Hi all, I’m Attilio,an Italian guy.
Yesterday I bought a laptop but I have a problem: everything is ok when the charger is on but on battery mode the laptop freezes and I have to force the shutdown; anyone can help me?
Thanks in advance.
Attilio.
Welcome here, @Attila23
Have you updated already? If not, then open a terminal window and enter
sudo pacman-mirrors -f && sudo pacman -Syyu
Afterwards, reboot.
Please provide some details of your system by posting output of
inxi -Fazy
Hi Wollie, thanks for your help!
I don’t know how to link the details of my system because the system said that I can’t link images or other things.
Normal copy = [CTRL + C]
Normal paste = {CTRL + V
Terminal copy = [CTRL + SHIFT + C]
Terminal paste = {CTRL + SHIFT + V]
- Type or copy
inxi -Fazy
in the ‘yakuake’-terminal - Than copy from terminal with [CTRL + SHIFT + C] the results/outuput
- Insert here in the forum/answer the copied parts
- Select with the mouse the inserted test in the answer and click on
symbol on top of answer.
I’m having the same problem; These are the system details:
> System:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=41f330d9-36c8-45cb-a06f-1c02967a1e3f ro quiet apparmor=1 security=apparmor resume=UUID=48536126-d78c-4ddf-a605-00884f5c65d8 udev.log_priority=3 Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X421IAY_M413IA v: 1.0 serial: <filter> Mobo: ASUSTeK model: X421IAY v: 1.0 serial: <filter> UEFI: American Megatrends v: X421IAY.305 date: 07/31/2020 Battery: ID-1: BAT0 charge: 38.1 Wh condition: 38.5/42.1 Wh (92%) volts: 11.8/11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging cycles: 62 CPU: Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600106 L2 cache: 3 MiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28453 Speed: 1397 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 04:00.0 chip ID: 1002:1636 Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-3:3 chip ID: 13d3:56a8 serial: <filter> Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9") Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14") OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.1) v: 4.6 Mesa 20.3.3 direct render: Yes Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:1637 Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3 Sound Server: ALSA v: k5.9.16-1-MANJARO Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0 chip ID: 8086:2723 IF: wlp1s0 state: up mac: <filter> Drives: Local Storage: total: 709.83 GiB used: 19.9 GiB (2.8%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C temp: 24.9 C ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Kingston model: SA2000M8250G size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S5Z42105 temp: 29.9 C Partition: ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%) used: 19.9 GiB (9.1%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7 ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default) ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8 Sensors: System Temperatures: cpu: 45.4 C mobo: N/A gpu: amdgpu temp: 35.0 C Fan Speeds (RPM): cpu: 2000 Info: Processes: 247 Uptime: 11m wakeups: 1315 Memory: 7.26 GiB used: 2.57 GiB (35.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1316 pacman: 1298 lib: 400 flatpak: 8 snap: 10 Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.2.02
> [attila23@attila23-f7s ~]$ inxi -Fazy
> System:
> Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
> root=UUID=1b9667f6-539e-42f1-ac8a-7bb84ae5f8e3 ro quiet apparmor=1
> security=apparmor udev.log_priority=3
> Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
> Machine:
> Type: Laptop System: TECLAST product: F7S v: N/A serial: <filter>
> Mobo: TECLAST model: F7S serial: <filter> UEFI: TECLAST v: tPAD 3.02
> date: 12/04/2020
> Battery:
> ID-1: BAT0 charge: 37.0 Wh condition: 37.0/37.0 Wh (100%) volts: 7.6/N/A
> model: OlineTech ApolloLake type: Li-ion serial: <filter> status: Charging
> CPU:
> Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP arch: Goldmont
> family: 6 model-id: 5C (92) stepping: 9 microcode: 40 L2 cache: 1024 KiB
> flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
> Speed: 2089 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 2089 2: 1680
> 3: 2033 4: 2000
> Type: spec_store_bypass status: Not affected
> Type: spectre_v1
> Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
> Graphics:
> Device-1: Intel HD Graphics 500 driver: i915 v: kernel bus ID: 00:02.0
> chip ID: 8086:5a85
> Device-2: Alcor Micro USB 2.0 Camera type: USB driver: uvcvideo
> bus ID: 1-8:5 chip ID: 058f:5608
> loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
> screens: 1
> Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
> diag: 354mm (13.9")
> OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 20.3.3
> direct render: Yes
> Audio:
> Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
> vendor: Realtek driver: snd_hda_intel v: kernel
> alternate: snd_soc_skl,snd_sof_pci bus ID: 00:0e.0 chip ID: 8086:5a98
> Sound Server: ALSA v: k5.10.7-3-MANJARO
> Network:
> Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
> driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: e000 bus ID: 01:00.0
> chip ID: 10ec:c821
> Drives:
> Local Storage: total: 119.24 GiB used: 16.21 GiB (13.6%)
> ID-1: /dev/sda maj-min: 8:0 vendor: Teclast model: 128GB NS550-2242
> size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
> serial: <filter> rev: 0A0
> Partition:
> ID-1: / raw size: 118.95 GiB size: 116.58 GiB (98.01%)
> used: 16.21 GiB (13.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
> used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
> Swap:
> Alert: No Swap data was found.
> Sensors:
> System Temperatures: cpu: 57.0 C mobo: N/A
> Fan Speeds (RPM): N/A
> Info:
> Processes: 205 Uptime: 7m wakeups: 1 Memory: 7.6 GiB used: 2 GiB (26.3%)
> Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1459 lib: 438
> flatpak: 0 snap: 0 Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.2.02
