Hello ARM community.
Plasma 5.27 is here. So is Kernel 6.2.
Some highlights:
- Most of our kernels got updated, some to 6.2.1
linux60 removed from repository. Please install
linux61
orlinux62
instead. - Thunderbird updated to 102.8.0
- Plasma updated to 5.27.1
- Pipewire updated to 0.3.66
- Mesa updated to 22.3.6
- Kodi updated to 20.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
End Of Life kernels (will be removed from repo soon):
linux60
(EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy
packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Feb 26 09:01:31 CET 2023)
- arm-testing community aarch64: 398 new and 381 removed package(s)
- arm-testing core aarch64: 63 new and 60 removed package(s)
- arm-testing extra aarch64: 297 new and 290 removed package(s)
- arm-testing kde-unstable aarch64: 107 new and 106 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023-02-15 2023-02-26
chatty0.7.0rc4+14+g1ea66460-1 0.7.0-1
code 1.74.2-0 1.75.1-0
electron 22.2.0-1 23.1.1-1
electron21 21.4.1-1 21.4.2-1
element-desktop 1.11.23-1 1.11.23-2
element-web 1.11.23-1 1.11.23-2
kodi 19.4-3 20.0-6
kodi-dev 19.4-3 20.0-6
kodi-eventclients 19.4-3 20.0-6
kodi-rpi 19.4.1-5 20.0-7
kodi-rpi-dev 19.4.1-5 20.0-7
kodi-rpi-eventclients 19.4.1-5 20.0-7
kodi-rpi-tools-texturepacker 19.4.1-5 20.0-7
kodi-tools-texturepacker 19.4-3 20.0-6
libgbinder 1.1.32-1 1.1.33-1
osmin 1.8.7-1 1.9.6-1
phoc 0.24.0-1 0.24.0+28+g2e5a9db-1
phosh 0.24.0-10.24.0+38+gd86b8b68-1
pika-backup 1:0.4.2-1 1:0.5.2-1
qt5-virtualkeyboard-bigscreen 5.15.8-2 5.15.8-3
signal-desktop 6.2.0-1 6.6.0-1
squeekboard 1.20.0+36+gf4c03ce-1 1.20.0+75+g5595674-1
watchmate 0.4.1-1 0.4.2-1
electron22 - 22.3.1-1
manjaro-starter - 0.31.2-1
:: Different sync package(s) in repository community aarch64
adrdox 2.5.3-1 2.5.3-2
aliyun-cli 3.0.149-1 3.0.150-1
ansible-lint 6.12.2-1 6.13.1-1
apko 0.6.0-1 0.6.1-1
appstream-generator 0.9.0-1 0.9.0-2
ardour 7.2-1 7.3-1
arpack 3.8.0-3 3.9.0-1
arrow 10.0.1-3 10.0.1-4
avfs 1.1.4-2 1.1.5-1
aws-cli-v2 2.9.18-1 2.10.2-1
awxkit 21.11.0-1 21.12.0-2
blender 17:3.4.1-13 17:3.4.1-14
bootconfig 6.1-1 6.2-1
bpf 6.1-1 6.2-1
broot 1.20.1-1 1.20.2-1
buildkit 0.11.2-1 0.11.3-1
caddy 2.6.2-1 2.6.4-1
calc 2.14.1.0-1 2.14.1.3-1
cargo-edit 0.11.8-2 0.11.9-1
cargo-fuzz 0.11.1-1 0.11.2-1
cargo-generate 0.17.6-2 0.18.1-1
cargo-llvm-cov 0.5.9-1 0.5.10-1
cargo-zigbuild 0.16.0-1 0.16.1-1
certbot 2.2.0-1 2.3.0-1
certbot-apache 2.2.0-1 2.3.0-1
certbot-dns-cloudflare 2.2.0-1 2.3.0-1
certbot-dns-digitalocean 2.2.0-1 2.3.0-1
certbot-dns-dnsimple 2.2.0-1 2.3.0-1
certbot-dns-dnsmadeeasy 2.2.0-1 2.3.0-1
certbot-dns-gehirn 2.2.0-1 2.3.0-1
certbot-dns-google 2.2.0-1 2.3.0-1
certbot-dns-linode 2.2.0-1 2.3.0-1
certbot-dns-luadns 2.2.0-1 2.3.0-1
certbot-dns-nsone 2.2.0-1 2.3.0-1
certbot-dns-ovh 2.2.0-1 2.3.0-1
certbot-dns-rfc2136 2.2.0-1 2.3.0-1
certbot-dns-route53 2.2.0-1 2.3.0-1
certbot-dns-sakuracloud 2.2.0-1 2.3.0-1
certbot-nginx 2.2.0-1 2.3.0-1
cgroup_event_listener 6.1-1 6.2-1
chafa 1.12.4-2 1.12.4-3
chezmoi 2.30.1-1 2.31.0-1
cjdns 21-1 22-1
containerd 1.6.16-1 1.6.18-1
containers-common 1:0.51.0-1 1:0.51.0-3
cpupower 6.1-1 6.2-1
croc 9.6.1-1 9.6.3-1
cxxbridge 1.0.88-1 1.0.91-1
cxxopts 3.0.0-1 3.1.1-1
d-containers 0.8.0-8 0.8.0-9
d-mir-core 1.1.14-10 1.1.14-11
d-stdx-allocator 3.0.2-20 3.0.2-21
darktable 2:4.2.0-3 2:4.2.1-1
dart-sass 1.58.0-1 1.58.1-1
datovka 4.21.1-2 4.22.0-1
diffoscope 235-1 236-1
distorm 3.5.2-3 3.5.2.b-1
dnf 4.13.0-1 4.14.0-1
docker-buildx 0.10.0-1 0.10.3-1
docker-scan 0.23.0-1 0.25.0-1
dscanner 0.13.0-1 0.14.0-1
dua-cli 2.19.1-1 2.19.2-1
ebumeter 0.4.2-4 0.5.1-1
espup 0.2.8-1 0.3.0-1
etherwall 3.0.4-1 3.0.5-1
fd 8.6.0-1 8.7.0-1
fdkaac 1.0.3-1 1.0.5-1
fdm 2.2-1 2.2-2
fennel 1.2.1-1 1.3.0-1
filezilla 3.63.1-1 3.63.2-1
findomain 8.2.1-1 8.2.2-1
firefox-noscript 11.4.15-1 11.4.16-1
firefox-ublock-origin 1.47.0-1 1.47.2-1
flashgbx 3.21-1 3.22-1
