So, my Fn Lock indicator works and doesn’t work on the version of kernel it is on. It didn’t used to work on linux version 4. It worked in linux 5 on stable branch and not in lts branch. It is not working again right now in my linux 6.1 kernel. Can anyone tell me how is it working and not working ?
Additionally, I also wanna query something about Kernel update policy.
So today I received an stable update in my system and during the entire update I didn’t receive any kernel update at all. I remember downgrading to Stable kernel 5.15.8(something) so that my indicator could work. Now I got to know that the kernel I previously downgraded isn’t supported, I had to manually upgrade it. Normally during an update the package manager would normally remove the previous kernel and install the kernel that is to be supported and up-to-date with branch it is on.
I would love to know if I lack any knowledge on these things.
Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.26.4 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5
serial: <superuser required>
serial: <superuser required> UEFI: LENOVO v: FSCN14WW date: 08/26/2020
ID-1: BAT0 charge: 50.7 Wh (100.0%) condition: 50.7/60.0 Wh (84.5%)
volts: 17.2 min: 15.4 model: Celxpert L19C4PC0 status: full
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 2728 high: 2900 min/max: 1400/2900 boost: disabled
cores: 1: 2900 2: 2900 3: 2900 4: 2900 5: 2900 6: 2900 7: 2900 8: 2900
9: 1664 10: 1397 11: 2900 12: 2900 13: 2900 14: 2900 15: 2900 16: 2900
bogomips: 92658
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
bus-ID: 05:00.0 temp: 31.0 C
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-3:2
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting
dri: radeonsi gpu: amdgpu resolution: 1920x1080~144Hz
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.0-1-MANJARO) direct render: Yes
Device-1: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
bus-ID: 05:00.5
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6
Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-3:3
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 148.31 GiB (31.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS512GD9TNI-L2A0B
size: 476.94 GiB temp: 27.9 C
ID-1: / size: 468.09 GiB used: 148.31 GiB (31.7%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 33.4 C mobo: N/A gpu: amdgpu temp: 31.0 C
Processes: 338 Uptime: 24m Memory: 15 GiB used: 3.6 GiB (24.0%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1488 Shell: Zsh
v: 5.9 inxi: 3.3.24
Hope you have a great day.
