Completely borked my video drivers
Hello all,
I have a bit of a problem with video drivers on manjaro kde (latestes updates, kernel 5.12). I had a setup with two video cards, one Radeon RX580 and one Nvidia model (forgot the exact one). The main vga was nvidia, while the radeon one was isolated at startup and passthrough to a windows VM.
I had removed the Nvidia card because I had to give it away and I am now left with the radeon one and tried to switch to the radeon drivers, by removing all the nvidia ones and installing the radeon drivers. But for some reason all I get on screen is an image formed of very fine RGB lines and nothing else.
here is some system info (let me know if I should add more):
# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
02:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
02:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
02:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
02:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
04:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
04:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
05:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev e7)
07:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
09:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
09:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
09:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
# inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=4dc1d8c7-f61a-4136-a047-b291f6b63b0d rw quiet apparmor=1
  security=apparmor amd_iommu=on iommu=pt
  Console: tty pts/0 DM: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: N/A
  Mobo: Gigabyte model: X570 AORUS ELITE serial: N/A
  UEFI: American Megatrends LLC. v: F33g date: 03/25/2021
  RAM: total: 31.3 GiB used: 764.5 MiB (2.4%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
  note: est.
  Device-1: DIMM 0 size: No Module Installed
  Device-2: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
  detail: synchronous unbuffered (unregistered) bus-width: 64 bits
  total: 64 bits manufacturer: G.Skill part-no: F4-3600C16-16GTZRC serial: N/A
  Device-3: DIMM 0 size: No Module Installed
  Device-4: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
  Info: 8-Core model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP
  arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: 0
  microcode: 8701021 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB bogomips: 115016
  Speed: 3591 MHz min/max: 2200/3600 MHz base/boost: 3600/4400 boost: enabled
  volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 3591 2: 2052 3: 2051
  4: 2052 5: 2195 6: 2194 7: 2195 8: 2196 9: 2051 10: 2053 11: 2193 12: 2193
  13: 2194 14: 2193 15: 3588 16: 2053
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
  vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
  xsaveopt xsaves
  conditional, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 07:00.0
  chip-ID: 1002:67df class-ID: 0300
  Device-2: HP HP Webcam 3100 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-3.4.4:7 chip-ID: 03f0:8e07 class-ID: 0102
  Display: server: X.org 1.20.11 driver: loaded: radeon,vesa alternate: nvidia
  tty: 232x56
  Message: Advanced graphics data unavailable in console for root.
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 07:00.1
  chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-3: HP HP Webcam 3100 type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
  port: f000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF-ID-1: virbr0 state: down mac: <filter>
  ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
  uuid: 087CD7547CD73B60
  ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 237.41 GiB fs: ntfs label: system
  uuid: 01D29F758FED0170
  ID-4: /dev/sda5 maj-min: 8:5 size: 527 MiB fs: ntfs label: N/A
  uuid: 58CA1DC6CA1DA0F4
  ID-5: /dev/sdb1 maj-min: 8:17 size: 1.3 TiB fs: ntfs label: data
  uuid: 7E68087968083287
  ID-6: /dev/sdb2 maj-min: 8:18 size: 529.15 GiB fs: ntfs label: media
  uuid: 01D59F18520071D0
  ID-7: /dev/sdf1 maj-min: 8:81 size: 3.72 GiB fs: N/A label: ventoy
  uuid: 7620-851E
  ID-8: /dev/sdf2 maj-min: 8:82 size: 32 MiB fs: N/A label: VTOYEFI
  uuid: 9FB4-70F2
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-3: 1-3.4:4 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
  Device-1: 1-3.4.1:5 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
  power: 100mA chip-ID: 258a:1006 class-ID: 0300
  Device-2: 1-3.4.2:6 info: Corsair M65 Gaming Mouse type: Mouse,Keyboard
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 1b1c:1b05 class-ID: 0300
  Device-3: 1-3.4.4:7 info: HP HP Webcam 3100 type: Video,Audio
  power: 250mA chip-ID: 03f0:8e07 class-ID: 0102
  Device-4: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
  type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
  Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-6: 3-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-9: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  power: 500mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 5-3.3:3 info: Corsair UFD type: Mass Storage driver: usb-storage
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1b1c:0a10
  class-ID: 0806 serial: <filter>
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-11: 6-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  chip-ID: 05e3:0612 class-ID: 0900
  Device-1: 6-4:3 info: SanDisk SDDR-489 ImageMate Pro Reader
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
  power: 896mA chip-ID: 0781:cfc9 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 37.1 C mobo: 16.8 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 823
  Processes: 301 Uptime: 10m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: 1591 pacman: 1588 lib: 435
  flatpak: 0 snap: 3 Shell: Bash (su) v: 5.1.8 running-in: tty pts/0 (SSH)
  inxi: 3.3.04
I have used the following command to install the nonfree drivers for radeon:
mhwd -a pci nonfree 0300
Here is some more info:
# mhwd-gpu --status
:: status
  xorg configuration file: '/etc/X11/mhwd.d/vesa.conf'
# mhwd -li -d
   ATTACHED:    PCI
   VERSION:     2018.05.04
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
Not sure what other info I should add. Is there an easy-ish fix to this? or I have to reinstall?