fluidd 1.23.1-1 1.23.2-1
forgejo 1.18.3.1-1 1.18.5.0-1
freeradius 3.2.1-4 3.2.2-1
freerdp 2:2.9.0-1 2:2.10.0-1
fwupd 1.8.10-1 1.8.12-1
gimp-plugin-gmic 3.2.0-2 3.2.1-2
gir-to-d 0.22.0-8 0.22.0-9
gitoxide 0.20.0-2 0.22.1-1
glibd 2.3.0-7 2.3.0-8
gnuradio 3.10.5.0-3 3.10.5.0-4
gnuradio-companion 3.10.5.0-3 3.10.5.0-4
go 2:1.20-1 2:1.20.1-1
go-ethereum 1.10.26-1 1.11.2-1
go-yq 4.30.8-1 4.31.1-1
golang-golang-x-sys 0.0.20220829-1 0.0.20230208-1
gpio-utils 6.1-1 6.2-1
gpxsee 11.12-1 12.1-1
gtkd 3.10.0-4 3.10.0-5
helix 22.12-2 22.12-4
helm 3.11.0-1 3.11.1-1
hyperv 6.1-1 6.2-1
i2pd 2.45.1-2 2.46.1-1
i3status-rust 0.22.0-1 0.30.3-1
iaito 5.8.0-1 5.8.2-1
iio-utils 6.1-1 6.2-1
jacktrip 1:1.7.0-1 1:1.7.1-1
jenkins 2.390-1 2.392-1
jenv 0.5.5-1 0.5.6-1
jupyter-console 6.5.1-1 6.6.1-1
jupyter-nbclassic 0.5.1-2 0.5.2-1
jupyter-server 2.2.1-1 2.3.0-1
kak-lsp 14.1.0-1 14.2.0-1
kcptun 20230207-1 20230214-1
klavaro 3.13-2 3.14-1
kodi-addon-imagedecoder-heif 20.1.0-2 20.1.0-4
kodi-addon-imagedecoder-raw 20.1.0-2 20.1.0-4
kodi-platform 20190726.809c5e9-41 20190726.809c5e9-43
krita-plugin-gmic 3.1.6.1-1 3.2.1.2-1
ldc 3:1.30.0-2 3:1.31.0-1
ledger 3.2.1-12 3.3.0-1
libcli 1.10.4-1 1.10.7-1
libcutefish 0.7-1 0.7-2
libdatovka 0.2.1-3 0.3.0-2
libdnf 0.68.0-1 0.70.0-1
libfilezilla 1:0.41.0-1 1:0.41.1-1
libliftoff 0.3.0-1 0.4.0-1
liblphobos 3:1.30.0-2 3:1.31.0-1
libmysofa 1.3.1-1 1.3.1-2
libreoffice-extension-texmaths 0.49-1 0.50-1
librsync 1:2.3.2-1 1:2.3.4-1
libsemigroups 2.6.0-1 2.6.1-1
liburcu 0.13.2-1 0.14.0-1
libxmlb 0.3.10-1 0.3.11-1
linux-tools-meta 6.1-1 6.2-1
liteide 38.1-1 38.2.1-1
logcli 2.7.3-2 2.7.4-1
loki 2.7.3-2 2.7.4-1
loki-canary 2.7.3-2 2.7.4-1
luajit2.1.0.beta3.r467.gd0e88930-12.1.0.beta3.r471.g505e2c03-1
lxd 5.10-2 5.11-1
lxqt-config 1.2.0-1 1.2.0-2
lychee-link-checker 0.10.3-1 0.11.1-1
mame 0.251-1 0.252-1
mame-tools 0.251-1 0.252-1
marked 4.2.8-1 4.2.9-1
marked-man 1.3.2-1 1.3.3-1
mastodon-twitter-sync 1.9.1-2 1.10.0-1
maturin 0.14.12-1 0.14.14-1
maui-shelf 2.2.1-1 2.2.1-2
mediawiki 1.39.1-1 1.39.2-1
melange 0.1.0-1 0.2.0-1
memray 1.6.0-1 1.7.0-1
minikube 1.28.0-1 1.29.0-1
minio 2023.01.20-2 2023.02.10-1
minio-client 2023.01.11-1 2023.01.28-1
miniupnpd 2.3.2-1 2.3.3-1
mitmproxy2swagger 0.8.0-1 0.8.1-1
mk-configure 0.37.0-3 0.38.2-1
mmctl 7.7.1-1 7.8.0-1
mpv 1:0.35.1-1 1:0.35.1-2
mustache-d 0.1.5-7 0.1.5-8
mympd 10.2.1-1 10.2.3-1
neovim-nvim-treesitter 0.8.1-1 0.8.5.2-1
netdata 1.38.0-1 1.38.1-1
nextcloud 25.0.3-1 25.0.4-1
nextcloud-app-calendar 1:4.2.3-1 1:4.2.4-1
nextcloud-app-notify_push 0.5.2-1 0.6.0-1
ngspice 38-1 39-1
nodejs 19.6.0-1 19.7.0-1
nodejs-lts-gallium 16.19.0-1 16.19.1-1
nodejs-lts-hydrogen 18.14.0-1 18.14.2-1
nomad 1.4.3-1 1.4.4-1
npm-check-updates 16.7.1-1 16.7.2-1
nuklear 4.10.1-1 4.10.5-1
oil 0.14.0-1 0.14.1-1
onefetch 2.15.1-1 2.16.0-1
openpgp-card-tools 0.9.0-3 0.9.1-1
opensnitch 1.5.7-1 1.5.8-1
osbuild 78-1 80-1
osv-scanner 1.1.0-1 1.2.0-1
otf-font-awesome 6.2.1-1 6.3.0-1
owncloud-client 3.1.0.9872-1 3.2.0.10193-1
packer 1.8.0-2 1.8.6-1
parallel 20230122-1 20230222-1
parallel-docs 20230122-1 20230222-1
pd-lua 0.11.5-1 0.11.6-1
perf 6.1-1 6.2-1
perl-function-parameters 2.001003-6 2.001005-1
perl-html-form 6.10-1 6.11-1
perl-module-runtime 0.016-2 0.016-3
perl-net-openssh 0.82-1 0.83-1
perl-www-mechanize 2.15-1 2.16-1
phpldapadmin 1.2.6.4-7 1.2.6.4-8
plasma5-applets-window-buttons 0.11.1-1 0.11.1-2
po4a 0.68-1 0.69-1
podman 4.4.1-2 4.4.2-1
podman-docker 4.4.1-2 4.4.2-1
polymake 4.9-2 4.9-3
promtail 2.7.3-2 2.7.4-1
prosody 1:0.12.2-1 1:0.12.3-1
psalm 5.6.0-1 5.7.0-1
pyenv 2.3.12-1 2.3.13-1
pymol 2.5.0-3 2.5.0-4
pyright 1.1.293-1 1.1.295-1
python-acme 2.2.0-1 2.3.0-1
python-alembic 1.7.6-2 1.9.4-1
python-aws-sam-translator 1.58.1-1 1.59.0-1
python-beautifulsoup4 4.11.1-1 4.11.2-1
python-bidict 0.22.0-2 0.22.1-1
python-bincopy 17.14.0-1 17.14.5-1
python-black 22.12.0-2 23.1.0-2
python-boltons 21.0.0-1 23.0.0-1
