This may be a particularly niche issue I happened across but thought it worth mentioning.
manjaro.org has a DMARC policy of reject, and mails are not DKIM signed. Relying solely on SPF alignment, which will fail if forwarded.
Whether this is a me problem or manjaro.org problem is probably debatable and I know implementing DKIM is annoying but maybe the DMARC policy could be lowered to quarantine.
So the issue wasn’t really Manjaro domain settings?
It was your setup where you forward mail from one provider to another thus invalidating the chain.
I really don’t think it is a Manjaro domain administrator task to ensure you can forward mail through different services.
I have my domain’s DMARC policy setup to reject everything that fails validation.
I have domain which goes back more than 25 years and some of my email addresses has been part of several dataleaks and has been used as sender email by a lot of spam - so I have zero tolerance for abuse.
This is debatable as mentioned in the initial post, in order to pass DMARC either SPF or DKIM needs to validate. In my opinion using a forwarding mail server is not a strange or poor configuration, I also have owned domains for a similar amount of time but these days do not have the time to run my own mail server, using a forwarding service from my domains to a webmail service.
I agree to a point, however as mentioned I do not think a setup of using a forwarding mail server is particularly obtuse. If the system is sending mail unsigned mail in my opinion it is an admin error to rely on SPF alignment alone with a reject policy.
It appears the mail now being sent is in fact DKIM signed since my initial post? So a reject policy is now probably reasonable.
it is your forwarding policy setup which caused your mail to get lost
it is really of no concern for the sender of such mail to address your forwarding issues
sending mail using multiple forwarders is a well known technique used by spammers as reply-to address
The correct handling would be to setup the forwarder to encapsulate forwarded mail in a new envelope or send it as a forwarded mail using the intermediate address as sender - instead of using manjaro.org as sender domain which some poorly setup forwarders do.
The excessive amount of spam which is often using innocent mail-from addresses to legitimise the mail - is one of the reasons why domain owners setup DMARC and DKIM and SPF.
But DMARC is accepting mail if either exist - it doesn’t require both - which is why my domain has reject 100%.
As this is the feedback section I’ll also add this has been a favourite distro of mine for a while now but this interaction with a maintainer has felt unnecessarily defensive and aggressive. I regret getting involved at all.
