Thanks for the reponse.
Here’s the output of inxi -Fxxxza --no-host
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=4b53c2f9-8744-464d-8b92-52abac74eb7c ro quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B550 GAMING X V2 v: x.x
serial: <filter> UEFI: American Megatrends v: F11 date: 12/31/2020
Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 21 (33) stepping: N/A
microcode: A201009 L2 cache: 3 MiB
bogomips: 88679
Speed: 2350 MHz min/max: 2200/3700 MHz boost: enabled
Core speeds (MHz): 1: 2350 2: 2479 3: 2810 4: 2503 5: 2241 6: 2422
7: 2852 8: 2284 9: 2695 10: 2273 11: 2372 12: 2358
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 09:00.0 chip ID: 10de:2484
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 09:00.1
chip ID: 10de:228b
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 0b:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.10.7-3-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus ID: 08:00.0
chip ID: 10ec:8168
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.33 TiB used: 23.53 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S5Z42105 temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM005-2CW102
size: 1.82 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0001
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 57.28 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.00
ID-1: / raw size: 875 GiB size: 860.27 GiB (98.32%)
used: 23.53 GiB (2.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 37.4 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 267 Uptime: 29m wakeups: 0 Memory: 15.64 GiB
used: 3.01 GiB (19.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1277 lib: 397 flatpak: 0 Shell: Zsh v: 5.8
running in: konsole inxi: 3.2.02
Output of lspci -v
`00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 25
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 0
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=08, sec-latency=0
I/O behind bridge: 0000f000-0000ffff [size=4K]
Memory behind bridge: fc500000-fc7fffff [size=3M]
Prefetchable memory behind bridge: [disabled]
Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 2
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 3
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 4
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: fb000000-fc0fffff [size=17M]
Prefetchable memory behind bridge: 00000000d0000000-00000000e1ffffff [size=288M]
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 5
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 6
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 7
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 8
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 9
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 10
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: fc200000-fc4fffff [size=3M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Gigabyte Technology Co., Ltd Device 5001
Flags: 66MHz, medium devsel, IOMMU group 11
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 11
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
Flags: fast devsel, IOMMU group 12
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43ee (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. Device 1142
Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 13
Memory at fc7a0000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43eb (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device 1062
Flags: bus master, fast devsel, latency 0, IRQ 43, IOMMU group 13
Memory at fc780000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at fc700000 [disabled] [size=512K]
Kernel driver in use: ahci
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43e9 (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 13
Bus: primary=01, secondary=02, subordinate=08, sec-latency=0
Memory behind bridge: fc500000-fc6fffff [size=2M]
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 13
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
02:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 13
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
02:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 13
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 13
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: fc600000-fc6fffff [size=1M]
02:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 13
Bus: primary=02, secondary=07, subordinate=07, sec-latency=0
02:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 13
Bus: primary=02, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: fc500000-fc5fffff [size=1M]
06:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 2263 (rev 03) (prog-if 02 [NVM Express])
Subsystem: Kingston Technology Company, Inc. Device 2263
Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 13
Memory at fc600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 13
I/O ports at f000 [size=256]
Memory at fc504000 (64-bit, non-prefetchable) [size=4K]
Memory at fc500000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
09:00.0 VGA compatible controller: NVIDIA Corporation Device 2484 (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 146b
Flags: bus master, fast devsel, latency 0, IRQ 84, IOMMU group 14
Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at e0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
09:00.1 Audio device: NVIDIA Corporation Device 228b (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 80, IOMMU group 14
Memory at fc080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel, IOMMU group 15
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel, IOMMU group 16
0b:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Flags: bus master, fast devsel, latency 0, IRQ 76, IOMMU group 17
Memory at fc300000 (32-bit, non-prefetchable) [size=1M]
Memory at fc408000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
0b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device 5007
Flags: bus master, fast devsel, latency 0, IRQ 67, IOMMU group 18
Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
0b:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
DeviceName: Realtek ALC1220
Subsystem: Gigabyte Technology Co., Ltd Device a184
Flags: bus master, fast devsel, latency 0, IRQ 82, IOMMU group 19
Memory at fc400000 (32-bit, non-prefetchable) [size=32K]
The output of mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
