Whenever I reboot my laptop, the font settings aren’t applied. Also, my terminal customizations aren’t applied. I have to open the terminal, close it, and open it again. Only then is everything fixed. I have to restart most apps to get the font sizes fixed. Mostly electron apps and browsers seem to be affected by it. Btw, I use fish
as my default shell.
Here are some of my config files (ask to provide more of them if needed):
# ~/.bashrc
[[ $- != *i* ]] && return
colors() {
local fgc bgc vals seq0
printf "Color escapes are %s\n" '\e[${value};...;${value}m'
printf "Values 30..37 are \e[33mforeground colors\e[m\n"
printf "Values 40..47 are \e[43mbackground colors\e[m\n"
printf "Value 1 gives a \e[1mbold-faced look\e[m\n\n"
# foreground colors
for fgc in {30..37}; do
# background colors
for bgc in {40..47}; do
fgc=${fgc#37} # white
bgc=${bgc#40} # black
vals="${fgc:+$fgc;}${bgc}"
vals=${vals%%;}
seq0="${vals:+\e[${vals}m}"
printf " %-9s" "${seq0:-(default)}"
printf " ${seq0}TEXT\e[m"
printf " \e[${vals:+${vals+$vals;}}1mBOLD\e[m"
done
echo; echo
done
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
# Change the window title of X terminals
case ${TERM} in
xterm*|rxvt*|Eterm*|aterm|kterm|gnome*|interix|konsole*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\007"'
screen*)
PROMPT_COMMAND='echo -ne "\033_${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\033\\"'
esac
use_color=true
# Set colorful PS1 only on colorful terminals.
# dircolors --print-database uses its own built-in database
# instead of using /etc/DIR_COLORS. Try to use the external file
# first to take advantage of user additions. Use internal bash
# globbing instead of external grep binary.
safe_term=${TERM//[^[:alnum:]]/?} # sanitize TERM
match_lhs=""
[[ -f ~/.dir_colors ]] && match_lhs="${match_lhs}$(<~/.dir_colors)"
[[ -f /etc/DIR_COLORS ]] && match_lhs="${match_lhs}$(</etc/DIR_COLORS)"
[[ -z ${match_lhs} ]] \
&& type -P dircolors >/dev/null \
&& match_lhs=$(dircolors --print-database)
[[ $'\n'${match_lhs} == *$'\n'"TERM "${safe_term}* ]] && use_color=true
if ${use_color} ; then
# Enable colors for ls, etc. Prefer ~/.dir_colors #64489
if type -P dircolors >/dev/null ; then
if [[ -f ~/.dir_colors ]] ; then
eval $(dircolors -b ~/.dir_colors)
elif [[ -f /etc/DIR_COLORS ]] ; then
eval $(dircolors -b /etc/DIR_COLORS)
fi
fi
if [[ ${EUID} == 0 ]] ; then
PS1='\[\033[01;31m\][\h\[\033[01;36m\] \W\[\033[01;31m\]]\$\[\033[00m\] '
else
PS1='\[\033[01;32m\][\u@\h\[\033[01;37m\] \W\[\033[01;32m\]]\$\[\033[00m\] '
fi
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
else
# show root@ when we don't have colors
PS1='\u@\h \W \$ '
else
PS1='\u@\h \w \$ '
fi
fi
unset use_color safe_term match_lhs sh
alias cp="cp -i" # confirm before overwriting something
alias df='df -h' # human-readable sizes
alias free='free -m' # show sizes in MB
alias np='nano -w PKGBUILD'
