Firefox strange behaviour
I encountered some strange behavior with firefox that I was able to resolve, after updating and also moving to the latest kernel (6.14.0-1).
The bug specifically was that some websites didn’t want to fully load (yahoo specifically). I noticed that going incognito did load the website just fine, so I went over my extensions and noticed that “Dark Reader” would keep loading when clicking on it for its popup. I managed to resolve the issue by disabling the extension, reloading the web page, and enabling the extension again. After doing this, everything works fine.
I guess this is more of a firefox issue, but I thought I’d share anyway.
Your post has been moved to a dedicated topic.
As you correctly summised, your issue likely was unrelated to the recent Manjaro update.
I encountered no “strange behavior”
… or maybe not - but something within your configuration …
There is really nothing here to go on …
Yeah, could be a configuration issue… it is the first time this has happened though. I fixed anyway by doing the tried and tested method of turning it off and on again.
More likely related to the profile, or cache, related to your account - especially as incognito loaded it fine.
Dark Reader is a double-edged sword - abut a great tool, best set to be disabled by default (select ‘site list’ and ‘inverted only’) so that it is ONLY activated manually by yourself.
Yeah, but the thing is that Dark Reader wouldn’t even open (the window that opens when you click on the extension was just blank).
Even more reason to set it disabled by default - inverted list… though the fact that you fixed it by simply restarting it
[quote=“Official229, post:4, topic:176997, full:true”]I fixed anyway by doing the tried and tested method of turning it off and on again.
[/quote]
That’s another story - you’d be expected at the very least to follow at least the following steps before posting a request for support - especially in the Updates Announcement thread:
  1. Quit and restart Firefox and test
  2. Restart in safe mode and test
  3. Create a new profile, re-synchronise and test (then delete the last profile).
I think there’s been a misunderstanding. I didn’t post a request for support.
I’ve never had this happen before, and given that it occurred on the first restart after updating my system, I posted the behavior I encountered and how to fix it in the updates thread in case somebody else had it happen to them as well.
Your post was moved from the Update Announcement thread to SupportSoftware and Applications because your issue had nothing to do with the Update. While we appreciate your enthusiasm, your post was misplaced and off-topic for the Update Announcement topic.
However, this Support topic has hopefully allowed you to learn some valuable troubleshooting skills.
Thanks @Ben and @Nachlese :eyes:
Consider offering some thanks to our Moderation staff for attempting to guide you in the right direction; rather than reacting negatively when the help is offered.
It can make all the difference. :slight_smile:
Please do not refer to an issue as a bug. :beetle:
If you do that, you are expected at least to provide a link to a confirmed bug report. As it turns out, your “bug” was simply your failure to apply troubleshooting 101. Mozilla have all kinds of articles to help Firefox (and Thunderbird) issues. I dare say, they should have been your first port of call.
Remember, a bug is not a bug unless an issue can be reproduced – usually by the devs; or, in any case, other people. :family_man_man_girl:
Your resolution speaks for itself. :loudspeaker:
The following is added in case it’s useful;
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. :eyes:
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
