Foliate won't open
I just install Foliate and it won’t open, I tried on the terminal and got this output:
foliate         SEGV ✘
** (com.github.johnfactotum.Foliate:2051): CRITICAL **: 19:49:18.315: g_irepository_find_by_name: assertion 'typelib != NULL' failed
(com.github.johnfactotum.Foliate:2051): GLib-GObject-WARNING **: 19:49:18.315: cannot register existing type 'TrackerSparqlConnection'
(com.github.johnfactotum.Foliate:2051): GLib-CRITICAL **: 19:49:18.315: g_once_init_leave: assertion 'result != 0' failed
(com.github.johnfactotum.Foliate:2051): GLib-GObject-CRITICAL **: 19:49:18.315: g_type_register_static: assertion 'parent_type > 0' failed
(com.github.johnfactotum.Foliate:2051): GLib-GObject-WARNING **: 19:49:18.315: cannot add private field to invalid (non-instantiatable) type '<invalid>'
(com.github.johnfactotum.Foliate:2051): GLib-GObject-CRITICAL **: 19:49:18.315: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
(com.github.johnfactotum.Foliate:2051): Tracker-CRITICAL **: 19:49:18.315: tracker_sparql_backend_load_plugins: assertion 'self != NULL' failed
zsh: segmentation fault (core dumped)  foliate
How to solve that?
