Fractional scaling does not show up on gnome Wayland session, even though I activated it using
gsettings set org.gnome.mutter experimental-features "['scale-monitor-framebuffer']"
any ideas?
any ideas?
Did you reboot or at least log out and back in? Are you sure you are under wayland session? Check from terminal with:
echo $XDG_SESSION_TYPE
Yes I did a reboot, and I checked multiple times that I am under Wayland
