ZaeNae
February 25, 2021, 5:01pm
#21
Hey! I reinstalled my system. I didn’t touch nothing, the only setting are timezone and using my external monitor.
Here is the info:
inxi --graphics
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU117M driver: nvidia v: 455.45.01
Display: x11 server: X.Org 1.20.10 driver: modesetting FAILED: nvidia s-res: 1920x1200
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.3
ls /etc/X11/xorg.conf.d/
00-keyboard.conf 90-mhwd.conf
cat /etc/X11/xorg.conf.d/90-mhwd.conf
## Generated by mhwd - Manjaro Hardware Detection
What is next now?
Fabby
February 25, 2021, 8:16pm
#22
Sorry for having been unclear: you should have reinstalled with the nVidia driver instead of doing next, next finish… (non-free!)
My apologies!
ZaeNae
February 25, 2021, 8:55pm
#23
Uhh! Anyway… At least I have a brand new system. I did it with install-option non-free drivers.
Well, what information do you need and what should i do now?
Fabby
February 25, 2021, 8:56pm
#24
It’s always the same: inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information.
ZaeNae
February 25, 2021, 10:16pm
#25
OK.
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bac45e41-08bf-4c97-bceb-c73b0e657115 rw quiet udev.log_priority=3
Desktop: Cinnamon 4.8.0 tk: GTK 3.24.23 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: Micro-Star product: GF63 Thin 10SCXR v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16R4IMS.105 date: 04/17/2020
ID-1: BAT1 charge: 46.1 Wh condition: 48.6/51.3 Wh (95%) volts: 12.6/11.4
model: MSI Corp. MS-16R4 type: Li-ion serial: N/A status: Unknown
RAM: total: 31.18 GiB used: 3.18 GiB (10.2%)
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 2 microcode: E0 L2 cache: 12.0 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 1068 2: 961
3: 913 4: 956 5: 953 6: 940 7: 1023 8: 1022 9: 813 10: 945 11: 938 12: 963
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f99
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.0x12.5")
s-diag: 599mm (23.6")
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:06c8
Device-2: Logitech Headset H340 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5:5 chip ID: 046d:0a38
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 5000
bus ID: 00:14.3 chip ID: 8086:06f0
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 1.38 TiB used: 33.85 GiB (2.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3512GJ5
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: E8FK12.D scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw size: 238.42 GiB size: 233.68 GiB (98.01%) used: 6.12 GiB (2.6%)
fs: ext4 dev: /dev/sda2 label: N/A
uuid: bac45e41-08bf-4c97-bceb-c73b0e657115
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: FF3C-41DF
ID-3: /run/media/molnari/60978d81-4b3b-428f-a697-d01b64bee662
raw size: 467.84 GiB size: 459.50 GiB (98.22%) used: 10.02 GiB (2.2%)
fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 60978d81-4b3b-428f-a697-d01b64bee662
ID-4: /run/media/molnari/misc raw size: 684.00 GiB size: 672.26 GiB (98.28%)
used: 17.71 GiB (2.6%) fs: ext4 dev: /dev/sda4 label: misc
uuid: f417ae0c-6b9f-45d7-affb-827b6ad26286
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 label: N/A uuid: 42569afe-0e3a-49ef-9c01-93d866fdac4a
ID-1: /dev/nvme0n1p1 size: 300.0 MiB fs: vfat label: N/A uuid: 5784-E453
ID-2: /dev/nvme0n1p3 size: 8.80 GiB fs: swap label: N/A
uuid: 1b1e4b23-4337-48a2-adda-b0cb3b11da59
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-3:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046d:c077
Device-2: 1-4:3 info: Logitech Keyboard K120 type: Keyboard,HID
chip ID: 046d:c31c
Device-3: 1-5:5 info: Logitech Headset H340 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 046d:0a38
Device-4: 1-14:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0026
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 297 Uptime: 5h 25m Init: systemd v: 246 Compilers: gcc: N/A
Packages: pacman: 818 lib: 259 flatpak: 0 Shell: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.08
Let me know what else needs.
Fabby
February 25, 2021, 10:21pm
#26
Good, but that’s an old one, so use the command at the end to upgrade, but provide the output to:
glxinfo | grep vendor
first!
To upgrade:
pamac upgrade
ZaeNae
February 25, 2021, 11:02pm
#27
Here is the output>
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
OpenGL vendor string: Intel
Now I do the upgrqade.
eddier
February 25, 2021, 11:03pm
#28
On my lenovo I can select either Graphics system ONLY or Optimus in the BIOS.
Fabby
February 25, 2021, 11:18pm
#29
ZaeNae:
Was mentioned here:
But as you’re not doing that, I might have another idea:
What’s the output of
mhwd --listinstalled
ZaeNae
February 26, 2021, 7:54am
#30
Last night I did the pamac upgrade.
Now here is the output of mhwd:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
There is a strange thing. Meanwhile the pamac upgrade run i noticed this message series, more than one time.
ldconfig: /usr/lib32/libnvidia-glvkspirv.so.460.39 is not a symbolic link
ldconfig: /usr/lib32/libnvidia-glsi.so.460.39 is not a symbolic link
ldconfig: /usr/lib32/libnvidia-eglcore.so.460.39 is not a symbolic link
ldconfig: /usr/lib32/libnvidia-glcore.so.460.39 is not a symbolic link
ldconfig: /usr/lib32/libnvidia-tls.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-glvkspirv.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-glsi.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-gtk3.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-eglcore.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-rtcore.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-glcore.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-cbl.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-gtk2.so.460.39 is not a symbolic link
ldconfig: /usr/lib/libnvidia-tls.so.460.39 is not a symbolic link
Something went wrong?