alias more=less
xhost +local:root > /dev/null 2>&1
complete -cf sudo
# Bash won't get SIGWINCH if another process is in the foreground.
# Enable checkwinsize so that bash will check the terminal size when
# it regains control. #65623
# http://cnswww.cns.cwru.edu/~chet/bash/FAQ (E11)
shopt -s checkwinsize
shopt -s expand_aliases
# export QT_SELECT=4
# Enable history appending instead of overwriting. #139609
shopt -s histappend
# History settings
HISTSIZE=500
HISTFILESIZE=100000
# # ex - archive extractor
# # usage: ex <file>
ex ()
if [ -f $1 ] ; then
case $1 in
*.tar.bz2) tar xjf $1 ;;
*.tar.gz) tar xzf $1 ;;
*.bz2) bunzip2 $1 ;;
*.rar) unrar x $1 ;;
*.gz) gunzip $1 ;;
*.tar) tar xf $1 ;;
*.tbz2) tar xjf $1 ;;
*.tgz) tar xzf $1 ;;
*.zip) unzip $1 ;;
*.Z) uncompress $1;;
*.7z) 7z x $1 ;;
*) echo "'$1' cannot be extracted via ex()" ;;
esac
else
echo "'$1' is not a valid file"
fi
# better yaourt colors
export YAOURT_COLORS="nb=1:pkg=1:ver=1;32:lver=1;45:installed=1;42:grp=1;34:od=1;41;5:votes=1;44:dsc=0:other=1;35"
#set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
#enable ~/.bash_aliases
if [ -f ~/.bash_aliases ] ; then
. ~/.bash_aliases
fi
export LC_CTYPE="en_US.utf8"
PS1="\[\033[0;32m\][\[\033[0;34m\]\u\[\033[0;37m\]@\[\033[0;31m\]\h\[\033[0;32m\]:\w]$\[\033[0m\] "
~/.profile
export GREP_COLORS='ms=01;33'
[ -f ~/.Xresources ] && xrdb ~/.Xresources
[ $TERM != "screen" ] && tmux attach; and exec true
~/.Xresources
xterm*selectToClipboard: true
xterm*disallowedWindowOps: 20,21,SetXProp
*.font: Liberation Mono:pixelsize=16:antialias=true:autohint=true;
*.alpha: 0.8
! st*geometry: 100x30
! colors
! special
*.foreground: #ffffff
*.background: #000000
*.cursorColor: #ffffff
! black
*.color0: #000000
*.color8: #4d4d4d
! red
*.color1: #cc0403
*.color9: #aa2524
! green
*.color2: #19cb00
*.color10: #23fd00
! yellow
*.color3: #cecb00
*.color11: #fffd00
! blue
*.color4: #001cd1
*.color12: #0026ff
! magenta
*.color5: #cb1ed1
*.color13: #fd28ff
! cyan
*.color6: #0dcdcd
*.color14: #14ffff
! white
*.color7: #e5e5e5
*.color15: #ffffff
~/.tmux.conf
# https://github.com/seebi/tmux-colors-solarized/blob/master/tmuxcolors-256.conf
set-option -g status-style bg=colour235,fg=colour136,default # bg=base02, fg=yellow
# set window split
bind-key v split-window -h
bind-key b split-window
# default window title colors
set-window-option -g window-status-style fg=colour244,bg=default,dim # fg=base0
# active window title colors
set-window-option -g window-status-current-style fg=colour166,bg=default,bright # fg=orange
# pane border
set-option -g pane-border-style fg=colour235 #fg=base02
set-option -g pane-active-border-style fg=colour240 #fg=base01
# message text
set-option -g message-style bg=colour235,fg=colour166 # bg=base02, fg=orange
# pane number display
set-option -g display-panes-active-colour colour33 #blue
set-option -g display-panes-colour colour166 #orange
# clock
set-window-option -g clock-mode-colour green #green
set -g status-interval 1
set -g status-justify centre # center align window list
set -g status-left-length 20
set -g status-right-length 140
set -g status-left '#[fg=green]#H #[fg=black]• #[fg=green,bright]#(uname -r | cut -c 1-6)#[default]'
set -g status-right '#[fg=green,bg=default,bright]#(tmux-mem-cpu-load) #[fg=red,bg=default]#(uptime | cut -f 4-5 -d " " | cut -f 1 -d ",") #[fg=white,bg=default]%a%l:%M:%S %p#[default] #[fg=blue]%d-%m-%Y'
# C-b is not acceptable -- Vim uses it
set-option -g prefix C-a
bind-key C-a last-window
# Start numbering at 1
set -g base-index 1
# Allows for faster key repetition
set -s escape-time 0
# Rather than constraining window size to the maximum size of any client
# connected to the *session*, constrain window size to the maximum size of any
# client connected to *that window*. Much more reasonable.
setw -g aggressive-resize on
# Set window-size to smallest amongst all clients connected to that window
set-option -g window-size smallest
# Allows us to use C-a a <command> to send commands to a TMUX session inside
# another TMUX session
bind-key a send-prefix
# Activity monitoring
setw -g monitor-activity on
set -g visual-activity on
# hjkl pane traversal
bind h select-pane -L
bind j select-pane -D
bind k select-pane -U
bind l select-pane -R
# set to main-horizontal, 66% height for main pane
bind m run-shell "~/.tmux/scripts/resize-adaptable.sh -l main-horizontal -p 66"
# Same thing for verical layouts
bind M run-shell "~/.tmux/scripts/resize-adaptable.sh -l main-vertical -p 50"
bind-key C command-prompt -p "Name of new window: " "new-window -n '%%'"
# reload config
bind r source-file ~/.tmux.conf \; display-message "Config reloaded..."