python-cfn-lint 0.72.9-1 0.73.2-1
python-cinderclient 9.2.0-1 9.3.0-1
python-dbus-fast 1.84.0-1 1.84.2-1
python-designateclient 5.1.0-1 5.2.0-1
python-diff-cover 7.4.0-1 7.5.0-1
python-distorm 3.5.2-3 3.5.2.b-1
python-dkim 1.0.5-7 1.1.0-1
python-dotenv 0.21.1-1 1.0.0-1
python-dulwich 0.21.2-1 0.21.3-1
python-esbonio 0.16.0-1 0.16.1-1
python-faker 15.1.3-1 15.1.5-1
python-fakeredis 2.9.0-1 2.9.2-1
python-fastapi 0.91.0-1 0.92.0-1
python-flask-babel 2.0.0-5 3.0.1-1
python-flask-migrate 3.1.0-1 4.0.4-1
python-flask-socketio 5.2.0-1 5.3.2-1
python-gdstk 0.9.22-1 0.9.23-1
python-guessit 3.5.0-1 3.7.1-1
python-h5py 3.7.0-1 3.8.0-1
python-hatchling 1.11.1-2 1.13.0-1
python-home-assistant-bluetooth 1.9.2-1 1.9.3-1
python-httplib2 0.21.0-2 0.21.0-3
python-identify 2.5.17-1 2.5.18-1
python-importlib_resources 5.10.2-1 5.12.0-1
python-jaraco.functools 3.5.2-1 3.6.0-1
python-json-logger 2.0.4-1 2.0.5-1
python-jupyter-client 8.0.2-1 8.0.3-1
python-kubernetes 25.3.0-2 26.1.0-1
python-magnumclient 4.0.0-1 4.1.0-1
python-matplotlib 3.6.2-2 3.6.3-1
python-mpd2 3.0.5-2 3.1.0-1
python-neutronclient 8.2.1-1 9.0.0-1
python-openpyxl 3.1.0-1 3.1.1-1
python-osc-lib 2.6.2-1 2.7.0-1
python-oslo-config 9.1.0-1 9.1.1-1
python-oslo-serialization 5.0.0-1 5.1.0-1
python-pdm 2.4.5-1 2.4.6-1
python-pikepdf 7.0.0-1 7.1.1-1
python-pipenv 2023.2.4-1 2023.2.18-1
python-poetry-core 1.5.0-1 1.5.1-1
python-pydantic 1.10.4-1 1.10.5-1
python-pygls 1.0.0-1 1.0.1-1
python-pylint-venv 2.3.0-2 3.0.1-1
python-pynamodb 5.3.4-1 5.4.1-1
python-pyroute2 0.7.3-1 0.7.5-1
python-pytest-forked 1.5.0-1 1.6.0-1
python-pytest-rerunfailures 11.1-1 11.1.1-1
python-pytest-subtests 0.9.0-2 0.10.0-1
python-qrcode 7.3.1-1 7.4.2-1
python-qtawesome 1.2.1-1 1.2.2-1
python-r2pipe 5.7.0-1 5.7.2-1
python-railroad-diagrams 3.0.0-1 3.0.1-1
python-rebulk 3.1.0-2 3.2.0-1
python-rpy2 3.5.8-1 3.5.9-1
python-scapy 2.4.5-4 2.5.0-2
python-scipy 1.10.0-1 1.10.1-1
python-soupsieve 2.3.2.post1-1 2.4-1
python-sphinxcontrib-spelling 7.7.0-1 8.0.0-1
python-starlette 0.24.0-1 0.25.0-1
python-swiftclient 4.1.0-2 4.2.0-1
python-tempora 5.2.0-1 5.2.1-1
python-testflo 1.4.10-1 1.4.11-1
python-thrift 0.17.0-1 0.18.0-1
python-tld 0.12.6-1 0.12.7-1
python-tlsh 4.7.2-3 4.8.2-1
python-voluptuous-serialize 2.5.0-3 2.6.0-1
python-weasyprint 57.2-1 58.0-1
python-werkzeug 2.2.2-1 2.2.3-1
python-z3-solver 4.12.0-1 4.12.1-1
python-zipp 3.13.0-1 3.14.0-1
python-zstandard 0.19.0-1 0.20.0-1
qcad 3.27.9.0-1 3.27.9.3-1
qutebrowser 2.5.2-2 2.5.3-1
r2ghidra 5.8.0-1 5.8.2-1
rabbitmq 3.10.7-1 3.11.9-1
rabbitmqadmin 3.10.7-1 3.11.9-1
radare2 5.8.0-2 5.8.2-1
rbw 1.4.3-1 1.5.0-1
readstat 1.1.8-1 1.1.9-1
remind 4.2.0-1 4.2.2-1
reprotest 0.7.22-1 0.7.23-1
rime-emoji 0.0.0.20230206-1 0.0.0.20230208-1
rizin 0.4.1-1 0.5.1-1
rnote 0.5.13-1 0.5.14-1
ruby-async-websocket 0.24.0-1 0.24.0-2
ruby-bake-modernize 0.14.4-1 0.15.1-1
ruby-hoe 3.24.0-1 4.0.2-1
ruby-maxitest 4.4.0-2 4.4.1-1
ruby-rack 2.2.4-1 3.0.4.1-1
ruby-rack-test 1.1.0-4 2.0.2-2
ruby-rouge 3.28.0-1 4.1.0-1
ruby-tilt 2.0.10-1 2.0.11-1
ruby-timers 4.3.3-1 4.3.5-1
ruby-webrick 1.7.0-1 1.8.1-1
ruff 0.0.246-1 0.0.252-1
ruff-lsp 0.0.17-1 0.0.19-1
rust-analyzer 20230213-1 20230220-1
rz-cutter 2.1.2-1 2.2.0-1
rz-ghidra 0.4.0-3 0.5.0-1
sc3-plugins 3.11.1-2 3.13.0-1
signify 31-2 31-3
singular 4.3.1.p3-1 4.3.2-1
skim 0.10.2-1 0.10.3-1
skopeo 1.11.0-1 1.11.1-1
slowhttptest 1.8.2-2 1.9.0-1
sqlc 1.16.0-1 1.17.0-1
sqlmap 1.6.12-1 1.7-1
stalonetray 0.8.4-2 0.8.5-1
starship 1.12.0-3 1.13.0-1
staticcheck 2023.1-1 2023.1.2-1
streamlink 5.2.1-1 5.3.1-1
stylelint 15.1.0-1 15.2.0-1
supercollider 3.12.2-4 3.13.0-1
telegram-desktop 4.6.2-2 4.6.3-1
terraform 1.3.8-1 1.3.9-1
thrift 0.17.0-2 0.18.0-1
tickrs 2:0.14.6-1 2:0.14.8-1
tilix 1.9.5-4 1.9.5-5
tmon 6.1-1 6.2-1
tokodon 23.01.0-1 23.02.0-1
tor 0.4.7.13-1 0.4.7.13-2
translate-toolkit 3.8.3-1 3.8.4-1
trash-cli 0.22.10.20-3 0.23.2.13.2-1
ttf-font-awesome 6.2.1-1 6.3.0-1
