First start with manjaro
Yesterday i installed manjaro xfce for the first time. After reading your wiki i was ready for it.
And suprisingly within 1 hour everything was working perfect, including wifi, nvidia, printing.
So a very good result thanks to your site, forum and wiki. I love manjaro very much.
Next job now you’ve got an installation working to your satisfaction: take a full backup and make sure you know how to restore from it if something goes wrong. There are various ways to take backups, I suggest doing a bit of research and seeing which suits you best. (Personally I still prefer the good, old-fashioned dump utility, for EXTn filesystems).
If at all possible, your backups should be on a completely separate physical device to the one your OS is installed on (USB-pluggable disc, second internal disc, etc) in readiness for the day your hard drive fails (they last a long time these days, but still fail eventually).
Welcome!
Just keep an eye on the Forum Announcements e.g. for Stable Updates for information on what you might need to do.
Hi @hvanessen and welcome to the Manjaro community.
Thanks for your kind words.
I wonder if you’d mind sharing system information with us; which will give others a fine example of hardware that works ‘out of the box’ with Manjaro.
Simply paste the output of the following command into a preformatted text box using the </> button:
inxi --admin --verbosity=8 --filter --no-host --width
Cheers.
Subscribe via RSS to the Update thread.
Check: Snapshots to roll back.
Check :Backups for data (maybe rsync with back-in-time or whatever u fancy).
Sorted. Congratulations :wink:
  Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=c30322ca-a888-4038-a815-132bec7c3295 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: ASUSTeK product: K30BF_M32BF_A_F_K31BF v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: K30BF_M32BF_A_F_K31BF v: Rev X.0x
    UEFI: American Megatrends v: 0602 date: 07/31/2015
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.57 GiB used: 1.38 GiB (8.9%)
  Array-1: capacity: 32 GiB slots: 2 modules: 2 EC: Multi-bit ECC
  Device-1: Channel-A DIMM 0 type: DDR3 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 1600 MT/s volts: N/A width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: BLS8G3D1609DS1S00.
    serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR3 detail: synchronous unbuffered
    serial: <filter>
  Info: model: AMD A8-6500 APU with Radeon HD Graphics bits: 64 type: MCP
    arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
    model-id: 0x13 (19) stepping: 1 microcode: 0x6001119
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 192 KiB desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
  Speed (MHz): avg: 1700 min/max: 1700/3500 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1700 2: 1700 3: 1700
    4: 1700 bogomips: 27936
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
    cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
    extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
    hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
    msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
    vme vmmcall wdt xop xsave
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: N/A failed: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0.0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 model: Asus VS247 serial: <filter> built: 2015
    res: 1920x1080 dpi: 94 gamma: 1.2 chroma: red: x: 0.643 y: 0.337 green:
    x: 0.310 y: 0.620 blue: x: 0.157 y: 0.059 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1440x576, 1024x768, 1440x480, 800x600, 720x576,
    720x480, 640x480
  Monitor-2: Unknown-1 size-res: N/A modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB
  Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
    class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: down mac: <filter>
  Device-2: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU] driver: rtl8xxxu
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-2:3
    chip-ID: 2357:0109 class-ID: 0000 serial: <filter>
  IF: wlp4s0u2 state: up mac: <filter>
  Local Storage: total: 3.18 TiB used: 146.24 GiB (4.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-22BN5A0
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD25EZRX-00AZ6B0 size: 2.27 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS DVD model: RAM GHC1N rev: AS00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 14.41 GiB (1.6%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: c30322ca-a888-4038-a815-132bec7c3295
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: E368-9C3C
  ID-3: /mnt/Blender raw-size: 1.63 TiB size: 1.63 TiB (100.00%)
    used: 37.64 GiB (2.3%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19 label: Blender
    uuid: ACF2A4FBF2A4CAC2
  ID-4: /mnt/HvESoft raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
    used: 2.87 GiB (1.0%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: HvESoft
    uuid: 446D84D30BE6C70E
