[ARM Testing Update] 2021-04-04 - SystemD, Mobile and kernels
Hello ARM community.
New testing update for all of you testers out there!
New Pinebook 1080p devices getting shipped to help with the digital divide
Some highlights:
  • A couple of our kernels got updated
  • SystemD got a big update to 248.1
  • A version bump for LibreOffice fresh brings it to 7.1.2
  • QT6 also got a minor version update to 6.0.3
  • Lots of Mobile specific packages got updated
  • Some python packages got updated
How to use the new Kodi RPI on Manjaro ARM
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4
The way they have it set up is to boot straight in to kodi
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
Also by default it uses the vc4-kms-v3d which means fbturbo is not installed.
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Sun Apr 4 20:01:33 CEST 2021)
  • arm-testing community aarch64: 177 new and 168 removed package(s)
  • arm-testing core aarch64: 16 new and 16 removed package(s)
  • arm-testing extra aarch64: 228 new and 238 removed package(s)
  • arm-testing kde-unstable aarch64: 236 new and 236 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-03-29         2021-04-04
                               calls  0.3.1+26+g52424ee-1  0.3.1+66+gd67e690-1
                              chatty 0.2.0+277+gcd919ea-10.3.0_beta+15+g6477649-1
                            electron             12.0.1-1             12.0.2-1
                          electron11             11.3.0-1             11.4.1-1
                          megapixels             0.15.0-1             0.16.0-1
                                 nvm             0.37.2-1             0.38.0-1
                        or1k-elf-gcc             10.2.0-0             10.2.0-1
                               phosh 0.10.0+23+g4279132-1 0.10.0+26+g0faac2a-1
                     pico-wizard-git       r119.a4b5d58-1       r124.edcd8d0-1
           pico-wizard-plamo-scripts       r119.a4b5d58-1       r124.edcd8d0-1
            pinephone-manjaro-tweaks           20210330-1           20210403-1
                             vivaldi        3.7.2218.49-1        3.7.2218.52-1
                           sofia-sip                    -             1.13.3-1
:: Different sync package(s) in repository community aarch64
                       android-tools             30.0.5-3             31.0.0-1
                             ansible              3.1.0-1              3.2.0-1
                          arch-audit             0.1.18-1             0.1.19-1
                      arch-audit-gtk              0.1.2-1              0.2.0-1
                            autopep8            1:1.5.6-1            1:1.5.6-2
                           aws-vault              6.3.0-1              6.3.1-1
                           babel-cli            7.13.10-1            7.13.14-1
                           bctoolbox             4.4.34-1              4.5.1-1
                                borg             1.1.16-1             1.1.16-2
                           borgmatic             1.5.12-4             1.5.13-2
                               bzrtp             4.4.34-1              4.5.1-1
                             cargo-c              0.7.3-1              0.8.0-1
                             chezmoi              2.0.4-1              2.0.7-1
                             cockpit                240-1                241-1
                    cockpit-machines                240-1                241-1
                         cockpit-pcp                240-1                241-1
                   containers-common             0.35.4-1             0.35.4-2
                            cppcheck                2.3-2              2.4.1-1
                                crun               0.18-1               0.19-1
                               cryfs             0.10.2-2             0.10.3-1
                             crystal             0.36.1-1              1.0.0-3
                         dark-reader             4.9.29-1             4.9.30-1
                                 din                 50-1               50.1-1
                           docbook2x             0.8.8-17             0.8.8-18
                               doctl             1.57.0-1             1.58.0-1
                           drumstick              2.1.0-1              2.1.1-1
                                dune              2.8.4-1              2.8.5-1
                            electrum              4.0.9-1              4.1.0-1
                              faudio           21.03.05-1              21.04-1
                          fcitx5-gtk              5.0.6-1              5.0.6-2
                   firefox-clearurls             1.21.0-1             1.21.0-2
                 firefox-dark-reader             4.9.29-1             4.9.30-1
              firefox-tree-style-tab              3.7.3-1              3.7.4-1
                             foliate              2.6.0-1              2.6.3-1
                              fossil               2.14-1               2.15-1
               freepats-general-midi           20201122-1           20210329-1
                          github-cli              1.7.0-2              1.8.1-1
                                  go           2:1.16.2-1           2:1.16.3-1
                              gopass             1.12.4-1             1.12.5-1
                              groovy             2.5.14-1              3.0.7-1
                             haproxy              2.3.8-1              2.3.9-1
                             hostapd                2.9-4                2.9-5
                                 iwd               1.12-1               1.13-1
                jedi-language-server             0.30.1-1             0.30.2-1
                             jenkins              2.285-1              2.286-1
                                jp2a              1.1.0-1              1.1.0-2
                               jruby           9.2.16.0-1           9.2.17.0-1
                                 k9s             0.24.4-1             0.24.7-1
                                kbfs              5.6.1-1              5.6.1-2
                             keybase              5.6.1-1              5.6.1-2
                         keybase-gui              5.6.1-1              5.6.1-2
                              kotlin             1.4.31-1             1.4.32-1
                           kustomize              4.0.1-1              4.0.5-1
                            lib3mf-1              1.8.1-5              1.8.1-6
                      libcurl-compat             7.75.0-1             7.76.0-1
                      libcurl-gnutls             7.75.0-1             7.76.0-1
                              libime              1.0.5-1              1.0.6-1
                            libiodbc            3.52.13-2            3.52.14-1
                         lsp-plugins             1.1.29-1             1.1.30-1
                                 m2r              0.2.1-6              0.2.1-7
