Flatpak - no nvidia drivers installed
HI!
i have installed the pcsx2-emulator and flatpak has not installed the nvidia runtime driver…
how can i install them?
thanks!
greets
ulrich
Try running flatpak update, it should pull in / update any dependencies.
faltpak update says - nothing to do…
flatpak has installed the mesa-drivers…
thanks!
Usually, it is the responsibility of the package maintainer to add it as a dependency. Better ask there…
The package have to match the current installed driver version exactly. So it should be something like:
org.freedesktop.Platform.GL.nvidia-535-86-05
If @ulrichu used Pamac, it may not have pulled in the required Runtimes:
