Font issue in Flash Player, Firefox
#1
sometimes i use flash player for casual browser games, the odd thing is flash has wrong font, when i type something or there is a message, it appears like this:
font
symbols instead of letters and numbers.
installed flash player via octopi, reinstalled it and nothing changed, version : 31,0,0,122
the same issue after updating to 31,0,0,153
no other application has this issue, and it didnt happen using others distros
pls send help!
#2
Do you have the ttf-ms-font package installed? If not, this might already help as the flash player defaults to font names … if some of the searched-for font name is not there it might go quirky.
If that doesn’t do the trick, it may be that this is still applicable:
http://muzso.hu/2010/02/15/font-problems-with-flash-and-linux
#3
No.
how do i install it ?
#4
install from aur
#5
cant find the ttf-ms-font :rage:
#6
Make sure you activate AUR. I sue trizen as wrapper and from Octopi you get this:
#7
activated AUR, trizen, and found the ttf-ms-fonts
i try installing it, terminal opens a window , i press y, then it just hangs with the message at the bottom,
Read 41 lines
:face_with_symbols_over_mouth:
#8
Read the comments on this here also read the comments on win10 fonts always read the AUR page it save wasted time trying to install software and you sometimes get a work around as well.
https://aur.archlinux.org/packages/ttf-ms-fonts/
#9
ma bad, i had to check the boxes -noconfirm -noedit, in Trizen, then it installed fine. :relieved:
#10
yay i got font in flashplayer
so this was the solution… install “ttf-ms-fonts” from AUR with trizen
:triumph:
thanks guys :hugs:
