Kernel 5.4 throws a bunch of pcie errors and gets stuck on boot, my hardware is 8th gen.
export LANG=C
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=65d636ee-0ab4-449d-af5e-dcca6287b106 rw quiet apparmor=1
security=apparmor resume=UUID=14d6daae-cb02-4990-8ac6-71599551ba0f
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: SAMSUNG product: 550XBE/350XBE v: P10REU
serial: Chassis: type: 10 serial:
Mobo: SAMSUNG model: NP350XBE-KD1BR v: SGL9970A0B-C01-G001-S0001+10.0.17763
serial: UEFI: American Megatrends v: P10REU.088.200306.JJ
date: 03/06/2020
ID-1: BAT1 charge: 32.5 Wh (95.0%) condition: 34.2/43.1 Wh (79.4%)
volts: 12.2 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: status: Discharging cycles: 1223
RAM: total: 7.67 GiB used: 1.71 GiB (22.3%)
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE cache: L2: 6 MiB bogomips: 28808
Speed: 3773 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3773 2: 3846
3: 3762 4: 3759 5: 3654 6: 3878 7: 3720 8: 3859
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Silicon Motion Web Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 2232:1080 class-ID: 0e02 serial:
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel port: efa0 bus-ID: 01:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp1s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Samsung Co
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
broadcast:
WAN IP:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 0cf3:e500 class-ID: e001
Local Storage: total: 931.51 GiB used: 75.35 GiB (8.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-35Z10T0
rotation: 5400 rpm serial: rev: 1A04 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 75.35 GiB (8.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 65d636ee-0ab4-449d-af5e-dcca6287b106
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 4965-F53B
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 14d6daae-cb02-4990-8ac6-71599551ba0f
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 1-6:3 info: Silicon Motion Web Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2232:1080
Device-3: 1-7:4 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: 47.0 C
Processes: 234 Uptime: 13m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1303 lib: 441 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