tuna 1:0.18-1 1:0.19-1
txt2tags 3.7-7 3.8-1
typescript-language-server 3.1.0-1 3.3.0-1
typos 1.13.10-1 1.13.12-1
ukui-control-center 3.0.4-4 3.0.4-5
ukui-settings-daemon 3.1.1.1-2 3.1.1.1-3
usbip 6.1-1 6.2-1
v2ray-domain-list-community 20230214100320-1 20230223064004-1
v2ray-geoip 202302090046-1 202302230047-1
vaultwarden-web 2023.1.1-1 2023.2.0-1
wasmtime 5.0.0-1 6.0.0-1
wifite 2:2.6.0-1 2:2.6.8-1
xh 0.17.0-1 0.18.0-1
xmake 2.7.5-1 2.7.7-1
xpdf 4.04-1 4.04-2
yoshimi 2.2.2.1-1 2.2.3-2
yq 3.1.0-1 3.1.1-1
yt-dlp 2023.01.06-1 2023.02.17-1
yuzu 1337-1 1346-1
z3 4.12.0-1 4.12.1-1
zerotier-one 1.10.2-1 1.10.3-1
zk 0.12.0-1 0.13.0-1
zola 0.16.1-1 0.17.1-1
zutty 0.13-1 0.14-1
ansible-language-server - 1.0.4-2
arduino-language-server - 0.7.4-1
coeurl - 0.3.0-2
committed - 1.0.8-1
d2 - 0.2.0-1
dot-language-server - 1.1.24-1
ebumeter-docs - 0.5.1-1
esbuild - 0.17.10-1
igrep - 1.1.0-2
lmdbxx - 1.0.0-2
lychee - 0.11.1-2
mauikit-documents - 1.0.0-1
trompeloeil - 43-1
verdict - 1.4.1-1
zls - 0.10.0-2
:: Different overlay package(s) in repository core aarch64
linux 6.1.12-1 6.2.1-1
linux-clockworkpi-a06 6.1.11-1 6.2.1-1
linux-clockworkpi-a06-headers 6.1.11-1 6.2.1-1
linux-headers 6.1.12-1 6.2.1-1
linux-lts 6.1.12-1 6.1.14-1
linux-lts-headers 6.1.12-1 6.1.14-1
linux-pinephone 6.1.9-2 6.1.12-1
linux-pinephone-headers 6.1.9-2 6.1.12-1
linux-pinephonepro 6.1.9-3 6.1.12-1
linux-pinephonepro-headers 6.1.9-3 6.1.12-1
linux-rc 6.2.rc8-1 6.2.rc8-3
linux-rc-headers 6.2.rc8-1 6.2.rc8-3
linux-rpi4-mainline 6.1.11-1 6.2.0-1
linux-rpi4-mainline-headers 6.1.11-1 6.2.0-1
linux60 6.0.19-1 -
linux60-headers 6.0.19-1 -
linux61 6.1.12-1 6.1.14-1
linux61-headers 6.1.12-1 6.1.14-1
raspberrypi-bootloader 20230210-1 20230220-1
raspberrypi-bootloader-x 20230210-1 20230220-1
uboot-pinephone 2022.10-1 2023.01-1
linux-rk3588 - 6.1.0-3
linux-rk3588-headers - 6.1.0-3
linux62 - 6.2.1-1
linux62-headers - 6.2.1-1
uboot-orangepi5 - 2017.09-2
:: Different sync package(s) in repository core aarch64
amd-ucode 20230117.7e4f0ed-1 20230210.bf4115c-1
archlinux-keyring 20230130-1 20230223-1
brotli 1.0.9-9 1.0.9-10
brotli-testdata 1.0.9-9 1.0.9-10
curl 7.87.0-3 7.88.1-3
device-mapper 2.03.18-5 2.03.19-1
dialog 1:1.3_20221229-1 1:1.3_20230209-1
file 5.44-2 5.44-3
gnutls 3.7.9-1 3.8.0-1.1
iproute2 6.1.0-5 6.2.0-2
lemon 3.40.1-1 3.41.0-1
libcurl-compat 7.87.0-3 7.88.1-3
libcurl-gnutls 7.87.0-3 7.88.1-3
libldap 2.6.3-2 2.6.4-1
linux-firmware 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-bnx2x 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-liquidio 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-marvell 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-mellanox 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-nfp 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-qcom 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-qlogic 20230117.7e4f0ed-1 20230210.bf4115c-1
linux-firmware-whence 20230117.7e4f0ed-1 20230210.bf4115c-1
lvm2 2.03.18-5 2.03.19-1
man-pages 6.02-1 6.03-1
openldap 2.6.3-2 2.6.4-1
python-brotli 1.0.9-9 1.0.9-10
sqlite 3.40.1-1 3.41.0-1
sqlite-analyzer 3.40.1-1 3.41.0-1
sqlite-doc 3.40.1-1 3.41.0-1
sqlite-tcl 3.40.1-1 3.41.0-1
sudo 1.9.12.p2-2 1.9.13-1
systemd 252.5-1 253-1
systemd-libs 252.5-1 253-1
systemd-resolvconf 252.5-1 253-1
systemd-sysvcompat 252.5-1 253-1
texinfo 7.0.2-2 7.0.2-2.1
thin-provisioning-tools 1.0.1-1 1.0.2-1
zstd 1.5.2-8 1.5.4-1
:: Different overlay package(s) in repository extra aarch64
libdrm-pinebookpro 2.4.114-1 2.4.115-1
libva-mesa-driver 22.3.5-0.2 22.3.6-0.1
mesa 22.3.5-0.2 22.3.6-0.1
mesa-vdpau 22.3.5-0.2 22.3.6-0.1
opencl-mesa 22.3.5-0.2 22.3.6-0.1
plasma-mobile 5.26.5-1 5.27.1-1
plasma-mobile-nm 5.26.5-1 5.27.1-1
qqc2-breeze-style 5.26.5-1 5.27.1-1
snapd 2.58.2-1 2.58.3-1
vulkan-broadcom 22.3.5-0.2 22.3.6-0.1
vulkan-mesa-layers 22.3.5-0.2 22.3.6-0.1
vulkan-panfrost 22.3.5-0.2 22.3.6-0.1
