Hello,
I am using Manjaro on my DELL XPS 7590 as a primary OS, but sometimes I can see some flickering on the screen.
I do not use NVIDIA driver, I am just using the integrated video card.
The flickering is not always visible. It happen when I change the view such as scrolling browser and so on.
Similar issue here, with a Dell Inspiron 15, using intel iris integrated graphics.
The glitch appears on one or two thick lines on the screen, although not always the same (checked using axosnake – great benchmark, I know–, the line changes but not over a short period of time).
intel_gpu_top says the pc is far from peak capacity, with everything pretty low, the cpu is low as well, the only thing that seems weird is that in the intel_gpu_top does say “RC6” is at 75-80%, sometimes more, but I have no idea what this is…
Also potentially relevant, this did not happen earlier this day, back when I had not updated (the big update from a few days ago) and when my kernel was still 5.7 (vs 5.9 now, but the glitch also does happen on 5.4, so I don’t think that’s a factor).
So, actually I had the instinct that it was related to the integrated graphics, because it would make sense, so I went on the ArchWiki and found this: Intel graphics - ArchWiki. When enabling framebuffer compression (adding options i915 enable_fbc=1 to /etc/modprobe.d/i915.conf, see the Archwiki), then rebooting, it fixed the problem on my machine.
Before that I also flicked all the tunables from powertop to “good” and rebooted, it didn’t seem to fix anything but those are the two things I changed recently, and I don’t see the problem anymore, so if the first option doesn’t work you may try the second.
It kinda bothers me not to actually understand what was wrong, but I don’t have too much time to spend on this, so…
Does your problem persists on 5.9? Because more people are having these issues at the moment for some time now without a resolve or solution. Please try downgrading to 5.8 if your problem still persists.
For myself, the screen glitches like a “seizure” when I scroll or move the mouse. It is not artifacting but just… graphical glitches.
