1c6e n/a (gmenudbusmenuproxy + 0x9c6e)
#11 0x00007fc8a3639c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007fc8a3639d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x00005578644a1f45 n/a (gmenudbusmenuproxy + 0x9f45)
Stack trace of thread 7180:
#0 0x00007fc8a371c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fc8a29e28fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fc8a297ff95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fc8a33a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007fc8a314f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007fc8a323a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007fc8a4118dfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007fc8a32c96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007fc8a36a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007fc8a372a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 7173 (gmenudbusmenupr) dumped core
ββ
ββ Process 7173 (gmenudbusmenupr) crashed and dumped core.
ββ
Tem 05 12:09:50 ckurdu-last-denver systemd-coredump[7182]: Process 7170 (xembedsniproxy) of user 1000 dumped core.
Stack trace of thread 7170:
#0 0x00007f1bb3ea8e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007f1bb3e50a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007f1bb3e384c3 abort (libc.so.6 + 0x244c3)
#3 0x00007f1bb388c6b7 n/a (libQt6Core.so.6 + 0x8c6b7)
#4 0x00007f1bb388ce5b _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x8ce5b)
#5 0x00007f1bb40daa45 n/a (libQt6Gui.so.6 + 0xdaa45)
#6 0x00007f1bb417af38 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x17af38)
#7 0x00007f1bb3948d75 _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x148d75)
#8 0x00007f1bb417afce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x17afce)
#9 0x00007f1bb4173bdd _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x173bdd)
#10 0x0000557aaf29524e n/a (xembedsniproxy + 0x624e)
#11 0x00007f1bb3e39c88 n/a (libc.so.6 + 0x25c88)
#12 0x00007f1bb3e39d4c __libc_start_main (libc.so.6 + 0x25d4c)
#13 0x0000557aaf2955b5 n/a (xembedsniproxy + 0x65b5)
Stack trace of thread 7175:
#0 0x00007f1bb3f1c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f1bb32358fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f1bb31d2f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f1bb3ba28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007f1bb394f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007f1bb3a3a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007f1bb4913dfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007f1bb3ac96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007f1bb3ea6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f1bb3f2a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 7170 (xembedsniproxy) dumped core
ββ
ββ Process 7170 (xembedsniproxy) crashed and dumped core.
ββ
Tem 05 12:09:51 ckurdu-last-denver systemd-coredump[7162]: Process 1103 (ksmserver) of user 1000 dumped core.
Stack trace of thread 1103:
#0 0x00007f6f7b691c2b _ZN10QXcbScreen23updateColorSpaceAndEdidEv (libQt6XcbQpa.so.6 + 0x60c2b)
#1 0x00007f6f7b66c763 _ZN14QXcbConnection20createScreen_monitorEP18QXcbVirtualDesktopP24xcb_randr_monitor_info_tj (libQt6XcbQpa.so.6 + 0x3b763)
#2 0x00007f6f7b66d17f _ZN14QXcbConnection28initializeScreensFromMonitorEP21xcb_screen_iterator_tiPP10QXcbScreenb (libQt6XcbQpa.so.6 + 0x3c17f)
#3 0x00007f6f7b66d997 _ZN14QXcbConnection17initializeScreensEb (libQt6XcbQpa.so.6 + 0x3c997)
#4 0x00007f6f7b661c1d _ZN14QXcbConnection14handleXcbEventEP19xcb_generic_event_t (libQt6XcbQpa.so.6 + 0x30c1d)
#5 0x00007f6f7b668962 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6XcbQpa.so.6 + 0x37962)
#6 0x00007f6f7b67fedf n/a (libQt6XcbQpa.so.6 + 0x4eedf)
#7 0x00007f6f807f5a89 n/a (libglib-2.0.so.0 + 0x5ca89)
#8 0x00007f6f808579b7 n/a (libglib-2.0.so.0 + 0xbe9b7)
#9 0x00007f6f807f4f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#10 0x00007f6f815a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#11 0x00007f6f8134f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#12 0x00007f6f8134945d _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x14945d)
#13 0x0000555b08f5235e n/a (ksmserver + 0xb35e)
#14 0x00007f6f81839c88 n/a (libc.so.6 + 0x25c88)
#15 0x00007f6f81839d4c __libc_start_main (libc.so.6 + 0x25d4c)
#16 0x0000555b08f52ce5 n/a (ksmserver + 0xbce5)
Stack trace of thread 1114:
#0 0x00007f6f8191c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007f6f808578fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007f6f807f4f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007f6f815a28dd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3a28dd)
#4 0x00007f6f8134f10e _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x14f10e)
#5 0x00007f6f8143a4e0 _ZN7QThread4execEv (libQt6Core.so.6 + 0x23a4e0)
#6 0x00007f6f8231bdfe n/a (libQt6DBus.so.6 + 0x2ddfe)
#7 0x00007f6f814c96e7 n/a (libQt6Core.so.6 + 0x2c96e7)
#8 0x00007f6f818a6ded n/a (libc.so.6 + 0x92ded)
#9 0x00007f6f8192a0dc n/a (libc.so.6 + 0x1160dc)
ββ Subject: Process 1103 (ksmserver) dumped core
ββ
ββ Process 1103 (ksmserver) crashed and dumped core.