vulkan-radeon 22.3.5-0.2 22.3.6-0.1
vulkan-swrast 22.3.5-0.2 22.3.6-0.1
vulkan-virtio 22.3.5-0.2 22.3.6-0.1
plasma-desktop - 5.27.1-1.1
:: Different sync package(s) in repository extra aarch64
a2ps 4.14-13 4.14-14
alsa-card-profiles 1:0.3.65-6 1:0.3.66-2
archlinux-appstream-data 20230115-1 20230220-1
aura-browser 5.26.5-1 5.27.1-1
babl 0.1.98-1 0.1.100-1
bind 9.18.11-1 9.18.12-1
bluedevil 1:5.26.5-1 1:5.27.1-1
breeze 5.26.5-1 5.27.1-1
breeze-grub 5.26.5-1 5.27.1-1
breeze-gtk 5.26.5-1 5.27.1-1
chromium 110.0.5481.77-2 110.0.5481.177-1
clamav 1.0.0-1 1.0.1-1
composer 2.5.3-1 2.5.4-1
conky 1.17.0-1 1.18.1-1
ctags 1:5.9.20220828.0-1 1:6.0.0-1
cups 1:2.4.2-5 1:2.4.2-6
dav1d 1.0.0-1 1.1.0-1
dav1d-doc 1.0.0-1 1.1.0-1
dfu-programmer 0.7.2-3 1.0.0-1
discover 5.26.5-1 5.27.1-1
drkonqi 5.26.5-1 5.27.1-1
epiphany 43.0-1 43.1-1
flatpak 1:1.15.2-1 1:1.15.3-1
flatpak-docs 1:1.15.2-1 1:1.15.3-1
gegl 0.4.40-4 0.4.42-2
genxrdpattern 1.1-2 1.1-3
ghostpcl 10.0.0-4 10.0.0-5
ghostscript 10.0.0-4 10.0.0-5
ghostxps 10.0.0-4 10.0.0-5
gimp 2.10.32-3 2.10.34-1
gnome-backgrounds 43-1 43.1-1
gnome-control-center 43.4.1-1 43.4.1-2
gnome-desktop 1:43.1-1 1:43.2-1
gnome-desktop-4 1:43.1-1 1:43.2-1
gnome-desktop-common 1:43.1-1 1:43.2-1
gparted 1.4.0-1 1.5.0-1
gst-plugin-pipewire 1:0.3.65-6 1:0.3.66-2
gvim 9.0.1302-1 9.0.1337-1
harfbuzz 7.0.0-1 7.0.1-1
harfbuzz-cairo 7.0.0-1 7.0.1-1
harfbuzz-docs 7.0.0-1 7.0.1-1
harfbuzz-icu 7.0.0-1 7.0.1-1
hwdetect 2023.02.12-1 2023.02.20-1
hwloc 2.8.0-1 2.9.0-1
kactivitymanagerd 5.26.5-1 5.27.1-1
kde-cli-tools 5.26.5-1 5.27.1-1
kde-gtk-config 5.26.5-1 5.27.1-1
kdecoration 5.26.5-1 5.27.1-1
kdeplasma-addons 5.26.5-1 5.27.1-1
kgamma5 5.26.5-1 5.27.1-1
khotkeys 5.26.5-1 5.27.1-1
kinfocenter 5.26.5-1 5.27.1-1
kmenuedit 5.26.5-1 5.27.1-1
kpipewire 5.26.5-1 5.27.1-1
kscreen 5.26.5-1 5.27.1.1-1
kscreenlocker 5.26.5-1 5.27.1-1
ksshaskpass 5.26.5-1 5.27.1-1
ksystemstats 5.26.5-1 5.27.1-1
kwallet-pam 5.26.5-1 5.27.1-1
kwayland-integration 5.26.5-1 5.27.1-1
kwin 5.26.5-2 5.27.1-1
kwrited 5.26.5-1 5.27.1-1
layer-shell-qt 5.26.5-1 5.27.1-1
libcbor 0.10.1-1 0.10.2-1
libcups 1:2.4.2-5 1:2.4.2-6
libdrm 2.4.114-1 2.4.115-1
libfido2 1.12.0-5 1.13.0-1
libheif 1.14.2-1 1.15.1-1
libkscreen 5.26.5-1 5.27.1-1
libksysguard 5.26.5-1 5.27.1-1
libmad 0.15.1b-9 0.15.1b-10
libnotify 0.8.1-1 0.8.2-1
libpaper 1.1.28-2 2.0.10-1
libplacebo 5.229.1-2 5.229.2-1
libsynctex 2022.62885-3 2022.62885-5
libtiff 4.5.0-1 4.5.0-2
libunrar 1:6.2.5-1 1:6.2.6-1
mariadb 10.10.3-1 10.11.2-1
mariadb-clients 10.10.3-1 10.11.2-1
mariadb-libs 10.10.3-1 10.11.2-1
memcached 1.6.17-1 1.6.18-1
meson 1.0.0-2 1.0.1-1
milou 5.26.5-1 5.27.1-1
mkinitcpio-archiso 67-1 68-1
mkvtoolnix-cli 73.0.0-3 74.0.0-1
mkvtoolnix-gui 73.0.0-3 74.0.0-1
mpd 0.23.12-1 0.23.12-2
mutt 2.2.9-1 2.2.9-3
mytop 10.10.3-1 10.11.2-1
ostree 2022.7-1 2023.1-1
oxygen 5.26.5-1 5.27.1-1
oxygen-sounds 5.26.5-1 5.27.1-1
p7zip 1:17.04-4 1:17.05-1
pango 1:1.50.12-1 1:1.50.13-1
pango-docs 1:1.50.12-1 1:1.50.13-1
perl-http-daemon 6.14-2 6.15-1
perl-mail-authenticationresults 2.20210915-2 2.20230112-1
perl-mail-dkim 1.20220520-1 1.20230212-1
perl-net-dns-resolver-mock 1.20220817-1 1.20230216-1
pgbouncer 1.17.0-2 1.18.0-1
php 8.2.2-1 8.2.3-1
php-apache 8.2.2-1 8.2.3-1
php-cgi 8.2.2-1 8.2.3-1
php-dblib 8.2.2-1 8.2.3-1
php-embed 8.2.2-1 8.2.3-1
php-enchant 8.2.2-1 8.2.3-1
php-fpm 8.2.2-1 8.2.3-1
php-gd 8.2.2-1 8.2.3-1
php-legacy 8.1.15-1 8.1.16-1
php-legacy-apache 8.1.15-1 8.1.16-1
php-legacy-cgi 8.1.15-1 8.1.16-1
php-legacy-dblib 8.1.15-1 8.1.16-1
php-legacy-embed 8.1.15-1 8.1.16-1
php-legacy-enchant 8.1.15-1 8.1.16-1
php-legacy-fpm 8.1.15-1 8.1.16-1
php-legacy-gd 8.1.15-1 8.1.16-1
php-legacy-odbc 8.1.15-1 8.1.16-1
php-legacy-pgsql 8.1.15-1 8.1.16-1
php-legacy-phpdbg 8.1.15-1 8.1.16-1
php-legacy-pspell 8.1.15-1 8.1.16-1
php-legacy-snmp 8.1.15-1 8.1.16-1
php-legacy-sodium 8.1.15-1 8.1.16-1
php-legacy-sqlite 8.1.15-1 8.1.16-1
