Hi! I’m using a Razer Deathadder elite. The side and top buttons stopped working. xinput test <id>
doesn’t output anything when pushing those buttons
I believe it may have happened after installing openrazer-meta
and polychromatic
, but I’m not sure. I had uninstalled those later on. I tried reinstalling them again, it did not fix the buttons. Neither when still installed or after uninstalling them once more
Please help!
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=97dd37d5-1395-4fe9-91a1-5c5335a75b8a rw nouveau.modeset=0
nvidia-drm.modeset=1 intel_pstate=disable quiet splash apparmor=1
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: ASUSTeK product: ROG Strix G733ZW_G733ZW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G733ZW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G733ZW.303 date: 12/27/2021
ID-1: BAT0 charge: 88.5 Wh (100.0%) condition: 88.5/90.0 Wh (98.4%)
volts: 17.2 min: 15.9 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: full
RAM: total: 31.02 GiB used: 7.33 GiB (23.6%)
RAM Report:
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x413
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 730 high: 959 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 444 2: 582 3: 653 4: 487
5: 646 6: 593 7: 919 8: 620 9: 709 10: 398 11: 814 12: 958 13: 833 14: 911
15: 816 16: 879 17: 630 18: 959 19: 951 20: 808 bogomips: 116780
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni
smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel ports: active: eDP-2 empty: DP-2,DP-3
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 470.103.01 alternate: nouveau,nvidia_drm ports:
active: none off: HDMI-A-1 empty: DP-1,eDP-1 bus-ID: 0000:01:00.0
chip-ID: 10de:24a0 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
gpu: i915,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
s-diag: 1245mm (49.01")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: LG (GoldStar) E2242 serial: <filter> built: 2012 res: 1920x1080
hz: 60 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-2 mapped: eDP-1-2 pos: primary,left
model: BOE Display 0x0a69 built: 2021 res: 2560x1440 hz: 240 dpi: 171
gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
modes: 2560x1440
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
IF-ID-1: br-e4dce6a69314 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth1c79af2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 647.67 GiB (67.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P7MA001 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 758.26 GiB size: 745.36 GiB (98.30%)
used: 647.67 GiB (86.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 97dd37d5-1395-4fe9-91a1-5c5335a75b8a
label: NO_LABEL uuid: 0641-9146
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:5 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-2: 3-3:2 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 489 Uptime: 4h 49m wakeups: 2 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 Packages: 1521 pacman: 1499 lib: 476
flatpak: 13 snap: 9 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
inxi: 3.3.14
