Freeze on sleep
Every time I put my Laptop to sleep it freezes instantly, only the Networks Symbol in the taskbar changes to the Disconnected Symbol. The only way from there (as far as is know) is to shut down the system and restart it with the power button.
I have installed Manjaro one or two Weeks ago as Dual Boot on a HP Probook 455 G8 besides Win11 using this Guide.
I started using KDE Plasma X11 as DE and switched to Wayland after a friend of mine suggested it to fix my problem. It work for a day and now it keeps freezing again on sleep.
My system doesn’t have deep sleep:
cat /sys/power/mem_sleep
[s2idle]
Logs
journalctl --boot=-1
Dec 15 23:16:04 l30n-hpprobook systemd-logind[667]: The system will suspend now!
Dec 15 23:16:04 l30n-hpprobook NetworkManager[662]: <info>  [1734300964.8196] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Dec 15 23:16:04 l30n-hpprobook ModemManager[715]: <msg> [sleep-monitor-systemd] system is about to suspend
Dec 15 23:16:04 l30n-hpprobook NetworkManager[662]: <info>  [1734300964.8198] device (enp1s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Dec 15 23:16:04 l30n-hpprobook NetworkManager[662]: <info>  [1734300964.8328] manager: NetworkManager state is now ASLEEP
Dec 15 23:16:04 l30n-hpprobook NetworkManager[662]: <info>  [1734300964.8332] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
Dec 15 23:16:04 l30n-hpprobook kded6[1127]: org.kde.plasma.nm.kded: Unhandled active connection state change:  3
Dec 15 23:16:04 l30n-hpprobook systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 15 23:16:04 l30n-hpprobook systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 15 23:16:04 l30n-hpprobook kernel: wlp2s0: deauthenticating from 50:c7:bf:bb:fb:03 by local choice (Reason: 3=DEAUTH_LEAVING)
Dec 15 23:16:05 l30n-hpprobook wpa_supplicant[740]: nl80211: send_event_marker failed: Source based routing not supported
Dec 15 23:16:05 l30n-hpprobook wpa_supplicant[740]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=50:c7:bf:bb:fb:03 reason=3 locally_generated=1
Dec 15 23:16:05 l30n-hpprobook wpa_supplicant[740]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0936] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
Dec 15 23:16:05 l30n-hpprobook wpa_supplicant[740]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0944] dhcp4 (wlp2s0): canceled DHCP transaction
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0944] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0944] dhcp4 (wlp2s0): state changed no lease
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0948] dhcp6 (wlp2s0): canceled DHCP transaction
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0948] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.0948] dhcp6 (wlp2s0): state changed no lease
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.1141] device (wlp2s0): set-hw-addr: set MAC address to 0A:B9:3A:6A:87:BF (scanning)
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.4754] device (wlp2s0): supplicant interface state: completed -> disconnected
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.4756] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.4757] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.4764] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Dec 15 23:16:05 l30n-hpprobook plasmashell[1249]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
Dec 15 23:16:05 l30n-hpprobook NetworkManager[662]: <info>  [1734300965.7639] device (wlp2s0): set-hw-addr: reset MAC address to CC:6B:1E:49:EE:DB (unmanage)
Dec 15 23:16:05 l30n-hpprobook systemd[1]: Reached target Sleep.
Dec 15 23:16:05 l30n-hpprobook systemd[1]: Starting System Suspend...
Dec 15 23:16:06 l30n-hpprobook wpa_supplicant[740]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 15 23:16:06 l30n-hpprobook wpa_supplicant[740]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Dec 15 23:16:14 l30n-hpprobook systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
I enjoy using Manjaro, but without a functional Sleep every distro would be a pain.
Hopefully I provided everything relevant to this issue (it’s my first post). If some information is missing I will be happy to provide it.
Thanks for the help in advance.
Hello and welcome,
Sadly, you have now gained an introduction to the wild world of random guides found online.
They are of extremely varying quality.
In this case … we have a few problems.
  • Rufus. Maybe its better now, but the dev was actively hostile to manjaro, ensuring for a long while that ISOs written using rufus would be broken. Even if it technically worked now I would never trust it.
  • Manual partitioning. For some reason it guides you to do this … and then does not give explanations for personal configurations. Instead it just dictates a handful of manual steps … and they arent very good.
    • A 2gb SWAP? Thats near useless.
    • A separate ESP? There may be some cases where this is desirable, but its generally more desirable to share the existing ESP.
      ( For example - usually Grub would not provide other OSs to boot into if the ESP is not shared. )
Now for your situation … maybe none of that is related.
But lets get some system info
inxi -Farz
Try to disable fast boot in windows and try again. One way to try this fast is to disconnect the laptop from the mains and then remove the battery for a couple of minutes. Then boot directly Manjaro (without booting windows). If sleep works as expected then Windows is messing with your BIOS state.
Disable Fast Startup in Windows (hibernation variant).