php-legacy-tidy 8.1.15-1 8.1.16-1
php-legacy-xsl 8.1.15-1 8.1.16-1
php-odbc 8.2.2-1 8.2.3-1
php-pgsql 8.2.2-1 8.2.3-1
php-phpdbg 8.2.2-1 8.2.3-1
php-pspell 8.2.2-1 8.2.3-1
php-snmp 8.2.2-1 8.2.3-1
php-sodium 8.2.2-1 8.2.3-1
php-sqlite 8.2.2-1 8.2.3-1
php-tidy 8.2.2-1 8.2.3-1
php-xsl 8.2.2-1 8.2.3-1
pipewire-alsa 1:0.3.65-6 1:0.3.66-2
pipewire-audio 1:0.3.65-6 1:0.3.66-2
pipewire-docs 1:0.3.65-6 1:0.3.66-2
pipewire-jack 1:0.3.65-6 1:0.3.66-2
pipewire-pulse 1:0.3.65-6 1:0.3.66-2
pipewire-roc 1:0.3.65-6 1:0.3.66-2
pipewire-v4l2 1:0.3.65-6 1:0.3.66-2
pipewire-x11-bell 1:0.3.65-6 1:0.3.66-2
pipewire-zeroconf 1:0.3.65-6 1:0.3.66-2
plank-player 5.26.5-1 5.27.1-1
plasma-bigscreen 5.26.5-1 5.27.1-1
plasma-browser-integration 5.26.5-1 5.27.1-1
plasma-desktop 5.26.5-1 5.27.0-1
plasma-disks 5.26.5-1 5.27.1-1
plasma-firewall 5.26.5-1 5.27.1-1
plasma-integration 5.26.5-1 5.27.1-1
plasma-meta 5.25-1 5.27-2
plasma-nano 5.26.5-1 5.27.1-1
plasma-nm 5.26.5-1 5.27.1-1
plasma-pa 5.26.5-1 5.27.1-1
plasma-remotecontrollers 5.26.5-1 5.27.1-1
plasma-sdk 5.26.5-1 5.27.1-1
plasma-systemmonitor 5.26.5-1 5.27.1-1
plasma-thunderbolt 5.26.5-1 5.27.1-1
plasma-vault 5.26.5-1 5.27.1-1
plasma-wayland-session 5.26.5-3 5.27.1-1
plasma-workspace 5.26.5-3 5.27.1-1
plasma-workspace-wallpapers 5.26.5-1 5.27.1-1
polkit-kde-agent 5.26.5-1 5.27.1-1
postgresql 15.1-3 15.2-1
postgresql-docs 15.1-3 15.2-1
postgresql-libs 15.1-3 15.2-1
postgresql-old-upgrade 14.6-1 14.7-1
powerdevil 5.26.5-1 5.27.1-2
publicsuffix-list20220825.1289.4f29f15-120230222.1337.ab05301-1
python-numpy 1.24.1-1 1.24.2-1
python-pip 23.0-1 23.0.1-1
python-platformdirs 2.6.2-1 3.0.0-1
python-requests 2.28.1-1 2.28.2-1
python-setuptools 1:67.3.0-1 1:67.3.3-1
qbs 1.24.0-1 1.24.1-1
qtcreator 9.0.1-3 9.0.2-1
qtcreator-devel 9.0.1-3 9.0.2-1
sane 1.2.1-3 1.2.1-4
sbcl 2.3.0-1 2.3.1-1
sddm-kcm 5.26.5-1 5.27.1-1
shaderc 2022.4-1 2023.2-1
systemsettings 5.26.5-1 5.27.1-1
texlive-bin 2022.62885-3 2022.62885-5
thunar 4.18.3-1 4.18.4-1
thunderbird 102.7.2-1 102.8.0-1
thunderbird-i18n-af 102.7.2-1 102.8.0-1
thunderbird-i18n-ar 102.7.2-1 102.8.0-1
thunderbird-i18n-ast 102.7.2-1 102.8.0-1
thunderbird-i18n-be 102.7.2-1 102.8.0-1
thunderbird-i18n-bg 102.7.2-1 102.8.0-1
thunderbird-i18n-br 102.7.2-1 102.8.0-1
thunderbird-i18n-ca 102.7.2-1 102.8.0-1
thunderbird-i18n-cak 102.7.2-1 102.8.0-1
thunderbird-i18n-cs 102.7.2-1 102.8.0-1
thunderbird-i18n-cy 102.7.2-1 102.8.0-1
thunderbird-i18n-da 102.7.2-1 102.8.0-1
thunderbird-i18n-de 102.7.2-1 102.8.0-1
thunderbird-i18n-dsb 102.7.2-1 102.8.0-1
thunderbird-i18n-el 102.7.2-1 102.8.0-1
thunderbird-i18n-en-gb 102.7.2-1 102.8.0-1
thunderbird-i18n-en-us 102.7.2-1 102.8.0-1
thunderbird-i18n-es-ar 102.7.2-1 102.8.0-1
thunderbird-i18n-es-es 102.7.2-1 102.8.0-1
thunderbird-i18n-et 102.7.2-1 102.8.0-1
thunderbird-i18n-eu 102.7.2-1 102.8.0-1
thunderbird-i18n-fi 102.7.2-1 102.8.0-1
thunderbird-i18n-fr 102.7.2-1 102.8.0-1
thunderbird-i18n-fy-nl 102.7.2-1 102.8.0-1
thunderbird-i18n-ga-ie 102.7.2-1 102.8.0-1
thunderbird-i18n-gd 102.7.2-1 102.8.0-1
thunderbird-i18n-gl 102.7.2-1 102.8.0-1
thunderbird-i18n-he 102.7.2-1 102.8.0-1
thunderbird-i18n-hr 102.7.2-1 102.8.0-1
thunderbird-i18n-hsb 102.7.2-1 102.8.0-1
thunderbird-i18n-hu 102.7.2-1 102.8.0-1
thunderbird-i18n-hy-am 102.7.2-1 102.8.0-1
thunderbird-i18n-id 102.7.2-1 102.8.0-1
thunderbird-i18n-is 102.7.2-1 102.8.0-1
thunderbird-i18n-it 102.7.2-1 102.8.0-1
thunderbird-i18n-ja 102.7.2-1 102.8.0-1
thunderbird-i18n-ka 102.7.2-1 102.8.0-1
thunderbird-i18n-kab 102.7.2-1 102.8.0-1
thunderbird-i18n-kk 102.7.2-1 102.8.0-1
thunderbird-i18n-ko 102.7.2-1 102.8.0-1
thunderbird-i18n-lt 102.7.2-1 102.8.0-1
thunderbird-i18n-ms 102.7.2-1 102.8.0-1
thunderbird-i18n-nb-no 102.7.2-1 102.8.0-1
thunderbird-i18n-nl 102.7.2-1 102.8.0-1
thunderbird-i18n-nn-no 102.7.2-1 102.8.0-1
thunderbird-i18n-pa-in 102.7.2-1 102.8.0-1
thunderbird-i18n-pl 102.7.2-1 102.8.0-1
