Tab Crashes on Youtube/Facebook and sometimes on News channels (BBC/SKY etc.) The latter crashes the whole App.
Seeking advice as to what info I should provide next time for analysis.
I guess running Firefox via a Terminal might provide some information here as you should be able to see and capture any error messages which cause a crash ā¦ not sure about tab crashes though?
Iād try starting Firefox without loading the current profile (easiest is probably to create a test User Account on your system and switch to that, then run Firefox from there).
That sounds tryable. I suspect a Hardware problem as it runs fine on my other PC (HP g800 mini).
Lets see what happens. Currently installed/switched to Brave, so far no problem.
Aside from simply starting firefox in the terminal;
firefox
There is also starting in safe mode (which disables all themes and extensions);
firefox --safe-mode
And/or the profile manager to create/manage/use different profiles;
firefox --ProfileManager
I,ve actually given up and switched to Brave. Thanks for the input folks.
Solution unset because it was a non-solution.