I did turn off fast Startup with powercfg /h off in the terminal, because it is quite hard to get my laptop open and im not even sure if the battery is removable. Sadly didn’t work.
Oh. The guide seemed quite detailed and not harmful. Any tips on finding better guides?
System info
inxi -Farz
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_CTYPE = (unset),
        LC_NUMERIC = "de_DE.UTF-8",
        LC_COLLATE = (unset),
        LC_TIME = "de_DE.UTF-8",
        LC_MESSAGES = (unset),
        LC_MONETARY = "en_DE.UTF-8",
        LC_ADDRESS = "de_DE.UTF-8",
        LC_IDENTIFICATION = "de_DE.UTF-8",
        LC_MEASUREMENT = "de_DE.UTF-8",
        LC_PAPER = "de_DE.UTF-8",
        LC_TELEPHONE = "de_DE.UTF-8",
        LC_NAME = "de_DE.UTF-8",
        LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=23853a33-be9e-4bfc-b488-b270fe7d7569 rw quiet splash
    resume=UUID=0026abbc-3b02-4c09-93af-64f96f4e18a3 udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: HP product: HP ProBook 455 G8 Notebook PC v: N/A
  Mobo: HP model: 8864 v: KBC Version 41.28.00 serial: <superuser required>
    part-nu: 3Z6P6ES#ABD uuid: <superuser required> UEFI: HP
    v: T78 Ver. 01.11.00 date: 10/14/2022
  ID-1: BAT0 charge: 32.3 Wh (98.8%) condition: 32.7/45.0 Wh (72.6%)
    volts: 12.4 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: not charging cycles: 486
  Info: model: AMD Ryzen 7 5800U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1396 min/max: 400/1901 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1396 2: 1396 3: 1396
    4: 1396 5: 1396 6: 1396 7: 1396 8: 1396 9: 1396 10: 1396 11: 1396 12: 1396
    13: 1396 14: 1396 15: 1396 16: 1396 bogomips: 60717
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: DP-4,HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-5 bus-ID: 05:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 50.0 C
  Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 0408:5347
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5760x1080
    display-ID: 0
  Monitor-1: DP-4 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: center res: 1920x1080 size: N/A modes: N/A
  Monitor-3: eDP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    renoir LLVM 18.1.8 DRM 3.59 6.11.10-2-MANJARO) device-ID: 1002:1638
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.8-arch1.1
    device-ID: 1002:1638 surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: N/A alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
    chip-ID: 10ec:c822 class-ID: 0280
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:5
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp5s0f3u1u1 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 0bda:b00c
  Local Storage: total: 953.87 GiB used: 56.98 GiB (6.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: PC711 HFS001TDE9X073N size: 953.87 GiB block-size: physical: 512 B
    fw-rev: HPS0 temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 248.56 GiB size: 243.6 GiB (98.00%)
    used: 56.98 GiB (23.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-2: /boot/efi raw-size: 512.6 MiB size: 511.5 MiB (99.80%)
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 51.4 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1435 libs: 448 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    2: http://manjaro.grena.ge/stable/$repo/$arch
    3: https://mirrors2.manjaro.org/stable/$repo/$arch
    4: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    5: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    6: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    7: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    9: https://manjaro.kurdy.org/stable/$repo/$arch
    10: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    11: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    13: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://manjaro.ynh.ovh/stable/$repo/$arch
    16: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    17: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    18: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    19: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    20: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    21: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    22: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    23: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    24: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    27: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    28: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    29: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    30: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    31: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    32: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    33: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    34: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    35: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    36: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    37: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    38: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    39: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    41: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    42: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    43: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    44: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    45: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    46: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    47: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    48: https://linorg.usp.br/manjaro/stable/$repo/$arch
    49: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    50: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    52: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    53: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    54: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    55: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    56: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    57: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    58: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    59: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    61: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    62: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    63: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    64: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    65: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    67: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    68: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    69: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    70: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    71: https://mirror.23m.com/manjaro/stable/$repo/$arch
    72: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    74: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    75: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    76: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    77: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    78: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    79: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    80: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    81: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    83: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    84: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    85: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    86: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    87: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    89: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    90: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    91: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    92: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    93: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    94: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    95: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    97: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    98: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    99: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    100: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    101: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    102: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    103: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    104: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    105: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    106: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    107: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    108: https://mirror.init7.net/manjaro/stable/$repo/$arch
    109: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    110: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    111: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    112: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    113: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
  Memory: total: 16 GiB note: est. available: 14.94 GiB used: 3.23 GiB (21.6%)
  Processes: 340 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    image: 5.95 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
Thats unsual.
Was this the product of intentionally augmenting the output? Or is there something wrong with your locale settings in general?
( Possible remedy - open Manjaro Settings Manager and apply locale settings )
If my search-foo is correct then you have available BIOS updates.
https://support.hp.com/us-en/drivers/hp-probook-455-g8-notebook-pc/38228735
Be warned that 6.11 kernel is EOL and should be replaced by 6.12.
