Probably, it’s a fresh install and Wayland is enabled by default. Let me check …
Actually no, I’m on X11. I think the OS detected I’m using a virtual machine
I can reproduce this in a freshly installed VM (20.2.1) when closing the browser with more then 1 tab open.
But not on my fully updated production machine. (using matcha-dark-sea theme)
Tried different themes, layouts, disabled all extentions, removed manjaro branding from the layouts settings menu, full update. no sign of something that triggers this.
Again, this is a fresh install. I’ll try what you’re suggesting, but if that was the case why does Manjaro include an extension causing this kind of issues?
Disabled every extension and then Extensions entirely, same issue.
seems to be specific to running default Gnome in a VM - instead of on real hardware
I can can confirm this (running Manjaro Gnome in VirtualBox) - but I probably wouldn’t have even noticed without this heads up and the subsequent deliberate looking for it.
Thanks, I’ll try that even though I can’t see why it should work.
Anyways I don’t think it’s a grey bar, it’s more like you can see the desktop background (and the right edge of the default background is grey). I may be wrong of course … I should try changing the background and see if the bar changes accordingly.
Mhh, I’m pretty sure it also happens on real hardware but can’t install Manjaro right now.
Ok, it worked! Thank you.
What can we conclude from this?
is Manjaro changing some default settings of Firefox before packaging their ISOs, causing this to happen? (Not on purpose obviously) I’ve got lots of complaints about Manjaro’s defaults (both on Gnome and Plasma), guess I’m gonna add this to the list?
That there is something that changed somewhere that causes this, unknown precisely when and that it might be related to default settings for firefox. Since reproduction is not a fix and the fix is a workaround at best and the issue is minute, I guess this will be solved in future releases as a byproduct of the improvements in the release cycles.
Feedback is welcomed, but remember that a complaint is more of a supplier-buyer relationship, so I would phrase it as suggestions. Did you know you can build your own Manjaro with your own defaults?
I was a bit too hasty. Refreshing Firefox solves the issue momentarily: if you close the app without refreshing, then launch it again (and, of course, trigger some kind of dialogue to pop up), the right edge is still cut off.
So yeah, refreshing Firefox every time clearly isn’t an acceptable workaround (considering the issue at hand)
