the output of cat /etc/mkinitcpio.conf | grep HOOKS
is
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# HOOKS=(base)
# HOOKS=(base udev autodetect block filesystems)
# HOOKS=(base udev block filesystems)
# HOOKS=(base udev block mdadm encrypt filesystems)
# HOOKS=(base udev block lvm2 filesystems)
HOOKS="base udev autodetect modconf block keyboard keymap consolefont resume filesystems fsck"
the output of lsblk -f
is
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
│ ext4 1.0 7b78da41-454b-42bb-828c-cc25b079cc29 401.8G 4% /
└─sda2
swap 1 swap fd6b19e2-231d-4b72-9316-494d3929df3e [SWAP]
sdb
└─sdb1
ntfs 1TB HITACHI B
E2EAB1DDEAB1AE63 518.9G 44% /run/media/samual/1TB HITACHI B
I’ll edit with more command output after I reboot
I’ve waited more than 5 minutes at one point and nothing changed
edit:
the output of journalctl -p3 -b-1
is
Jul 28 09:55:33 samual-pc systemd-udevd[254]: event12: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Jul 28 09:55:33 samual-pc kernel:
Jul 28 09:55:33 samual-pc kernel: usb 3-1: 5:1: cannot get min/max values for control 2 (id 5)
Jul 28 09:55:33 samual-pc systemd-udevd[272]: controlC2: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/sound/card2/controlC2/../uevent}, ignoring: No such file or directory
Jul 28 09:55:36 samual-pc sddm-helper[490]: gkr-pam: couldn't unlock the login keyring.
Jul 28 09:55:38 samual-pc kernel: ntfs3: Unknown parameter 'windows_names'
Jul 28 09:56:03 samual-pc pulseaudio[650]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jul 28 10:02:41 samual-pc systemd-coredump[1149]: Process 1144 (firefox) of user 1000 dumped core.
Module /usr/lib/firefox/libmozsandbox.so with build-id 737b4f94dc082641ef04e3e3ed05fc254e66b6ca
Module linux-vdso.so.1 with build-id d538355c2edfd4598db560bcb7271b30b92d3b31
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module librt.so.1 with build-id f696f0167950c759f9ea43d46167fae35d43dded
Module libplds4.so with build-id 2b49ec2f43d2e5fc2e56f35bcd094968f9bf36e6
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id c12fc69a86f3eef0797ef4870148bde8568f6fac
Module libnss3.so with build-id 84bbb6b8dbdd8166bca28eb1158d4a72a78e0af6
Module libsmime3.so with build-id f9c97caf66dcd1c55e8e27d5858b425f06108ba4
Module libssl3.so with build-id 06274b79b2198e48a2eb6ea2da9f41c18d99231d
Module libplc4.so with build-id 2f3f90e73b1f4fc3424689615d6d32f7427bb783
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libxul.so with build-id df5df7cca77bbb20d8d023735d6a2e3007704f96
Module libmozwayland.so with build-id 3f89e1e6b103635baf1a3f7616088efc0a6cde48
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libsystemd.so.0 with build-id 761a39da56f185d6f1ef6f7bb95a3299789eb3e2
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id 90fb9a043b4a51db25530e16cd543c4b2a9319a9
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 31895d2bd133f34f0cdc2d4ac855ed838ec927b6
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id eb5972c9f0b0292b8a7053255db5245c07669a88
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 1d293edcbaefc8c1b024f83d0935e88e6f09dfcb
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libharfbuzz.so.0 with build-id aad49fa51ffb89551ebb021336f56cfa28334823
Module libpango-1.0.so.0 with build-id b358a862a5ca8b1e4e69235edce1780e9f860a0a
Module libpangocairo-1.0.so.0 with build-id e7a2a9e56f2e2f6121d9c5741b3e93871b673cfa
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
Module libmozgtk.so with build-id 3556db01b713cbc87af838233f58c16a8ceb0079
Module libmozsqlite3.so with build-id ac4e88133b28442d673acfa7640814c404fde869
Module liblgpllibs.so with build-id 081553b68087ea2aaaeff0f256cd9e46d7edf667
Module libnspr4.so with build-id e54087b0e38cf8936f6c458e922589406343b05d
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module firefox with build-id e6b65d95282c4101fec6f3871fc5d7d213918a7c
Stack trace of thread 1144:
#0 0x00007fd40f27c814 XDisplayString (libX11.so.6 + 0x2b814)
#1 0x00007fd4025b1a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
#2 0x00007fd402258c8a n/a (libva.so.2 + 0x3c8a)
#3 0x00007fd40225ebe1 vaInitialize (libva.so.2 + 0x9be1)
#4 0x00007fd40aaf09f7 n/a (libxul.so + 0x85369f7)
#5 0x00007fd40aaf1609 n/a (libxul.so + 0x8537609)
#6 0x00007fd406a713de n/a (libxul.so + 0x44b73de)
#7 0x00007fd406a6f1e5 n/a (libxul.so + 0x44b51e5)
#8 0x00007fd406a62125 n/a (libxul.so + 0x44a8125)
#9 0x00007fd406a613ed n/a (libxul.so + 0x44a73ed)
#10 0x0000559883a0c912 n/a (firefox + 0x49912)
#11 0x00007fd411065290 n/a (libc.so.6 + 0x29290)
#12 0x00007fd41106534a __libc_start_main (libc.so.6 + 0x2934a)
#13 0x0000559883a205b5 _start (firefox + 0x5d5b5)
Jul 28 10:07:10 samual-pc systemd-coredump[2405]: Process 2403 (firefox) of user 1000 dumped core.
Stack trace of thread 2403:
#0 0x00007f04cb0f3814 XDisplayString (libX11.so.6 + 0x2b814)
#1 0x00007f04be42da1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
#2 0x00007f04bdfd4c8a n/a (libva.so.2 + 0x3c8a)
#3 0x00007f04bdfdabe1 vaInitialize (libva.so.2 + 0x9be1)
#4 0x00007f04c696c9f7 n/a (libxul.so + 0x85369f7)
#5 0x00007f04c696d609 n/a (libxul.so + 0x8537609)
#6 0x00007f04c28ed3de n/a (libxul.so + 0x44b73de)
#7 0x00007f04c28eb1e5 n/a (libxul.so + 0x44b51e5)
#8 0x00007f04c28de125 n/a (libxul.so + 0x44a8125)
#9 0x00007f04c28dd3ed n/a (libxul.so + 0x44a73ed)
#10 0x000055a2d47c8912 n/a (firefox + 0x49912)
#11 0x00007f04ccee4290 n/a (libc.so.6 + 0x29290)
#12 0x00007f04ccee434a __libc_start_main (libc.so.6 + 0x2934a)
#13 0x000055a2d47dc5b5 _start (firefox + 0x5d5b5)
the output of journalctl -e -b-1
is
Jul 28 11:20:39 samual-pc krunner[1066]: [2022-07-28 11:20:39.888] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:42 samual-pc krunner[1066]: [2022-07-28 11:20:42.891] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:45 samual-pc krunner[1066]: [2022-07-28 11:20:45.895] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:46 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:20:48 samual-pc krunner[1066]: [2022-07-28 11:20:48.895] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:51 samual-pc krunner[1066]: [2022-07-28 11:20:51.898] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:54 samual-pc krunner[1066]: [2022-07-28 11:20:54.898] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:20:57 samual-pc krunner[1066]: [2022-07-28 11:20:57.901] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:00 samual-pc krunner[1066]: [2022-07-28 11:21:00.903] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:03 samual-pc krunner[1066]: [2022-07-28 11:21:03.905] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:06 samual-pc krunner[1066]: [2022-07-28 11:21:06.908] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:09 samual-pc krunner[1066]: [2022-07-28 11:21:09.910] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:12 samual-pc krunner[1066]: [2022-07-28 11:21:12.912] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:15 samual-pc krunner[1066]: [2022-07-28 11:21:15.915] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:18 samual-pc krunner[1066]: [2022-07-28 11:21:18.918] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:21 samual-pc krunner[1066]: [2022-07-28 11:21:21.918] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:24 samual-pc krunner[1066]: [2022-07-28 11:21:24.921] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:27 samual-pc krunner[1066]: [2022-07-28 11:21:27.925] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:30 samual-pc krunner[1066]: [2022-07-28 11:21:30.925] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:33 samual-pc krunner[1066]: [2022-07-28 11:21:33.928] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:36 samual-pc krunner[1066]: [2022-07-28 11:21:36.932] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:39 samual-pc krunner[1066]: [2022-07-28 11:21:39.935] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:42 samual-pc krunner[1066]: [2022-07-28 11:21:42.938] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:45 samual-pc krunner[1066]: [2022-07-28 11:21:45.941] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:47 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:21:48 samual-pc krunner[1066]: [2022-07-28 11:21:48.942] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:51 samual-pc krunner[1066]: [2022-07-28 11:21:51.945] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:54 samual-pc krunner[1066]: [2022-07-28 11:21:54.945] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:21:57 samual-pc krunner[1066]: [2022-07-28 11:21:57.948] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:00 samual-pc krunner[1066]: [2022-07-28 11:22:00.951] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:03 samual-pc krunner[1066]: [2022-07-28 11:22:03.955] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:06 samual-pc krunner[1066]: [2022-07-28 11:22:06.955] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:09 samual-pc krunner[1066]: [2022-07-28 11:22:09.956] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:12 samual-pc krunner[1066]: [2022-07-28 11:22:12.958] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:15 samual-pc krunner[1066]: [2022-07-28 11:22:15.962] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:18 samual-pc krunner[1066]: [2022-07-28 11:22:18.965] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:21 samual-pc krunner[1066]: [2022-07-28 11:22:21.965] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:24 samual-pc krunner[1066]: [2022-07-28 11:22:24.968] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:27 samual-pc krunner[1066]: [2022-07-28 11:22:27.971] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:30 samual-pc krunner[1066]: [2022-07-28 11:22:30.972] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:33 samual-pc krunner[1066]: [2022-07-28 11:22:33.975] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:36 samual-pc krunner[1066]: [2022-07-28 11:22:36.978] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:39 samual-pc krunner[1066]: [2022-07-28 11:22:39.980] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:42 samual-pc krunner[1066]: [2022-07-28 11:22:42.982] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:45 samual-pc krunner[1066]: [2022-07-28 11:22:45.984] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:47 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:22:48 samual-pc krunner[1066]: [2022-07-28 11:22:48.985] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:51 samual-pc krunner[1066]: [2022-07-28 11:22:51.988] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:54 samual-pc krunner[1066]: [2022-07-28 11:22:54.991] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:22:57 samual-pc krunner[1066]: [2022-07-28 11:22:57.992] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:00 samual-pc krunner[1066]: [2022-07-28 11:23:00.995] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:03 samual-pc krunner[1066]: [2022-07-28 11:23:03.998] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:07 samual-pc krunner[1066]: [2022-07-28 11:23:07.001] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:10 samual-pc krunner[1066]: [2022-07-28 11:23:10.002] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:13 samual-pc krunner[1066]: [2022-07-28 11:23:13.005] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:16 samual-pc krunner[1066]: [2022-07-28 11:23:16.008] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:19 samual-pc krunner[1066]: [2022-07-28 11:23:19.009] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:22 samual-pc krunner[1066]: [2022-07-28 11:23:22.012] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:25 samual-pc krunner[1066]: [2022-07-28 11:23:25.015] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:28 samual-pc krunner[1066]: [2022-07-28 11:23:28.017] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:31 samual-pc krunner[1066]: [2022-07-28 11:23:31.018] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:34 samual-pc krunner[1066]: [2022-07-28 11:23:34.021] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:37 samual-pc krunner[1066]: [2022-07-28 11:23:37.025] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:40 samual-pc krunner[1066]: [2022-07-28 11:23:40.027] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:43 samual-pc krunner[1066]: [2022-07-28 11:23:43.028] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:46 samual-pc krunner[1066]: [2022-07-28 11:23:46.031] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:48 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:23:49 samual-pc krunner[1066]: [2022-07-28 11:23:49.035] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:52 samual-pc krunner[1066]: [2022-07-28 11:23:52.037] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:55 samual-pc krunner[1066]: [2022-07-28 11:23:55.038] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:23:58 samual-pc krunner[1066]: [2022-07-28 11:23:58.041] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:01 samual-pc krunner[1066]: [2022-07-28 11:24:01.042] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:04 samual-pc krunner[1066]: [2022-07-28 11:24:04.043] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:07 samual-pc krunner[1066]: [2022-07-28 11:24:07.045] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:10 samual-pc krunner[1066]: [2022-07-28 11:24:10.048] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:13 samual-pc krunner[1066]: [2022-07-28 11:24:13.051] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:16 samual-pc krunner[1066]: [2022-07-28 11:24:16.055] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:19 samual-pc krunner[1066]: [2022-07-28 11:24:19.055] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:22 samual-pc krunner[1066]: [2022-07-28 11:24:22.058] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:25 samual-pc krunner[1066]: [2022-07-28 11:24:25.061] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:28 samual-pc krunner[1066]: [2022-07-28 11:24:28.062] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:31 samual-pc krunner[1066]: [2022-07-28 11:24:31.064] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:34 samual-pc krunner[1066]: [2022-07-28 11:24:34.065] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:37 samual-pc krunner[1066]: [2022-07-28 11:24:37.068] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:40 samual-pc krunner[1066]: [2022-07-28 11:24:40.072] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:43 samual-pc krunner[1066]: [2022-07-28 11:24:43.075] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:46 samual-pc krunner[1066]: [2022-07-28 11:24:46.078] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:48 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:24:49 samual-pc krunner[1066]: [2022-07-28 11:24:49.078] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:52 samual-pc krunner[1066]: [2022-07-28 11:24:52.081] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:55 samual-pc krunner[1066]: [2022-07-28 11:24:55.085] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:24:58 samual-pc krunner[1066]: [2022-07-28 11:24:58.085] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:01 samual-pc krunner[1066]: [2022-07-28 11:25:01.088] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:04 samual-pc krunner[1066]: [2022-07-28 11:25:04.091] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:07 samual-pc krunner[1066]: [2022-07-28 11:25:07.092] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:10 samual-pc krunner[1066]: [2022-07-28 11:25:10.095] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:13 samual-pc krunner[1066]: [2022-07-28 11:25:13.098] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:16 samual-pc krunner[1066]: [2022-07-28 11:25:16.098] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:19 samual-pc krunner[1066]: [2022-07-28 11:25:19.100] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:22 samual-pc krunner[1066]: [2022-07-28 11:25:22.103] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:25 samual-pc krunner[1066]: [2022-07-28 11:25:25.105] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:28 samual-pc krunner[1066]: [2022-07-28 11:25:28.108] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:31 samual-pc krunner[1066]: [2022-07-28 11:25:31.111] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:34 samual-pc krunner[1066]: [2022-07-28 11:25:34.115] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:37 samual-pc krunner[1066]: [2022-07-28 11:25:37.115] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:38 samual-pc NetworkManager[448]: <info> [1659003938.0063] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:25:40 samual-pc krunner[1066]: [2022-07-28 11:25:40.118] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:43 samual-pc krunner[1066]: [2022-07-28 11:25:43.121] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:46 samual-pc krunner[1066]: [2022-07-28 11:25:46.124] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:49 samual-pc krunner[1066]: [2022-07-28 11:25:49.125] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:49 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:25:52 samual-pc krunner[1066]: [2022-07-28 11:25:52.128] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:55 samual-pc krunner[1066]: [2022-07-28 11:25:55.131] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:25:58 samual-pc krunner[1066]: [2022-07-28 11:25:58.132] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:01 samual-pc krunner[1066]: [2022-07-28 11:26:01.134] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:04 samual-pc krunner[1066]: [2022-07-28 11:26:04.135] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:07 samual-pc krunner[1066]: [2022-07-28 11:26:07.138] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:10 samual-pc krunner[1066]: [2022-07-28 11:26:10.141] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:13 samual-pc krunner[1066]: [2022-07-28 11:26:13.145] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:16 samual-pc krunner[1066]: [2022-07-28 11:26:16.146] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:19 samual-pc krunner[1066]: [2022-07-28 11:26:19.148] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:22 samual-pc krunner[1066]: [2022-07-28 11:26:22.150] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:25 samual-pc krunner[1066]: [2022-07-28 11:26:25.152] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:28 samual-pc krunner[1066]: [2022-07-28 11:26:28.155] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:31 samual-pc krunner[1066]: [2022-07-28 11:26:31.158] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:34 samual-pc krunner[1066]: [2022-07-28 11:26:34.161] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:37 samual-pc krunner[1066]: [2022-07-28 11:26:37.165] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:40 samual-pc krunner[1066]: [2022-07-28 11:26:40.166] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:43 samual-pc krunner[1066]: [2022-07-28 11:26:43.168] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:46 samual-pc krunner[1066]: [2022-07-28 11:26:46.172] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:49 samual-pc krunner[1066]: [2022-07-28 11:26:49.175] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:49 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:26:52 samual-pc krunner[1066]: [2022-07-28 11:26:52.178] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:55 samual-pc krunner[1066]: [2022-07-28 11:26:55.178] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:26:58 samual-pc krunner[1066]: [2022-07-28 11:26:58.182] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:01 samual-pc krunner[1066]: [2022-07-28 11:27:01.184] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:04 samual-pc krunner[1066]: [2022-07-28 11:27:04.185] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:07 samual-pc krunner[1066]: [2022-07-28 11:27:07.188] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:10 samual-pc krunner[1066]: [2022-07-28 11:27:10.191] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:13 samual-pc krunner[1066]: [2022-07-28 11:27:13.192] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:16 samual-pc krunner[1066]: [2022-07-28 11:27:16.195] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:19 samual-pc krunner[1066]: [2022-07-28 11:27:19.198] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:22 samual-pc krunner[1066]: [2022-07-28 11:27:22.201] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:25 samual-pc krunner[1066]: [2022-07-28 11:27:25.202] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:28 samual-pc krunner[1066]: [2022-07-28 11:27:28.205] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:31 samual-pc krunner[1066]: [2022-07-28 11:27:31.208] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:34 samual-pc krunner[1066]: [2022-07-28 11:27:34.208] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:37 samual-pc krunner[1066]: [2022-07-28 11:27:37.211] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:40 samual-pc krunner[1066]: [2022-07-28 11:27:40.215] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:43 samual-pc krunner[1066]: [2022-07-28 11:27:43.215] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:46 samual-pc krunner[1066]: [2022-07-28 11:27:46.218] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:49 samual-pc krunner[1066]: [2022-07-28 11:27:49.222] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:50 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:27:52 samual-pc krunner[1066]: [2022-07-28 11:27:52.225] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:55 samual-pc krunner[1066]: [2022-07-28 11:27:55.228] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:27:58 samual-pc krunner[1066]: [2022-07-28 11:27:58.228] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:01 samual-pc krunner[1066]: [2022-07-28 11:28:01.231] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:04 samual-pc krunner[1066]: [2022-07-28 11:28:04.235] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:07 samual-pc krunner[1066]: [2022-07-28 11:28:07.238] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:10 samual-pc krunner[1066]: [2022-07-28 11:28:10.241] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:13 samual-pc krunner[1066]: [2022-07-28 11:28:13.245] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:16 samual-pc krunner[1066]: [2022-07-28 11:28:16.245] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:19 samual-pc krunner[1066]: [2022-07-28 11:28:19.248] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:22 samual-pc krunner[1066]: [2022-07-28 11:28:22.251] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:25 samual-pc krunner[1066]: [2022-07-28 11:28:25.252] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:28 samual-pc krunner[1066]: [2022-07-28 11:28:28.254] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:31 samual-pc krunner[1066]: [2022-07-28 11:28:31.255] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:34 samual-pc krunner[1066]: [2022-07-28 11:28:34.258] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:37 samual-pc krunner[1066]: [2022-07-28 11:28:37.258] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:40 samual-pc krunner[1066]: [2022-07-28 11:28:40.261] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:43 samual-pc krunner[1066]: [2022-07-28 11:28:43.262] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:46 samual-pc krunner[1066]: [2022-07-28 11:28:46.265] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:49 samual-pc krunner[1066]: [2022-07-28 11:28:49.268] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:51 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:28:52 samual-pc krunner[1066]: [2022-07-28 11:28:52.271] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:55 samual-pc krunner[1066]: [2022-07-28 11:28:55.275] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:28:58 samual-pc krunner[1066]: [2022-07-28 11:28:58.278] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:01 samual-pc krunner[1066]: [2022-07-28 11:29:01.281] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:04 samual-pc krunner[1066]: [2022-07-28 11:29:04.282] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:07 samual-pc krunner[1066]: [2022-07-28 11:29:07.285] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:10 samual-pc krunner[1066]: [2022-07-28 11:29:10.288] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:13 samual-pc krunner[1066]: [2022-07-28 11:29:13.291] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:16 samual-pc krunner[1066]: [2022-07-28 11:29:16.292] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:19 samual-pc