ββ
Tem 05 12:09:51 ckurdu-last-denver wireplumber[1243]: spa.alsa: Card can't get card_name from card_index 1
Tem 05 12:09:51 ckurdu-last-denver wireplumber[1243]: spa.alsa: can't open control for card hw:1: No such file or directory
Tem 05 12:09:51 ckurdu-last-denver wireplumber[1243]: spa.alsa: Card can't get card_name from card_index 0
Tem 05 12:09:51 ckurdu-last-denver wireplumber[1243]: spa.alsa: can't open control for card hw:0: No such file or directory
Tem 05 12:10:08 ckurdu-last-denver kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
I put my computer into sleep mode, and when I opened it in the morning,
none of the programs that were open in the previous session were restored.
For example, previously firefox was running.
The error log is below.
ββ Subject: Process 1094 (kwin_x11) dumped core
ββ
ββ Process 1094 (kwin_x11) crashed and dumped core.
ββ
Tem 08 08:33:47 ckurdu-last-denver kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Tem 08 08:33:58 ckurdu-last-denver systemd-coredump[1039299]: [π‘] Process 1038994 (python3) of user 1000 dumped core.
Stack trace of thread 1038994:
#0 0x00007ff1ea17da2b n/a (libc.so.6 + 0x169a2b)
#1 0x00007ff1e8c1da0e g_str_equal (libglib-2.0.so.0 + 0x47a0e)
#2 0x00007ff1e8c1e773 g_hash_table_lookup (libglib-2.0.so.0 + 0x48773)
#3 0x00007ff1e8c485c1 g_intern_string (libglib-2.0.so.0 + 0x725c1)
#4 0x00007ff1e8b96bc9 g_param_spec_internal (libgobject-2.0.so.0 + 0x1fbc9)
#5 0x00007ff1e8b9736e g_param_spec_string (libgobject-2.0.so.0 + 0x2036e)
#6 0x00007ff1cdf10fbf n/a (librsvg-2.so.2 + 0x310fbf)
#7 0x00007ff1cdc09916 n/a (librsvg-2.so.2 + 0x9916)
#8 0x00007ff1cdc0a0c8 n/a (librsvg-2.so.2 + 0xa0c8)
#9 0x00007ff1cdc23667 n/a (librsvg-2.so.2 + 0x23667)
#10 0x00007ff1e8bb4e4e g_type_class_ref (libgobject-2.0.so.0 + 0x3de4e)
#11 0x00007ff1e8b9bc23 g_object_new_with_properties (libgobject-2.0.so.0 + 0x24c23)
#12 0x00007ff1cdf0febd n/a (librsvg-2.so.2 + 0x30febd)
#13 0x00007ff1cdc2a311 rsvg_handle_new (librsvg-2.so.2 + 0x2a311)
#14 0x00007ff1dfab6245 n/a (libpixbufloader-svg.so + 0x1245)
#15 0x00007ff1e7db6cb5 n/a (libgdk_pixbuf-2.0.so.0 + 0xccb5)
#16 0x00007ff1e7dbb96e gdk_pixbuf_loader_close (libgdk_pixbuf-2.0.so.0 + 0x1196e)
#17 0x00007ff1e7dbc304 n/a (libgdk_pixbuf-2.0.so.0 + 0x12304)
#18 0x00007ff1e7dbc4a2 gdk_pixbuf_new_from_stream (libgdk_pixbuf-2.0.so.0 + 0x124a2)
#19 0x00007ff1e21106c0 n/a (libgtk-3.so.0 + 0x1106c0)
#20 0x00007ff1e211089a n/a (libgtk-3.so.0 + 0x11089a)
#21 0x00007ff1e2111c1f n/a (libgtk-3.so.0 + 0x111c1f)
#22 0x00007ff1e20fdda2 n/a (libgtk-3.so.0 + 0xfdda2)
#23 0x00007ff1e2131971 n/a (libgtk-3.so.0 + 0x131971)
#24 0x00007ff1e211a76b n/a (libgtk-3.so.0 + 0x11a76b)
#25 0x00007ff1e21153ab n/a (libgtk-3.so.0 + 0x1153ab)
#26 0x00007ff1e2115648 n/a (libgtk-3.so.0 + 0x115648)
#27 0x00007ff1e211569b n/a (libgtk-3.so.0 + 0x11569b)
#28 0x00007ff1e211569b n/a (libgtk-3.so.0 + 0x11569b)
#29 0x00007ff1e211569b n/a (libgtk-3.so.0 + 0x11569b)
#30 0x00007ff1e2367db7 n/a (libgtk-3.so.0 + 0x367db7)
#31 0x00007ff1e8b8864a g_closure_invoke (libgobject-2.0.so.0 + 0x1164a)
#32 0x00007ff1e8bb8e22 n/a (libgobject-2.0.so.0 + 0x41e22)
#33 0x00007ff1e8ba95dc n/a (libgobject-2.0.so.0 + 0x325dc)
#34 0x00007ff1e8ba9842 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32842)
