Hello,
i just looked up the following issue over the forum and the web without finding an answer, so here it is.
Today an update for a package has been released in AUR and, like the previous times, any AUR helper i try (paru/yay) won’t find there’s a newer version of it to be upgraded.
The package is whatsapp-for-linux
which is version 1.4.0-1 on AUR https://aur.archlinux.org/packages/whatsapp-for-linux
Launching both -Syu
and -Syua
the update is not found, as you can see below the only difference is that with the first command the warning tells me that the local package is more recent than the one in community. (that’s in Italian, my system’s language, feel free to ask for a translation)
$ paru -Syu
[sudo] password di bucch:
:: Sincronizzazione dei database in corso...
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Aggiornamento del sistema in corso...
attenzione: whatsapp-for-linux: la versione installata (1.3.2-1) è più recente di quella presente in community (1.1.2-0)
non ci sono aggiornamenti disponibili
:: Controllo di aggiornamenti dalla AUR in corso
:: Controllo di aggiornamenti da repository di sviluppo in corso
non c'è nulla da fare
$ paru -Syua
of course the actual package on my system is the second-last release:
$ paru -Qi whatsapp-for-linux
Nome : whatsapp-for-linux
Versione : 1.3.2-1
Querying the repos for that package gives me different results (I’ve truncated the output):
$ paru -Si whatsapp-for-linux
Repository : community
Versione : 1.1.2-0
$ paru -Sia whatsapp-for-linux
Repository : aur
Versione : 1.4.0-1
The last time i had to reinstall the package with paru -Sa whatsapp-for-linux
, because paru -S whatsapp-for-linux
will downgrade to community
version without asking for the repo.
I may be wrong, but it seems to me that the package manager is checking the version over community only and not on AUR so it’s not seeing the new one.
Is there a way to force the package manager to always check over AUR for a single package in order to be automatically updated?
Thanks and sorry for the wallpost.