krunner[1066]: [2022-07-28 11:29:19.293] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:22 samual-pc krunner[1066]: [2022-07-28 11:29:22.295] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:25 samual-pc krunner[1066]: [2022-07-28 11:29:25.298] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:28 samual-pc krunner[1066]: [2022-07-28 11:29:28.301] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:31 samual-pc krunner[1066]: [2022-07-28 11:29:31.302] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:34 samual-pc krunner[1066]: [2022-07-28 11:29:34.305] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:37 samual-pc krunner[1066]: [2022-07-28 11:29:37.308] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:40 samual-pc krunner[1066]: [2022-07-28 11:29:40.311] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:43 samual-pc krunner[1066]: [2022-07-28 11:29:43.315] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:46 samual-pc krunner[1066]: [2022-07-28 11:29:46.317] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:49 samual-pc krunner[1066]: [2022-07-28 11:29:49.318] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:52 samual-pc krunner[1066]: [2022-07-28 11:29:52.321] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:53 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:29:55 samual-pc krunner[1066]: [2022-07-28 11:29:55.323] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:29:58 samual-pc krunner[1066]: [2022-07-28 11:29:58.326] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:01 samual-pc krunner[1066]: [2022-07-28 11:30:01.328] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:04 samual-pc krunner[1066]: [2022-07-28 11:30:04.331] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:06 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:30:07 samual-pc krunner[1066]: [2022-07-28 11:30:07.334] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:10 samual-pc krunner[1066]: [2022-07-28 11:30:10.335] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:13 samual-pc krunner[1066]: [2022-07-28 11:30:13.338] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:16 samual-pc krunner[1066]: [2022-07-28 11:30:16.338] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:19 samual-pc krunner[1066]: [2022-07-28 11:30:19.341] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:22 samual-pc krunner[1066]: [2022-07-28 11:30:22.345] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:25 samual-pc krunner[1066]: [2022-07-28 11:30:25.345] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:28 samual-pc krunner[1066]: [2022-07-28 11:30:28.348] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:31 samual-pc krunner[1066]: [2022-07-28 11:30:31.351] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:34 samual-pc krunner[1066]: [2022-07-28 11:30:34.352] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:37 samual-pc krunner[1066]: [2022-07-28 11:30:37.354] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:38 samual-pc NetworkManager[448]: <info> [1659004238.0035] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:30:40 samual-pc krunner[1066]: [2022-07-28 11:30:40.355] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:43 samual-pc krunner[1066]: [2022-07-28 11:30:43.358] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:46 samual-pc krunner[1066]: [2022-07-28 11:30:46.361] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:49 samual-pc krunner[1066]: [2022-07-28 11:30:49.364] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:52 samual-pc krunner[1066]: [2022-07-28 11:30:52.365] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:53 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:30:55 samual-pc krunner[1066]: [2022-07-28 11:30:55.368] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:30:58 samual-pc krunner[1066]: [2022-07-28 11:30:58.372] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:01 samual-pc krunner[1066]: [2022-07-28 11:31:01.375] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:03 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:31:04 samual-pc krunner[1066]: [2022-07-28 11:31:04.378] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:07 samual-pc krunner[1066]: [2022-07-28 11:31:07.380] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:10 samual-pc krunner[1066]: [2022-07-28 11:31:10.382] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:13 samual-pc krunner[1066]: [2022-07-28 11:31:13.385] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:16 samual-pc krunner[1066]: [2022-07-28 11:31:16.388] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:19 samual-pc krunner[1066]: [2022-07-28 11:31:19.391] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:22 samual-pc krunner[1066]: [2022-07-28 11:31:22.394] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:25 samual-pc krunner[1066]: [2022-07-28 11:31:25.395] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:28 samual-pc krunner[1066]: [2022-07-28 11:31:28.396] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:31 samual-pc krunner[1066]: [2022-07-28 11:31:31.398] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:34 samual-pc krunner[1066]: [2022-07-28 11:31:34.400] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:37 samual-pc krunner[1066]: [2022-07-28 11:31:37.402] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:40 samual-pc krunner[1066]: [2022-07-28 11:31:40.405] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:43 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55165, resource id: 14861828, major code: 3 (GetWindowAttributes), minor code: 0
Jul 28 11:31:43 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 55166, resource id: 14861828, major code: 14 (GetGeometry), minor code: 0
Jul 28 11:31:43 samual-pc krunner[1066]: [2022-07-28 11:31:43.405] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:44 samual-pc kwin_x11[559]: org.kde.bismuth: onCurrentSurfaceChanged,[object Object]
Jul 28 11:31:44 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:31:44 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:31:46 samual-pc krunner[1066]: [2022-07-28 11:31:46.408] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:49 samual-pc krunner[1066]: [2022-07-28 11:31:49.411] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:52 samual-pc krunner[1066]: [2022-07-28 11:31:52.415] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:55 samual-pc krunner[1066]: [2022-07-28 11:31:55.418] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:31:55 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:31:58 samual-pc krunner[1066]: [2022-07-28 11:31:58.422] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:01 samual-pc krunner[1066]: [2022-07-28 11:32:01.425] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:04 samual-pc krunner[1066]: [2022-07-28 11:32:04.428] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:07 samual-pc krunner[1066]: [2022-07-28 11:32:07.432] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:10 samual-pc krunner[1066]: [2022-07-28 11:32:10.435] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:13 samual-pc krunner[1066]: [2022-07-28 11:32:13.438] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:16 samual-pc krunner[1066]: [2022-07-28 11:32:16.439] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:19 samual-pc krunner[1066]: [2022-07-28 11:32:19.442] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:22 samual-pc krunner[1066]: [2022-07-28 11:32:22.443] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:25 samual-pc krunner[1066]: [2022-07-28 11:32:25.445] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:28 samual-pc krunner[1066]: [2022-07-28 11:32:28.448] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:31 samual-pc krunner[1066]: [2022-07-28 11:32:31.450] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:34 samual-pc krunner[1066]: [2022-07-28 11:32:34.452] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:37 samual-pc krunner[1066]: [2022-07-28 11:32:37.454] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:40 samual-pc krunner[1066]: [2022-07-28 11:32:40.455] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:43 samual-pc krunner[1066]: [2022-07-28 11:32:43.457] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:46 samual-pc krunner[1066]: [2022-07-28 11:32:46.458] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:49 samual-pc krunner[1066]: [2022-07-28 11:32:49.461] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:52 samual-pc krunner[1066]: [2022-07-28 11:32:52.465] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:55 samual-pc krunner[1066]: [2022-07-28 11:32:55.468] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:32:58 samual-pc krunner[1066]: [2022-07-28 11:32:58.472] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:01 samual-pc krunner[1066]: [2022-07-28 11:33:01.474] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:04 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:33:04 samual-pc krunner[1066]: [2022-07-28 11:33:04.475] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:07 samual-pc krunner[1066]: [2022-07-28 11:33:07.478] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:10 samual-pc krunner[1066]: [2022-07-28 11:33:10.481] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:13 samual-pc krunner[1066]: [2022-07-28 11:33:13.482] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:16 samual-pc krunner[1066]: [2022-07-28 11:33:16.484] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:19 samual-pc krunner[1066]: [2022-07-28 11:33:19.485] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:22 samual-pc krunner[1066]: [2022-07-28 11:33:22.488] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:25 samual-pc krunner[1066]: [2022-07-28 11:33:25.492] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:28 samual-pc krunner[1066]: [2022-07-28 11:33:28.495] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:31 samual-pc krunner[1066]: [2022-07-28 11:33:31.498] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:34 samual-pc krunner[1066]: [2022-07-28 11:33:34.502] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:37 samual-pc krunner[1066]: [2022-07-28 11:33:37.505] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:40 samual-pc krunner[1066]: [2022-07-28 11:33:40.508] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:43 samual-pc krunner[1066]: [2022-07-28 11:33:43.512] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:46 samual-pc krunner[1066]: [2022-07-28 11:33:46.515] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:49 samual-pc krunner[1066]: [2022-07-28 11:33:49.517] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:52 samual-pc krunner[1066]: [2022-07-28 11:33:52.518] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:55 samual-pc krunner[1066]: [2022-07-28 11:33:55.522] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:33:58 samual-pc krunner[1066]: [2022-07-28 11:33:58.525] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:01 samual-pc krunner[1066]: [2022-07-28 11:34:01.528] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:04 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:34:04 samual-pc krunner[1066]: [2022-07-28 11:34:04.532] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:07 samual-pc krunner[1066]: [2022-07-28 11:34:07.535] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:10 samual-pc krunner[1066]: [2022-07-28 11:34:10.535] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:13 samual-pc krunner[1066]: [2022-07-28 11:34:13.538] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:16 samual-pc krunner[1066]: [2022-07-28 11:34:16.541] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:19 samual-pc krunner[1066]: [2022-07-28 11:34:19.545] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:22 samual-pc krunner[1066]: [2022-07-28 11:34:22.545] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:25 samual-pc krunner[1066]: [2022-07-28 11:34:25.548] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:28 samual-pc krunner[1066]: [2022-07-28 11:34:28.551] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:31 samual-pc krunner[1066]: [2022-07-28 11:34:31.555] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:34 samual-pc krunner[1066]: [2022-07-28 11:34:34.555] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:37 