#35 0x00007ff1e8ba9904 g_signal_emit (libgobject-2.0.so.0 + 0x32904)
#36 0x00007ff1e2346963 gtk_widget_show (libgtk-3.so.0 + 0x346963)
#37 0x00007ff1e8b73596 n/a (libffi.so.8 + 0x7596)
#38 0x00007ff1e8b7000e n/a (libffi.so.8 + 0x400e)
#39 0x00007ff1e8b72bd3 ffi_call (libffi.so.8 + 0x6bd3)
#40 0x00007ff1e8d4e091 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x2a091)
#41 0x00007ff1e8d4c680 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x28680)
#42 0x00007ff1e8d3e256 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x1a256)
#43 0x00007ff1ea380abb _PyObject_MakeTpCall (libpython3.12.so.1.0 + 0x180abb)
#44 0x00007ff1ea38931f _PyEval_EvalFrameDefault (libpython3.12.so.1.0 + 0x18931f)
#45 0x00007ff1ea383846 _PyObject_FastCallDictTstate (libpython3.12.so.1.0 + 0x183846)
#46 0x00007ff1ea3bfaf7 n/a (libpython3.12.so.1.0 + 0x1bfaf7)
#47 0x00007ff1ea380a68 _PyObject_MakeTpCall (libpython3.12.so.1.0 + 0x180a68)
#48 0x00007ff1ea38931f _PyEval_EvalFrameDefault (libpython3.12.so.1.0 + 0x18931f)
#49 0x00007ff1ea44d0f5 PyEval_EvalCode (libpython3.12.so.1.0 + 0x24d0f5)
#50 0x00007ff1ea4703ea n/a (libpython3.12.so.1.0 + 0x2703ea)
#51 0x00007ff1ea46b2ef n/a (libpython3.12.so.1.0 + 0x26b2ef)
#52 0x00007ff1ea485924 n/a (libpython3.12.so.1.0 + 0x285924)
#53 0x00007ff1ea484c51 _PyRun_SimpleFileObject (libpython3.12.so.1.0 + 0x284c51)
ββ
ββ
#54 0x00007ff1ea48480f _PyRun_AnyFileObject (libpython3.12.so.1.0 + 0x28480f)
#55 0x00007ff1ea47d034 Py_RunMain (libpython3.12.so.1.0 + 0x27d034)
#56 0x00007ff1ea43860c Py_BytesMain (libpython3.12.so.1.0 + 0x23860c)
#57 0x00007ff1ea039c88 n/a (libc.so.6 + 0x25c88)
#58 0x00007ff1ea039d4c __libc_start_main (libc.so.6 + 0x25d4c)
#59 0x00005576fdfb6045 _start (python3.12 + 0x1045)
Stack trace of thread 1039126:
#0 0x00007ff1ea127e9d syscall (libc.so.6 + 0x113e9d)
#1 0x00007ff1e8c8d9e0 g_cond_wait (libglib-2.0.so.0 + 0xb79e0)
#2 0x00007ff1e8bfb8dc n/a (libglib-2.0.so.0 + 0x258dc)
#3 0x00007ff1e8bfb94d g_async_queue_pop (libglib-2.0.so.0 + 0x2594d)
#4 0x00007ff1e78b45fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007ff1e8c62236 n/a (libglib-2.0.so.0 + 0x8c236)
#6 0x00007ff1ea0a6ded n/a (libc.so.6 + 0x92ded)
#7 0x00007ff1ea12a0dc n/a (libc.so.6 + 0x1160dc)
Stack trace of thread 1039081:
#0 0x00007ff1ea11c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007ff1e8c948fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007ff1e8c33787 g_main_loop_run (libglib-2.0.so.0 + 0x5d787)
#3 0x00007ff1e8061494 n/a (libgio-2.0.so.0 + 0x112494)
#4 0x00007ff1e8c62236 n/a (libglib-2.0.so.0 + 0x8c236)
#5 0x00007ff1ea0a6ded n/a (libc.so.6 + 0x92ded)
#6 0x00007ff1ea12a0dc n/a (libc.so.6 + 0x1160dc)
Stack trace of thread 1039079:
#3 0x00007ff1e8c67687 n/a (libglib-2.0.so.0 + 0x91687)
Stack trace of thread 1039223:
#1 0x00007ff1e8c8e337 g_cond_wait_until (libglib-2.0.so.0 + 0xb8337)
#2 0x00007ff1e8bfb8a5 n/a (libglib-2.0.so.0 + 0x258a5)
#3 0x00007ff1e8bfba18 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x25a18)
#4 0x00007ff1e8c68080 n/a (libglib-2.0.so.0 + 0x92080)
Stack trace of thread 1039080:
#2 0x00007ff1e8c31f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007ff1e8c31fea n/a (libglib-2.0.so.0 + 0x5bfea)
ββ Subject: Process 1038994 (python3) dumped core
ββ
ββ Process 1038994 (python3) crashed and dumped core.
