I’m installing Manjaro using the Calamares installer. The question is that, after installation, I see the following partition scheme:
Which has free space at the beginning and end.
I guessed this is for aliment. But if I resize the partitions to fill those gaps:
- Move EFI partition to the left.
- Move root partition to the left, then resize to fill the end.
Then I check aliment with parted:
parted /dev/sda
align-check opt n
It says that partitions are aligned nowadays.
So I’m guessing why leaving those blank spaces.