samual-pc krunner[1066]: [2022-07-28 11:34:37.558] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:40 samual-pc krunner[1066]: [2022-07-28 11:34:40.561] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:43 samual-pc krunner[1066]: [2022-07-28 11:34:43.565] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:46 samual-pc krunner[1066]: [2022-07-28 11:34:46.566] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:49 samual-pc krunner[1066]: [2022-07-28 11:34:49.568] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:52 samual-pc krunner[1066]: [2022-07-28 11:34:52.572] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:55 samual-pc krunner[1066]: [2022-07-28 11:34:55.575] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:34:58 samual-pc krunner[1066]: [2022-07-28 11:34:58.578] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:01 samual-pc krunner[1066]: [2022-07-28 11:35:01.579] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:04 samual-pc krunner[1066]: [2022-07-28 11:35:04.582] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:07 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:35:07 samual-pc krunner[1066]: [2022-07-28 11:35:07.585] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:10 samual-pc krunner[1066]: [2022-07-28 11:35:10.586] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:13 samual-pc krunner[1066]: [2022-07-28 11:35:13.588] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:16 samual-pc krunner[1066]: [2022-07-28 11:35:16.592] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:19 samual-pc krunner[1066]: [2022-07-28 11:35:19.595] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:22 samual-pc krunner[1066]: [2022-07-28 11:35:22.598] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:25 samual-pc krunner[1066]: [2022-07-28 11:35:25.602] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:28 samual-pc krunner[1066]: [2022-07-28 11:35:28.605] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:31 samual-pc krunner[1066]: [2022-07-28 11:35:31.608] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:34 samual-pc krunner[1066]: [2022-07-28 11:35:34.611] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:37 samual-pc krunner[1066]: [2022-07-28 11:35:37.615] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:38 samual-pc NetworkManager[448]: <info> [1659004538.0031] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:35:40 samual-pc krunner[1066]: [2022-07-28 11:35:40.618] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:43 samual-pc krunner[1066]: [2022-07-28 11:35:43.622] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:46 samual-pc krunner[1066]: [2022-07-28 11:35:46.625] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:49 samual-pc krunner[1066]: [2022-07-28 11:35:49.628] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:52 samual-pc krunner[1066]: [2022-07-28 11:35:52.628] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:55 samual-pc krunner[1066]: [2022-07-28 11:35:55.632] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:35:58 samual-pc krunner[1066]: [2022-07-28 11:35:58.635] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:01 samual-pc krunner[1066]: [2022-07-28 11:36:01.637] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:04 samual-pc krunner[1066]: [2022-07-28 11:36:04.638] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:07 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:36:07 samual-pc krunner[1066]: [2022-07-28 11:36:07.642] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:10 samual-pc krunner[1066]: [2022-07-28 11:36:10.645] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:13 samual-pc krunner[1066]: [2022-07-28 11:36:13.648] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:16 samual-pc krunner[1066]: [2022-07-28 11:36:16.651] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:19 samual-pc krunner[1066]: [2022-07-28 11:36:19.655] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:22 samual-pc krunner[1066]: [2022-07-28 11:36:22.658] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:25 samual-pc krunner[1066]: [2022-07-28 11:36:25.662] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:28 samual-pc krunner[1066]: [2022-07-28 11:36:28.665] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:31 samual-pc krunner[1066]: [2022-07-28 11:36:31.669] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:34 samual-pc krunner[1066]: [2022-07-28 11:36:34.672] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:37 samual-pc krunner[1066]: [2022-07-28 11:36:37.675] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:40 samual-pc krunner[1066]: [2022-07-28 11:36:40.678] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:43 samual-pc krunner[1066]: [2022-07-28 11:36:43.682] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:46 samual-pc krunner[1066]: [2022-07-28 11:36:46.685] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:49 samual-pc krunner[1066]: [2022-07-28 11:36:49.688] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:52 samual-pc krunner[1066]: [2022-07-28 11:36:52.691] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:55 samual-pc krunner[1066]: [2022-07-28 11:36:55.692] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:36:58 samual-pc krunner[1066]: [2022-07-28 11:36:58.695] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:01 samual-pc krunner[1066]: [2022-07-28 11:37:01.698] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:04 samual-pc krunner[1066]: [2022-07-28 11:37:04.701] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:07 samual-pc krunner[1066]: [2022-07-28 11:37:07.705] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:08 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:37:10 samual-pc krunner[1066]: [2022-07-28 11:37:10.708] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:13 samual-pc krunner[1066]: [2022-07-28 11:37:13.712] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:16 samual-pc krunner[1066]: [2022-07-28 11:37:16.715] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:19 samual-pc krunner[1066]: [2022-07-28 11:37:19.718] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:22 samual-pc krunner[1066]: [2022-07-28 11:37:22.722] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:25 samual-pc krunner[1066]: [2022-07-28 11:37:25.725] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:28 samual-pc krunner[1066]: [2022-07-28 11:37:28.728] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:31 samual-pc krunner[1066]: [2022-07-28 11:37:31.732] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:34 samual-pc krunner[1066]: [2022-07-28 11:37:34.735] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:37 samual-pc krunner[1066]: [2022-07-28 11:37:37.738] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:40 samual-pc krunner[1066]: [2022-07-28 11:37:40.742] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:43 samual-pc krunner[1066]: [2022-07-28 11:37:43.745] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:46 samual-pc krunner[1066]: [2022-07-28 11:37:46.748] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:49 samual-pc krunner[1066]: [2022-07-28 11:37:49.752] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:52 samual-pc krunner[1066]: [2022-07-28 11:37:52.755] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:55 samual-pc krunner[1066]: [2022-07-28 11:37:55.758] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:37:58 samual-pc krunner[1066]: [2022-07-28 11:37:58.762] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:01 samual-pc krunner[1066]: [2022-07-28 11:38:01.765] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:04 samual-pc krunner[1066]: [2022-07-28 11:38:04.768] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:07 samual-pc krunner[1066]: [2022-07-28 11:38:07.771] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:08 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:38:10 samual-pc krunner[1066]: [2022-07-28 11:38:10.774] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:13 samual-pc krunner[1066]: [2022-07-28 11:38:13.778] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:16 samual-pc krunner[1066]: [2022-07-28 11:38:16.782] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:19 samual-pc krunner[1066]: [2022-07-28 11:38:19.785] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:22 samual-pc krunner[1066]: [2022-07-28 11:38:22.788] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:25 samual-pc krunner[1066]: [2022-07-28 11:38:25.792] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:28 samual-pc krunner[1066]: [2022-07-28 11:38:28.795] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:31 samual-pc krunner[1066]: [2022-07-28 11:38:31.799] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:34 samual-pc krunner[1066]: [2022-07-28 11:38:34.802] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:37 samual-pc krunner[1066]: [2022-07-28 11:38:37.803] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:40 samual-pc krunner[1066]: [2022-07-28 11:38:40.805] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:43 samual-pc krunner[1066]: [2022-07-28 11:38:43.808] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:46 samual-pc krunner[1066]: [2022-07-28 11:38:46.811] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:49 samual-pc krunner[1066]: [2022-07-28 11:38:49.815] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:52 samual-pc krunner[1066]: [2022-07-28 11:38:52.818] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:55 samual-pc krunner[1066]: [2022-07-28 11:38:55.821] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:38:58 samual-pc krunner[1066]: [2022-07-28 11:38:58.825] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:01 samual-pc krunner[1066]: [2022-07-28 11:39:01.828] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:04 samual-pc krunner[1066]: [2022-07-28 11:39:04.831] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:07 samual-pc krunner[1066]: [2022-07-28 11:39:07.832] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:10 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:39:10 samual-pc krunner[1066]: [2022-07-28 11:39:10.835] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:13 samual-pc krunner[1066]: [2022-07-28 11:39:13.838] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:16 samual-pc krunner[1066]: [2022-07-28 11:39:16.842] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:19 samual-pc krunner[1066]: [2022-07-28 11:39:19.845] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:22 samual-pc krunner[1066]: [2022-07-28 11:39:22.848] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:25 samual-pc krunner[1066]: [2022-07-28 11:39:25.852] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:28 samual-pc krunner[1066]: [2022-07-28 11:39:28.855] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:31 samual-pc krunner[1066]: [2022-07-28 11:39:31.858] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:34 samual-pc krunner[1066]: [2022-07-28 11:39:34.862] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:37 samual-pc krunner[1066]: [2022-07-28 11:39:37.865] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:40 samual-pc krunner[1066]: [2022-07-28 11:39:40.868] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:43 samual-pc krunner[1066]: [2022-07-28 11:39:43.871] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:46 samual-pc krunner[1066]: [2022-07-28 11:39:46.875] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:49 samual-pc krunner[1066]: [2022-07-28 11:39:49.878] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:52 samual-pc krunner[1066]: [2022-07-28 11:39:52.882] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:55 samual-pc krunner[1066]: [2022-07-28 11:39:55.885] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:39:58 samual-pc krunner[1066]: [2022-07-28 11:39:58.888] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:01 samual-pc krunner[1066]: [2022-07-28 11:40:01.888] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:04 samual-pc krunner[1066]: [2022-07-28 11:40:04.891] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:07 samual-pc krunner[1066]: [2022-07-28 11:40:07.895] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:10 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:40:10 