The firefox does not start properly. About one half of the time I start it, it takes a screenshot of the desktop and freeze here forever. Only the edge of the window is visible, but nothing appears inside.
When, I use selenium, and some times I try selenium.Firefox()
and it also goes into this weird mode. However, the functionality does not break, my script still run correctly, just nothing changed inside the firefox.
I guess some thing wrong about the kde has to do with it.
And the output of normal start up is.
ATTENTION: default value of option mesa_glthread overridden by environment.
[GFX1-]: Failed to create EGLContext!: 0x3001 #Somehow, it is normal. Only when this log has produced. my firefox works.
###!!! [Parent][RunMessage] Error: Channel closing: too late to send/recv, messages will be lost #I close the firefox here.
The output of log of abnormal start up is this:
And details about firefox are listed below:
firefox --full-version ✔
Mozilla Firefox 95.0.1 20211217060815 20211217060815
And here is some info about system
inxi -Fazy ✔
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bf9bdbd9-6463-4c62-be31-a22dccf083df rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MECHREVO product: S2 Series v: N/A
Mobo: MECHREVO model: SW1 serial: <superuser required>
UEFI: American Megatrends v: SC1M.07 date: 03/18/2020
ID-1: BAT0 charge: 46.6 Wh (92.8%) condition: 50.2/50.2 Wh (100.0%)
volts: 11.4 min: 11.4 model: N/A type: Unknown serial: <filter>
status: Discharging
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce MX350] driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:1c94 class-ID: 0302
Device-3: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 0bda:0568 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158
size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 709.66 GiB used: 33.32 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: ForeseSU04Ge model: S50AF512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 117B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: MS 256GB USB3.0
size: 232.72 GiB block-size: physical: 4096 B logical: 4096 B type: N/A
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 210.49 GiB size: 206.12 GiB (97.93%)
used: 26.21 GiB (12.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 45.7 MiB (8.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 80.0 C pch: 39.0 C mobo: N/A
Processes: 272 Uptime: 30m wakeups: 2 Memory: 15.51 GiB
used: 3.32 GiB (21.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1420 lib: 368 flatpak: 0
Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
Thanks for your help!
