I was trying to install anaconda on my laptop and I had to play around bashrc even though i had no idea how to deal with it, anaconda-navigator wasn’t running. I didn’t backup the file how can i login back again, plz help
You can find a skeleton version of the .bashrc file in /etc/skel/.bashrc
Maybe replacing your bashrc with that one will resolve your issue…
Copy over the file @chomsky mentioned to your homedir.
If you can’t login anylonger try a LiveUSB image to access your files.
i am going to try this thanks
No luck
Couldn’t login back
I even tried replacing .bashrc with a .bashrc.old after renaming it
Still no luck what to do now? I’ll have reinstall all those software etc?
I can not sign it
Tried what u told
Use an USB stick with Manjaro to chroot into your install.
Thanks giving it a try