samual-pc krunner[1066]: [2022-07-28 11:40:10.898] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:13 samual-pc krunner[1066]: [2022-07-28 11:40:13.901] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:16 samual-pc krunner[1066]: [2022-07-28 11:40:16.905] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:19 samual-pc krunner[1066]: [2022-07-28 11:40:19.908] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:22 samual-pc krunner[1066]: [2022-07-28 11:40:22.911] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:25 samual-pc krunner[1066]: [2022-07-28 11:40:25.915] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:28 samual-pc krunner[1066]: [2022-07-28 11:40:28.915] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:31 samual-pc krunner[1066]: [2022-07-28 11:40:31.918] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:34 samual-pc krunner[1066]: [2022-07-28 11:40:34.922] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:37 samual-pc krunner[1066]: [2022-07-28 11:40:37.925] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:38 samual-pc NetworkManager[448]: <info> [1659004838.0046] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:40:40 samual-pc krunner[1066]: [2022-07-28 11:40:40.928] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:43 samual-pc krunner[1066]: [2022-07-28 11:40:43.931] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:46 samual-pc krunner[1066]: [2022-07-28 11:40:46.935] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:49 samual-pc krunner[1066]: [2022-07-28 11:40:49.938] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:52 samual-pc krunner[1066]: [2022-07-28 11:40:52.942] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:55 samual-pc krunner[1066]: [2022-07-28 11:40:55.945] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:40:58 samual-pc krunner[1066]: [2022-07-28 11:40:58.948] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:01 samual-pc krunner[1066]: [2022-07-28 11:41:01.951] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:04 samual-pc krunner[1066]: [2022-07-28 11:41:04.955] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:07 samual-pc krunner[1066]: [2022-07-28 11:41:07.955] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:10 samual-pc krunner[1066]: [2022-07-28 11:41:10.958] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:13 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:41:13 samual-pc krunner[1066]: [2022-07-28 11:41:13.962] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:16 samual-pc krunner[1066]: [2022-07-28 11:41:16.965] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:19 samual-pc krunner[1066]: [2022-07-28 11:41:19.968] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:22 samual-pc krunner[1066]: [2022-07-28 11:41:22.972] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:25 samual-pc krunner[1066]: [2022-07-28 11:41:25.975] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:28 samual-pc krunner[1066]: [2022-07-28 11:41:28.978] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:31 samual-pc krunner[1066]: [2022-07-28 11:41:31.982] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:34 samual-pc krunner[1066]: [2022-07-28 11:41:34.985] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:37 samual-pc krunner[1066]: [2022-07-28 11:41:37.988] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:40 samual-pc krunner[1066]: [2022-07-28 11:41:40.992] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:43 samual-pc krunner[1066]: [2022-07-28 11:41:43.995] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:46 samual-pc krunner[1066]: [2022-07-28 11:41:46.998] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:50 samual-pc krunner[1066]: [2022-07-28 11:41:50.002] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:53 samual-pc krunner[1066]: [2022-07-28 11:41:53.005] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:56 samual-pc krunner[1066]: [2022-07-28 11:41:56.008] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:41:59 samual-pc krunner[1066]: [2022-07-28 11:41:59.012] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:02 samual-pc krunner[1066]: [2022-07-28 11:42:02.015] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:05 samual-pc krunner[1066]: [2022-07-28 11:42:05.018] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:08 samual-pc krunner[1066]: [2022-07-28 11:42:08.021] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:11 samual-pc krunner[1066]: [2022-07-28 11:42:11.025] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:13 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:42:14 samual-pc krunner[1066]: [2022-07-28 11:42:14.028] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:17 samual-pc krunner[1066]: [2022-07-28 11:42:17.032] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:20 samual-pc krunner[1066]: [2022-07-28 11:42:20.035] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:23 samual-pc krunner[1066]: [2022-07-28 11:42:23.038] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:26 samual-pc krunner[1066]: [2022-07-28 11:42:26.042] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:29 samual-pc krunner[1066]: [2022-07-28 11:42:29.045] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:30 samual-pc kscreenlocker_greet[8605]: Qt: Session management error: networkIdsList argument is NULL
Jul 28 11:42:31 samual-pc kscreenlocker_greet[8605]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:42:9: Unable to assign [undefined] to bool
Jul 28 11:42:32 samual-pc krunner[1066]: [2022-07-28 11:42:32.048] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:35 samual-pc krunner[1066]: [2022-07-28 11:42:35.052] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:38 samual-pc krunner[1066]: [2022-07-28 11:42:38.055] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:41 samual-pc krunner[1066]: [2022-07-28 11:42:41.058] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:44 samual-pc krunner[1066]: [2022-07-28 11:42:44.062] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:47 samual-pc krunner[1066]: [2022-07-28 11:42:47.065] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:50 samual-pc krunner[1066]: [2022-07-28 11:42:50.068] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:53 samual-pc krunner[1066]: [2022-07-28 11:42:53.071] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:56 samual-pc krunner[1066]: [2022-07-28 11:42:56.075] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:42:59 samual-pc krunner[1066]: [2022-07-28 11:42:59.078] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:02 samual-pc krunner[1066]: [2022-07-28 11:43:02.082] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:05 samual-pc krunner[1066]: [2022-07-28 11:43:05.085] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:08 samual-pc krunner[1066]: [2022-07-28 11:43:08.088] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:11 samual-pc krunner[1066]: [2022-07-28 11:43:11.092] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:14 samual-pc krunner[1066]: [2022-07-28 11:43:14.095] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:14 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:43:17 samual-pc krunner[1066]: [2022-07-28 11:43:17.099] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:20 samual-pc krunner[1066]: [2022-07-28 11:43:20.102] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:23 samual-pc krunner[1066]: [2022-07-28 11:43:23.105] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:26 samual-pc krunner[1066]: [2022-07-28 11:43:26.108] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:29 samual-pc krunner[1066]: [2022-07-28 11:43:29.112] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:32 samual-pc krunner[1066]: [2022-07-28 11:43:32.115] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:35 samual-pc krunner[1066]: [2022-07-28 11:43:35.118] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:38 samual-pc krunner[1066]: [2022-07-28 11:43:38.122] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:41 samual-pc krunner[1066]: [2022-07-28 11:43:41.125] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:44 samual-pc krunner[1066]: [2022-07-28 11:43:44.128] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:47 samual-pc krunner[1066]: [2022-07-28 11:43:47.132] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:50 samual-pc krunner[1066]: [2022-07-28 11:43:50.135] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:53 samual-pc krunner[1066]: [2022-07-28 11:43:53.138] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:56 samual-pc krunner[1066]: [2022-07-28 11:43:56.142] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:43:59 samual-pc krunner[1066]: [2022-07-28 11:43:59.145] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:02 samual-pc krunner[1066]: [2022-07-28 11:44:02.149] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:05 samual-pc krunner[1066]: [2022-07-28 11:44:05.151] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:08 samual-pc krunner[1066]: [2022-07-28 11:44:08.155] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:11 samual-pc krunner[1066]: [2022-07-28 11:44:11.158] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:14 samual-pc krunner[1066]: [2022-07-28 11:44:14.162] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:14 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:44:17 samual-pc krunner[1066]: [2022-07-28 11:44:17.165] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:20 samual-pc krunner[1066]: [2022-07-28 11:44:20.168] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:23 samual-pc krunner[1066]: [2022-07-28 11:44:23.172] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:26 samual-pc krunner[1066]: [2022-07-28 11:44:26.175] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:29 samual-pc krunner[1066]: [2022-07-28 11:44:29.178] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:32 samual-pc krunner[1066]: [2022-07-28 11:44:32.181] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:35 samual-pc krunner[1066]: [2022-07-28 11:44:35.185] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:38 samual-pc krunner[1066]: [2022-07-28 11:44:38.188] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:41 samual-pc krunner[1066]: [2022-07-28 11:44:41.192] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:44 samual-pc krunner[1066]: [2022-07-28 11:44:44.195] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:47 samual-pc krunner[1066]: [2022-07-28 11:44:47.198] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:50 samual-pc krunner[1066]: [2022-07-28 11:44:50.202] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:53 samual-pc krunner[1066]: [2022-07-28 11:44:53.205] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:56 samual-pc krunner[1066]: [2022-07-28 11:44:56.208] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:44:59 samual-pc krunner[1066]: [2022-07-28 11:44:59.212] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:02 samual-pc krunner[1066]: [2022-07-28 11:45:02.215] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:05 samual-pc krunner[1066]: [2022-07-28 11:45:05.218] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:08 samual-pc krunner[1066]: [2022-07-28 11:45:08.222] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:11 samual-pc krunner[1066]: [2022-07-28 11:45:11.225] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:14 samual-pc krunner[1066]: [2022-07-28 11:45:14.228] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:16 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:45:17 samual-pc krunner[1066]: [2022-07-28 11:45:17.231] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:20 samual-pc krunner[1066]: [2022-07-28 11:45:20.235] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:23 samual-pc krunner[1066]: [2022-07-28 11:45:23.238] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:26 samual-pc krunner[1066]: [2022-07-28 11:45:26.242] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:29 samual-pc krunner[1066]: [2022-07-28 11:45:29.248] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:32 samual-pc krunner[1066]: [2022-07-28 11:45:32.251] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:35 samual-pc krunner[1066]: [2022-07-28 11:45:35.255] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:38 samual-pc NetworkManager[448]: <info> [1659005138.0067] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:45:38 samual-pc krunner[1066]: [2022-07-28 11:45:38.258] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:41 samual-pc krunner[1066]: [2022-07-28 11:45:41.262] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:44 samual-pc krunner[1066]: [2022-07-28 11:45:44.265] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:47 samual-pc krunner[1066]: [2022-07-28 11:45:47.268] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:50 samual-pc krunner[1066]: [2022-07-28 11:45:50.271] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:53 samual-pc krunner[1066]: [2022-07-28 11:45:53.274] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:56 samual-pc krunner[1066]: [2022-07-28 11:45:56.275] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:45:59 samual-pc krunner[1066]: [2022-07-28 11:45:59.278] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:02 samual-pc krunner[1066]: [2022-07-28 11:46:02.279] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:05 samual-pc krunner[1066]: [2022-07-28 11:46:05.282] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:08 samual-pc krunner[1066]: [2022-07-28 11:46:08.285] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:11 samual-pc krunner[1066]: [2022-07-28 11:46:11.288] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:14 samual-pc krunner[1066]: [2022-07-28 11:46:14.292] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:17 samual-pc krunner[1066]: [2022-07-28 11:46:17.295] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:19 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:46:20 samual-pc krunner[1066]: [2022-07-28 11:46:20.298] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:23 samual-pc krunner[1066]: [2022-07-28 11:46:23.302] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:26 samual-pc krunner[1066]: [2022-07-28 11:46:26.305] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:29 samual-pc krunner[1066]: [2022-07-28 11:46:29.308] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:32 samual-pc krunner[1066]: [2022-07-28 11:46:32.312] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:35 samual-pc krunner[1066]: [2022-07-28 11:46:35.315] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:38 samual-pc krunner[1066]: [2022-07-28 11:46:38.318] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:41 samual-pc krunner[1066]: [2022-07-28 11:46:41.322] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:44 samual-pc krunner[1066]: [2022-07-28 11:46:44.325] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:47 samual-pc krunner[1066]: [2022-07-28 11:46:47.328] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:50 samual-pc krunner[1066]: [2022-07-28 11:46:50.332] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:53 samual-pc krunner[1066]: [2022-07-28 11:46:53.335] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:56 samual-pc krunner[1066]: [2022-07-28 11:46:56.338] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:46:59 samual-pc krunner[1066]: [2022-07-28 11:46:59.342] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:02 samual-pc krunner[1066]: [2022-07-28 11:47:02.345] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:05 samual-pc krunner[1066]: [2022-07-28 11:47:05.348] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:08 samual-pc krunner[1066]: [2022-07-28 11:47:08.352] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:11 samual-pc krunner[1066]: [2022-07-28 11:47:11.355] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:14 samual-pc krunner[1066]: [2022-07-28 11:47:14.358] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:17 samual-pc krunner[1066]: [2022-07-28 11:47:17.362] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:19 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:47:20 samual-pc krunner[1066]: [2022-07-28 11:47:20.365] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:23 samual-pc krunner[1066]: [2022-07-28 11:47:23.368] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:26 samual-pc krunner[1066]: [2022-07-28 11:47:26.372] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:29 samual-pc krunner[1066]: [2022-07-28 11:47:29.375] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:143): *** OnDevicesChanged:
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:144): * audioInput:
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:147): - default: Razer Barracuda X Mono ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:147): - Razer Barracuda X Mono ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:147): - Built-in Audio Analog Stereo ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:149): * audioOutput:
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:152): - default: Razer Barracuda X Analog Stereo ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:152): - Razer Barracuda X Analog Stereo ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.735] [1082] (engine.cpp:152): - Built-in Audio Analog Stereo ()
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.738] [1082] (audio_engine.cpp:156): Setting audio output device: 'default'
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.738] [1082] (audio_device_impl.cc:821): PlayoutIsInitialized
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.738] [1082] (audio_device_impl.cc:709): SetPlayoutDevice(0)
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.739] [1082] (audio_device_impl.cc:613): StereoPlayoutIsAvailable
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.739] [1082] (audio_mixer_manager_pulse_linux.cc:189): SpeakerIsInitialized
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.740] [1082] (audio_device_impl.cc:620): output: 1
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.740] [1082] (audio_device_impl.cc:625): SetStereoPlayout(1)
Jul 28 11:47:30 samual-pc krunner[1066]: [2022-07-28 11:47:30.740] [1082] (audio_device_buffer.cc:206): SetPlayoutChannels(2)
Jul 28 11:47:32 samual-pc krunner[1066]: [2022-07-28 11:47:32.378] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:35 samual-pc krunner[1066]: [2022-07-28 11:47:35.382] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:38 samual-pc krunner[1066]: [2022-07-28 11:47:38.385] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:41 samual-pc krunner[1066]: [2022-07-28 11:47:41.388] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:44 samual-pc krunner[1066]: [2022-07-28 11:47:44.392] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:47 samual-pc krunner[1066]: [2022-07-28 11:47:47.395] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:50 samual-pc krunner[1066]: [2022-07-28 11:47:50.398] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:53 samual-pc krunner[1066]: [2022-07-28 11:47:53.401] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:56 samual-pc krunner[1066]: [2022-07-28 11:47:56.405] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:47:59 samual-pc krunner[1066]: [2022-07-28 11:47:59.408] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:02 samual-pc krunner[1066]: [2022-07-28 11:48:02.412] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:05 samual-pc krunner[1066]: [2022-07-28 11:48:05.415] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:08 samual-pc krunner[1066]: [2022-07-28 11:48:08.418] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:11 samual-pc krunner[1066]: [2022-07-28 11:48:11.421] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:14 samual-pc krunner[1066]: [2022-07-28 11:48:14.424] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:17 samual-pc krunner[1066]: [2022-07-28 11:48:17.425] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:19 samual-pc rtkit-daemon[663]: Supervising 11 threads of 6 processes of 1 users.
Jul 28 11:48:20 samual-pc krunner[1066]: [2022-07-28 11:48:20.428] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:23 samual-pc krunner[1066]: [2022-07-28 11:48:23.432] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:26 samual-pc krunner[1066]: [2022-07-28 11:48:26.435] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:29 samual-pc krunner[1066]: [2022-07-28 11:48:29.438] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:32 samual-pc krunner[1066]: [2022-07-28 11:48:32.442] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:35 samual-pc krunner[1066]: [2022-07-28 11:48:35.445] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:38 samual-pc krunner[1066]: [2022-07-28 11:48:38.448] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:41 samual-pc krunner[1066]: [2022-07-28 11:48:41.452] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:44 samual-pc krunner[1066]: [2022-07-28 11:48:44.455] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:47 samual-pc krunner[1066]: [2022-07-28 11:48:47.458] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:50 samual-pc krunner[1066]: [2022-07-28 11:48:50.461] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:53 samual-pc krunner[1066]: [2022-07-28 11:48:53.465] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:56 samual-pc krunner[1066]: [2022-07-28 11:48:56.468] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:59 samual-pc krunner[1066]: [2022-07-28 11:48:59.471] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:48:59 samual-pc rtkit-daemon[663]: Supervising 11 threads of 6 processes of 1 users.
Jul 28 11:49:02 samual-pc krunner[1066]: [2022-07-28 11:49:02.473] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:05 samual-pc krunner[1066]: [2022-07-28 11:49:05.475] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:08 samual-pc krunner[1066]: [2022-07-28 11:49:08.478] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:11 samual-pc krunner[1066]: [2022-07-28 11:49:11.482] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:14 samual-pc krunner[1066]: [2022-07-28 11:49:14.485] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:17 samual-pc krunner[1066]: [2022-07-28 11:49:17.488] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:20 samual-pc krunner[1066]: [2022-07-28 11:49:20.491] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:23 samual-pc krunner[1066]: [2022-07-28 11:49:23.495] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:26 samual-pc krunner[1066]: [2022-07-28 11:49:26.498] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:29 samual-pc krunner[1066]: [2022-07-28 11:49:29.501] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:32 samual-pc krunner[1066]: [2022-07-28 11:49:32.505] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:35 samual-pc krunner[1066]: [2022-07-28 11:49:35.508] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:38 samual-pc krunner[1066]: [2022-07-28 11:49:38.511] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:41 samual-pc krunner[1066]: [2022-07-28 11:49:41.515] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:44 samual-pc krunner[1066]: [2022-07-28 11:49:44.518] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:47 samual-pc krunner[1066]: [2022-07-28 11:49:47.522] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:50 samual-pc krunner[1066]: [2022-07-28 11:49:50.525] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:53 samual-pc krunner[1066]: [2022-07-28 11:49:53.528] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:56 samual-pc krunner[1066]: [2022-07-28 11:49:56.531] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:49:59 samual-pc krunner[1066]: [2022-07-28 11:49:59.535] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:01 samual-pc rtkit-daemon[663]: Supervising 11 threads of 6 processes of 1 users.
Jul 28 11:50:02 samual-pc krunner[1066]: [2022-07-28 11:50:02.538] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:05 samual-pc krunner[1066]: [2022-07-28 11:50:05.538] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:08 samual-pc krunner[1066]: [2022-07-28 11:50:08.541] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:11 samual-pc krunner[1066]: [2022-07-28 11:50:11.545] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:14 samual-pc krunner[1066]: [2022-07-28 11:50:14.548] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:16 samual-pc rtkit-daemon[663]: Supervising 11 threads of 6 processes of 1 users.
Jul 28 11:50:16 samual-pc rtkit-daemon[663]: Successfully made thread 8877 of process 650 owned by '1000' RT at priority 5.
