The audio will continue to play and the mouse and keyboard becomes completely unresponsive. Sometimes the cursor turns into a loading wheel and I can move it around. After I downgraded my kernel and made a swapfile to try to fix it it seems to have been occuring less, it usually occurs 1-2 hours after booting. I’m new to Linux and manjaro was installed a few days ago.
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=908e90fc-6162-419f-abf1-269748546baf rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H81M-E v: Rev X.0x serial: <filter>
BIOS: American Megatrends v: 0301 date: 07/18/2013
RAM: total: 7.71 GiB used: 1.27 GiB (16.5%)
Info: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB
bogomips: 11977
Speed: 798 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 798 2: 851
Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fc6 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-1 res: 2560x1440 hz: 60 dpi: 118
size: 553x311mm (21.8x12.2") diag: 634mm (25")
OpenGL: renderer: NVE7 v: 4.3 Mesa 21.2.1 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Dell AC511 Sound Bar type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-10:7 chip-ID: 413c:a503
class-ID: 0300
Device-4: C-Media Sharkoon SKILLER SGH30 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3 chip-ID: 0d8c:0012
class-ID: 0300
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
vendor: ASUSTeK H81M-C driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
bus-ID: 3-1.2:6 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
IF: wlp0s20u1u2 state: up mac: <filter>
Local Storage: total: 704.24 GiB used: 19.83 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6B0Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKS-65YGA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1C02
scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 19.83 GiB (8.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 908e90fc-6162-419f-abf1-269748546baf
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ntfs label: N/A
uuid: 7C963BD9963B929E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Hub-6: 3-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Device-1: 3-1.1:4 info: Cooler Master CK530 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 2516:009f class-ID: 0300
Device-2: 3-1.2:6 info: Qualcomm Atheros AR9271 802.11n type: Network
driver: ath9k_htc interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-7: 3-1.4:8 info: Texas Instruments TUSB8041 4-Port Hub ports: 2 rev: 2.1
Device-1: 3-3:3 info: C-Media Sharkoon SKILLER SGH30 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0012 class-ID: 0300
Device-2: 3-9:5 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Device-3: 3-10:7 info: Dell AC511 Sound Bar type: Audio,HID
speed: 12 Mb/s power: 200mA chip-ID: 413c:a503 class-ID: 0300
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-9: 4-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-10: 4-1.4:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 2
rev: 3.0 speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 68.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Processes: 162 Uptime: 11m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1079 lib: 304 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
What should I do?