ββ
I think problem is not related to normal programs.
Display card or kde-plasma error not sure.
The same thing happened again.
I put my Manjaro system into sleep mode, and when I tried to power up my computer in the morning, it initially opened my windows correctly but then crashed and auto-logged into KDE Plasma without the previous windows.
Tem 09 10:00:55 ckurdu-last-denver pipewire[1039028]: spa.alsa: 'hdmi:1': playback open failed: No such file or directory
Tem 09 10:00:55 ckurdu-last-denver pipewire[1039028]: mod.adapter: usage: node.name=<string>
Tem 09 10:01:29 ckurdu-last-denver pipewire[1039028]: spa.alsa: 'hdmi:1': playback open failed: No such file or directory
Tem 09 10:01:29 ckurdu-last-denver pipewire[1039028]: mod.adapter: usage: node.name=<string>
Tem 09 10:01:30 ckurdu-last-denver systemd-coredump[1143757]: Process 1026225 (Xorg) of user 0 dumped core.
Stack trace of thread 1026225:
#0 0x00007fcf15f60e44 n/a (libc.so.6 + 0x94e44)
#1 0x00007fcf15f08a30 raise (libc.so.6 + 0x3ca30)
#2 0x00007fcf15ef04c3 abort (libc.so.6 + 0x244c3)
#3 0x0000560e9200812e OsAbort (Xorg + 0x14b12e)
#4 0x0000560e920095e7 FatalError (Xorg + 0x14c5e7)
#5 0x0000560e92010268 n/a (Xorg + 0x153268)
#6 0x00007fcf15f08ae0 n/a (libc.so.6 + 0x3cae0)
#7 0x00007fcf150b0f05 n/a (nvidia_drv.so + 0x4b0f05)
ββ Subject: Process 1026225 (Xorg) dumped core
ββ
ββ Process 1026225 (Xorg) crashed and dumped core.
ββ
Tem 09 10:02:13 ckurdu-last-denver kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
Tem 09 10:05:31 ckurdu-last-denver systemd-coredump[1145415]: Process 1144132 (python3) of user 1000 dumped core.