ZaeNae
February 26, 2021, 7:56am
#31
On my MSI I can’t find such option. I don’t know why.
ZaeNae
February 27, 2021, 7:58pm
#32
I must reinstall my system from the scratch, again. It wont work, I got only a black screen, nothing else, ctrl+alt+f2 wont respond.
So, here are the collected info again:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=bd4da113-5777-4835-ae61-c87d9e43f3fb rw quiet udev.log_priority=3
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.24 dm: LightDM 1.30.0
ID-1: BAT1 charge: 44.7 Wh condition: 47.6/51.3 Wh (93%) volts: 12.6/11.4
RAM: total: 31.18 GiB used: 1.75 GiB (5.6%)
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
L2 cache: 12 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bus ID: 00:02.0 chip ID: 8086:9bc4 class ID: 0300
Device-2: NVIDIA TU117M vendor: Micro-Star MSI driver: nouveau v: kernel
bus ID: 01:00.0 chip ID: 10de:1f99 class ID: 0302
Display: x11 server: X.Org 1.20.10 driver: loaded: intel,modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
bus ID: 00:1f.3 chip ID: 8086:06c8 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
bus ID: 00:14.3 chip ID: 8086:06f0 class ID: 0280
chip ID: 10ec:8168 class ID: 0200
Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 1-14:4
chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.38 TiB used: 24.47 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3512GJ5
lanes: 2 rotation: SSD serial: <filter> rev: E8FK12.D temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw size: 238.42 GiB size: 233.68 GiB (98.01%) used: 6.76 GiB (2.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: bd4da113-5777-4835-ae61-c87d9e43f3fb
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FF3C-41DF
ID-3: /mnt/misc_disk raw size: 684 GiB size: 672.26 GiB (98.28%)
used: 17.71 GiB (2.6%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: misc
dev: /dev/sda3 maj-min: 8:3 label: N/A
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: 5784-E453
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 467.84 GiB fs: ext4 label: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 8.8 GiB fs: swap label: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
chip ID: 046d:c077 class ID: 0301
chip ID: 046d:c31c class ID: 0300
Device-3: 1-14:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0026 class ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 25.0 C
Processes: 281 Uptime: 9m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 912 lib: 330 flatpak: 0 Shell: Bash v: 5.1.0
running in: gnome-terminal inxi: 3.3.01
Let me know what else do you need?
Fabby
February 28, 2021, 7:43pm
#33
Let’s take a step back:
in this config you should just have removed video-modesetting
and video-hybrid-intel-nvidia-prime
and added video-nvidia
in this one you need to add video-nvidia
and remove video-linux
as stated in my original message …
If that doesn’t work, your system’s nVidia card is not hooked up to the internal display electrically (it happens on cheap systems) and then you need to install the video-hybrid-intel-nvidia-prime
and do a prime-switch
to make the nVidia card the primary. (the intel will be used as a pass-through card for displaying what the nVidia calculated)…
Am I making sense now or am I still talking gibberish?
ZaeNae
February 28, 2021, 8:29pm
#34
None of the commands were worked, with one exception the reboot.
Error: config video-hybrid-intel-nvidia-prime
is not installed!
No such file or directory
Error: config video-nvidia
does not exist!
So I would follow the second part of your post.
Which command does install the video-hybrid-intel-nvidia-prime
Fabby
February 28, 2021, 8:32pm
#35
Can you give me the full output, please?
Also, what’s the output of:
mhwd --listall
ZaeNae
February 28, 2021, 9:04pm
#36
sudo mhwd --remove pci video-hybrid-intel-nvidia-prime
Error: config 'video-hybrid-intel-nvidia-prime' is not installed!
sudo mv /etc/X11/mhwd.d/nvidia.conf /etc/X11/mhwd.d/nvidia.conf.bak
mv: cannot stat '/etc/X11/mhwd.d/nvidia.conf': No such file or directory
sudo mv /etc/X11/xorg.conf.d/90-mhwd.conf /etc/X11/xorg.conf.d/90-mhwd.conf.bak
mv: cannot stat '/etc/X11/xorg.conf.d/90-mhwd.conf': No such file or directory
sudo mhwd --install pci video-nvidia
Error: config 'video-nvidia' does not exist!
mhwd --listall
> All PCI configs:
video-voodoo 2017.03.12 true PCI
video-virtualmachine 2020.03.26 true PCI
video-s3 2020.01.18 true PCI
video-vesa 2017.03.12 true PCI
video-sisusb 2020.01.18 true PCI
video-rendition 2020.01.18 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false PCI
video-nvidia-390xx 2020.11.30 false PCI
video-openchrome 2020.01.18 true PCI
network-rt3562sta 2013.12.07 true PCI
network-broadcom-wl 2018.10.07 true PCI
network-r8168 2016.04.20 true PCI
network-slmodem 2013.12.07 true PCI
Warning: No USB configs found!
Fabby
February 28, 2021, 9:10pm
#37
You’re on the 5.9 kernel and that’s EOL!
sudo mhwd-kernel --install linux510
sudo mhwd-kernel --install linux54
sudo mhwd-kernel --remove linux59
sudo reboot
then try again…
Sorry! I should have caught that!!!
ZaeNae
February 28, 2021, 9:21pm
#38
The kernel is updated with that three commands.
Now:
mhwd --listall
> All PCI configs:
Fabby
February 28, 2021, 9:22pm
#39
Did you do a
pamac upgrade
for one of those kernels too?
ZaeNae
February 28, 2021, 9:24pm
#40
I didn’t do that. But after I read your post I did right now.
pamac upgrade
Preparing...
Nothing to do.