thunderbird-i18n-pt-br 102.7.2-1 102.8.0-1
thunderbird-i18n-pt-pt 102.7.2-1 102.8.0-1
thunderbird-i18n-rm 102.7.2-1 102.8.0-1
thunderbird-i18n-ro 102.7.2-1 102.8.0-1
thunderbird-i18n-ru 102.7.2-1 102.8.0-1
thunderbird-i18n-sk 102.7.2-1 102.8.0-1
thunderbird-i18n-sl 102.7.2-1 102.8.0-1
thunderbird-i18n-sq 102.7.2-1 102.8.0-1
thunderbird-i18n-sr 102.7.2-1 102.8.0-1
thunderbird-i18n-sv-se 102.7.2-1 102.8.0-1
thunderbird-i18n-th 102.7.2-1 102.8.0-1
thunderbird-i18n-tr 102.7.2-1 102.8.0-1
thunderbird-i18n-uk 102.7.2-1 102.8.0-1
thunderbird-i18n-uz 102.7.2-1 102.8.0-1
thunderbird-i18n-vi 102.7.2-1 102.8.0-1
thunderbird-i18n-zh-cn 102.7.2-1 102.8.0-1
thunderbird-i18n-zh-tw 102.7.2-1 102.8.0-1
tomcat10 10.1.5-1 10.1.6-1
tomcat8 8.5.85-1 8.5.86-1
tomcat9 9.0.71-1 9.0.72-1
vim-runtime 9.0.1302-1 9.0.1337-1
vpnc 1:0.5.3.r506.r204-2 1:0.5.3.r526.r213-1
webkit2gtk 2.38.4-1 2.38.5-1
webkit2gtk-4.1 2.38.4-1 2.38.5-1
webkit2gtk-4.1-docs 2.38.4-1 2.38.5-1
webkit2gtk-5.0 2.38.4-1 2.38.5-1
webkit2gtk-5.0-docs 2.38.4-1 2.38.5-1
webkit2gtk-docs 2.38.4-1 2.38.5-1
wpewebkit 2.38.4-1 2.38.5-1
wpewebkit-docs 2.38.4-1 2.38.5-1
xbitmaps 1.1.2-3 1.1.3-1
xcursor-themes 1.0.6-3 1.0.7-1
xdg-desktop-portal-kde 5.26.5-1 5.27.1-1
xf86-video-amdgpu 22.0.0-1 23.0.0-1
xfce4-notifyd 0.8.0-1 0.8.1-1
xorg-font-util 1.3.3-1 1.4.0-1
xorg-util-macros 1.19.3-1 1.20.0-2
xterm 378-1 379-1
zenity 3.44.0-1 3.44.0-2
zita-resampler 1.8.0-1 1.10.1-1
zvbi 0.2.40-1 0.2.41-1
flatpak-kcm - 5.27.1-1
harfbuzz-utils - 7.0.1-1
libnotify-docs - 0.8.2-1
libpipewire - 1:0.3.66-2
plasma-welcome - 5.27.1-1
zita-resampler-docs - 1.10.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi-notes22.12.1.r1122.ge64f9e3-122.12.2.r1137.g14f5e30-1
alligator 22.11.r27.gfbabd3b-123.01.0.r18.g212bd80-1
amazfish 2.1.0.r0.g1166c01-1 2.1.2.r0.g27f6b1d-1
analitza22.12.2.r2382.gb66406cf-122.12.2.r2384.ga5a5e671-1
audiotube 22.11.r68.g57b1c07-123.01.0.r58.gf3ff6e3-1
aura-browser5.26.0.r173.ga76ee37-15.26.0.r189.g48f04aa-1
baloo5.102.0.r3126.g3181bd87-15.103.0.r3139.g11775528-1
blinken22.12.1.r714.gc6b2588-122.12.2.r721.g10869d8-1
breeze-grub5.26.5.r11.g63136a9-25.27.1.r11.g63136a9-1
breeze-gtk5.26.5.r496.gbb7d086-25.27.1.r496.gbb7d086-1
breeze-icons5.103.0.r1967.ge74b4a2b-15.103.0.r1968.g0fe3f321-1
cask-server r14.g7a9096d-1 r18.g006f893-1
extra-cmake-modules5.103.0.r3557.g7409c38e-15.103.0.r3558.gc3741f92-1
frameworkintegration5.102.0.r665.g7a5a095-15.103.0.r674.g6d87885-1
kalgebra22.12.1.r2123.ge77c387-122.12.2.r2137.gb50a5b6-1
kalk 22.11.r42.g5595af6-123.01.0.r15.g2736dc1-1
kapidox5.103.0.r585.gef3fe99-15.103.0.r586.g9b7591b-1
karchive5.103.0.r612.g3c179ae-15.103.0.r625.gc07cde9-1
kasts 22.11.r87.gcdec053-123.01.0.r55.g13b3f5d-1
kauth5.103.0.r543.g0cc153a-15.103.0.r544.g14b99f5-1
kbruch22.12.1.r926.gd978f5d-122.12.2.r934.gc334230-1
kcmutils5.102.0.r703.ged76bce-15.103.0.r732.g8a55777-1
kcodecs5.103.0.r478.g2b221bf-15.103.0.r482.g7ece417-1
kconfig5.103.0.r1050.g3f84ef82-15.103.0.r1051.gfc46a221-1
kconfigwidgets5.103.0.r864.ge908c257-15.103.0.r867.g09cb5c18-1
kcontacts1:5.103.0.r3399.g839c9827-11:5.103.0.r3401.g6b368747-1
kcoreaddons5.103.0.r1702.g3fd46255-15.103.0.r1705.g927e19c1-1
kde-gtk-config5.26.5.r959.gaa9eabd-15.27.1.r969.gaf1cc78-1
kdeclarative5.102.0.r1091.g9720a04-15.103.0.r1119.g119dd80-1
kdecoration5.26.5.r323.g83f6148-15.27.1.r330.gff7198a-1
kdesignerplugin5.102.0.r386.g48a8e4e-15.103.0.r393.g906403e-1
kdnssd5.103.0.r390.g9b2e4e0-15.103.0.r392.g799d9d8-1
kdoctools5.103.0.r716.gb3e5202-15.103.0.r718.geb37448-1
keysmith 22.11.r12.gb5d92ab-123.01.0.r7.g7c8a8c0-1
kgamma55.26.5.r510.g2fb40b3-15.27.1.r516.g459f6b7-1
kgeography22.12.1.r1223.g3adbf50-122.12.2.r1232.g70cb71e-1
kglobalaccel5.103.0.r635.g4bf729c-15.103.0.r637.g45e355b-1
khealthcertificate 22.11.r5.gdd2c53a-123.01.0.r1.ge18e3a2-1
kholidays1:5.103.0.r1105.g9d961eb-11:5.103.0.r1119.g67e7876-1
ki18n5.103.0.r621.g550dff7-15.103.0.r622.gfb7d5e2-1
