Hi everyone. I’ve recently made a new fresh installation of Manjaro (de: gnome), but it is complitely freezing randomly, without doing anything particular.
Every times it happen I have to shut down pc using the power button.
I had the same problem also with my previous installation (with kde) so it doesn’t seam to depend from DE or errors during installation.
Here is the register of last crash:
Register
21:52:17 touchegg: Reconnecting in 5 seconds...
21:52:13 cat: Fontconfig error: Cannot load default config file: No such file: (null)
21:52:12 touchegg: Reconnecting in 5 seconds...
21:51:40 systemd-timesyn: Contacted time server 93.94.88.51:123 (0.manjaro.pool.ntp.org).
21:51:37 touchegg: Reconnecting in 5 seconds...
21:51:04 python3: 2023-03-21 21:51:04,690: Startup complete
21:51:02 touchegg: Reconnecting in 5 seconds...
21:51:01 python3: 2023-03-21 21:51:01,028: Extracting /home/andreas/.local/share/lutris/runtime/d3d_extras/v2.tar.xz to /home/andreas/.local/share/lutris/runtime/d3d_extras/v2
21:50:57 touchegg: Reconnecting in 5 seconds...
21:50:56 python3: 2023-03-21 21:50:56,699: Extracting /home/andreas/.local/share/lutris/runtime/dxvk/dxvk-2.1.tar.xz to /home/andreas/.local/share/lutris/runtime/dxvk/v2.1
21:50:53 cat: [7369:7369:0321/215053.559582:ERROR:object_proxy.cc(622)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented
21:50:52 python3: 2023-03-21 21:50:52,672: Non existent path: /home/andreas/.local/share/lutris/runtime/Ubuntu-18.04-x86_64
21:50:52 cat: [7456:7456:0321/215052.283180:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
21:50:52 touchegg: Reconnecting in 5 seconds...
21:50:52 cat: [7409:7409:0321/215052.036778:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
21:50:52 gnome-keyring-d: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
21:50:51 systemd: Started Application launched by gnome-shell.
21:50:51 python3: 2023-03-21 21:50:51,465: Non existent path: /home/andreas/.local/share/lutris/runtime/Ubuntu-18.04-i686
21:50:47 touchegg: Reconnecting in 5 seconds...
21:50:42 python3: 2023-03-21 21:50:42,975: Vulkan is not available or your system isn't Vulkan capable
21:50:42 touchegg: Reconnecting in 5 seconds...
21:50:38 systemd: Started Application launched by gnome-shell.
21:50:37 kernel: audit: type=1334 audit(1679431837.445:227): prog-id=61 op=UNLOAD
21:50:37 kernel: BPF prog-id=61 op=UNLOAD
21:50:37 kernel: audit: type=1131 audit(1679431837.419:224): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:37 kernel: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:37 systemd: systemd-timedated.service: Deactivated successfully.
21:50:37 touchegg: Reconnecting in 5 seconds...
21:50:26 systemd: app-gnome-manjaro\x2dsettings\x2dmanager-7259.scope: Consumed 2.058s CPU time.
21:50:25 manjaro-setting: Shutting down Manjaro Settings Manager...
21:50:22 touchegg: Reconnecting in 5 seconds...
21:50:15 kernel: audit: type=1334 audit(1679431815.081:223): prog-id=60 op=UNLOAD
21:50:15 kernel: BPF prog-id=60 op=UNLOAD
21:50:15 kernel: audit: type=1131 audit(1679431815.054:222): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:15 kernel: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:15 systemd: fprintd.service: Deactivated successfully.
21:50:12 touchegg: Reconnecting in 5 seconds...
21:50:11 gnome-character: JS LOG: Characters Application exiting
21:50:07 kernel: audit: type=1130 audit(1679431807.360:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:07 kernel: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
21:50:07 systemd: Started Time & Date Service.
21:50:07 dbus-daemon: [system] Successfully activated service 'org.freedesktop.timedate1'
21:50:07 systemd: Starting Time & Date Service...
21:50:07 kernel: audit: type=1334 audit(1679431807.273:220): prog-id=63 op=LOAD
21:50:07 kernel: BPF prog-id=63 op=LOAD
21:50:07 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.193' (uid=1000 pid=7259 comm="manjaro-settings-manager")
21:50:07 touchegg: Reconnecting in 5 seconds...
21:50:05 systemd: app-gnome-org.gnome.Settings-6316.scope: Consumed 8.388s CPU time.
21:50:04 manjaro-setting: Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
21:50:03 systemd: Started Application launched by gnome-shell.
21:50:02 touchegg: Reconnecting in 5 seconds...
Can someone help me?
Thank you.