                                 mac               5.38-1               6.14-1
                                  mc             4.8.25-3             4.8.26-1
                              mcomix         1.3.0.dev0-3         1.3.0.dev0-4
                       mediastreamer             4.4.35-1              4.5.1-1
                         meilisearch             0.19.0-1             0.20.0-1
                       mod_passenger              6.0.7-1              6.0.8-1
                              mopidy              3.1.1-1              3.1.1-2
                                mypy              0.812-1              0.812-2
                      nginx-mainline             1.19.8-1             1.19.9-1
                  nginx-mainline-src             1.19.8-1             1.19.9-1
                       nginx-mod-njs              0.5.2-1              0.5.3-1
                 nginx-mod-passenger              6.0.7-1              6.0.8-1
                           nicotine+              3.0.2-1              3.0.3-1
                              nodejs            15.12.0-1            15.13.0-1
                                 npm              7.7.5-1              7.8.0-1
                     openttd-opengfx              0.6.0-1              0.6.1-1
                                ortp             4.4.34-1              4.5.1-1
                  papirus-icon-theme           20210302-1           20210401-1
                              picard              2.5.6-1                2.6-1
                             plocate              1.1.5-4              1.1.6-1
                                 pm2              4.5.5-1              4.5.6-1
                              podman              3.0.1-2              3.1.0-1
                       podman-docker              3.0.1-2              3.1.0-1
                           py3status               3.35-1               3.36-1
                      python-aiohttp              3.7.3-1              3.7.4-1
                      python-aiorpcx             0.18.4-3             0.18.7-1
                         python-amqp              5.0.5-1              5.0.6-1
                      python-apispec              4.3.0-1              4.4.0-1
                     python-billiard            3.6.3.0-3            3.6.4.0-1
                    python-braintree              4.6.0-1              4.7.0-1
                      python-breathe             4.27.0-1             4.28.0-1
                        python-click              7.1.2-3              7.1.2-4
                    python-construct            2.10.63-1            2.10.64-1
     python-cucumber-tag-expressions              3.0.0-1              3.0.1-1
        python-django-rest-framework             3.12.3-1             3.12.4-1
                       python-dotenv             0.15.0-3             0.16.0-1
                        python-faker              6.6.3-1              7.0.1-1
                        python-fido2              0.8.1-3              0.9.1-1
                     python-httplib2             0.19.0-1             0.19.1-1
                   python-hypothesis              6.8.3-1              6.8.4-1
                     python-identify              2.2.1-1              2.2.2-1
                        python-js2py               0.70-3               0.71-1
                  python-jsonpointer                2.0-7                2.1-1
            python-jupyter_packaging              0.8.1-1              0.8.2-1
            python-jupyterlab_server              2.3.0-1              2.4.0-1
                  python-marshmallow             3.10.0-1             3.11.1-1
                   python-matplotlib              3.4.0-2              3.4.1-2
                         python-milc              1.2.0-1              1.3.0-1
                      python-mistune              0.8.4-5              0.8.4-6
                      python-olefile               0.46-3               0.46-4
                python-parameterized              0.7.5-1              0.8.1-1
                       python-pg8000             1.18.0-1             1.19.0-1
                      python-pikepdf              2.9.2-1             2.10.0-1
                     python-pwntools              4.3.1-4              4.4.0-1
                  python-pycodestyle              2.7.0-1              2.7.0-2
                   python-pyhamcrest              1.9.0-7             1.10.0-1
                       python-qasync             0.14.0-1             0.15.0-1
                    python-responses             0.13.1-1             0.13.2-1
                         python-rich             9.13.0-1             10.1.0-1
                  python-ruamel-yaml             0.17.0-1             0.17.2-1
                       python-scramp              1.2.2-1              1.4.0-1
                  python-statsmodels             0.12.2-1             0.12.2-2
                    python2-autopep8            1:1.5.6-1                    -
                       python2-click              7.1.2-3                    -
                         python2-m2r              0.2.1-6                    -
                     python2-mistune              0.8.4-5                    -
                     python2-olefile               0.46-3                    -
                      python2-pillow              6.2.1-3                    -
                 python2-pycodestyle              2.7.0-1                    -
                  python2-pyhamcrest              1.9.0-7                    -
                            r2cutter           1:1.12.0-2           1:1.12.0-3
                            r2ghidra              5.1.1-1              5.1.1-2
                         rednotebook               2.21-1               2.21-2
                           retroarch              1.9.0-2              1.9.1-1
                          rime-emoji     0.0.0.20191102-1     0.0.0.20210328-1
                               rtirq           20210319-1           20210329-1
                       rust-analyzer           20210322-1           20210329-1
                                salt             3002.6-1               3003-1
                                 sbt            1:1.4.6-1            1:1.4.7-1
                              shards             0.13.0-1             0.14.1-1
                      soundconverter              3.0.2-3              4.0.0-1
                            starship             0.51.0-1             0.51.0-2
                                sway            1:1.5.1-1            1:1.5.1-2
                             thefuck               3.30-2               3.30-3
             thunderbird-dark-reader             4.9.29-1             4.9.30-1
                         timescaledb              2.1.0-1              2.1.1-1
                   ttf-sarasa-gothic             0.18.9-1             0.20.2-1
                           uglify-js             3.13.2-1             3.13.3-1
         v2ray-domain-list-community     20210328132031-1     20210401091829-1