Stack trace of thread 1144132:
#0 0x00007fa7e557da2b n/a (libc.so.6 + 0x169a2b)
#1 0x00007fa7e3f64a0e g_str_equal (libglib-2.0.so.0 + 0x47a0e)
#2 0x00007fa7e3f65773 g_hash_table_lookup (libglib-2.0.so.0 + 0x48773)
#3 0x00007fa7e3f8f5c1 g_intern_string (libglib-2.0.so.0 + 0x725c1)
#4 0x00007fa7e3eddbc9 g_param_spec_internal (libgobject-2.0.so.0 + 0x1fbc9)
#5 0x00007fa7e3ede36e g_param_spec_string (libgobject-2.0.so.0 + 0x2036e)
#6 0x00007fa7cab10fbf n/a (librsvg-2.so.2 + 0x310fbf)
#7 0x00007fa7ca809916 n/a (librsvg-2.so.2 + 0x9916)
#8 0x00007fa7ca80a0c8 n/a (librsvg-2.so.2 + 0xa0c8)
#9 0x00007fa7ca823667 n/a (librsvg-2.so.2 + 0x23667)
#10 0x00007fa7e3efbe4e g_type_class_ref (libgobject-2.0.so.0 + 0x3de4e)
#11 0x00007fa7e3ee2c23 g_object_new_with_properties (libgobject-2.0.so.0 + 0x24c23)
#12 0x00007fa7cab0febd n/a (librsvg-2.so.2 + 0x30febd)
#13 0x00007fa7ca82a311 rsvg_handle_new (librsvg-2.so.2 + 0x2a311)
#14 0x00007fa7d8b82245 n/a (libpixbufloader-svg.so + 0x1245)
#15 0x00007fa7e310fcb5 n/a (libgdk_pixbuf-2.0.so.0 + 0xccb5)
#16 0x00007fa7e311496e gdk_pixbuf_loader_close (libgdk_pixbuf-2.0.so.0 + 0x1196e)
#17 0x00007fa7e3115304 n/a (libgdk_pixbuf-2.0.so.0 + 0x12304)
#18 0x00007fa7e31154a2 gdk_pixbuf_new_from_stream (libgdk_pixbuf-2.0.so.0 + 0x124a2)
#19 0x00007fa7dd5106c0 n/a (libgtk-3.so.0 + 0x1106c0)
#20 0x00007fa7dd51089a n/a (libgtk-3.so.0 + 0x11089a)
#21 0x00007fa7dd511c1f n/a (libgtk-3.so.0 + 0x111c1f)
#22 0x00007fa7dd4fdda2 n/a (libgtk-3.so.0 + 0xfdda2)
#23 0x00007fa7dd531971 n/a (libgtk-3.so.0 + 0x131971)
#24 0x00007fa7dd51a76b n/a (libgtk-3.so.0 + 0x11a76b)
#25 0x00007fa7dd5153ab n/a (libgtk-3.so.0 + 0x1153ab)
#26 0x00007fa7dd515648 n/a (libgtk-3.so.0 + 0x115648)
#27 0x00007fa7dd51569b n/a (libgtk-3.so.0 + 0x11569b)
#28 0x00007fa7dd51569b n/a (libgtk-3.so.0 + 0x11569b)
#29 0x00007fa7dd51569b n/a (libgtk-3.so.0 + 0x11569b)
#30 0x00007fa7dd767db7 n/a (libgtk-3.so.0 + 0x367db7)
#31 0x00007fa7e3ecf64a g_closure_invoke (libgobject-2.0.so.0 + 0x1164a)
#32 0x00007fa7e3effe22 n/a (libgobject-2.0.so.0 + 0x41e22)
#33 0x00007fa7e3ef05dc n/a (libgobject-2.0.so.0 + 0x325dc)
#34 0x00007fa7e3ef0842 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32842)
#35 0x00007fa7e3ef0904 g_signal_emit (libgobject-2.0.so.0 + 0x32904)
#36 0x00007fa7dd746963 gtk_widget_show (libgtk-3.so.0 + 0x346963)
#37 0x00007fa7e48e0596 n/a (libffi.so.8 + 0x7596)
#38 0x00007fa7e48dd00e n/a (libffi.so.8 + 0x400e)
#39 0x00007fa7e48dfbd3 ffi_call (libffi.so.8 + 0x6bd3)
#40 0x00007fa7e4095091 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x2a091)
#41 0x00007fa7e4093680 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x28680)
#42 0x00007fa7e4085256 n/a (_gi.cpython-312-x86_64-linux-gnu.so + 0x1a256)
#43 0x00007fa7e5780abb _PyObject_MakeTpCall (libpython3.12.so.1.0 + 0x180abb)
#44 0x00007fa7e578931f _PyEval_EvalFrameDefault (libpython3.12.so.1.0 + 0x18931f)
#45 0x00007fa7e5783846 _PyObject_FastCallDictTstate (libpython3.12.so.1.0 + 0x183846)
#46 0x00007fa7e57bfaf7 n/a (libpython3.12.so.1.0 + 0x1bfaf7)
#47 0x00007fa7e5780a68 _PyObject_MakeTpCall (libpython3.12.so.1.0 + 0x180a68)
#48 0x00007fa7e578931f _PyEval_EvalFrameDefault (libpython3.12.so.1.0 + 0x18931f)
#49 0x00007fa7e584d0f5 PyEval_EvalCode (libpython3.12.so.1.0 + 0x24d0f5)
#50 0x00007fa7e58703ea n/a (libpython3.12.so.1.0 + 0x2703ea)
#51 0x00007fa7e586b2ef n/a (libpython3.12.so.1.0 + 0x26b2ef)