Jul 28 11:50:16 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:143): *** OnDevicesChanged:
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:144): * audioInput:
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:147): - default: Razer Barracuda X Mono ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:147): - Razer Barracuda X Mono ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:147): - Built-in Audio Analog Stereo ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:149): * audioOutput:
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:152): - default: Razer Barracuda X Analog Stereo ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:152): - Razer Barracuda X Analog Stereo ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:152): - Built-in Audio Analog Stereo ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.832] [1082] (engine.cpp:152): - GP106 High Definition Audio Controller Digital Stereo (HDMI) ()
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_engine.cpp:156): Setting audio output device: 'default'
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_impl.cc:821): PlayoutIsInitialized
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_impl.cc:709): SetPlayoutDevice(0)
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_impl.cc:613): StereoPlayoutIsAvailable
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_mixer_manager_pulse_linux.cc:189): SpeakerIsInitialized
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_impl.cc:620): output: 1
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_impl.cc:625): SetStereoPlayout(1)
Jul 28 11:50:16 samual-pc krunner[1066]: [2022-07-28 11:50:16.833] [1082] (audio_device_buffer.cc:206): SetPlayoutChannels(2)
Jul 28 11:50:17 samual-pc krunner[1066]: [2022-07-28 11:50:17.551] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:20 samual-pc krunner[1066]: [2022-07-28 11:50:20.554] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:21 samual-pc dbus-daemon[422]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.278' (uid=1000 pid=8886 comm="kcheckpass -m classic -S 66")
Jul 28 11:50:21 samual-pc dbus-daemon[422]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jul 28 11:50:21 samual-pc kcheckpass[8886]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 28 11:50:21 samual-pc audit[8889]: USER_AUTH pid=8889 uid=1000 auid=1000 ses=1 msg='op=PAM:unix_chkpwd acct="samual" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jul 28 11:50:21 samual-pc kernel: audit: type=1100 audit(1659005421.149:98): pid=8889 uid=1000 auid=1000 ses=1 msg='op=PAM:unix_chkpwd acct="samual" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Jul 28 11:50:21 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31021, resource id: 104857640, major code: 18 (ChangeProperty), minor code: 0
Jul 28 11:50:23 samual-pc krunner[1066]: [2022-07-28 11:50:23.555] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:26 samual-pc krunner[1066]: [2022-07-28 11:50:26.556] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:29 samual-pc krunner[1066]: [2022-07-28 11:50:29.558] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:32 samual-pc krunner[1066]: [2022-07-28 11:50:32.560] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:35 samual-pc krunner[1066]: [2022-07-28 11:50:35.561] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:38 samual-pc NetworkManager[448]: <info> [1659005438.0039] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:50:38 samual-pc kwin_x11[559]: org.kde.bismuth: onCurrentSurfaceChanged,[object Object]
Jul 28 11:50:38 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:50:38 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:50:38 samual-pc krunner[1066]: [2022-07-28 11:50:38.563] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:39 samual-pc kwin_x11[559]: org.kde.bismuth: onCurrentSurfaceChanged,[object Object]
Jul 28 11:50:39 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:50:39 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:50:40 samual-pc kwin_x11[559]: org.kde.bismuth: onCurrentSurfaceChanged,[object Object]
Jul 28 11:50:40 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:50:40 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:50:41 samual-pc krunner[1066]: [2022-07-28 11:50:41.565] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:41 samual-pc kglobalaccel5[8905]: kstart: Unknown options: profile-directory, app-id.
Jul 28 11:50:44 samual-pc krunner[1066]: [2022-07-28 11:50:44.568] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:45 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd8bd970)
Jul 28 11:50:45 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:50:45 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:50:45 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:50:45 samual-pc kwin_x11[559]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x5635fd8bd970)
Jul 28 11:50:47 samual-pc krunner[1066]: [2022-07-28 11:50:47.571] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:48 samual-pc systemd[492]: Started YouTube Music.
Jul 28 11:50:48 samual-pc dbus-daemon[422]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.279' (uid=1000 pid=8921 comm="/opt/google/chrome/chrome --profile-directory=Defa")
Jul 28 11:50:48 samual-pc systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Jul 28 11:50:48 samual-pc krunner[8926]: [8963:8963:0728/115048.858504:ERROR:vaapi_wrapper.cc(1139)] vaQuerySurfaceAttributes failed, VA error: invalid parameter
Jul 28 11:50:48 samual-pc krunner[8926]: [8963:8963:0728/115048.864179:ERROR:vaapi_wrapper.cc(1086)] FillProfileInfo_Locked failed for va_profile VAProfileH264Main and entrypoint VAEntrypointVLD
Jul 28 11:50:48 samual-pc krunner[8926]: [8963:8963:0728/115048.869006:ERROR:vaapi_wrapper.cc(1139)] vaQuerySurfaceAttributes failed, VA error: invalid parameter
Jul 28 11:50:48 samual-pc krunner[8926]: [8963:8963:0728/115048.869076:ERROR:vaapi_wrapper.cc(1086)] FillProfileInfo_Locked failed for va_profile VAProfileH264High and entrypoint VAEntrypointVLD
Jul 28 11:50:49 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fda14a20)
Jul 28 11:50:49 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:50:49 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:50:49 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:50:49 samual-pc kwin_x11[559]: org.kde.bismuth: Client is ok, can manage. Bind events now...
Jul 28 11:50:50 samual-pc krunner[1066]: [2022-07-28 11:50:50.575] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:53 samual-pc krunner[1066]: [2022-07-28 11:50:53.578] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:56 samual-pc krunner[1066]: [2022-07-28 11:50:56.578] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:50:59 samual-pc krunner[1066]: [2022-07-28 11:50:59.580] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:02 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:51:02 samual-pc krunner[1066]: [2022-07-28 11:51:02.583] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:05 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd90ab10)
Jul 28 11:51:05 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:51:05 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:51:05 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:51:05 samual-pc kwin_x11[559]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x5635fd90ab10)
Jul 28 11:51:05 samual-pc krunner[1066]: [2022-07-28 11:51:05.585] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:08 samual-pc krunner[1066]: [2022-07-28 11:51:08.588] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:11 samual-pc krunner[1066]: [2022-07-28 11:51:11.591] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:13 samual-pc dbus-daemon[422]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jul 28 11:51:14 samual-pc krunner[1066]: [2022-07-28 11:51:14.591] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:15 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:51:17 samual-pc krunner[1066]: [2022-07-28 11:51:17.595] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:17 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:51:20 samual-pc krunner[1066]: [2022-07-28 11:51:20.598] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:23 samual-pc krunner[1066]: [2022-07-28 11:51:23.598] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:26 samual-pc krunner[1066]: [2022-07-28 11:51:26.601] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:29 samual-pc krunner[1066]: [2022-07-28 11:51:29.603] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:32 samual-pc krunner[1066]: [2022-07-28 11:51:32.605] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:35 samual-pc krunner[1066]: [2022-07-28 11:51:35.608] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:38 samual-pc krunner[1066]: [2022-07-28 11:51:38.610] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:38 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:51:41 samual-pc krunner[1066]: [2022-07-28 11:51:41.612] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:43 samual-pc krunner[9305]: [2022-07-28T10:51:43Z ERROR mp4parse] Found 2 nul bytes in "\0\0"
Jul 28 11:51:43 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:51:44 samual-pc krunner[1066]: [2022-07-28 11:51:44.615] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:47 samual-pc krunner[1066]: [2022-07-28 11:51:47.618] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:50 samual-pc krunner[1066]: [2022-07-28 11:51:50.621] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:53 samual-pc krunner[1066]: [2022-07-28 11:51:53.624] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:56 samual-pc krunner[1066]: [2022-07-28 11:51:56.625] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:51:59 samual-pc krunner[1066]: [2022-07-28 11:51:59.628] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:02 samual-pc plasmashell[636]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e533f62400) QQmlContext(0x55e531c78b20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 28 11:52:02 samual-pc plasmashell[636]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 28 11:52:02 samual-pc plasmashell[636]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 28 11:52:02 samual-pc plasmashell[636]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Jul 28 11:52:02 samual-pc plasmashell[636]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Jul 28 11:52:02 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd90ab10)
Jul 28 11:52:02 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:52:02 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:52:02 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:52:02 samual-pc kwin_x11[559]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x5635fd90ab10)
Jul 28 11:52:02 samual-pc krunner[1066]: [2022-07-28 11:52:02.630] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:03 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:52:05 samual-pc krunner[1066]: [2022-07-28 11:52:05.632] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:07 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62347, resource id: 44040368, major code: 15 (QueryTree), minor code: 0
Jul 28 11:52:08 samual-pc krunner[1066]: [2022-07-28 11:52:08.635] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:11 samual-pc krunner[1066]: [2022-07-28 11:52:11.638] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:14 samual-pc krunner[1066]: [2022-07-28 11:52:14.641] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:17 samual-pc krunner[1066]: [2022-07-28 11:52:17.643] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:17 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:52:20 samual-pc krunner[1066]: [2022-07-28 11:52:20.645] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:21 samual-pc plasmashell[636]: libkcups: Renew-Subscription last error: 0 successful-ok
Jul 28 11:52:23 samual-pc rtkit-daemon[663]: Supervising 12 threads of 6 processes of 1 users.
Jul 28 11:52:23 samual-pc rtkit-daemon[663]: Successfully made thread 9638 of process 9393 owned by '1000' RT at priority 10.
Jul 28 11:52:23 samual-pc rtkit-daemon[663]: Supervising 13 threads of 7 processes of 1 users.
Jul 28 11:52:23 samual-pc krunner[1066]: [2022-07-28 11:52:23.648] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:26 samual-pc krunner[1066]: [2022-07-28 11:52:26.651] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:29 samual-pc krunner[1066]: [2022-07-28 11:52:29.652] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:32 samual-pc krunner[1066]: [2022-07-28 11:52:32.655] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:35 samual-pc krunner[1066]: [2022-07-28 11:52:35.657] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:38 samual-pc krunner[1066]: [2022-07-28 11:52:38.660] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:41 samual-pc krunner[1066]: [2022-07-28 11:52:41.661] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:44 samual-pc krunner[1066]: [2022-07-28 11:52:44.663] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:47 samual-pc krunner[1066]: [2022-07-28 11:52:47.665] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:50 samual-pc krunner[1066]: [2022-07-28 11:52:50.668] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:53 samual-pc krunner[1066]: [2022-07-28 11:52:53.668] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:56 samual-pc kstart5[9649]: Omitting both --window and --windowclass arguments is not recommended
Jul 28 11:52:56 samual-pc systemd[492]: Started alacritty.
Jul 28 11:52:56 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9843, resource id: 121634825, major code: 18 (ChangeProperty), minor code: 0
Jul 28 11:52:56 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd90ab10)
Jul 28 11:52:56 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:52:56 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:52:56 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:52:56 samual-pc kwin_x11[559]: org.kde.bismuth: Client is ok, can manage. Bind events now...