                         v2ray-geoip       202103250007-1       202104010913-1
                           vidcutter              6.0.5-1              6.0.5-2
                                vmpk              0.8.1-1              0.8.2-1
                             you-get           0.4.1500-2           0.4.1520-1
                          youtube-dl         2021.03.25-1         2021.04.01-1
                  yubikey-manager-qt              1.2.0-1              1.2.1-1
                    maliit-framework                    -              2.0.0-2
                     maliit-keyboard                    -              2.0.0-2
                             mutter6                    -             3.36.8-2
                             presage                    -              0.9.1-1
                       python-r2pipe                    -              5.1.0-1
                       python-rzpipe                    -              0.1.0-1
                               rizin                    -              0.1.2-2
                           rz-cutter                    -              2.0.0-1
                           rz-ghidra                    -              0.1.1-1
                              tickrs                    -             0.14.4-2
                          tpm2-abrmd                    -              2.4.0-1
                          tpm2-tools                    -                5.0-1
                           tpm2-totp                    -              0.3.0-1
                            tpm2-tss                    -              3.0.3-1
                     tpm2-tss-engine                    -              1.1.0-1
                             wezterm                    -20210314.114017.04b7cedd-1
:: Different overlay package(s) in repository core aarch64
                     linux-pinephone            5.11.10-1            5.11.11-1
             linux-pinephone-headers            5.11.10-1            5.11.11-1
                            linux-rc           5.12.rc5-1           5.12.rc5-4
                    linux-rc-headers           5.12.rc5-1           5.12.rc5-4
                     manjaro-release              21.03-1              21.04-1
:: Different sync package(s) in repository core aarch64
                              cronie              1.5.6-1              1.5.7-2
                                curl             7.75.0-1             7.76.0-1
                                file               5.39-1               5.40-1
                               groff             1.22.4-4             1.22.4-5
                             libldap             2.4.57-1             2.4.58-1
                            openldap             2.4.57-1             2.4.58-1
                             systemd              247.4-2                248-1
                        systemd-libs              247.4-2                248-1
                  systemd-resolvconf              247.4-2                248-1
                  systemd-sysvcompat              247.4-2                248-1
                            xfsprogs             5.10.0-2             5.11.0-1
:: Different overlay package(s) in repository extra aarch64
                           pamac-cli             10.0.5-1         10.1.0beta-1
                        pamac-common             10.0.5-1         10.1.0beta-1
                pamac-flatpak-plugin             10.0.5-1         10.1.0beta-1
             pamac-gnome-integration             10.0.5-1         10.1.0beta-1
                           pamac-gtk             10.0.5-1         10.1.0beta-1
                   pamac-snap-plugin             10.0.5-1         10.1.0beta-1
:: Different sync package(s) in repository extra aarch64
                         archinstall              2.1.2-1              2.1.3-1
                                babl             0.1.84-1             0.1.86-1
                                bird              2.0.7-2              2.0.8-1
                                blas              3.9.0-3              3.9.1-1
                               bluez               5.56-2               5.57-1
                          bluez-cups               5.56-2               5.57-1
                       bluez-hid2hci               5.56-2               5.57-1
                          bluez-libs               5.56-2               5.57-1
                       bluez-plugins               5.56-2               5.57-1
                         bluez-utils               5.56-2               5.57-1
                               cblas              3.9.0-3              3.9.1-1
                            chromium       89.0.4389.90-1      89.0.4389.114-1
                            composer             2.0.11-1             2.0.12-1
                            coordgen              2.0.0-1              2.0.2-1
                       docbook-utils            0.6.14-11            0.6.14-12
                              dracut                052-1                053-1
                                 ell               0.38-1               0.39-1
                              ffmpeg            2:4.3.2-3            2:4.3.2-5
                               finch             2.14.1-3             2.14.2-1
                                gegl             0.4.28-2             0.4.30-1
                            ghostpcl             9.53.3-3             9.54.0-2
                         ghostscript             9.53.3-3             9.54.0-2
                            ghostxps             9.53.3-3             9.54.0-2
                           gi-docgen 2021.2+76+g7416fbe-1 2021.2+90+g7fbbaf3-1
                                gimp            2.10.22-2            2.10.24-1
                            graphviz             2.46.1-1             2.47.0-1
                       grilo-plugins           1:0.3.12-2           1:0.3.13-1
           gsettings-desktop-schemas               40.0-1               40.0-2
                      gst-plugin-gtk             1.18.4-1             1.18.4-2
                    gst-plugin-qmlgl             1.18.4-1             1.18.4-2
                    gst-plugins-good             1.18.4-1             1.18.4-2
               gtk-update-icon-cache1:4.0.3+61+gcb05be0aa5-1            1:4.2.0-2
                                gtk41:4.0.3+61+gcb05be0aa5-1            1:4.2.0-2
                            help2man             1.48.2-1             1.48.3-1
                         imagemagick           7.0.11.5-1           7.0.11.6-1
                     imagemagick-doc           7.0.11.5-1           7.0.11.6-1
                    kirigami-gallery            20.12.3-1            20.12.3-2
                              lapack              3.9.0-3              3.9.1-1
                          lapack-doc              3.9.0-3              3.9.1-1
                             lapacke              3.9.0-3              3.9.1-1
                          libisoburn              1.5.4-1              1.5.4-2
                           libpurple             2.14.1-3             2.14.2-1
