Hi, my computer runs manjaro kde for a couple years now and since a few days the entire system freezes shortly after booting up. i then tried to do a clean install from a live usb stick (up to date manjaro gnome) which had the same issue so i assume it has to do something with the kernel version, since that seems to be the cause for other people having similar problems. sadly i cant post any logfiles or anything because i only ever have about a minute until it freezes, giving me also no time to try any fixes like downgrading the kernel. im now posting this from a fedora live stick but dont really know how to proceed from here…
“Several days”? Any updates happend?
Would be helpful so see some informations about the hardware you’re using, because in case of freezes I can think of several bugs causing them (like the freeze-bug of early Ryzens) or the current amdgpu-firmware freezes of vega and navi.
Well, 1 minute isn’t much time, but did you try to get some informations via
# journalctl -b -1
or
# dmesg
It would also be possible to enter the grub-menu and alter the the commandline to
GRUB_CMDLINE_LINUX_DEFAULT="text"
to prevent the xserver from starting and at least get some informations/logs without running into a possible gpu-related freeze.
So the fedora live usb is freezing too now, is this still a manjaro forum topic?At least i got this: I know text is preferred over pictures but its not possible for me to copy it that fast
photo_2021-06-02_14-49-20|281x500
photo_2021-06-02_14-49-24|281x500
I do upates for my machine every few days but im not sure if there were any major system or kernel updates right before the freezing started happening.
Right now, after removing the fedora usb i cant access my system at all, not even the bios, just all black so no chance of doing journalctl or any grub -menu things for me. am really not sure if this is a manjaro problem any more, but still in desperate need of help
With (good 'ol) Sandy Bridge and also rather old Nvidia 970 it would be very unlikely any driver-optimizations causing this.
But more important:
it sounds like an ordinary hardware-failure. Time to replace components until it’s gone. Would start with GPU and then power supply unit.
i got the journalctl
-- Journal begins at Fri 2020-06-19 16:44:01 CEST, ends at Wed 2021-06-02 16:09:48 CEST. --
Jun 02 14:46:27 bob-pc kernel: microcode: microcode updated early to revision 0x2f, date = 2019-02-17
Jun 02 14:46:27 bob-pc kernel: Linux version 5.4.118-1-MANJARO (builduser@LEGION) (gcc version 10.2.0 (GCC)) #1 SMP PREEMPT Tue May 11 17:46:18 UTC 2021
Jun 02 14:46:27 bob-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=d116a507-f29e-403c-bb3e-8c88295798d3 rw quiet
Jun 02 14:46:27 bob-pc kernel: KERNEL supported cpus:
Jun 02 14:46:27 bob-pc kernel: Intel GenuineIntel
Jun 02 14:46:27 bob-pc kernel: AMD AuthenticAMD
Jun 02 14:46:27 bob-pc kernel: Hygon HygonGenuine
Jun 02 14:46:27 bob-pc kernel: Centaur CentaurHauls
Jun 02 14:46:27 bob-pc kernel: zhaoxin Shanghai
Jun 02 14:46:27 bob-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jun 02 14:46:27 bob-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jun 02 14:46:27 bob-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jun 02 14:46:27 bob-pc kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Jun 02 14:46:27 bob-pc kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Jun 02 14:46:27 bob-pc kernel: BIOS-provided physical RAM map:
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000040200000-0x00000000da38ffff] usable
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da390000-0x00000000da3d4fff] type 20
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da3d5000-0x00000000da404fff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da405000-0x00000000da415fff] type 20
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da416000-0x00000000da5f6fff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da5f7000-0x00000000da67afff] ACPI NVS
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da67b000-0x00000000da93ffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000da940000-0x00000000dab84fff] ACPI NVS
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000dab85000-0x00000000dab92fff] ACPI data
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000dab93000-0x00000000dabbffff] ACPI NVS
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000dabc0000-0x00000000dabc4fff] ACPI data
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000dabc5000-0x00000000dac07fff] ACPI NVS
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000dac08000-0x00000000daffffff] usable
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jun 02 14:46:27 bob-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000041f5fffff] usable
Jun 02 14:46:27 bob-pc kernel: NX (Execute Disable) protection: active
Jun 02 14:46:27 bob-pc kernel: efi: EFI v2.31 by American Megatrends
Jun 02 14:46:27 bob-pc kernel: efi: ACPI=0xdab85000 ACPI 2.0=0xdab85000 SMBIOS=0xda428e98 MPS=0xfc9d0
Jun 02 14:46:27 bob-pc kernel: SMBIOS 2.6 present.
Jun 02 14:46:27 bob-pc kernel: DMI: System manufacturer System Product Name/P8Z68-V PRO GEN3, BIOS 3802 01/15/2015
Jun 02 14:46:27 bob-pc kernel: tsc: Fast TSC calibration using PIT
Jun 02 14:46:27 bob-pc kernel: tsc: Detected 3310.825 MHz processor
Jun 02 14:46:27 bob-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jun 02 14:46:27 bob-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jun 02 14:46:27 bob-pc kernel: last_pfn = 0x41f600 max_arch_pfn = 0x400000000
Jun 02 14:46:27 bob-pc kernel: MTRR default type: uncachable
Jun 02 14:46:27 bob-pc kernel: MTRR fixed ranges enabled:
Jun 02 14:46:27 bob-pc kernel: 00000-9FFFF write-back
Jun 02 14:46:27 bob-pc kernel: A0000-BFFFF uncachable
Jun 02 14:46:27 bob-pc kernel: C0000-D3FFF write-protect
demsg is incredibly long and i dont think i copied the whole of it, should i send it anyways?