Jul 28 11:52:56 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10135, resource id: 14918722, major code: 3 (GetWindowAttributes), minor code: 0
Jul 28 11:52:56 samual-pc kwin_x11[559]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 10136, resource id: 14918722, major code: 14 (GetGeometry), minor code: 0
Jul 28 11:52:56 samual-pc krunner[1066]: [2022-07-28 11:52:56.671] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:52:59 samual-pc krunner[1066]: [2022-07-28 11:52:59.675] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:02 samual-pc krunner[1066]: [2022-07-28 11:53:02.678] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:05 samual-pc krunner[1066]: [2022-07-28 11:53:05.678] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:08 samual-pc krunner[1066]: [2022-07-28 11:53:08.681] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:11 samual-pc krunner[1066]: [2022-07-28 11:53:11.685] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:14 samual-pc krunner[1066]: [2022-07-28 11:53:14.688] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:17 samual-pc krunner[1066]: [2022-07-28 11:53:17.688] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:20 samual-pc krunner[1066]: [2022-07-28 11:53:20.690] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:23 samual-pc krunner[1066]: [2022-07-28 11:53:23.691] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:26 samual-pc krunner[1066]: [2022-07-28 11:53:26.693] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:29 samual-pc krunner[1066]: [2022-07-28 11:53:29.695] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:32 samual-pc krunner[1066]: [2022-07-28 11:53:32.698] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:35 samual-pc krunner[1066]: [2022-07-28 11:53:35.701] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:38 samual-pc krunner[1066]: [2022-07-28 11:53:38.705] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:41 samual-pc krunner[1066]: [2022-07-28 11:53:41.708] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:44 samual-pc krunner[1066]: [2022-07-28 11:53:44.708] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:47 samual-pc krunner[1066]: [2022-07-28 11:53:47.712] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:50 samual-pc krunner[1066]: [2022-07-28 11:53:50.713] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:53 samual-pc krunner[1066]: [2022-07-28 11:53:53.715] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:56 samual-pc krunner[1066]: [2022-07-28 11:53:56.718] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:53:59 samual-pc krunner[1066]: [2022-07-28 11:53:59.718] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:02 samual-pc krunner[1066]: [2022-07-28 11:54:02.721] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:05 samual-pc krunner[1066]: [2022-07-28 11:54:05.725] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:08 samual-pc krunner[1066]: [2022-07-28 11:54:08.725] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:11 samual-pc krunner[1066]: [2022-07-28 11:54:11.728] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:14 samual-pc krunner[1066]: [2022-07-28 11:54:14.731] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:17 samual-pc krunner[1066]: [2022-07-28 11:54:17.734] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:20 samual-pc krunner[1066]: [2022-07-28 11:54:20.738] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:23 samual-pc krunner[1066]: [2022-07-28 11:54:23.741] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:26 samual-pc krunner[1066]: [2022-07-28 11:54:26.741] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:29 samual-pc krunner[1066]: [2022-07-28 11:54:29.745] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:32 samual-pc krunner[1066]: [2022-07-28 11:54:32.748] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:35 samual-pc krunner[1066]: [2022-07-28 11:54:35.748] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:38 samual-pc krunner[1066]: [2022-07-28 11:54:38.751] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:41 samual-pc krunner[1066]: [2022-07-28 11:54:41.755] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:44 samual-pc krunner[1066]: [2022-07-28 11:54:44.755] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:47 samual-pc krunner[1066]: [2022-07-28 11:54:47.758] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:50 samual-pc krunner[1066]: [2022-07-28 11:54:50.760] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:53 samual-pc krunner[1066]: [2022-07-28 11:54:53.761] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:56 samual-pc krunner[1066]: [2022-07-28 11:54:56.765] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:54:59 samual-pc krunner[1066]: [2022-07-28 11:54:59.768] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:02 samual-pc krunner[1066]: [2022-07-28 11:55:02.768] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:05 samual-pc krunner[1066]: [2022-07-28 11:55:05.771] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:08 samual-pc krunner[1066]: [2022-07-28 11:55:08.775] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:11 samual-pc krunner[1066]: [2022-07-28 11:55:11.778] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:14 samual-pc krunner[1066]: [2022-07-28 11:55:14.781] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:17 samual-pc krunner[1066]: [2022-07-28 11:55:17.782] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:20 samual-pc krunner[1066]: [2022-07-28 11:55:20.785] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:23 samual-pc krunner[1066]: [2022-07-28 11:55:23.788] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:26 samual-pc krunner[1066]: [2022-07-28 11:55:26.791] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:29 samual-pc krunner[1066]: [2022-07-28 11:55:29.794] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:32 samual-pc krunner[1066]: [2022-07-28 11:55:32.795] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:35 samual-pc krunner[1066]: [2022-07-28 11:55:35.798] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:38 samual-pc NetworkManager[448]: <info> [1659005738.0027] dhcp4 (enp3s0): state changed new lease, address=10.0.0.34
Jul 28 11:55:38 samual-pc krunner[1066]: [2022-07-28 11:55:38.801] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:41 samual-pc krunner[1066]: [2022-07-28 11:55:41.803] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:44 samual-pc krunner[1066]: [2022-07-28 11:55:44.806] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:47 samual-pc krunner[1066]: [2022-07-28 11:55:47.808] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:50 samual-pc krunner[1066]: [2022-07-28 11:55:50.811] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:53 samual-pc krunner[1066]: [2022-07-28 11:55:53.815] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:56 samual-pc krunner[1066]: [2022-07-28 11:55:56.815] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:55:59 samual-pc krunner[1066]: [2022-07-28 11:55:59.818] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:02 samual-pc krunner[1066]: [2022-07-28 11:56:02.821] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:05 samual-pc krunner[1066]: [2022-07-28 11:56:05.824] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:08 samual-pc krunner[1066]: [2022-07-28 11:56:08.825] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:11 samual-pc krunner[1066]: [2022-07-28 11:56:11.828] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:14 samual-pc krunner[1066]: [2022-07-28 11:56:14.831] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:17 samual-pc krunner[1066]: [2022-07-28 11:56:17.831] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:20 samual-pc krunner[1066]: [2022-07-28 11:56:20.834] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:23 samual-pc krunner[1066]: [2022-07-28 11:56:23.835] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:26 samual-pc krunner[1066]: [2022-07-28 11:56:26.838] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:29 samual-pc krunner[1066]: [2022-07-28 11:56:29.839] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:32 samual-pc krunner[1066]: [2022-07-28 11:56:32.841] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:35 samual-pc krunner[1066]: [2022-07-28 11:56:35.843] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:38 samual-pc krunner[1066]: [2022-07-28 11:56:38.845] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:41 samual-pc krunner[1066]: [2022-07-28 11:56:41.848] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:44 samual-pc krunner[1066]: [2022-07-28 11:56:44.851] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:47 samual-pc krunner[1066]: [2022-07-28 11:56:47.851] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:50 samual-pc krunner[1066]: [2022-07-28 11:56:50.855] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:53 samual-pc krunner[1066]: [2022-07-28 11:56:53.858] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:56 samual-pc krunner[1066]: [2022-07-28 11:56:56.861] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:56:59 samual-pc krunner[1066]: [2022-07-28 11:56:59.861] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:02 samual-pc krunner[1066]: [2022-07-28 11:57:02.865] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:05 samual-pc krunner[1066]: [2022-07-28 11:57:05.868] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:08 samual-pc krunner[1066]: [2022-07-28 11:57:08.868] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:09 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd9339e0)
Jul 28 11:57:09 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:57:09 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:57:09 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:57:09 samual-pc kwin_x11[559]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x5635fd9339e0)
Jul 28 11:57:11 samual-pc krunner[1066]: [2022-07-28 11:57:11.869] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:13 samual-pc kwin_x11[559]: org.kde.bismuth: Client added: KWin::X11Client(0x5635fd9a9d70)
Jul 28 11:57:13 samual-pc kwin_x11[559]: org.kde.bismuth: onWindowAdded,[object Object]
Jul 28 11:57:13 samual-pc kwin_x11[559]: org.kde.bismuth: arrange
Jul 28 11:57:13 samual-pc kwin_x11[559]: org.kde.bismuth: arrangeScreen/finished,[object Object]
Jul 28 11:57:13 samual-pc kwin_x11[559]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Client(0x5635fd9a9d70)
Jul 28 11:57:14 samual-pc krunner[1066]: [2022-07-28 11:57:14.871] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:17 samual-pc krunner[1066]: [2022-07-28 11:57:17.875] [1083] (device_info_linux.cc:45): NumberOfDevices
Jul 28 11:57:18 samual-pc NetworkManager[448]: <info> [1659005838.0985] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jul 28 11:57:18 samual-pc ModemManager[457]: <info> [sleep-monitor] system is about to suspend
Jul 28 11:57:18 samual-pc NetworkManager[448]: <info> [1659005838.0986] manager: NetworkManager state is now ASLEEP
Jul 28 11:57:18 samual-pc kscreenlocker_greet[9891]: Qt: Session management error: networkIdsList argument is NULL
Jul 28 11:57:19 samual-pc systemd[1]: Reached target Sleep.
Jul 28 11:57:19 samual-pc systemd[1]: Starting Hibernate...
Jul 28 11:57:19 samual-pc systemd-sleep[9909]: Entering sleep state 'hibernate'...
Jul 28 11:57:19 samual-pc kernel: PM: hibernation: hibernation entry
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:143): *** OnDevicesChanged:
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:144): * audioInput:
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:147): - default: Razer Barracuda X Mono ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:147): - Razer Barracuda X Mono ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:147): - Built-in Audio Analog Stereo ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:149): * audioOutput:
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:152): - default: Razer Barracuda X Analog Stereo ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:152): - Razer Barracuda X Analog Stereo ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.116] [1082] (engine.cpp:152): - Built-in Audio Analog Stereo ()
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.117] [1082] (audio_engine.cpp:156): Setting audio output device: 'default'
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.117] [1082] (audio_device_impl.cc:821): PlayoutIsInitialized
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.117] [1082] (audio_device_impl.cc:709): SetPlayoutDevice(0)
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.117] [1082] (audio_device_impl.cc:613): StereoPlayoutIsAvailable
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.117] [1082] (audio_mixer_manager_pulse_linux.cc:189): SpeakerIsInitialized
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.118] [1082] (audio_device_impl.cc:620): output: 1
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.118] [1082] (audio_device_impl.cc:625): SetStereoPlayout(1)
Jul 28 11:57:20 samual-pc krunner[1066]: [2022-07-28 11:57:20.118] [1082] (audio_device_buffer.cc:206): SetPlayoutChannels(2)
btw I don’t know if this helps but I probably should have mentioned it already, it’s less that the screens are black and more that they’re complaining that they’re not recieving signal