                   libreoffice-fresh              7.1.1-1              7.1.2-1
                libreoffice-fresh-af              7.1.1-1              7.1.2-1
                libreoffice-fresh-am              7.1.1-1              7.1.2-1
                libreoffice-fresh-ar              7.1.1-1              7.1.2-1
                libreoffice-fresh-as              7.1.1-1              7.1.2-1
               libreoffice-fresh-ast              7.1.1-1              7.1.2-1
                libreoffice-fresh-be              7.1.1-1              7.1.2-1
                libreoffice-fresh-bg              7.1.1-1              7.1.2-1
                libreoffice-fresh-bn              7.1.1-1              7.1.2-1
             libreoffice-fresh-bn-in              7.1.1-1              7.1.2-1
                libreoffice-fresh-bo              7.1.1-1              7.1.2-1
                libreoffice-fresh-br              7.1.1-1              7.1.2-1
               libreoffice-fresh-brx              7.1.1-1              7.1.2-1
                libreoffice-fresh-bs              7.1.1-1              7.1.2-1
                libreoffice-fresh-ca              7.1.1-1              7.1.2-1
       libreoffice-fresh-ca-valencia              7.1.1-1              7.1.2-1
               libreoffice-fresh-ckb              7.1.1-1              7.1.2-1
                libreoffice-fresh-cs              7.1.1-1              7.1.2-1
                libreoffice-fresh-cy              7.1.1-1              7.1.2-1
                libreoffice-fresh-da              7.1.1-1              7.1.2-1
                libreoffice-fresh-de              7.1.1-1              7.1.2-1
               libreoffice-fresh-dgo              7.1.1-1              7.1.2-1
               libreoffice-fresh-dsb              7.1.1-1              7.1.2-1
                libreoffice-fresh-dz              7.1.1-1              7.1.2-1
                libreoffice-fresh-el              7.1.1-1              7.1.2-1
             libreoffice-fresh-en-gb              7.1.1-1              7.1.2-1
             libreoffice-fresh-en-za              7.1.1-1              7.1.2-1
                libreoffice-fresh-eo              7.1.1-1              7.1.2-1
                libreoffice-fresh-es              7.1.1-1              7.1.2-1
                libreoffice-fresh-et              7.1.1-1              7.1.2-1
                libreoffice-fresh-eu              7.1.1-1              7.1.2-1
                libreoffice-fresh-fa              7.1.1-1              7.1.2-1
                libreoffice-fresh-fi              7.1.1-1              7.1.2-1
                libreoffice-fresh-fr              7.1.1-1              7.1.2-1
               libreoffice-fresh-fur              7.1.1-1              7.1.2-1
                libreoffice-fresh-fy              7.1.1-1              7.1.2-1
                libreoffice-fresh-ga              7.1.1-1              7.1.2-1
                libreoffice-fresh-gd              7.1.1-1              7.1.2-1
                libreoffice-fresh-gl              7.1.1-1              7.1.2-1
                libreoffice-fresh-gu              7.1.1-1              7.1.2-1
               libreoffice-fresh-gug              7.1.1-1              7.1.2-1
                libreoffice-fresh-he              7.1.1-1              7.1.2-1
                libreoffice-fresh-hi              7.1.1-1              7.1.2-1
                libreoffice-fresh-hr              7.1.1-1              7.1.2-1
               libreoffice-fresh-hsb              7.1.1-1              7.1.2-1
                libreoffice-fresh-hu              7.1.1-1              7.1.2-1
                libreoffice-fresh-id              7.1.1-1              7.1.2-1
                libreoffice-fresh-is              7.1.1-1              7.1.2-1
                libreoffice-fresh-it              7.1.1-1              7.1.2-1
                libreoffice-fresh-ja              7.1.1-1              7.1.2-1
                libreoffice-fresh-ka              7.1.1-1              7.1.2-1
               libreoffice-fresh-kab              7.1.1-1              7.1.2-1
                libreoffice-fresh-kk              7.1.1-1              7.1.2-1
                libreoffice-fresh-km              7.1.1-1              7.1.2-1
          libreoffice-fresh-kmr-latn              7.1.1-1              7.1.2-1
                libreoffice-fresh-kn              7.1.1-1              7.1.2-1
                libreoffice-fresh-ko              7.1.1-1              7.1.2-1
               libreoffice-fresh-kok              7.1.1-1              7.1.2-1
                libreoffice-fresh-ks              7.1.1-1              7.1.2-1
                libreoffice-fresh-lb              7.1.1-1              7.1.2-1
                libreoffice-fresh-lo              7.1.1-1              7.1.2-1
                libreoffice-fresh-lt              7.1.1-1              7.1.2-1
                libreoffice-fresh-lv              7.1.1-1              7.1.2-1
               libreoffice-fresh-mai              7.1.1-1              7.1.2-1
                libreoffice-fresh-mk              7.1.1-1              7.1.2-1
                libreoffice-fresh-ml              7.1.1-1              7.1.2-1
                libreoffice-fresh-mn              7.1.1-1              7.1.2-1
               libreoffice-fresh-mni              7.1.1-1              7.1.2-1
                libreoffice-fresh-mr              7.1.1-1              7.1.2-1
                libreoffice-fresh-my              7.1.1-1              7.1.2-1
                libreoffice-fresh-nb              7.1.1-1              7.1.2-1
                libreoffice-fresh-ne              7.1.1-1              7.1.2-1
                libreoffice-fresh-nl              7.1.1-1              7.1.2-1
                libreoffice-fresh-nn              7.1.1-1              7.1.2-1
                libreoffice-fresh-nr              7.1.1-1              7.1.2-1
               libreoffice-fresh-nso              7.1.1-1              7.1.2-1
                libreoffice-fresh-oc              7.1.1-1              7.1.2-1
                libreoffice-fresh-om              7.1.1-1              7.1.2-1
                libreoffice-fresh-or              7.1.1-1              7.1.2-1
             libreoffice-fresh-pa-in              7.1.1-1              7.1.2-1
                libreoffice-fresh-pl              7.1.1-1              7.1.2-1
                libreoffice-fresh-pt              7.1.1-1              7.1.2-1
             libreoffice-fresh-pt-br              7.1.1-1              7.1.2-1
                libreoffice-fresh-ro              7.1.1-1              7.1.2-1
                libreoffice-fresh-ru              7.1.1-1              7.1.2-1
                libreoffice-fresh-rw              7.1.1-1              7.1.2-1
             libreoffice-fresh-sa-in              7.1.1-1              7.1.2-1
               libreoffice-fresh-sat              7.1.1-1              7.1.2-1
                libreoffice-fresh-sd              7.1.1-1              7.1.2-1
