Fixing freezes on a new desktop using the Manjarowish liveCD
#1
Moved from Linux 5.1 causes freezing, anything below causes horrendous gaming performance..
My new high-end desktop computer keeps randomly freezing at some time after I boot it up, then I have to restart it or it won't unfreeze. I'm on the 5.0.7 kernel. I installed Manjarowish recently on a brand new high-end desktop computer. I've installed earlier kernels and may try them out later, after updating the BIOS for my ASUS motherboard as per Jonathan's suggestion. My GPU is NVIDIA TU104, however, not Radeon VII.
It's not very clear how to use the CAP file to update the BIOS on a Manjaro Linux computer. Since ASUS customer support isn't open now, I'll just try putting the CAP file on a USB, booting into the BIOS and see if I can run the file.
~ >>> inxi -Fxzc0
  Host: fm Kernel: 5.0.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
  Desktop: KDE Plasma 5.15.4 Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: TUF B450M-PLUS GAMING v: Rev X.0x
  serial: <filter> UEFI [Legacy]: American Megatrends v: 0604
  date: 12/07/2018
  Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP
  arch: Zen+ rev: 2 L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 118220
  Speed: 4198 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 4266
  2: 4260 3: 4266 4: 4254 5: 2131 6: 2134 7: 2846 8: 2844 9: 2844 10: 2836
  11: 2133 12: 2132 13: 2839 14: 2846 15: 4268 16: 4093
  Device-1: NVIDIA TU104 vendor: ASUSTeK driver: nouveau v: kernel
  bus ID: 07:00.0
  Display: x11 server: X.Org 1.20.4 driver: modesetting,nouveau
  resolution: 1920x1080~60Hz
  OpenGL: renderer: llvmpipe (LLVM 8.0 128 bits) v: 3.3 Mesa 19.0.2
  direct render: Yes
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus ID: 07:00.1
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 09:00.3
  Sound Server: ALSA v: k5.0.7-1-MANJARO
  vendor: ASUSTeK driver: r8168 v: 8.045.08-NAPI port: f000
  bus ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.36 TiB used: 282.93 GiB (20.2%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
  ID-2: /dev/sda type: USB vendor: Seagate model: Expansion
  ID-1: / size: 389.33 GiB used: 282.93 GiB (72.7%) fs: ext4
  dev: /dev/nvme0n1p1
  ID-2: swap-1 size: 69.20 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 64.8 C mobo: N/A gpu: nouveau temp: 30 C
  Fan Speeds (RPM): cpu: 0 gpu: nouveau fan: 1009
  Processes: 324 Uptime: 6m Memory: 62.91 GiB used: 3.31 GiB (5.3%)
  Init: systemd Compilers: gcc: 8.2.1 clang: 8.0.0 Shell: zsh v: 5.7.1
  inxi: 3.0.32
I'll read the manual as well.
#2
I guess need to listen Jonathan's advice. Update a bios and see whether freezes gone.
For more information you can google "ryzen" "freeze" "c-states"
But will hope updating bios help.
#3
All good, let's see how following this goes:
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/PRIME_A320M-A/E13571_BIOS_Update_EM_V4_WEB.pdf#E13571_BIOS_Update_EM_V4.indd%3A.16124%3A79990
#4
  1. Does this type of issue appear when running from various different live disks.
  2. How many different live versions have you tested.
  3. Has this issue been absent on any of the live versions, if so which ones.
  4. Was this issue apparent as soon as you installed, or did it appear after making changes to your system.
#5
All fixed! Well, the BIOS is updated. Let's see if it keeps happening. @tbg, I'll answer those queries if it keeps happening.
  serial: <filter> UEFI [Legacy]: American Megatrends v: 1002
  date: 03/07/2019
#6
OK it just froze after about 2 hours. I'll try other kernels and other live disks.
This issue was apparent as soon as I installed, IIRC. Although, I may have installed yay and ran it straight away after using it. But I have probably only used it for a few hours all up, and AFAICR it has frozen every session.
However, I'm flying to Berlin, then travelling to Zug, Switzerland, in 2 days, for about a month, so I won't be taking the desktop with me. And I have stuff to do before I fly so I may come back to this when I get back.
#7
I also can't copy files from an SD card to a phone, both connected by SS USB. I get a "Could not make folder /" error. I'll try burning the latest kde official stable iso , 18.0.4, and try installing.
#8
install gvfs-mtp
but i doubt it will help as kde uses kio.
but official iso include
this package
#9
I can't even do that, it fails to download from multiple mirrors.
#10
use this command to rfresh mirrors
sudo pacman-mirrors -f0 && sudo pacman -Syyu
you can alao use 10,5 etc any number instead of 0
Kernel panic - not syncing: No working init found
#11
just chiming in here to -again- point out that manjarowish is one individuals 'spin' and not an official, or even community, variant of manjaro.
Well after running the above commands, there have been no freezes so far. The screen is quite flickery with a DisplayPort connection.
https://wiki.archlinux.org/index.php/NVIDIA/Troubleshooting#Avoid_screen_tearing_in_KDE_(KWin)
check this out and see if it helps
#14
OK I did: https://wiki.archlinux.org/index.php/NVIDIA/Troubleshooting#1._GL_threads
The screen is still pretty flickery.
#15
It's still freezing. It has frozen twice in the past couple of hours, including just now. Going to try https://osdn.net/projects/manjaro/storage/kde/18.0.4/manjaro-kde-18.0.4-stable-x86_64.iso/.
#16
When I boot the KDE stable iso on a live USB and DVD I get to this point:
#17
you can access tty.
also since your hardware is new you can use kde-dev iso which has latest kernel.
does your hardware boot with 4.19 kernel??
#18
I hadn't been able to boot into it after installing with the KDE iso. After installing Ubuntu I can now boot into Ubuntu. I'll try the kde-dev iso.
#19
Just now, still with Ubuntu, I noticed that there was an issue while typing in a field in a job board page. Keystrokes would lag and the text displayed would not be as expected.
#20
i think you should try the kernel 5.1 when its released.
as your hardware is new your issues might be solved with new kernel.
