Fixing notification color issue in Arc/Arc-Maia theme in Gnome 3.24
tutorial
#1
I saw this topic, which is closed automatically after 30 days, so I created a new one.
Finally I found a way to solve this.
it’s better to make a child theme based on the installed main theme. because we must change something in the core files. so we make a child theme, to avoid editing the core files.
  1. make these folder structures and a css file like this:
~/.local/share/themes/Arc-Maia-Modified/gnome-shell/gnome-shell.css
  1. then add these lines to this file:
@import url("/usr/share/themes/Arc-Maia/gnome-shell/gnome-shell.css");
.message-title {
color: #5c616c; }
.message-content {
color: #5c616c; }
I assume that your Arc-Maia theme which is installed as a package, is under /usr/share/themes/Arc-Maia/
If you installed your theme in a different location, you should change the @import line location.
3. after that, restart Gnome, and run gnome-tweaks, then choose Arc-Maia-Modified for the shell part.
split this topic #2
6 posts were merged into an existing topic: Maia shell theme on Gnome 3.24; dash-to-dock and notification panel issues
closed #3