               libreoffice-fresh-sdk              7.1.1-1              7.1.2-1
                libreoffice-fresh-si              7.1.1-1              7.1.2-1
               libreoffice-fresh-sid              7.1.1-1              7.1.2-1
                libreoffice-fresh-sk              7.1.1-1              7.1.2-1
                libreoffice-fresh-sl              7.1.1-1              7.1.2-1
                libreoffice-fresh-sq              7.1.1-1              7.1.2-1
                libreoffice-fresh-sr              7.1.1-1              7.1.2-1
           libreoffice-fresh-sr-latn              7.1.1-1              7.1.2-1
                libreoffice-fresh-ss              7.1.1-1              7.1.2-1
                libreoffice-fresh-st              7.1.1-1              7.1.2-1
                libreoffice-fresh-sv              7.1.1-1              7.1.2-1
             libreoffice-fresh-sw-tz              7.1.1-1              7.1.2-1
               libreoffice-fresh-szl              7.1.1-1              7.1.2-1
                libreoffice-fresh-ta              7.1.1-1              7.1.2-1
                libreoffice-fresh-te              7.1.1-1              7.1.2-1
                libreoffice-fresh-tg              7.1.1-1              7.1.2-1
                libreoffice-fresh-th              7.1.1-1              7.1.2-1
                libreoffice-fresh-tn              7.1.1-1              7.1.2-1
                libreoffice-fresh-tr              7.1.1-1              7.1.2-1
                libreoffice-fresh-ts              7.1.1-1              7.1.2-1
                libreoffice-fresh-tt              7.1.1-1              7.1.2-1
                libreoffice-fresh-ug              7.1.1-1              7.1.2-1
                libreoffice-fresh-uk              7.1.1-1              7.1.2-1
                libreoffice-fresh-uz              7.1.1-1              7.1.2-1
                libreoffice-fresh-ve              7.1.1-1              7.1.2-1
               libreoffice-fresh-vec              7.1.1-1              7.1.2-1
                libreoffice-fresh-vi              7.1.1-1              7.1.2-1
                libreoffice-fresh-xh              7.1.1-1              7.1.2-1
             libreoffice-fresh-zh-cn              7.1.1-1              7.1.2-1
             libreoffice-fresh-zh-tw              7.1.1-1              7.1.2-1
                libreoffice-fresh-zu              7.1.1-1              7.1.2-1
                             libupnp             1.14.2-1             1.14.4-1
                             libxres              1.2.0-2              1.2.1-1
                      mkvtoolnix-cli             55.0.0-1             55.0.0-2
                      mkvtoolnix-gui             55.0.0-1             55.0.0-2
                            mousepad              0.5.3-1              0.5.4-1
                             mutter6             3.36.8-1                    -
              networkmanager-openvpn             1.8.12-1             1.8.14-1
                              okteta           1:0.26.5-1           1:0.26.6-1
                              ostree             2020.8-1             2021.1-1
                               p7zip              17.04-1            1:17.03-1
                  perl-io-socket-ssl              2.067-2              2.070-1
                        perl-net-dns               1.29-1               1.30-1
                              pidgin             2.14.1-3             2.14.2-1
            plasma-wayland-protocols              1.2.0-1              1.2.0-2
                          prometheus             2.25.2-1             2.26.0-1
                  python-archinstall              2.1.2-1              2.1.3-1
                      python-astroid              2.5.1-1              2.5.2-1
                      python-automat             20.2.0-5             20.2.0-6
                   python-constantly             15.1.0-8             15.1.0-9
                 python-cryptography              3.4.6-1              3.4.7-1
                   python-defusedxml              0.7.1-1              0.7.1-2
                      python-gobject             3.40.0-1             3.40.1-1
                    python-hyperlink             21.0.0-1             21.0.0-2
                         python-idna               2.10-3                3.1-1
                  python-incremental             17.5.0-6             21.3.0-2
               python-pyasn1-modules              0.2.8-3              0.2.8-4
                       python-pylint              2.7.2-1              2.7.4-1
             python-service-identity             18.1.0-6             18.1.0-7
                   python-setuptools           1:54.1.2-1           1:54.2.0-1
                      python-twisted             20.3.0-3             21.2.0-2
                      python-urllib3             1.26.3-1             1.26.4-1
                  python-urllib3-doc             1.26.3-1             1.26.4-1
                      python-wstools             0.4.10-3             0.4.10-4
               python-zope-interface              5.2.0-3              5.3.0-1
                     python2-automat             20.2.0-5                    -
                  python2-constantly             15.1.0-8                    -
                  python2-defusedxml              0.7.1-1                    -
                   python2-hyperlink             21.0.0-1                    -
                        python2-idna               2.10-4                    -
                 python2-incremental             17.5.0-6                    -
              python2-pyasn1-modules              0.2.8-3                    -
            python2-service-identity             18.1.0-6                    -
                     python2-twisted             20.3.0-3                    -
                     python2-urllib3             1.26.3-1             1.26.4-1
                     python2-wstools             0.4.10-3                    -
              python2-zope-interface              5.2.0-3              5.3.0-1
                             qt5-svg             5.15.2-1             5.15.2-2
                              qt6-3d              6.0.2-1              6.0.3-1
                         qt6-5compat              6.0.2-1              6.0.3-1
                            qt6-base              6.0.2-2              6.0.3-1
                     qt6-declarative              6.0.2-2              6.0.3-1
                             qt6-doc              6.0.2-1              6.0.3-1
                        qt6-examples              6.0.2-1              6.0.3-1
                    qt6-imageformats              6.0.2-1              6.0.3-1
                     qt6-networkauth              6.0.2-1              6.0.3-1
                         qt6-quick3d              6.0.2-1              6.0.3-1
                  qt6-quickcontrols2              6.0.2-1              6.0.3-1
                   qt6-quicktimeline              6.0.2-1              6.0.3-1