#52 0x00007fa7e5885924 n/a (libpython3.12.so.1.0 + 0x285924)
#53 0x00007fa7e5884c51 _PyRun_SimpleFileObject (libpython3.12.so.1.0 + 0x284c51)
#54 0x00007fa7e588480f _PyRun_AnyFileObject (libpython3.12.so.1.0 + 0x28480f)
#55 0x00007fa7e587d034 Py_RunMain (libpython3.12.so.1.0 + 0x27d034)
#56 0x00007fa7e583860c Py_BytesMain (libpython3.12.so.1.0 + 0x23860c)
#57 0x00007fa7e5439c88 n/a (libc.so.6 + 0x25c88)
#58 0x00007fa7e5439d4c __libc_start_main (libc.so.6 + 0x25d4c)
#59 0x000055f3b54f9045 _start (python3.12 + 0x1045)
Stack trace of thread 1144197:
#0 0x00007fa7e551c39d __poll (libc.so.6 + 0x10839d)
#1 0x00007fa7e3fdb8fd n/a (libglib-2.0.so.0 + 0xbe8fd)
#2 0x00007fa7e3f7a787 g_main_loop_run (libglib-2.0.so.0 + 0x5d787)
#3 0x00007fa7e33ba494 n/a (libgio-2.0.so.0 + 0x112494)
#4 0x00007fa7e3fa9236 n/a (libglib-2.0.so.0 + 0x8c236)
#5 0x00007fa7e54a6ded n/a (libc.so.6 + 0x92ded)
#6 0x00007fa7e552a0dc n/a (libc.so.6 + 0x1160dc)
Stack trace of thread 1144247:
#0 0x00007fa7e5527e9d syscall (libc.so.6 + 0x113e9d)
#1 0x00007fa7e3fd49e0 g_cond_wait (libglib-2.0.so.0 + 0xb79e0)
#2 0x00007fa7e3f428dc n/a (libglib-2.0.so.0 + 0x258dc)
#3 0x00007fa7e3f4294d g_async_queue_pop (libglib-2.0.so.0 + 0x2594d)
#4 0x00007fa7e2c0d5fc n/a (libpangoft2-1.0.so.0 + 0xc5fc)
#5 0x00007fa7e3fa9236 n/a (libglib-2.0.so.0 + 0x8c236)
#6 0x00007fa7e54a6ded n/a (libc.so.6 + 0x92ded)
#7 0x00007fa7e552a0dc n/a (libc.so.6 + 0x1160dc)
Stack trace of thread 1144195:
#3 0x00007fa7e3fae687 n/a (libglib-2.0.so.0 + 0x91687)
Stack trace of thread 1145402:
#1 0x00007fa7e3fd5337 g_cond_wait_until (libglib-2.0.so.0 + 0xb8337)
#2 0x00007fa7e3f428a5 n/a (libglib-2.0.so.0 + 0x258a5)
#3 0x00007fa7e3f42a18 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x25a18)
#4 0x00007fa7e3faf080 n/a (libglib-2.0.so.0 + 0x92080)
Stack trace of thread 1144196:
#2 0x00007fa7e3f78f95 g_main_context_iteration (libglib-2.0.so.0 + 0x5bf95)
#3 0x00007fa7e3f78fea n/a (libglib-2.0.so.0 + 0x5bfea)
ββ Subject: Process 1144132 (python3) dumped core
ββ
ββ Process 1144132 (python3) crashed and dumped core.
ββ
Tem 09 10:06:28 ckurdu-last-denver pipewire[1039028]: spa.alsa: 'hdmi:1': playback open failed: No such file or directory
Tem 09 10:06:28 ckurdu-last-denver pipewire[1039028]: mod.adapter: usage: node.name=<string>
Tem 09 10:06:32 ckurdu-last-denver kscreenlocker_greet[1145512]: Failed to initialize graphics backend for OpenGL.
Tem 09 10:44:11 ckurdu-last-denver pipewire[1039028]: spa.alsa: 'hdmi:1': playback open failed: No such file or directory
Tem 09 10:44:11 ckurdu-last-denver pipewire[1039028]: mod.adapter: usage: node.name=<string>
Tem 09 10:44:15 ckurdu-last-denver kscreenlocker_greet[1149511]: Failed to initialize graphics backend for OpenGL.
I tested my system three times after the latest crash. I put the computer in sleep mode and then powered it up again. However, the error didnβt occur.
I think this problem is not related to vscode
or chrome
and just because we are using them frequently we think this problem is caused by them.
Also I doubt if this problem comes from plasma itself. We are just sure that this problem is because of recent big update which migrate plasma
from version 5 to 6.
Also I never use chorme
or chromium
! I always use firefox
. So Iβm sure this problem is not related to chrome
at all.
@ckurdu @alok
If there was any update, please share it here. Maybe we would be able to figure it out.