  ID-5: /mnt/Overig raw-size: 366.21 GiB size: 366.21 GiB (100.00%)
    used: 91.31 GiB (24.9%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: Overig
    uuid: 64729D18729CF052
  Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Device-1: 1-5:2 info: Trust Gaming Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:01ac class-ID: 0301
  Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
  Device-1: 2-2:2 info: Alcor Micro Multi Flash Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 250mA chip-ID: 058f:6366 class-ID: 0806
    serial: <filter>
  Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
  Hub-4: 3-5:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Hub-5: 4-0:1 info: full speed or root hub ports: 4 rev: 2.0
  Hub-6: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
  Hub-7: 6-0:1 info: full speed or root hub ports: 4 rev: 1.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 7-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 7-2:3 info: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU]
    type: Network driver: rtl8xxxu interfaces: 1 rev: 2.1
  Hub-9: 8-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 10.0 C mobo: N/A gpu: nvidia temp: 28 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
  Packages: 1156 pm: pacman pkgs: 1148 libs: 342 tools: pamac pm: flatpak
    pkgs: 8
    1: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 219
  1: cpu: 50.0% command: ps pid: 1711 mem: 3.25 MiB (0.0%)
  2: cpu: 13.8% command: chrome pid: 1549 mem: 252.6 MiB (1.5%)
  3: cpu: 8.3% command: chrome pid: 1373 mem: 290.0 MiB (1.8%)
  4: cpu: 7.4% command: chrome pid: 1414 mem: 240.8 MiB (1.5%)
  5: cpu: 2.2% command: Xorg pid: 717 mem: 75.3 MiB (0.4%)
  Memory top: 5 of 219
  1: mem: 290.0 MiB (1.8%) command: chrome pid: 1373 cpu: 8.3%
  2: mem: 252.6 MiB (1.5%) command: chrome pid: 1549 cpu: 13.8%
  3: mem: 240.8 MiB (1.5%) command: chrome pid: 1414 cpu: 7.4%
  4: mem: 142.4 MiB (0.8%) command: chrome pid: 1525 cpu: 0.6%
  5: mem: 114.0 MiB (0.7%) command: chrome pid: 1419 cpu: 1.8%
  Processes: 219 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.32 running-in: xfce4-terminal
    inxi: 3.3.36
I’d definitely install another Kernel, as this one is EOL and may cause issues with future system updates. I suggest trying linux66 which should work with hardware of that vintage, or linux61 if not.
Those are both LTS (Long Term Support) kernels.
Example:
sudo mhwd-kernel -i linux66
You might also need to run:
sudo update-grub
… but mhwd-kernel should take care of that.
You can select the Kernel to boot from via the GRUB menu. If you don’t see that, feel free to ask. :wink:
Cheers! :slight_smile:
ETA: To list available and installed Kernels:
mhwd-kernel -l && mhwd-kernel -li
Agreed. Kernels 6.10 and 6.11 have been available since. Kernel 6.12 (LTS) is expected to be released in November; if you can hold out that long.
You might also wish to configure swap space.
Start a new thread if you’re uncertain how to do this, and I’m sure someone will point you in the right direction.
Cheers.
I followed your(s) advice with a new kernel and a swapfile. Performance is better i noticed.
Thanks
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    status: discharging
  System RAM: total: 16 GiB available: 15.57 GiB used: 1.82 GiB (11.7%)
    serial: <filter>
    serial: <filter>
    4: 1700 bogomips: 27941
    720x480, 640x480
    memory: 3.91 GiB
    class-ID: 0403
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Local Storage: total: 3.18 TiB used: 163 GiB (5.0%)
    dev-links: cdrom
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 31.17 GiB (3.4%)
    uuid: E368-9C3C
    used: 37.65 GiB (2.3%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19 label: Blender
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Hub-3: 2-5:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
  Hub-4: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
  Device-1: 3-2:2 info: Alcor Micro Multi Flash Reader type: mass storage
    serial: <filter>
  System Temperatures: cpu: 3.5 C mobo: N/A gpu: nvidia temp: 29 C
  Packages: 1158 pm: pacman pkgs: 1150 libs: 342 tools: pamac pm: flatpak
    pkgs: 8
Processes:
  CPU top: 5 of 232
  1: cpu: 100% command: ps pid: 2132 mem: 3.37 MiB (0.0%)
  2: cpu: 19.7% command: chrome pid: 2094 mem: 242.7 MiB (1.5%)
  3: cpu: 2.0% command: chrome pid: 2053 mem: 149.9 MiB (0.9%)
  4: cpu: 1.9% command: chrome pid: 1543 mem: 305.4 MiB (1.9%)
  5: cpu: 1.6% command: chrome pid: 1588 mem: 248.6 MiB (1.5%)
  Memory top: 5 of 232
  1: mem: 305.4 MiB (1.9%) command: chrome pid: 1543 cpu: 1.9%
  2: mem: 248.6 MiB (1.5%) command: chrome pid: 1588 cpu: 1.6%
  3: mem: 242.7 MiB (1.5%) command: chrome pid: 2094 cpu: 19.7%
  4: mem: 219.6 MiB (1.3%) command: chrome pid: 1625 cpu: 1.1%
  5: mem: 195.0 MiB (1.2%) command: chrome pid: 1867 cpu: 0.7%
  Processes: 232 Power: uptime: 27m states: freeze,mem,disk suspend: deep
    inxi: 3.3.36
We aim to please. :slight_smile:
This will help to prevent the system choking when RAM is starved.