Note: Its generally considered a good idea to keep at least one known working LTS kernel, like 6.6, installed.
Also. You may notice that kernel 6.6 does not exhibit the same behavior. If so then it could be related to PSR (Panel Self Refresh) a power saving feature that got new implementation beginning with kernel 6.11.
As mentioned above this SWAP is paltry.
You have 16gb of memory, so you may not run out easily, but when you do, then that 2gb isnt going to cover very much.
I might suggest reworking this setup for something larger. You may also consider using a swapfile or zram in place of a regular partition if reworking the partitions is a headache.
zram is also generally noticeably more performant, though it negates hibernation ability. But I might assume thats not a concern as the current system setup could not possibly hibernate due to the near nonexistence of SWAP.
If you are dual-booting then also make sure to verify the disablement of ‘Fast Start’/Hibernation in windoze (this ‘feature’ is intentionally misleading … This setting in fact ensures that windoze hibernates instead of shutting down. You gain faster startup by never shutting down), as mentioned by the other posters. It is a common pitfall that can have various negative consequences if left enabled.
I think you would have gotten a better end result from just doing the automated install, let alone different choices from manual.
For guidance your first stops should be the forums or the wikis.
https://wiki.manjaro.org
https://wiki.archlinux.org
Aside from that its hard to give a good rule for which guides are OK.
I might say to just generally stay away from ones that arent recognizably vetted and/or that you cant fully understand yourself. Its never a good idea to run things you cant at least interpret.
Maybe we can say that youtube has the dubious honor of being considered an almost overwhelmingly bad source of information? Of course there are still exceptions to (almost) every rule.
A post was split to a new topic: Freeze on waking up from sleep
I didn’t change anything, since the startup configuration. I reconfigured the local settings. Now everything is en_US, but thats ok for now and the error is gone.
Updated System Info
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  ID-1: BAT0 charge: 9.4 Wh (28.7%) condition: 32.7/45.0 Wh (72.6%)
    volts: 12.1 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: charging cycles: 487
    microcode: 0xA500011
  Speed (MHz): avg: 400 min/max: 400/1901 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 400 16: 400 bogomips: 60706
    affected
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 48.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    renoir LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:1638
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
    class-ID: 0403
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:b00c
  Local Storage: total: 953.87 GiB used: 55.41 GiB (5.8%)
    fw-rev: HPS0 temp: 33.9 C scheme: GPT
    used: 55.41 GiB (22.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
  Packages: pm: pacman pkgs: 1437 libs: 448 tools: pamac,yay pm: flatpak
    pkgs: 0
  Memory: total: 16 GiB note: est. available: 14.94 GiB used: 2.51 GiB (16.8%)
  Processes: 364 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
I installed all driver updates from the hp-support and tested the kernels 515, 66, 611, 612. Doesn’t change anything with the freezing.
I have no problem reinstalling the distro completely as dual boot. Wouldn’t that be the easiest way?
I don’t have the two options hilighted in the image below on windows. I also tried turning fast start off with powercfg /h off , but didn’t get any response. Turning fast boot off in the BIOS settings didn’t help either.
When I got my HP laptop, I then found out that if I chose Windows operating (the newest option available) in the support page, I got more BIOS updates than by choosing Linux operating system. So I always installed BIOS updates from the Windows 11 64bit support page.
(just making notice)
For the sake of clarification: Fast Boot and Fast Startup are not the same thing.
Fast Boot (BIOS option)
Fast Boot is a BIOS option which (if present, and enabled) allows certain self-tests to be skipped during pre-boot (before handoff to a bootloader). Fast Boot settings may exist in varying locations, or not exist at all; as every BIOS has differing capabilities.
Misinformation in Internet search results may lead to a belief that Fast Boot (the BIOS option) and Fast Startup (hibernation) are the same; they are not:
It is generally recommended (but not compulsory) to disable Fast Boot when using Linux either standalone or in a multiboot scenario.
Fast Startup (Windows)
Fast Startup is a hibernation variant which might be enabled by default on some Windows computers.
With Fast Startup enabled, Windows does not actually shut down; instead, it sleeps. When the computer subsequently wakes from the hibernation state, this gives the illusion of a faster startup and shutdown experience.
When multibooting, this can cause havoc with boot processes, and NTFS mounting functionality, in Linux. To better understand these issues, and their consequences, please see the related article [Primer] NTFS on Linux.
Fast Startup must be disabled in a multiboot scenario. :eyes:
There are many documented ways to turn off fast startup in both Windows 10 and 11, however, the easiest is to use the following command – from an administrative command prompt – this will disable all hibernation (other sleep states will not be affected):
powercfg /h off
Thanks for all the help. Disabling Windows’s Fast Startup couldn’t help me, so I reinstalled Manjaro and now and can sleep.
Are we to assume you didn’t already have it disabled?
Closing thread as no solution was reached.