I tried your command too:
journalctl --user -o cat --since "7 days ago" | grep "The X11"
And I got similar output. I think to narrow down the problem, we should make sure these errors happens right before crashing. So please next time your system crashed, look at clock and prints these errors along their timestamp by following command:
journalctl --user -o short-iso --since "7 days ago" | grep "The X11"
Then try to find out if they occurred right before crashing or not.
Iβm going to do following steps, you can accompany me if you like:
- There is a new stable update, There is no bug fix and I donβt hope to fix this problem but we can give it a try.
- Back in time,
plasma
had problem with notifications and upon notifications it was crashing. Iβm going to disable notifications to see if that is because of this old notification bug or not.
Next time, Iβll try to put my system into sleep and see what happens but I think there are two distinct problems in your system. They are not related to each other. Iβll inform you accordingly.
Thanks @vilmil
It happened again. I didnβt open any program except chrome. It is not related the chrome because same thing happened with firefox also before.
The last error happened before the crash.
output
2024-07-04T16:08:20+03:00 ckurdu-last-denver qtcreator[128830]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver dolphin[154832]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver konsole[157706]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kwalletmanager5[9027]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kded6[1129]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver kwin_x11[1130]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1184]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver pamac-tray-plasma[1357]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver konsole[138357]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kwalletd6[9003]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kaccess[1355]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver gmenudbusmenuproxy[1181]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver vlc[171636]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1182]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver plasmashell[1146]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver kactivitymanagerd[1180]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kglobalacceld[1082]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kdeconnectd[1332]: 2024-07-04T20:38:17 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver xembedsniproxy[1185]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver dolphin[120745]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kscreen_backend_launcher[1296]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver org_kde_powerdevil[1183]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver kglobalacceld[1082]: The X11 connection broke: I/O error (code 1)
2024-07-04T20:38:17+03:00 ckurdu-last-denver barrier[10146]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver msm_kde_notifier[1331]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-04T20:38:17+03:00 ckurdu-last-denver dolphin[119587]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kwalletmanager5[205096]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver konsole[438454]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kate[201761]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver konsole[194153]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kate[193032]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kwalletd6[188242]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver gmenudbusmenuproxy[188370]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver xdg-desktop-portal-kde[188373]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver pamac-tray-plasma[188540]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kded6[188313]: The X11 connection broke: I/O error (code 1)
2024-07-05T09:46:37+03:00 ckurdu-last-denver dolphin[257428]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[188371]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver msm_kde_notifier[188514]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kactivitymanagerd[188369]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver konsole[255887]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver plasmashell[188331]: The X11 connection broke: I/O error (code 1)
2024-07-05T09:46:37+03:00 ckurdu-last-denver kglobalacceld[188271]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kscreen_backend_launcher[188405]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver konsole[270341]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kdeconnectd[188520]: 2024-07-05T09:46:37 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver org_kde_powerdevil[188372]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kate[190518]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver xembedsniproxy[188374]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kaccess[188537]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T09:46:37+03:00 ckurdu-last-denver kglobalacceld[188271]: The X11 connection broke: I/O error (code 1)
2024-07-05T12:09:50+03:00 ckurdu-last-denver kscreen_backend_launcher[1322]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver pamac-tray-plasma[1316]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1144]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver kded6[1105]: The X11 connection broke: I/O error (code 1)
2024-07-05T12:09:50+03:00 ckurdu-last-denver org_kde_powerdevil[1143]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver kdeconnectd[1292]: 2024-07-05T12:09:50 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver plasmashell[1122]: The X11 connection broke: I/O error (code 1)
2024-07-05T12:09:50+03:00 ckurdu-last-denver kwin_x11[1106]: The X11 connection broke: I/O error (code 1)
2024-07-05T12:09:50+03:00 ckurdu-last-denver kaccess[1315]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver kglobalacceld[1050]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver xembedsniproxy[1145]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver msm_kde_notifier[1291]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1142]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver gmenudbusmenuproxy[1141]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-05T12:09:50+03:00 ckurdu-last-denver kglobalacceld[1050]: The X11 connection broke: I/O error (code 1)
2024-07-05T12:09:50+03:00 ckurdu-last-denver krunner[1506]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver nvim-qt[557752]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kglobalacceld[1037]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1137]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1139]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kded6[1093]: The X11 connection broke: I/O error (code 1)