                     qt6-shadertools              6.0.2-1              6.0.3-1
                             qt6-svg              6.0.2-1              6.0.3-1
                           qt6-tools              6.0.2-2              6.0.3-1
                    qt6-translations              6.0.2-1              6.0.3-1
                         qt6-wayland              6.0.2-1              6.0.3-1
                                   r              4.0.4-1              4.0.5-1
                                 re2         1:20210202-1         1:20210401-1
                                re2c              2.0.3-1              2.1.1-1
                          squashfuse            0.1.104-1            0.1.104-2
                          stellarium             0.20.4-2             0.21.0-1
                            tracker3              3.1.0-1              3.1.1-1
                     tracker3-miners              3.1.0-1              3.1.1-1
                           gtk4-docs                    -            1:4.2.0-2
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi20.12.2.r12472.g22977abb9-120.12.2.r12474.g82c621a1e-1
                    akonadi-calendar20.12.2.r1915.g4e664c9-120.12.2.r1916.geef1bbf-1
              akonadi-calendar-tools20.12.2.r854.g5098025-120.12.3.r855.g9656768-1
                    akonadi-contacts20.12.2.r2987.g26ab3f56-120.12.2.r2988.g1d32a51b-1
               akonadi-import-wizard20.12.2.r1692.g421eddb-120.12.2.r1693.g8e9e54f-1
                        akonadi-mime20.12.2.r1603.gf50d051-120.12.2.r1604.g7aee356-1
                       akonadi-notes20.12.2.r991.g49bbb2b-120.12.2.r992.g5305c2e-1
                      akonadi-search20.12.2.r1067.g1691c4c-120.12.2.r1073.gbcfb7b9-1
                      akonadiconsole20.12.2.r1474.g6212cf8-120.12.3.r1475.g369dd50-1
                           akregator20.12.2.r6069.gfb848652-120.12.3.r6082.g6969aea6-1
                                 ark20.12.2.r4496.g4e1b331b-120.12.2.r4498.g0171728f-1
                              attica5.79.0.r796.g11c2d07-15.80.0.r797.gd8deade-1
                         audiocd-kio20.12.2.r1011.g10f647f-120.12.3.r1011.g10f647f-1
                               baloo5.79.0.r2931.gf6a7845b-15.80.0.r2939.g097eb7d0-1
                            bluez-qt5.79.0.r642.ge7be95f-15.80.0.r644.g013e7b5-1
                              breeze5.21.0.r2164.gcbde1297-15.21.0.r2166.g80aeb86c-1
                          breeze-gtk5.21.0.r411.g538055e-15.21.0.r412.ge989639-1
                        breeze-icons5.79.0.r1719.gc2364d3d-15.80.0.r1724.gff3cc2de-1
                                buho  1.2.1.r4.g6f2d9f6-1  1.2.1.r5.g84c1cb7-1
                     calendarsupport20.12.2.r500.g2ab19e2-120.12.2.r501.g5b394e8-1
                           calindori    1.4.r8.g34b72c1-1    1.4.r9.gc05f1f0-1
                             dolphin20.12.2.r6525.g6f134975a-120.12.2.r6531.g69881f93b-1
                     dolphin-plugins20.12.2.r557.g3b57bb8-120.12.2.r560.g6bc584e-1
                              dragon20.12.2.r995.g56e66c3-120.12.3.r995.g56e66c3-1
                             drkonqi5.21.0.r589.ge6274ae8-15.21.0.r593.g42aca174-1
                               elisa20.12.2.r2650.gcc64c1f4-120.12.3.r2654.gc75c1cac-1
                          eventviews20.12.2.r615.gffae56d-120.12.2.r622.ge6933fe-1
                 extra-cmake-modules5.79.0.r3274.g04f4675-15.80.0.r3275.gd88db6a-1
                        ffmpegthumbs20.12.2.r168.g4ded4c4-120.12.3.r168.g4ded4c4-1
                           filelight20.12.2.r947.g43937ee-120.12.2.r948.g52915b7-1
                frameworkintegration5.79.0.r572.g3511866-15.80.0.r573.gb8da0f3-1
                           granatier20.12.2.r904.g6e060be-120.12.2.r905.g58e3541-1
                     grantlee-editor20.12.2.r733.gc5cbe8f-120.12.3.r734.g7f8d4be-1
                       grantleetheme20.12.2.r308.g12a10c0-120.12.2.r309.ga238ac9-1
                            gwenview20.12.2.r6535.gf60fd58f-120.12.3.r6548.g75588f73-1
                            index-fm 1.2.1.r28.g7f5343e-1 1.2.1.r29.g653d9f0-1
                           itinerary20.12.2.r1231.g9bddc25-120.12.3.r1238.g2e1ddab-1
                                 juk20.12.2.r3090.gd6b28a9b-120.12.3.r3098.g476c201e-1
                                 k3b1:20.12.2.r6600.g73bb928ab-11:20.12.3.r6600.g73bb928ab-1
                         kactivities5.79.0.r1334.gcae42a3-15.80.0.r1335.g04f61a7-1
                   kactivities-stats5.79.0.r339.gc4cd603-15.80.0.r340.g12cc0bf-1
                   kactivitymanagerd5.21.0.r1331.gef63a4f-15.21.0.r1333.g70226e8-1
                              kalarm20.12.2.r6338.g66dd308e-120.12.3.r6345.gf054bf96-1
                           kalarmcal20.12.2.r1097.g5f77557-120.12.2.r1098.gb6e7ecb-1
                                kalk   0.2.r45.gcf60acb-1   0.2.r56.g4499164-1
                              kamera20.12.2.r648.g1545cf6-120.12.3.r648.g1545cf6-1
                              kamoso20.12.2.r1417.geb8c618-120.12.3.r1417.geb8c618-1
                             kapidox5.79.0.r519.gc41f1bb-15.80.0.r519.gc41f1bb-1
                        kapptemplate20.12.2.r945.g0b6f831-120.12.2.r946.gee7d314-1
                            karchive5.79.0.r461.g2d6661f-15.80.0.r462.g1065010-1
                                kate20.12.2.r17984.g3512583c8-120.12.2.r17991.gac0842e6f-1
                               kauth5.79.0.r420.g679ae91-15.80.0.r421.g4fb774d-1
                          kbookmarks5.79.0.r394.g76ce8c4-15.80.0.r395.g03ef2d8-1
                           kbreakout20.12.2.r842.g79dd899-120.12.2.r843.gf97feab-1
                               kcalc20.12.2.r1478.geaec2d0-120.12.2.r1480.g3d4e60d-1
                       kcalendarcore5.79.0.r1187.gaf1ae5f60-15.80.0.r1188.gac71748d3-1
                           kcalutils20.12.2.r821.gcac2f7e68-120.12.2.r822.g20d06ee57-1
                              kclock 0.4.0.r45.gf0ed0a5-1 0.4.0.r49.g8f57bcb-1
                            kcmutils5.79.0.r486.g5529ce0-15.80.0.r487.g6227a8e-1
                             kcodecs5.79.0.r352.gd50848a-15.80.0.r353.g61107e6-1
                       kcolorchooser20.12.2.r213.g1417e95-120.12.3.r213.g1417e95-1
                             kconfig5.79.0.r805.gecf0250-15.80.0.r806.ge5aa388-1
                      kconfigwidgets5.79.0.r548.gffd1595-15.80.0.r550.g942704d-1
                           kcontacts1:5.79.0.r3224.g258a8ae3-11:5.80.0.r3225.g9d7dc0fa-1
                         kcoreaddons5.79.0.r1195.g95473f38-15.80.0.r1196.gac9f6000-1
                              kcrash5.79.0.r364.g88d4194-15.80.0.r366.g658f35a-1
                                kdav1:5.79.0.r1271.gd23b148-11:5.80.0.r1272.gf3fd27a-1
                         kdbusaddons5.79.0.r345.ge12a5e8-15.80.0.r346.ge31e79b-1
                     kde-dev-scripts20.12.2.r4117.g09a8b73-120.12.2.r4123.g1c7b507-1
                        kdeclarative5.79.0.r875.g2bf16eb-15.80.0.r876.g85f764d-1
                          kdeconnect20.12.2.r3169.g7b15f2f9-120.12.3.r3172.g9a58c34a-1
