Hypnotix doesn’t load the default provider after the last update (4.01).
I solved by disabling the line 1547 of the file:
/usr/lib/hypnotix/hypnotix.py
as follows
1547 # options [“vo”] = “x11”
Sounds like you need to install hypnotix-wayland
instead.
I had installed Hypnotix for Wayland but it did not load the default provider and not even others.
It seems that for the Wayland version the creator forgot to delete the 1547 line of the Hypnotix.ph file.
