I customized my xfce4-terminal both on my root account and on my own account (which is in sudoers).
Until this afternoon, when I opened a nemo window as root, and then opened a terminal, it would look like it does when I’m logged in on the root account.
But after this afternoon’s update, it shows up raw, utterly uncustomized.
Would you know how I can restore its original behavior?
When I try to modify the customization of the root terminal on my own account, the settings are not being saved.
That’s because anything running with root privileges looks for its configuration in /root/.config and /root/.local/share, whereas anything running under your own UID looks in ~/.config and ~/.local/share.
So I should, somehow, get the “open terminal” option to resort to the root/.config setting, as it did before the update. It’s a pity that I can’t look back how it was yesterday.