                                kded5.79.0.r388.g0d72d8f-15.80.0.r389.g2353103-1
            kdegraphics-thumbnailers20.12.2.r230.g289e6e9-120.12.3.r230.g289e6e9-1
              kdenetwork-filesharing20.12.2.r878.ga1acc22-120.12.3.r878.ga1acc22-1
                            kdenlive20.12.2.r14211.g8fc9b014b-120.12.3.r14258.gf4dabe7f5-1
                       kdepim-addons20.12.2.r4031.g73af59f4-120.12.3.r4035.g51f49171-1
                     kdesignerplugin5.79.0.r312.g1df4ef2-15.80.0.r313.g3d38a41-1
                               kdesu5.79.0.r447.g7650704-15.80.0.r448.ga7f811d-1
                             kdialog20.12.2.r1169.g7293f12d7-120.12.2.r1171.g6657eb574-1
                              kdnssd5.79.0.r294.g92d6cfc-15.80.0.r295.ga7158bb-1
                           kdoctools5.79.0.r596.g7bd6e4a-15.80.0.r597.g793baa8-1
                          kemoticons5.79.0.r360.g40c0955-15.80.0.r361.geba0e1f-1
                       kfilemetadata5.79.0.r769.g429183f-15.80.0.r771.g91d6f59-1
                             kfloppy20.12.2.r731.g907536f-120.12.2.r738.gb00a470-1
                                kget20.12.2.r3090.g0b14720b-120.12.3.r3091.gbb455273-1
                                kgpg20.12.2.r3108.gd8f8a7bf-120.12.2.r3111.gf3990e47-1
                          kguiaddons5.79.0.r348.ga196e60-15.80.0.r349.gda49268-1
                           kholidays1:5.79.0.r916.gf5479c3-11:5.80.0.r918.gfb2b896-1
                               ki18n5.79.0.r448.g6f6c69f-15.80.0.r449.g2d3b6fe-1
                         kiconthemes5.79.0.r501.g6308161-15.80.0.r505.gb36a237-1
                 kidentitymanagement20.12.2.r3766.g81a58fb5-120.12.2.r3767.g209c9e5d-1
                           kidletime5.79.0.r287.g091c4bc-15.80.0.r288.g9568a39-1
                       kimageformats5.79.0.r321.ge80fcd7-15.80.0.r323.g2755f74-1
                     kimagemapeditor20.12.2.r454.g6f28d0b-120.12.3.r454.g6f28d0b-1
                               kimap20.12.2.r1074.g0c2b000-120.12.2.r1075.g9a32f1b-1
                               kinit5.79.0.r383.g974952b-15.80.0.r384.g824f579-1
                                 kio5.79.0.r4598.g6f3f84e1-15.80.0.r4608.gdb71aef6-1
                          kio-extras20.12.2.r6986.gb235e6e6-120.12.3.r6986.gb235e6e6-1
                          kio-gdrive20.12.2.r550.g1785cb8-120.12.3.r551.gc1eda10-1
                        kipi-plugins20.12.2.r12058.g97feceaa3-120.12.3.r12058.g97feceaa3-1
                     kirigami-addons5.79.0.r25.g2fb3fb1-15.79.0.r26.gb87abcd-1
                           kirigami25.79.0.r2720.g21de2a29-15.80.0.r2726.gfb2a7db8-1
                         kitemmodels5.79.0.r522.gdd7f00f-15.80.0.r523.gbfb3867-1
                          kitemviews5.79.0.r312.g66390b1-15.80.0.r314.g8513135-1
                          kitinerary20.12.2.r1666.g4b4aa72-120.12.2.r1697.g9814ddd-1
                         kjobwidgets5.79.0.r348.g1a8b3eb-15.80.0.r349.g6435a9f-1
                                 kjs5.79.0.r315.gc93d759-15.80.0.r316.g1f6c85a-1
                               kldap20.12.2.r835.g8f77bca-120.12.2.r836.g40e8b49-1
                           kleopatra20.12.2.r5771.gcbdf536d-120.12.3.r5772.g7f416826-1
                                kmag20.12.2.r674.g5d34672-120.12.2.r677.ge892328-1
                               kmail20.12.2.r25628.g8a6ae3fbf-120.12.3.r25636.g8443f9c88-1
                kmail-account-wizard20.12.2.r769.g8a36777-120.12.3.r770.g82d977b-1
                      kmailtransport20.12.2.r1585.g4849ce8-120.12.2.r1586.g9ec34d3-1
                               kmbox20.12.2.r505.g5a6c676-120.12.2.r506.g133e1c2-1
                               kmime20.12.2.r1419.gbcd952e-120.12.2.r1420.g0e7ef26-1
                              kmines20.12.2.r1700.gf413b5d-120.12.2.r1701.g10fe6ae-1
                                kmix20.12.2.r2355.g44cf1b34-120.12.3.r2355.g44cf1b34-1
                          kmousetool20.12.2.r379.g8123a8f-120.12.2.r383.gbc1f3f6-1
                              kmouth20.12.2.r680.g651fded-120.12.2.r682.g32f259e-1
                           knewstuff5.79.0.r1065.g96f193a4-15.80.0.r1068.g2f2499cc-1
                             knights20.12.2.r1037.g8f2bbab-120.12.3.r1039.g9000e91-1
                              knotes20.12.2.r3427.g480145e7-120.12.2.r3428.ga09a5d72-1
                      knotifications5.79.0.r630.g7e62736-15.80.0.r631.g85d7912-1
                       knotifyconfig5.79.0.r327.g1366984-15.80.0.r328.g3af435c-1
                                kolf20.12.2.r1410.g2b43183-120.12.3.r1410.g2b43183-1
                           kollision20.12.2.r477.g6645b5c-120.12.3.r477.g6645b5c-1
                         kolourpaint20.12.2.r2336.g0dfd68ad-120.12.3.r2336.g0dfd68ad-1
                            kongress      r172.g2091d34-1      r173.gd0aeefd-1
                           konqueror20.12.2.r14874.g1c38a9788-120.12.3.r14879.g779c1f43e-1
                            konquest20.12.2.r878.ge6f67a1-120.12.3.r878.ge6f67a1-1
                             konsole20.12.2.r7746.gec170136-120.12.2.r7750.gba81c56a-1
                             kontact20.12.2.r5276.gdf93f43a-120.12.2.r5278.gdc031be5-1
                    kontactinterface20.12.2.r597.g6e957bb-120.12.2.r598.gee97fa8-1
                        konversation20.12.2.r8944.g9288fab5-120.12.3.r8944.g9288fab5-1
                       kosmindoormap20.12.2.r591.g8f62cfd-120.12.2.r591.g8f62cfd-2
                            kpackage5.79.0.r644.g6568a2c-15.80.0.r645.ga665887-1
                              kparts5.79.0.r486.gd20746a-15.80.0.r487.gfc14959-1
                           kpatience20.12.2.r2523.gf7a807c-120.12.3.r2525.ge420437-1
                             kpeople5.79.0.r1303.g8363a97-15.80.0.r1304.g144d6a9-1
                             kpkpass20.12.2.r203.gfdc36d7-120.12.2.r204.g0b4a6a2-1
                           kplotting5.79.0.r269.g1127e4c-15.80.0.r270.g7ce7156-1
                                kpty5.79.0.r310.geb16fea-15.80.0.r311.g36e200c-1
                    kpublictransport20.12.2.r1563.gecef8e6-120.12.2.r1566.ga9135c3-1
                        kquickcharts5.79.0.r426.gdb63e80-15.80.0.r432.g2f868bf-1
                                krdc20.12.2.r1501.gccaed1c-120.12.3.r1501.gccaed1c-1
                            kreversi20.12.2.r1204.g64fefc2-120.12.3.r1204.g64fefc2-1
                                krfb20.12.2.r1377.g730e4d7-120.12.3.r1377.g730e4d7-1
                              kruler20.12.2.r680.g6efab8c-120.12.3.r680.g6efab8c-1
                             krunner5.79.0.r591.g036826a-15.80.0.r594.g60c2088-1
                             kscreen5.21.0.r1307.gafb4a77-15.21.0.r1314.g47006b9-1
                            kservice5.79.0.r883.g3d4bf44-15.80.0.r885.g2536db8-1
                             kshisen20.12.2.r1174.g66b50ab-120.12.3.r1174.g66b50ab-1
                               ksirk20.12.2.r951.g3d8e528-120.12.3.r951.g3d8e528-1
                               ksmtp20.12.2.r333.g540819d-120.12.2.r334.g49b2874-1
                          ksnakeduel20.12.2.r785.gd0848f0-120.12.3.r785.gd0848f0-1
