Hello,
Im trying to let my AMD Ryzen 9800X3D run on a fixed value as i did in the past with Intel i7-6700k with cpupower-service.conf but for some reason it don’t work.
/etc/default/cpupower-service.conf:
# SPDX-License-Identifier: GPL-2.0-or-later
# Copyright (C) 2012, Sébastien Luttringer
# Copyright (C) 2024-2025, Francesco Poli <invernomuto@paranoici.org>
# Configuration file for cpupower.service systemd service unit
# Edit this file (uncommenting at least one of the options, depending on
# your preferences) and then enable cpupower.service, if you want cpupower
# to run at boot with these settings.
# --- CPU clock frequency ---
# Define CPU governor
# Valid governors: ondemand, performance, powersave, conservative, userspace
GOVERNOR='performance'
# Limit frequency range
# Valid suffixes: Hz, kHz (default), MHz, GHz, THz
MIN_FREQ="5.10GHz"
MAX_FREQ="5.10GHz"
# Set a specific frequency
# Requires userspace governor to be available.
# If this option is set, all the previous frequency options are ignored
#FREQ=
# --- CPU policy ---
# Set a register on supported Intel processore which allows software to convey
# its policy for the relative importance of performance versus energy savings to
# the processor. See man CPUPOWER-SET(1) for additional details
#PERF_BIAS=
# Set the Energy Performance Preference
# Available options can be read from
# /sys/devices/system/cpu/cpufreq/policy0/energy_performance_available_preferences
#EPP=
I also enabled the service after that change and restarted my PC:
$ systemctl status cpupower.service
● cpupower.service - Apply cpupower configuration
Loaded: loaded (/usr/lib/systemd/system/cpupower.service; enabled; preset: disabled)
Active: active (exited) since Sat 2026-10-03 19:03:56 CEST; 3min 32s ago
Invocation: bec8d4334e8941229a00399b1719eec1
Process: 765 ExecStart=/usr/lib/systemd/scripts/cpupower (code=exited, status=0/SUCCESS)
Main PID: 765 (code=exited, status=0/SUCCESS)
Mem peak: 2.7M
CPU: 5ms
Okt 03 19:03:56 koboldx-x870e systemd[1]: Starting Apply cpupower configuration...
Okt 03 19:03:56 koboldx-x870e systemd[1]: Finished Apply cpupower configuration.
But i can’t see any difference with watch grep \"cpu MHz\" /proc/cpuinfo it still idling around 600Mhz on Desktop , here are some System Info:
$ cpupower frequency-info
analyzing CPU 1:
driver: amd-pstate-epp
CPUs which run at the same hardware frequency: 1
CPUs which need to have their frequency coordinated by software: 1
energy performance preference: performance
hardware limits: 603 MHz - 5.27 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 603 MHz and 5.10 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 4.67 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
amd-pstate limits:
Highest Performance: 166. Maximum Frequency: 5.27 GHz.
Nominal Performance: 148. Nominal Frequency: 4.70 GHz.
Lowest Non-linear Performance: 19. Lowest Non-linear Frequency: 603 MHz.
Lowest Performance: 19. Lowest Frequency: 600 MHz.
Preferred Core Support: 1. Preferred Core Ranking: 191.
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 9800X3D 8-Core Processor
CPU family: 26
Model: 68
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Stepping: 0
Microcode version: 0xb404035
Frequency boost: enabled
CPU(s) scaling MHz: 26%
CPU max MHz: 5271,6221
CPU min MHz: 603,3790
BogoMIPS: 9381,80
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx f
xsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good am
d_lbr_v2 nopl xtopology nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq m
onitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cm
p_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit w
dt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpuid_fault cpb cat_l
3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp ibrs_enhanced vmmcall fsgsbase
tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx sm
ap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetb
v1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local user_shstk avx_vnni avx51
2_bf16 clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save
tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_
vmload vgif x2avic v_spec_ctrl vnmi avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes
vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid bus_lock_detect movdiri m
ovdir64b overflow_recov succor smca fsrm avx512_vp2intersect flush_l1d amd_lbr_pmc_fr
eeze
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 384 KiB (8 instances)
L1i: 256 KiB (8 instances)
L2: 8 MiB (8 instances)
L3: 96 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-15
Gather data sampling: Not affected
Ghostwrite: Not affected
Indirect target selection: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Old microcode: Not affected
Reg file data sampling: Not affected
Retbleed: Not affected
Spec rstack overflow: Mitigation; IBPB on VMEXIT only
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS; IBPB conditional; STIBP always-on; PBRSB-eIBRS
Not affected; BHI Not affected
Srbds: Not affected
Tsa: Not affected
Tsx async abort: Not affected
Vmscape: Mitigation; IBPB on VMEXIT
Hopefully someone has a idea what i did wrong, im a little bid lost now, adjusting my Intel i7 was way easier.
Edit: Okay after playing around with some values:
MIN_FREQ=“4.70GHz”
MAX_FREQ=“5.00GHz”
Showed clearly that Max Frequency is working and has a CPU Limiting impact when i run CPU heavy tasts.
But Min Frequency (which is the most important value for me) is fully ignored.
I also was in my Bios and fixed CPU Clock Ratio from Auto to 48 which still not allowed me min frequency but instead limiting my CPU to 4800Mhz on all cores. ![]()