Hello @luciandf :slight_smile:
Remove the vesa driver:
sudo mhwd -r video-vesa
Why did you install it?
because i thought it might fix the problem. it doesnā€™t work without it either
As megavolt has suggested, the vesa drivers are fallbacks for much older hardware
note: The mhwd profile ā€˜video-vesaā€™ is a generic fallback driver which should not be used in the vast majority of cases.
Here: Configure Graphics Cards - Manjaro
Try removing that driver, and you should be golden. If in doubt consult the documentation
ok give me a few mins and I will try again but as I said, I have tried without them too and it didnā€™t work. iā€™ll post again the results.
Also I have been reading the docs! :wink:
The Issue could be also the so called ā€œtiming issueā€, since you used nvidia as main before:
Just put amdgpu there.
OK i have removed the extra driver and modified the mkinicpio.conf but still no joy. However I have tracked down the issue with xorg.conf where I had these entries for some reason:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 460.39
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "DELL P2720DC"
    HorizSync       29.0 - 113.0
    VertRefresh     49.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 760"
EndSection
Section "Screen"
# Removed Option "metamodes" "DP-1.8: 2560x1440 +0+0, DVI-D-0: nvidia-auto-select +2560+0"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-3"
    Option         "metamodes" "DP-1.8: nvidia-auto-select +0+0, DVI-D-0: nvidia-auto-select +2560+0"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
I have tried startx from ssh and X started fine but with missing audio devices and in a default looking deskptop, not my old one with the icons and panels. So the question is, how do I regenerate the xorg.conf file?
I have tried X -configure and I got this:
# X -configure
X.Org X Server 1.20.11
Build Operating System: Linux Manjaro Linux
Current Operating System: Linux asgard 5.12.9-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:56:42 UTC 2021 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=4dc1d8c7-f61a-4136-a047-b291f6b63b0d rw quiet apparmor=1 security=apparmor amd_iommu=on iommu=pt
Build Date: 13 April 2021  04:11:08PM
Current version of pixman: 0.40.0
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 23 23:31:18 2021
List of video drivers:
        amdgpu
        ati
        intel
        nouveau
        radeon
        modesetting
(++) Using config file: "/root/xorg.conf.new"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(II) AMDGPU(0): [KMS] Kernel modesetting enabled.
(II) AMDGPU(1): [KMS] drm report modesetting isn't supported.
Xorg detected your mouse at device /dev/input/mice.
Please check your config if the mouse is still not
operational, as by default Xorg tries to autodetect
the protocol.
Xorg has configured a multihead system, please check your config.
Your xorg.conf file is /root/xorg.conf.new
To test the server, run 'X -config /root/xorg.conf.new'
(EE) Server terminated with error (2). Closing log file.
[asgard X11]# qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
And I donā€™t know what to make of it. Can anyone clarify this?
brainfart moment! changed the name of the xorg.conf file to xorg.conf.bkp and then restarted and bam! I got my deskptop back! wooohooo!
thank you all for your help!
@Marcoose777 @megavolt I think I spoke too soon. Now I get the desktop and everything is fine until it becomes idle. Then it doesnā€™t come back up and the lines from the beginning appear again and I have to restart. Also the fans go crazy when that happens.
I shall investigate further!