                          kspaceduel20.12.2.r612.g5f55bce-120.12.3.r612.g5f55bce-1
                            ksquares20.12.2.r503.gddb98cd-120.12.3.r503.gddb98cd-1
                             ksudoku20.12.2.r1037.g948c839-120.12.3.r1037.g948c839-1
                           ksysguard5.21.0.r3493.g19b26d4a-15.21.0.r3495.gbc64affe-1
                          ksystemlog20.12.2.r620.g344e620-120.12.2.r622.g830aa1d-1
                         ktexteditor5.79.0.r2774.gfaef3b02-15.80.0.r2775.g7dfa4816-1
                        ktextwidgets5.79.0.r381.g650378b-15.80.0.r382.g28d5027-1
                               ktnef20.12.2.r631.g674aef5-120.12.2.r632.ga63e2e1-1
                            ktorrent20.12.2.r2731.ga93634ac-120.12.3.r2732.gfa6b7a38-1
                          ktuberling20.12.2.r993.gf92e649-120.12.3.r993.gf92e649-1
                             kubrick20.12.2.r357.g4a31aa5-120.12.3.r358.g4759701-1
                     kunitconversion5.79.0.r348.g518f872-15.80.0.r349.gdc81767-1
                             kwallet5.79.0.r1051.g1e4cf04-15.80.0.r1052.gbba12a1-1
                               kwave20.12.2.r3732.g3b8c119a-120.12.3.r3732.g3b8c119a-1
                            kwayland5.79.0.r1058.g8a1c135-15.80.0.r1060.g91b5a89-1
                     kwayland-server5.21.0.r1283.g8c52142-15.21.0.r1287.g076b1d5-1
                            kweather   0.4.r50.g1272003-1   0.4.r54.g0b67229-1
                      kwidgetsaddons5.79.0.r783.g4df60cb8-15.80.0.r785.gefbaf35d-1
                                kwin5.21.0.r19110.ga7aee99a2-15.21.0.r19135.g9168ced30-1
                       kwindowsystem5.79.0.r565.ga50278d-15.80.0.r566.gc6968eb-1
                           kwordquiz20.12.2.r1129.gfa5f048-120.12.2.r1130.g671bd65-1
                              kwrite20.12.2.r17984.g3512583c8-120.12.2.r17991.gac0842e6f-1
                             kxmlgui5.79.0.r730.g3aa6075b-15.80.0.r731.g63d2ede-1
                          libakonadi20.12.2.r12472.g22977abb9-120.12.2.r12474.g82c621a1e-1
                         libgravatar20.12.2.r336.g1a491de-120.12.2.r337.gf4c7eb1-1
                           libkdepim20.12.2.r817.gf924dbf-120.12.2.r818.g5ab293f-1
                             libkleo20.12.2.r781.g84b8db1-120.12.2.r782.ga7f7089-1
                         libquotient     r1971.g3378096-1     r1973.gfd84529-1
                               lskat20.12.2.r795.g57fe206-120.12.3.r795.g57fe206-1
                        mailimporter20.12.2.r437.g04bb3e7-120.12.2.r438.g091a271-1
                    maliit-framework0.99.1.r54.gee7d872c-30.99.1.r60.ga478e928-1
                     maliit-keyboard    r2063.gc26efe01-1    r2077.g320d08b2-1
                              marble20.12.2.r13285.gb6f01874c-120.12.2.r13289.g070623fd3-1
                       marble-common20.12.2.r13285.gb6f01874c-120.12.2.r13289.g070623fd3-1
                           marble-qt20.12.2.r13285.gb6f01874c-120.12.2.r13289.g070623fd3-1
                             mauikit1.2.1.r86.g88523371-11.2.1.r88.g5c19e9b5-1
                          messagelib20.12.2.r5846.g54b6d1af-120.12.2.r5860.g8dc86487-1
                     modemmanager-qt5.79.0.r496.gdae4704-15.80.0.r497.g6531b1d-1
                   networkmanager-qt5.79.0.r1089.ga332c80-15.80.0.r1090.g56ac5a3-1
                              okular20.12.2.r9252.gd195ab4e9-120.12.3.r9253.g1786e6c99-1
                        oxygen-icons1:5.79.0.r5.gbff159d-21:5.80.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.79.0.r5.gbff159d-21:5.80.0.r5.gbff159d-1
                            palapeli20.12.2.r1205.ge23ef85-120.12.3.r1205.ge23ef85-1
                              parley20.12.2.r4395.g3f1ffcd7-120.12.2.r4396.gfa6df3e1-1
                               picmi20.12.2.r522.g471314a-120.12.3.r522.g471314a-1
                      plasma-desktop5.21.0.r8282.g3c911926b-15.21.0.r8292.gf4eb3fb15-1
                       plasma-dialer    0.3.r6.g5021b4c-1    0.3.r7.g8e2d027-1
                    plasma-framework5.79.0.r15798.gcde7f8a98-15.80.0.r15807.g93598ec18-1
                           plasma-nm5.21.0.r3021.gbdfa35e8-15.21.0.r3024.g2a974269-1
             plasma-phone-components5.21.0.r1339.g8f4377d-15.21.0.r1342.gff6141d-1
                     plasma-settings      r867.gfa88d91-1      r869.ged4ec97-1
                plasma-systemmonitor5.21.0.r384.g5a50fd8-15.21.0.r387.gb120af5-1
              plasma-wayland-session5.21.0.r10090.g5126f17ec-15.21.0.r10103.g4bc6709e4-1
                    plasma-workspace5.21.0.r10090.g5126f17ec-15.21.0.r10103.g4bc6709e4-1
                          powerdevil5.21.0.r2419.ge7e085fb-15.21.0.r2420.g2e5512d0-1
                              prison5.79.0.r300.g78cf306-15.80.0.r301.gea4a2ea-1
                             purpose5.79.0.r837.g1831f3c-15.80.0.r838.g9f8a2ca-1
                          qmlkonsole       r81.g303bc52-1       r82.g81e74ad-1
                  qqc2-desktop-style5.79.0.r467.ge102a4e-15.80.0.r468.g5930de3-1
                                rocs20.12.2.r3004.g46cb716d-120.12.2.r3005.g6d26a1ff-1
                            sddm-kcm5.21.0.r569.g1dc118c-15.21.0.r571.g7949a4c-1
                               solid5.79.0.r653.g1b04dda-15.80.0.r654.gc15437b-1
                              sonnet5.79.0.r593.gcf1e696-15.80.0.r595.g09601ac-1
                            spacebar      r357.gd70459d-1      r361.g2388d52-1
                           spectacle20.12.2.r1067.gbe8ee0f-120.12.3.r1067.gbe8ee0f-1
                             svgpart20.12.2.r154.g7d74b09-120.12.3.r155.g7a8de92-1
                 syntax-highlighting5.79.0.r1556.g30caf2a0-15.80.0.r1558.g38ca36a7-1
          telepathy-kde-accounts-kcm20.12.2.r1192.g5a27a75-120.12.3.r1192.g5a27a75-1
              telepathy-kde-approver20.12.2.r293.g45db24b-120.12.3.r293.g45db24b-1
          telepathy-kde-auth-handler20.12.2.r276.g48e529c-120.12.3.r276.g48e529c-1
               telepathy-kde-call-ui20.12.2.r445.g8815182-120.12.3.r445.g8815182-1
          telepathy-kde-contact-list20.12.2.r1084.gd88224a-120.12.3.r1084.gd88224a-1
        telepathy-kde-contact-runner20.12.2.r252.g6d4f602-120.12.3.r252.g6d4f602-1
       telepathy-kde-desktop-applets20.12.2.r992.g4a74f96-120.12.3.r992.g4a74f96-1
  telepathy-kde-filetransfer-handler20.12.2.r219.gd345782-120.12.3.r219.gd345782-1
    telepathy-kde-integration-module20.12.2.r390.g08eac55-120.12.3.r390.g08eac55-1
             telepathy-kde-send-file20.12.2.r227.g53297c0-120.12.3.r227.g53297c0-1
               telepathy-kde-text-ui20.12.2.r2018.gab616c1-120.12.3.r2019.g2cae1c7-1
                        threadweaver5.79.0.r482.g1249d30-15.80.0.r483.gb06056f-1
                               vvave 1.2.1.r23.gae6d243-1 1.2.1.r24.g4e587ce-1
                    zeroconf-ioslave20.12.2.r336.g9bfa090-120.12.3.r336.g9bfa090-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Raspberry Pi 4 Model B Rev 1.1
Linux 5.11.10-1-MANJARO-ARM
Plasma 5.21.3
:egg::rabbit2:
Noticed libfido as an optional dep for systemd. Interesting.
And thanks very much for the update!
oooooooooooooomd.
