I did an installation on another computer with ext4 and now I am wondering why there is a folder named grub-btrfs in /etc/default
, although the system was not installed with btrfs. What is the reason for this?
edith: typo
edith: typo
sorry, typo
/etc/default
ofcourse
I believe grub-btrfs
is included in the default install in case people use btrfs. It is safe to remove if you don’t use btrfs.
Thanks @ben75 , that would probably be done with sudo pacman -Rns grub-btrfs
, right?
The question is, why does the installer not recognize by itself that no brtfs is present?
The installer simply copies a preset list of packages from the live media to your installed system. I’m sure they could include a script to remove unnecessary packages, but in most cases they are harmless to keep installed.
OK, thanks for your explanations.
You would do
sudo pacman -Syu grub
(and ‘yes’ to replace grub-btrfs)