2024-07-07T16:58:52+03:00 ckurdu-last-denver ksmserver[1091]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver org_kde_powerdevil[1138]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver msm_kde_notifier[1255]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver pamac-tray-plasma[1281]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver gmenudbusmenuproxy[1136]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kscreen_backend_launcher[1289]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kactivitymanagerd[1127]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver plasmashell[1108]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver xembedsniproxy[1141]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver konsole[2638]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kdeconnectd[1258]: 2024-07-07T16:58:52 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kglobalacceld[1037]: The X11 connection broke: I/O error (code 1)
2024-07-07T16:58:52+03:00 ckurdu-last-denver kaccess[1274]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-07T16:58:52+03:00 ckurdu-last-denver kscreenlocker_greet[1026008]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver konsole[1041322]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kwalletd6[1038759]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kwin_x11[1038831]: The X11 connection broke: I/O error (code 1)
2024-07-09T10:01:30+03:00 ckurdu-last-denver kded6[1038830]: The X11 connection broke: I/O error (code 1)
2024-07-09T10:01:30+03:00 ckurdu-last-denver xembedsniproxy[1038889]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kscreen_backend_launcher[1038921]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kdeconnectd[1038996]: 2024-07-09T10:01:30 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kaccess[1039017]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver gmenudbusmenuproxy[1038885]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kactivitymanagerd[1038884]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1038888]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver ksmserver[1038828]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver msm_kde_notifier[1038995]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1038886]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver org_kde_powerdevil[1038887]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver pamac-tray-plasma[1039022]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kglobalacceld[1038788]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T10:01:30+03:00 ckurdu-last-denver kglobalacceld[1038788]: The X11 connection broke: I/O error (code 1)
2024-07-09T10:01:30+03:00 ckurdu-last-denver plasmashell[1038860]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kate[1154467]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver konsole[1152912]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver pamac-tray-plasma[1144160]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kaccess[1144156]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kdeconnectd[1144138]: 2024-07-09T22:04:18 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver msm_kde_notifier[1144135]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1144031]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1144033]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kded6[1143974]: The X11 connection broke: I/O error (code 1)
2024-07-09T22:04:18+03:00 ckurdu-last-denver kwalletd6[1143906]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver ksmserver[1143972]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver gmenudbusmenuproxy[1144030]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver krunner[1152863]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver org_kde_powerdevil[1144032]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kscreen_backend_launcher[1144170]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kglobalacceld[1143934]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kwin_x11[1157911]: The X11 connection broke: I/O error (code 1)
2024-07-09T22:04:18+03:00 ckurdu-last-denver xembedsniproxy[1144034]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kactivitymanagerd[1144029]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kglobalacceld[1143934]: The X11 connection broke: I/O error (code 1)
2024-07-09T22:04:18+03:00 ckurdu-last-denver plasmashell[1144005]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-09T22:04:18+03:00 ckurdu-last-denver kscreenlocker_greet[1244403]: The X11 connection broke: I/O error (code 1)
2024-07-10T14:34:15+03:00 ckurdu-last-denver kaccess[1247832]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kdeconnectd[1247818]: 2024-07-10T14:34:15 default: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver xdg-desktop-portal-kde[1247688]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver pamac-tray-plasma[1247837]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver org_kde_powerdevil[1247687]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kwalletd6[1247560]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver ksmserver[1247628]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kscreen_backend_launcher[1247734]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kded6[1247630]: The X11 connection broke: I/O error (code 1)
2024-07-10T14:34:15+03:00 ckurdu-last-denver msm_kde_notifier[1247817]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kglobalacceld[1247589]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver plasmashell[1247654]: The X11 connection broke: I/O error (code 1)
2024-07-10T14:34:15+03:00 ckurdu-last-denver xembedsniproxy[1247689]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kactivitymanagerd[1247684]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver polkit-kde-authentication-agent-1[1247686]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver gmenudbusmenuproxy[1247685]: The X11 connection broke (error 1). Did the X11 server die?
2024-07-10T14:34:15+03:00 ckurdu-last-denver kglobalacceld[1247589]: The X11 connection broke: I/O error (code 1)
2024-07-10T14:34:15+03:00 ckurdu-last-denver kscreenlocker_greet[1249050]: The X11 connection broke: I/O error (code 1)
I have some updates:
- Updating system didnβt fix the problem.
- Disabling notification didnβt fix the problem.
- I think these error messages
andThe X11 connection broke: I/O error (code 1)
are not cause of crash because it didnβt occurred during my last boot which resulted in crash. Another possibility is that plasma even donβt get opportunity to print logs but I prefer to think this is not the case
Thanks for the update @vilmil
Now, I am trying the wayland.
If the problem does not happen again, we can say the error x11 is related.
You was still using vs code or chrome when a crash occurred under X11 or not?
Since both progβs donβt work under Wayland is hard to tell whats going on