# auto window rename
set-window-option -g automatic-rename
set-option -g allow-rename
# https://github.com/edkolev/dots/blob/master/tmux.conf
# Updates for tmux 1.9's current pane splitting paths.
# from powerline
run-shell "tmux set-environment -g TMUX_VERSION_MAJOR $(tmux -V | cut -d' ' -f2 | cut -d'.' -f1 | sed 's/[^0-9]*//g')"
run-shell "tmux set-environment -g TMUX_VERSION_MINOR $(tmux -V | cut -d' ' -f2 | cut -d'.' -f2 | sed 's/[^0-9]*//g')"
# Vi copypaste mode
set-window-option -g mode-keys vi
if-shell "test '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 4 \)'" 'bind-key -Tcopy-mode-vi v send -X begin-selection; bind-key -Tcopy-mode-vi y send -X copy-selection-and-cancel'
if-shell '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -lt 4\) -o #{$TMUX_VERSION_MAJOR} -le 1' 'bind-key -t vi-copy v begin-selection; bind-key -t vi-copy y copy-selection'
# choose tree
unbind T
bind T choose-tree
# status bar
if-shell '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -lt 2\) -o #{$TMUX_VERSION_MAJOR} -le 1' 'set-option -g status-utf8 on'
# rm mouse mode fail
if-shell '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 1\)' 'set -g mouse off'
if-shell '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -lt 1\) -o #{$TMUX_VERSION_MAJOR} -le 1' 'set -g mode-mouse off'
# fix pane_current_path on new window and splits
if-shell "test '#{$TMUX_VERSION_MAJOR} -gt 1 -o \( #{$TMUX_VERSION_MAJOR} -eq 1 -a #{$TMUX_VERSION_MINOR} -ge 8 \)'" 'unbind c; bind c new-window -c "#{pane_current_path}"'
if-shell "test '#{$TMUX_VERSION_MAJOR} -gt 1 -o \( #{$TMUX_VERSION_MAJOR} -eq 1 -a #{$TMUX_VERSION_MINOR} -ge 8 \)'" "unbind '\"'; bind '\"' split-window -v -c '#{pane_current_path}'"
if-shell "test '#{$TMUX_VERSION_MAJOR} -gt 1 -o \( #{$TMUX_VERSION_MAJOR} -eq 1 -a #{$TMUX_VERSION_MINOR} -ge 8 \)'" 'unbind v; bind v split-window -h -c "#{pane_current_path}"'
# if-shell "test '#{$TMUX_VERSION_MAJOR} -gt 1 -o \( #{$TMUX_VERSION_MAJOR} -eq 1 -a #{$TMUX_VERSION_MINOR} -ge 8 \)'" 'unbind %; bind % split-window -h -c "#{pane_current_path}"'
# Colors
# How to use true colors in vim under tmux? #1246 for 2.6 and higher
# https://github.com/tmux/tmux/issues/1246:
# set -g default-terminal "tmux-256color"
# set -ga terminal-overrides ",*256col*:Tc"
# 2.5 and lower:
# set -g default-terminal "screen-256color"
# Doesn't work on iterm2 / mac
# if-shell "test '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 6 \)'" 'set -g default-terminal "tmux-256color"'
# if-shell "test '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 6 \)'" 'set -ga terminal-overrides ",*256col*:Tc"'
# Try screen256-color (https://github.com/tmux/tmux/issues/622):
if-shell "test '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 6 \)'" 'set -g default-terminal "screen-256color"'
if-shell "test '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -ge 6 \)'" 'set -ga terminal-overrides ",screen-256color:Tc"'
if-shell '\( #{$TMUX_VERSION_MAJOR} -eq 2 -a #{$TMUX_VERSION_MINOR} -lt 6\) -o #{$TMUX_VERSION_MAJOR} -le 1' 'set -g default-terminal "screen-256color"'
set-option -g default-command fish
set -g mouse
set -g set-clipboard external
bind -T root MouseUp2Pane paste
# if run as "tmux attach", create a session if one does not already exist
new-session -s $$