kidletime5.102.0.r388.g897991a-15.103.0.r398.g53779a8-1
kio5.102.0.r6016.g6ed4ba88d-15.103.0.r6153.g1b7d72ff1-1
kirigami-addons1:0.6.1.r30.g45d7fef-11:0.7.0.r21.gb0eb78f-1
kirigami25.102.0.r3570.g38caa088-15.103.0.r3630.g6c693b64-1
kitinerary22.12.1.r2650.g33144ce4-122.12.2.r2734.g217a6e8b-1
kjobwidgets5.102.0.r458.ge2c9bed-15.103.0.r467.g127a375-1
kjs5.102.0.r386.g62ecf47-15.103.0.r389.g9182973-1
kjsembed5.102.0.r358.g9f818ff-15.103.0.r365.ga6fba3c-1
kmbox22.12.1.r628.gf4bd7e3-122.12.2.r640.gc763690-1
kmime22.12.1.r1579.g97571b4-122.12.2.r1595.gf9818d2-1
knewstuff5.102.0.r1454.g06ddecf7-15.103.0.r1496.g686d8c33-1
knotifications5.103.0.r811.gd0655e7-15.103.0.r812.g2dfb510-1
knotifyconfig5.102.0.r417.gfddd532-15.103.0.r426.gea9df2e-1
kontrast22.12.1.r281.g86365ac-122.12.2.r293.g41a3c89-1
kopeninghours22.12.1.r361.g2d25401-122.12.2.r366.gf4d6c83-1
kosmindoormap22.12.1.r901.ga23a68f-122.12.2.r938.ga039767-1
kpackage5.103.0.r847.gccc1854-15.103.0.r848.g586f58e-1
kparts5.102.0.r649.g8bf8256-15.103.0.r676.g9b1d206-1
kpeoplesink r81.g4f129cb-3 r81.g4f129cb-4
kpeoplevcard 0.1.r65.gd77c159-1 0.1.r77.g936e18c-1
kpipewire5.26.5.r205.g67f8d36-15.27.1.r231.gebc5fe7-1
kpkpass22.12.1.r323.gd199b02-122.12.2.r335.g12609d7-1
kpmcore22.12.1.r1345.g1031e44-122.12.2.r1353.gaf3677d-1
kpty5.103.0.r413.g58baed4-15.103.0.r413.g73c7142-1
kpublictransport22.12.1.r2096.g85ad4727-122.12.2.r2106.g807d9b3a-1
kquickcharts5.102.0.r550.ga6d0e25-15.103.0.r553.g6e63a5f-1
krecorder 22.11.r32.g9edceef-123.01.0.r8.gab8fe59-1
ksanecore r680.geac62c5-1 r682.g7958180-1
ktexteditor5.102.0.r3724.g12589220-15.103.0.r3758.gd74bdc4a-1
ktrip 22.11.r9.gddb7389-123.01.0.r4.gd4ee52d-1
kunitconversion5.103.0.r479.gaaba6a1-15.103.0.r486.gce56837-1
kwallet5.103.0.r1236.g374eee9-15.103.0.r1238.g130491f-1
kwayland-integration5.26.5.r227.g88136ec-15.27.1.r228.g9e8779c-1
kweathercore 0.7.r24.g048a045-1 0.7.r29.g03bdc49-1
kxmlgui5.103.0.r1004.gd27a8a92-15.103.0.r1006.g9c872446-1
layer-shell-qt5.26.5.r75.gb9f8f64-15.27.1.r76.g3c85e2e-1
libkcompactdisc22.12.1.r415.g71f5996-122.12.2.r422.g687e795-1
libkdepim22.12.1.r956.gc495141-122.12.2.r972.gfad90a9-1
libkleo22.12.1.r1375.gfd14003-122.12.2.r1399.g197adf4-1
libkmahjongg22.12.1.r514.g89af43e-122.12.2.r519.g0a26550-1
libksane22.12.1.r632.g64ae234-122.12.2.r637.g82fef38-1
libkscreen5.26.5.r1728.gefc3105-15.27.1.r1747.g1d237c2-1
mauikit-accounts 2.2.1.r21.ga36fe1b-1 2.2.1.r35.g67b4a5e-1
mauikit-texteditor 2.2.1.r19.g97b3429-1 2.2.1.r34.g0dc9604-1
minuet22.12.1.r659.gff10cf6-122.12.2.r672.gc3e4ee9-1
modemmanager-qt5.102.0.r583.gfd113eb-15.103.0.r583.gfd113eb-1
mycroft-skill-installer r101.d3f8c93-1 r102.a965aa5-1
networkmanager-qt5.102.0.r1187.g5cb4128-15.103.0.r1187.g5cb4128-1
oxygen-icons1:5.102.0.r5.gbff159d-21:5.103.0.r5.gbff159d-1
oxygen-icons-svg1:5.102.0.r5.gbff159d-21:5.103.0.r5.gbff159d-1
plank-player5.26.0.r129.gd158cb6-15.26.0.r144.g13f006c-1
plasma-camera 1.0.r151.g710500c-1 1.0.r155.ga1e5bd8-1
plasma-phonebook 22.11.r33.g3db6255-123.01.0.r16.g9d7ed55-1
plasma-wayland-protocols1.4.0.r1068.gb9cb11d-21.4.0.r1069.g4c5a31b-1
plasma-workspace-wallpapers5.26.5.r419.g7d9a87b-15.27.1.r423.g91bd0fe-1
plasmatube 22.11.r39.gf63fae1-123.01.0.r35.gc9a4d09-1
polkit-kde-agent5.26.5.r562.ga99d98e-15.27.1.r568.gd926ae2-1
prison5.102.0.r425.gd195b3a-15.103.0.r425.gd195b3a-1
pulseaudio-qt 1.3.0.r26.g9bba225-2 1.3.0.r26.g9bba225-3
qmlkonsole 22.11.r37.g1d83e9f-123.01.0.r32.gd69e71a-1
qqc2-breeze-style5.26.5.r261.g86ff42e-15.27.1.r261.g86ff42e-1
qqc2-desktop-style5.102.0.r711.g122cd90-15.103.0.r741.g2bd3e08-1
sddm0.19.0.r185.gc42bb38-10.19.0.r201.g676fb59-1
syndication5.102.0.r901.gd69d294-15.103.0.r901.gd69d294-1
syntax-highlighting5.102.0.r2097.g0cb9300b-15.103.0.r2137.gac0ddc75-1
threadweaver5.103.0.r571.g0e06e69-15.103.0.r572.g280eb5c-1
ktextaddons - r181.g15e36db-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
