Fixed my Pamac AUR problem, may help others.
I could see the AUR repository and search it, yet install always failed. From another post, I found the default directory was /var/tmp/"username". I created the directory, sudo mkdir etc. Selected it in the Pamac preferences, and it still failed. Changed owner to my username. Changed mode to 775 so both root and I had full privileges. It worked. I now have the browser plugin for OBS.
Hopefully this will help others who may be having similar problems
@guinux is this needed?
No the default folder is created automatically with good permissions.
Unfortunately, the directory was not created automatically for me, and it was a simple stock install of the OS.
@guinux: can we revisit this?
I can't check it now because I'm not at home for the next two weeks but it easy to test: remove your build dir and try to build a package.
