Whenever I try to use adobe connect on my Manjaro machine I get the following error:
Adobe Connect requires Flash Player 11.2 or above. Adobe Connect requires the Flash Player plugin, version 11.2 or above. Please download and install the Flash Player to continue.
I tried to download flash player but I guess adobe flash player has ended its life. So what I can do?
Adobe Flash is End of life… As of December 31, 2020. 2 years ago.
I know, but how can I use the services like adobe connect when they ask for adobe flash player?
Hi @Leviathan,
Please see:
https://unix.stackexchange.com/questions/605442/is-there-a-way-to-get-adobe-connect-to-work-in-linux
Hope it helps!
Edit:
Or,
https://askubuntu.com/questions/1305834/20-04-how-to-use-adobe-connect-in-ubuntu
Or you could add ?html_view=true
at the end of the meeting URL to open without flash.
As per my first link
That’s the URL:
site.com/system/get-player?urlPath=/rmqu27oxqe63/
Changed that to this:
site.com/system/get-player?urlPath=/rmqu27oxqe63?html_view=true
and this:
site.com/system/get-player?urlPath=/rmqu27oxqe63/?html_view=true
Still not working
How about if you add &proto=true
to the end, as per my second link?
try this:
site.com/system/get-player?urlPath=/rmqu27oxqe63&html_view=true
