It should download, compile, etc. driver from github, but it is failing at beginning compilation:
(2/2) Install DKMS modules
==> dkms install --no-depmod -m fl2000 -v r23.2fc7b1b -k 5.4.64-1-MANJARO
Error! Bad return status for module build on kernel: 5.4.64-1-MANJARO (x86_64)
Consult /var/lib/dkms/fl2000/r23.2fc7b1b/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m fl2000 -v r23.2fc7b1b -k 5.4.64-1-MANJARO' returned 10
==> depmod 5.4.64-1-MANJARO
In the log there is an information about missing kernel headers files, first I downloaded manjaro headers from gitlab and copy missing files to /usr/lib/… but it needed more files every time, so I just edited dkms.conf.in and replaced ${kernel_source_dir} with path to my manjaro headers from git in /home, then it starting to compile and after 2h it fails with other code:
==> dkms install --no-depmod -m fl2000 -v r32.2a89a51 -k 5.4.67-1-MANJARO
Error! Build of fl2000.ko failed for: 5.4.67-1-MANJARO (x86_64)
Consult the make.log in the build directory
/var/lib/dkms/fl2000/r32.2a89a51/build/ for more information.
==> Warning, `dkms install --no-depmod -m fl2000 -v r32.2a89a51 -k 5.4.67-1-MANJARO' returned 7
==> depmod 5.4.67-1-MANJARO
DKMS make.log for fl2000-r23.2fc7b1b for kernel 5.4.67-1-MANJARO (x86_64)
nie, 4 paĹş 2020, 21:50:53 CEST
make: Entering directory '/usr/lib/modules/5.4.67-1-MANJARO/build'
scripts/Makefile.build:42: arch/x86/entry/syscalls/Makefile: No such file or directory
make[1]: *** No rule to make target 'arch/x86/entry/syscalls/Makefile'. Stop.
make: *** [arch/x86/Makefile:238: archheaders] Error 2
make: *** Waiting for unfinished jobs....
make: Leaving directory '/usr/lib/modules/5.4.67-1-MANJARO/build'
If I copy arch/x86/entry it need arch/x86/tools then I give up and give it headers from git
